Affordable Refurbished Smart Lock: Bluetooth, Zigbee & Fingerprint
Affordable Refurbished Smart Lock with Bluetooth, Zigbee, and Fingerprint Sensor
Looking for a budget-friendly, high-tech smart lock that combines convenience, security, and modern connectivity? The Wyze Lock Bolt stands out as an excellent choice for anyone wanting a reliable smart lock with Bluetooth, fingerprint sensor, and Zigbee compatibility — all at an affordable price point. This page highlights the key features and specs of the Wyze Lock Bolt and related accessories, helping you make an informed decision for your smart home security upgrade.
Wyze Lock Bolt: Keyless Entry with Fingerprint and Bluetooth
The Wyze Lock Bolt is a Bluetooth-enabled smart lock designed to replace your existing deadbolt with ease. It offers a seamless keyless entry experience using an ultra-fast fingerprint sensor and a backlit keypad, making fumbling for keys a thing of the past.
Standout Features
  • Ultra-fast Fingerprint Reader: Unlock your door in less than a second with just a touch of your finger. The fingerprint sensor is highly responsive and supports up to 50 fingerprints, perfect for family members and frequent guests.
  • Bluetooth Connectivity: Control your lock locally via the Wyze app on your smartphone. Lock or unlock your door remotely when within Bluetooth range.
  • Auto-lock Function: Never worry about leaving your door unlocked. Set an auto-lock timer in the app, and the lock will secure your door automatically after the delay.
  • Anti-Peep Keypad: Enter your access code with confidence. The keypad supports anti-peep technology, allowing you to add extra random digits before or after your code to prevent onlookers from guessing it.
  • Durable and Weatherproof: Crafted from solid metal with an IPX5 weatherproof rating, the Wyze Lock Bolt is built to withstand outdoor elements and resist tampering.
  • Long Battery Life: Powered by 4 AA batteries, it can last up to 12 months. A low battery indicator and USB-C emergency charging port ensure you’re never locked out.
Specifications
  • Price: $79.98 (Matte Black or Satin Nickel)
  • Installation: Replaces existing deadbolt in about 20 minutes
  • Security: Hardware encryption, two-factor authentication via app
  • Compatibility: Works with Android 5.0+ and iOS 9.0+
  • Dimensions: 4.9" L x 2.5" W x 1.3" D (2" including knob)
  • Battery: 4x AA batteries (included)
  • Weather Resistance: IPX5 rated
  • Access Codes: Store up to 20 unique codes with auto-expiring options
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Wyze Lock Bolt Lifestyle Secure your home effortlessly with Wyze Lock Bolt’s fingerprint sensor and sleek design.
Zigbee and Bluetooth Connectivity for Smart Home Integration
While the Wyze Lock Bolt primarily uses Bluetooth for local control, it also supports Zigbee communication when paired with the Wyze Lock Gateway. This allows integration with broader smart home ecosystems, enabling you to:
  • Control your lock remotely beyond Bluetooth range
  • Receive real-time notifications and lock status updates
  • Automate lock/unlock schedules and integrate with other Zigbee-compatible devices
This makes the Wyze Lock Bolt a versatile option for smart home enthusiasts who want both fingerprint convenience and smart automation.
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning smoothly, several replacement parts are available, ensuring longevity and easy maintenance:
Wyze Lock Replacement Part Kit
  • Contains essential screws, cables, and components to restore your lock to like-new condition.
  • Price: $19.99 (currently sold out, check availability)
Wyze Lock Bolt Screws
  • A set of replacement screws compatible with the Wyze Lock Bolt.
  • Price: $2.99
Wyze Lock Bolt Interior Assembly Metal Plate
  • Metal plate to securely anchor the interior assembly to your door.
  • Price: $4.99
Wyze Lock Bolt Interior Assembly Battery Cover
  • Replacement battery cover for the interior assembly.
  • Price: $9.99
These parts help extend the life of your smart lock without the need for a full replacement.
Enhance Your Security with The Front Porch Security Bundle
For a comprehensive smart home security solution, consider the Front Porch Security Bundle which pairs the Wyze Lock Bolt with Wyze Video Doorbell and Chime. This bundle offers:
  • 1080p HD video monitoring of your front porch with two-way audio
  • Remote lock/unlock control and lock history tracking via the Wyze app
  • Compatibility with Alexa and Google Assistant for voice control
  • Zigbee and Bluetooth connectivity for seamless smart home integration
This bundle is perfect for those who want to secure their entryway with both smart locks and video surveillance. Wyze Lock Bolt with Video Doorbell Combine smart lock convenience with video doorbell security for peace of mind.
Why Choose Wyze Lock Bolt for Your Smart Home?
  • Affordable Price: At just $79.98, it offers premium features without breaking the bank.
  • Fingerprint Sensor: Ultra-fast and reliable biometric access.
  • Bluetooth & Zigbee: Flexible connectivity options for local and smart home control.
  • Easy Installation: Replace your existing deadbolt in about 20 minutes.
  • Robust Security: Hardware encryption and two-factor authentication protect your home.
  • Long Battery Life: Up to 12 months on 4 AA batteries with emergency USB-C charging.
Upgrade your home security today with the Wyze Lock Bolt — the affordable, feature-rich smart lock that fits your lifestyle.
FeatureWyze Lock BoltWyze Lock Bolt ScrewsThe Front Porch Security Bundle
TypeConnected Home Smart LockReplacement PartsSmart Home Security Bundle
DescriptionBluetooth smart lock replacing deadbolt with fingerprint reader and backlit keypad; auto-lock featureReplacement set of screws for Wyze Lock BoltIncludes Wyze Lock and Wyze Video Doorbell + Chime for front porch security
Price$79.98$2.99$123.99 - $173.97 (varies by variant)
VariantsMatte Black, Satin NickelDefault TitleMultiple bundles including Wyze Lock + Video Doorbell Pro, Wyze Lock Bolt + Video Doorbell v2, etc.
Key Features- Ultra-fast fingerprint sensor
- Backlit keypad with anti-peep technology
- Auto-lock timer
- Pick-proof & weatherproof (IPX5)
- Up to 12 months battery life
- Local Bluetooth connection
- Hardware encryption
- Two-factor authentication
Replacement screws for installation and maintenance- 1080p HD video doorbell with two-way audio
- Remote lock/unlock via app
- View motion events and lock history
- Works with Alexa and Google Assistant
CompatibilityReplaces existing deadboltCompatible with Wyze Lock BoltCompatible with Wyze Lock and Wyze Video Doorbell
Installation TimeAbout 20 minutesN/AN/A
Battery LifeUp to 12 months (4 AA batteries)N/AWyze Lock: 5-6 months (4 AA batteries)
Weather ResistanceIPX5N/AVideo Doorbell: IP65
Lock: Indoor only
ConnectivityBluetooth 5.0N/ALock: Bluetooth, Zigbee
Doorbell: Wi-Fi 2.4GHz
App FeaturesLock/unlock history, access codes, fingerprints, emergency codes, auto-expiring codesN/AView porch video, two-way audio, lock/unlock remotely, motion alerts
Included ItemsLock Bolt unitScrews setWyze Lock, Wyze Lock Gateway, Wyze Video Doorbell, Wyze Chime, and accessories
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
What is the Wyze Lock Bolt and what features does it offer?The Wyze Lock Bolt is an affordable smart lock designed for keyless entry, featuring an ultra-fast fingerprint sensor, Bluetooth connectivity, Zigbee compatibility (with Wyze Lock Gateway), a backlit anti-peep keypad, auto-lock function, and a weatherproof, durable build. It supports up to 50 fingerprints, stores up to 20 unique access codes, and offers long battery life with emergency USB-C charging.
How does the fingerprint sensor on the Wyze Lock Bolt work?The Wyze Lock Bolt’s fingerprint sensor allows you to unlock your door in less than a second with just a touch. It is highly responsive and can store up to 50 fingerprints, making it ideal for families and frequent guests.
Can I control the Wyze Lock Bolt remotely?You can control the Wyze Lock Bolt locally via Bluetooth using the Wyze app on your smartphone. For remote control beyond Bluetooth range, you can pair it with the Wyze Lock Gateway to enable Zigbee connectivity, allowing for real-time notifications, lock status updates, and smart home automation.
Is the Wyze Lock Bolt compatible with smart home systems?Yes, the Wyze Lock Bolt supports Zigbee connectivity when paired with the Wyze Lock Gateway, enabling integration with broader smart home ecosystems. It is also compatible with Alexa and Google Assistant for voice control when used as part of the Front Porch Security Bundle.
How easy is it to install the Wyze Lock Bolt?The Wyze Lock Bolt is designed for easy installation, replacing your existing deadbolt in about 20 minutes. All necessary hardware and instructions are included.
What is the battery life of the Wyze Lock Bolt and how is it powered?The Wyze Lock Bolt is powered by 4 AA batteries, which can last up to 12 months. It features a low battery indicator and a USB-C emergency charging port to ensure you’re never locked out.
What security features does the Wyze Lock Bolt provide?The Wyze Lock Bolt offers robust security with hardware encryption, two-factor authentication via the Wyze app, an anti-peep keypad, and a durable, tamper-resistant metal construction with an IPX5 weatherproof rating.
Are replacement parts available for the Wyze Lock Bolt?Yes, several replacement parts are available for the Wyze Lock Bolt, including a replacement part kit, screws, interior assembly metal plate, and battery cover. These parts help extend the life of your smart lock without needing a full replacement.
What is included in the Front Porch Security Bundle?The Front Porch Security Bundle includes the Wyze Lock Bolt, Wyze Video Doorbell, and Chime. This bundle provides 1080p HD video monitoring, two-way audio, remote lock/unlock control, lock history tracking, and compatibility with Alexa and Google Assistant for voice control.
What is the price of the Wyze Lock Bolt and what finishes are available?The Wyze Lock Bolt is priced at $79.98 and is available in Matte Black or Satin Nickel finishes.
What mobile devices are compatible with the Wyze Lock Bolt?The Wyze Lock Bolt is compatible with Android devices running version 5.0 or higher and iOS devices running version 9.0 or higher.
How does the anti-peep keypad on the Wyze Lock Bolt work?The anti-peep keypad allows you to enter extra random digits before or after your access code, preventing onlookers from guessing your code and enhancing security.
What are the standout features of the Wyze Lock Bolt?How does the Wyze Lock Bolt integrate with other smart home devices?Is there a warranty policy for the Wyze Lock Bolt?
