Best Bluetooth Smart Lock Replacement for Deadbolt Doors
Upgrading your home security with a Bluetooth smart lock is a smart move for convenience and safety. If you're looking for the best Bluetooth smart lock replacement for your deadbolt door, the
Wyze Lock Bolt stands out as a top choice. Alongside the lock itself, Wyze offers a comprehensive range of replacement parts to keep your smart lock functioning flawlessly.
Wyze Lock Bolt: The Ultimate Bluetooth Smart Deadbolt Replacement
The
Wyze Lock Bolt is designed to replace your existing deadbolt with a modern, secure, and easy-to-use smart lock. It combines advanced technology with user-friendly features to enhance your home security.
Key Features:
- Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a quick fingerprint scan.
- Backlit Keypad with Anti-Peep: Enter your code discreetly even in low light.
- Bluetooth 5.0 Connectivity: Reliable connection up to 16 feet.
- Auto-Lock Function: Automatically locks your door if you forget.
- Built-in Alarm: Detects jam attempts and alerts you immediately.
- Emergency One-Time Codes: Share temporary access securely.
- Battery Life: Powered by 4 AA batteries included, lasting 10-12 months.
- Weather Resistance: Rated IPX5, suitable for various climates.
- Fits Standard Doors: Compatible with door thicknesses from 1-3/8” to 1-3/4” and backsets of 2-3/8” or 2-3/4”.
Available in stylish
Matte Black and
Satin Nickel finishes, the Wyze Lock Bolt blends seamlessly with your home’s exterior.
Experience the convenience of unlocking your door in less than a second with just a tap or fingerprint.
Secure your front door with Wyze Lock Bolt smart technology.
Essential Replacement Parts for Wyze Lock Bolt
To maintain or repair your Wyze Lock Bolt, Wyze offers a variety of replacement parts designed specifically for this model. These parts ensure your smart lock stays in perfect working condition without the need for a full replacement.
Wyze Lock Bolt Interior Assembly Battery Cover
- Purpose: Protects the battery compartment inside the lock.
- Compatibility: Designed exclusively for Wyze Lock Bolt.
- Price: $9.99
- Return Policy: 30-day hassle-free returns.
Wyze Lock Bolt Interior Assembly Metal Plate
- Purpose: Anchors the interior assembly securely to your door.
- Durability: Made of sturdy metal for long-lasting support.
- Price: $4.99
Wyze Lock Bolt Screws
- Purpose: Replacement set of screws for mounting and securing the lock.
- Compatibility: Fits Wyze Lock Bolt perfectly.
- Price: $2.99
Wyze Lock Replacement Part Kit
- Includes: Various essential parts for repair or replacement.
- Options: Available as a Replacement Part Kit or Adapter Replacement Kit.
- Price: $4.99 - $19.99
- Compatibility: Only for Wyze Lock.
Wyze Lock Bolt Deadbolt, Strike Plate, and Latch
- Purpose: Complete replacement unit for deadbolt, strike plate, and latch.
- Compatibility: Designed for Wyze Lock Bolt.
- Price: $9.99
Keeping these parts on hand or ordering replacements as needed ensures your smart lock remains reliable and secure.
Wyze Lock Bolt’s backlit keypad offers secure and easy access.
Why Choose Wyze Lock Bolt for Your Deadbolt Replacement?
- Seamless Installation: Designed to replace your existing deadbolt without complicated modifications.
- Smart Home Integration: Control and monitor your lock remotely via the Wyze app.
- Enhanced Security: Fingerprint sensor and alarm system provide multiple layers of protection.
- Durability: Weather-resistant and built to withstand daily use.
- User-Friendly: Intuitive app interface and quick access options.
Whether you want to upgrade your home security or replace worn-out parts, Wyze Lock Bolt and its replacement components offer a comprehensive solution tailored for deadbolt doors.
Easy installation and smart control with Wyze Lock Bolt.
Conclusion
For the best Bluetooth smart lock replacement for your deadbolt door, the
Wyze Lock Bolt is an excellent choice combining security, convenience, and smart technology. Supported by a full range of replacement parts like battery covers, metal plates, screws, and deadbolt assemblies, you can keep your smart lock in top condition effortlessly.
Upgrade your home security today with Wyze Lock Bolt — the smart, reliable, and stylish deadbolt replacement.
What is the Wyze Lock Bolt and how does it work as a Bluetooth smart lock replacement for deadbolt doors?
The Wyze Lock Bolt is a Bluetooth-enabled smart lock designed to replace your existing deadbolt. It offers advanced security features such as a fast fingerprint sensor, backlit keypad, auto-lock function, built-in alarm, and Bluetooth 5.0 connectivity. It fits standard door sizes and can be easily installed without complicated modifications, providing a secure and convenient way to control access to your home.What are the key features of the Wyze Lock Bolt smart deadbolt?
Key features of the Wyze Lock Bolt include an ultra-fast fingerprint sensor, backlit keypad with anti-peep technology, Bluetooth 5.0 connectivity up to 16 feet, auto-lock function, built-in alarm for jam detection, emergency one-time codes, long battery life (10-12 months on 4 AA batteries), IPX5 weather resistance, and compatibility with standard door thicknesses and backsets.Is the Wyze Lock Bolt compatible with my door?
The Wyze Lock Bolt is compatible with standard doors that have a thickness between 1-3/8” and 1-3/4”, and backsets of either 2-3/8” or 2-3/4”. It is designed to replace most existing deadbolts without the need for major modifications.What replacement parts are available for the Wyze Lock Bolt?
Wyze offers a range of replacement parts for the Wyze Lock Bolt, including the Interior Assembly Battery Cover, Interior Assembly Metal Plate, mounting screws, a Replacement Part Kit or Adapter Replacement Kit, and a complete Deadbolt, Strike Plate, and Latch set. These parts are designed specifically for the Wyze Lock Bolt to ensure proper fit and function.How do I purchase Wyze Lock Bolt replacement parts?
You can purchase Wyze Lock Bolt replacement parts directly from the Wyze website. Each part is listed with its price and comes with a 30-day hassle-free return policy.What is the battery life of the Wyze Lock Bolt and what type of batteries does it use?
The Wyze Lock Bolt is powered by 4 AA batteries, which are included with the lock. The battery life typically lasts between 10 to 12 months, depending on usage.Is the Wyze Lock Bolt weather resistant?
Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance, making it suitable for use in various climates and outdoor conditions.What security features does the Wyze Lock Bolt offer?
The Wyze Lock Bolt offers multiple security features, including an ultra-fast fingerprint sensor, a backlit anti-peep keypad, auto-lock function, built-in alarm for jam detection, and the ability to generate emergency one-time codes for secure temporary access.Can I control the Wyze Lock Bolt remotely?
Yes, the Wyze Lock Bolt can be controlled and monitored remotely via the Wyze app, allowing you to manage access and check the status of your lock from anywhere.What finishes are available for the Wyze Lock Bolt?
The Wyze Lock Bolt is available in two stylish finishes: Matte Black and Satin Nickel, allowing you to choose the option that best matches your home’s exterior.What is the return policy for Wyze Lock Bolt replacement parts?
All Wyze Lock Bolt replacement parts come with a 30-day hassle-free return policy, ensuring you can shop with confidence.Why should I choose the Wyze Lock Bolt for my deadbolt replacement?
The Wyze Lock Bolt is an excellent choice for deadbolt replacement because it offers seamless installation, advanced security features, smart home integration, durable weather-resistant construction, and a user-friendly app interface. It also comes with a full range of replacement parts to keep your lock in top condition.
