Bluetooth Smart Lock with Ultra-Fast Fingerprint Sensor: Wyze Lock Bolt
Upgrade your home security with the Wyze Lock Bolt, a cutting-edge Bluetooth smart lock designed for ultra-fast fingerprint access and seamless keyless entry. Say goodbye to fumbling with keys and enjoy the convenience of unlocking your door in less than a second with just a touch of your finger or a tap on the app.
Ultra-Fast Fingerprint Sensor & Keyless Entry
Wyze Lock Bolt features an ultra-fast fingerprint reader that lets you unlock your door instantly. This smart lock replaces your traditional deadbolt and offers a luxurious backlit keypad for easy nighttime use. The fingerprint sensor is designed for quick, reliable scans, ensuring you can enter your home swiftly and securely without the hassle of keys.
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
- Unlock your door in under a second with fingerprint or app tap
- Store up to 50 fingerprints for family and frequent users
- Create and manage up to 20 access codes for guests and family
- Emergency one-time codes for remote guest access
Experience ultra-fast fingerprint unlocking with Wyze Lock Bolt
Premium Design & Security Features
Crafted from solid metal, the Wyze Lock Bolt boasts a sleek, luxurious design that complements any exterior door. Its backlit keypad features anti-peep technology, allowing you to enter your code securely by adding extra digits before or after your actual code to prevent prying eyes from guessing it.
- Solid metal construction for maximum durability and security
- Backlit keypad for easy use in low light conditions
- Anti-peep technology to protect your passcode privacy
- Fully pick-proof by eliminating the need for physical keys
- Weatherproof with IPX5 rating to withstand rain and elements
Stylish and secure smart lock for your front door
Smart Features & App Control
The Wyze app acts as your command center, providing full control and monitoring of your lock via Bluetooth. You can view lock/unlock history, receive notifications of failed attempts, and remotely generate emergency access codes even without Bluetooth connection.
- Auto-lock timer to secure your door if you forget
- One-touch lock button on keypad or app control within Bluetooth range
- Hardware encryption ensures fingerprint and code data privacy
- Two-factor authentication for app access security
- Compatible with most exterior doors and installs in about 20 minutes
Long Battery Life & Convenient Power Options
Wyze Lock Bolt runs on 4 AA batteries that last up to 12 months depending on usage. When battery power is low, a red indicator flashes to remind you to replace them. In emergencies, the USB-C port allows a quick charge to gain temporary access.
- Up to 12 months battery life on 4 AA batteries
- Easy battery replacement with low battery alerts
- USB-C port for emergency power boost
- No cloud connection required; works locally via Bluetooth
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning perfectly, replacement parts are available:
- Wyze Lock Bolt Screws: Replacement set of screws for secure installation.
- Wyze Lock Bolt Interior Assembly Battery Cover: Compatible battery cover to protect internal components.
- Wyze Lock Bolt Interior Assembly Metal Plate: Metal plate to anchor the interior assembly firmly to your door.
These parts ensure your smart lock stays reliable and secure over time.
Enhance Your Home Security with the Front Porch Security Bundle
For a comprehensive smart home security solution, consider the Front Porch Security Bundle. It combines the Wyze Lock Bolt with the Wyze Video Doorbell and Chime, allowing you to monitor your front porch in 1080p HD, communicate with visitors via two-way audio, and control your door lock remotely.
- 1080p HD video with night vision and motion detection
- Two-way audio to greet visitors or delivery personnel
- Remote lock/unlock and lock history monitoring via app
- Works with Alexa and Google Assistant for voice control
Complete smart home security with Wyze Lock Bolt and Video Doorbell
Why Choose Wyze Lock Bolt?
"Tired of fumbling with your keys? Unlock your door in less than a second with the touch of a finger or a tap in the app."
Wyze Lock Bolt offers a perfect blend of speed, security, and convenience. Its ultra-fast fingerprint sensor, robust design, and smart app features make it an ideal choice for anyone looking to upgrade to a Bluetooth smart lock with advanced biometric access.
Summary of Key Features
Feature | Wyze Lock Bolt |
Unlock Method | Ultra-fast fingerprint, keypad, app |
Fingerprint Capacity | Up to 50 fingerprints |
Access Codes | Up to 20 codes |
Auto-Lock | Yes, customizable timer |
Weather Resistance | IPX5 rated |
Battery Life | Up to 12 months (4 AA batteries) |
Security | Hardware encryption, anti-peep tech |
Installation | Replaces existing deadbolt, ~20 mins |
Experience the future of home access with Wyze Lock Bolt — the Bluetooth smart lock with an ultra-fast fingerprint sensor designed for your convenience and security.
What is the Wyze Lock Bolt and how does it work?
The Wyze Lock Bolt is a Bluetooth smart lock that replaces your traditional deadbolt, offering ultra-fast fingerprint access and keyless entry. You can unlock your door in less than a second using your fingerprint, a backlit keypad, or the Wyze app within Bluetooth range.How fast is the fingerprint sensor on the Wyze Lock Bolt?
The Wyze Lock Bolt features an ultra-fast fingerprint sensor that unlocks your door in under a second, providing quick and secure access without the need for keys.How many fingerprints and access codes can the Wyze Lock Bolt store?
The Wyze Lock Bolt can store up to 50 fingerprints for family and frequent users, and you can create and manage up to 20 access codes for guests and family members.What security features does the Wyze Lock Bolt offer?
The Wyze Lock Bolt offers several security features, including solid metal construction, anti-peep technology on the backlit keypad, hardware encryption for data privacy, two-factor authentication for app access, and a pick-proof design by eliminating physical keys.Is the Wyze Lock Bolt weatherproof?
Yes, the Wyze Lock Bolt is weatherproof with an IPX5 rating, making it suitable for use on exterior doors and able to withstand rain and the elements.How is the Wyze Lock Bolt powered and how long does the battery last?
The Wyze Lock Bolt runs on 4 AA batteries, which can last up to 12 months depending on usage. A red indicator flashes when the battery is low, and a USB-C port is available for emergency power boosts.Can I control the Wyze Lock Bolt remotely?
You can control the Wyze Lock Bolt via Bluetooth using the Wyze app. While remote unlocking is not available without Bluetooth, you can generate emergency one-time access codes remotely for guests.Does the Wyze Lock Bolt require a cloud connection to work?
No, the Wyze Lock Bolt works locally via Bluetooth and does not require a cloud connection, ensuring your data stays private and secure.How easy is it to install the Wyze Lock Bolt?
The Wyze Lock Bolt is designed for easy installation and can replace your existing deadbolt in about 20 minutes. It is compatible with most exterior doors.What replacement parts are available for the Wyze Lock Bolt?
Replacement parts for the Wyze Lock Bolt include screws, an interior assembly battery cover, and an interior assembly metal plate to ensure your smart lock remains secure and functional.What is the Front Porch Security Bundle and how does it enhance home security?
The Front Porch Security Bundle combines the Wyze Lock Bolt with the Wyze Video Doorbell and Chime, providing 1080p HD video monitoring, two-way audio, motion detection, and remote lock/unlock capabilities for comprehensive front porch security.Is the Wyze Lock Bolt compatible with voice assistants?
Yes, when used as part of the Front Porch Security Bundle, the Wyze Lock Bolt works with Alexa and Google Assistant for convenient voice control.What makes the Wyze Lock Bolt a good choice for home security?
The Wyze Lock Bolt offers a blend of speed, security, and convenience with its ultra-fast fingerprint sensor, robust metal design, advanced encryption, anti-peep keypad, and easy app control, making it an ideal upgrade for modern home security.
