Weatherproof Refurbished Smart Lock for Exterior Doors
When it comes to securing your home’s exterior doors, a weatherproof smart lock is an essential upgrade. These locks combine advanced technology with durable construction to withstand outdoor elements while providing seamless access control. If you’re searching for a reliable, refurbished smart lock that offers both security and convenience, the
Wyze Lock Bolt stands out as a top choice.
Wyze Lock Bolt: The Ultimate Weatherproof Smart Lock
The
Wyze Lock Bolt is a Bluetooth-enabled smart lock designed to replace your existing deadbolt with a modern, weather-resistant solution perfect for exterior doors. Its robust features and durable build make it ideal for outdoor use, ensuring your home stays secure no matter the weather.
Key Features and Specifications
- Weather Resistance: Rated IPX5, the Wyze Lock Bolt is built to resist water splashes and rain, making it suitable for exterior door installation.
- Operating Temperature: Functions reliably in extreme temperatures from -13°F to 122°F on the keypad, and can be stored in temperatures as low as -22°F up to 158°F.
- Power Source: Powered by 4 AA batteries (included) with a battery life of 10-12 months, ensuring long-lasting performance without frequent replacements.
- Communication: Uses Bluetooth 5.0 with a 16 ft range for quick and secure connectivity to your smartphone.
- Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a touch of your finger, providing both speed and security.
- Backlit Keypad with Anti-Peep: Enter your code discreetly even in low light, with a keypad designed to prevent others from seeing your entry.
- Auto-Lock Function: Automatically locks the door if you forget, giving you peace of mind.
- Built-in Alarm: Detects jam attempts and alerts you immediately.
- Emergency One-Time Codes: Share temporary access with trusted visitors without compromising security.
- Compatibility: Fits doors with thickness between 1-3/8” and 1-3/4”, and supports backsets of 2-3/8” or 2-3/4”.
Stylish and Durable Design
Available in
Matte Black and
Satin Nickel, the Wyze Lock Bolt complements any exterior door style while providing a sturdy, weatherproof finish that stands up to outdoor conditions.
“Unlock your door in less than a second with the touch of a finger or a tap in the app.”
Secure your home with the weatherproof Wyze Lock Bolt smart lock.
Enhance Your Smart Home Security with Wyze Accessories
To maintain and optimize your Wyze Lock Bolt, consider these essential replacement parts designed specifically for this model:
Wyze Lock Bolt Interior Assembly Metal Plate
- Anchors the interior assembly securely to your door.
- Ensures stable installation and long-term durability.
- Affordable and easy to replace if needed.
Wyze Lock Bolt Interior Assembly Battery Cover
- Protects the battery compartment from dust and moisture.
- Compatible exclusively with the Wyze Lock Bolt.
- Helps maintain the lock’s weather resistance and battery life.
Wyze Lock Replacement Part Kit
- Includes essential components for quick repairs.
- Compatible only with Wyze Lock models.
- Ideal for refurbishing or maintaining your smart lock.
Wyze Lock Bolt Screws
- Replacement set of screws for secure mounting.
- Ensures your lock stays firmly attached to your door.
- Comes with a 30-day hassle-free return policy.
Why Choose a Weatherproof Refurbished Smart Lock?
Refurbished smart locks like the Wyze Lock Bolt offer a cost-effective way to upgrade your home security without compromising on quality or features. With weatherproof ratings and durable materials, these locks are designed to withstand outdoor conditions such as rain, snow, and temperature fluctuations, making them perfect for exterior doors.
Investing in a weatherproof smart lock means you get reliable security, convenience, and peace of mind, all while enhancing your home’s smart ecosystem.
Experience seamless home security with smart locks designed for outdoor use.
Conclusion
For a weatherproof refurbished smart lock tailored for exterior doors, the
Wyze Lock Bolt is an outstanding choice. Its advanced fingerprint sensor, backlit keypad, and durable weather-resistant design make it a smart investment for any homeowner looking to enhance security and convenience. Complement your lock with Wyze replacement parts to keep your system running smoothly for years to come.
Secure your home with confidence—choose Wyze Lock Bolt for a smart, weatherproof solution.
What makes the Wyze Lock Bolt a good choice for exterior doors?
The Wyze Lock Bolt is specifically designed for exterior doors with its IPX5 weather resistance, allowing it to withstand rain and water splashes. Its durable construction, wide operating temperature range, and weatherproof finish ensure reliable performance in various outdoor conditions.Is the Wyze Lock Bolt weatherproof?
Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance, making it suitable for outdoor use on exterior doors. It can handle rain, water splashes, and extreme temperatures, ensuring your home stays secure in all weather conditions.What are the key features of the Wyze Lock Bolt smart lock?
Key features of the Wyze Lock Bolt include Bluetooth 5.0 connectivity, ultra-fast fingerprint sensor, backlit anti-peep keypad, auto-lock function, built-in alarm for jam attempts, emergency one-time codes, and a long battery life of 10-12 months using 4 AA batteries.How does the Wyze Lock Bolt enhance home security?
The Wyze Lock Bolt enhances home security with its advanced fingerprint sensor for instant unlocking, anti-peep backlit keypad for discreet code entry, auto-lock feature, and a built-in alarm that alerts you to jam attempts. It also allows you to share temporary access codes securely.What replacement parts are available for the Wyze Lock Bolt?
Wyze offers several replacement parts for the Lock Bolt, including the Interior Assembly Metal Plate, Interior Assembly Battery Cover, Lock Replacement Part Kit, and Lock Bolt Screws. These parts help maintain the lock’s performance and weather resistance.What is the battery life of the Wyze Lock Bolt and how is it powered?
The Wyze Lock Bolt is powered by 4 AA batteries, which are included with the lock. The battery life typically lasts between 10 to 12 months, reducing the need for frequent replacements.Can I install the Wyze Lock Bolt on any door?
The Wyze Lock Bolt is compatible with doors that are 1-3/8” to 1-3/4” thick and support backsets of 2-3/8” or 2-3/4”. This makes it suitable for most standard exterior doors.What are the available finishes for the Wyze Lock Bolt?
The Wyze Lock Bolt is available in Matte Black and Satin Nickel finishes, allowing you to choose a style that best matches your exterior door and home decor.Why should I consider a refurbished smart lock for my home?
Refurbished smart locks like the Wyze Lock Bolt offer a cost-effective way to upgrade your home security. They provide the same advanced features and weatherproof durability as new models, making them a smart investment for exterior doors.How does the Wyze Lock Bolt connect to my smartphone?
The Wyze Lock Bolt uses Bluetooth 5.0 technology with a 16 ft range to connect quickly and securely to your smartphone, allowing you to control access and monitor your lock with ease.
