Smart Locks with Alarm Notification for Open Door Alerts
Enhance your home security with smart locks that not only provide keyless convenience but also alert you instantly if your door is left open or tampered with. These advanced locks combine biometric technology, app connectivity, and built-in alarms to keep your home safe and give you peace of mind.
Wyze Lock Bolt: The Ultimate Smart Lock with Alarm Notification
Experience seamless access and robust security with the
Wyze Lock Bolt, a Bluetooth-enabled smart lock designed to replace your existing deadbolt. It offers ultra-fast fingerprint recognition and a backlit keypad with anti-peep technology, ensuring both convenience and privacy.
Key Features
- Ultra-Fast Fingerprint Sensor: Unlock your door in less than a second with a simple touch.
- Backlit Keypad with Anti-Peep: Enter your code discreetly even in low light.
- Auto-Lock Function: Automatically locks your door if you forget, preventing accidental security lapses.
- Built-in Alarm for Jam Detection: Alerts you immediately if the lock is jammed or tampered with.
- Lock and Unlock History: Monitor access events directly from the Wyze app.
- Emergency One-Time Codes: Grant temporary access to guests or service providers securely.
- Weather Resistant (IPX5): Durable for outdoor use, operating in temperatures from -13°F to 122°F.
- Battery Life: Powered by 4 AA batteries lasting 10-12 months.
Specifications
- Communication: Bluetooth 5.0 with a 16 ft range.
- Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick with standard deadbolt dimensions.
- Color Options: Matte Black and Satin Nickel.
- Weight: 2.75 lbs.
The Wyze Lock Bolt is perfect for those who want a secure, smart home upgrade with real-time alerts and easy app control.
Alt text: Front door with Wyze Lock Bolt and smartphone app control
Essential Security Bundle: Comprehensive Home Protection Including Wyze Lock Bolt
For a full home security solution, the
Essential Security Bundle combines the Wyze Lock Bolt with other smart devices to cover every angle of your home’s safety.
Bundle Includes
- Wyze Lock Bolt: Smart lock with fingerprint sensor, backlit keypad, and auto-lock.
- Wyze Video Doorbell v2: 1080p HD video with two-way audio and person detection to monitor your front door.
- Wyze Cam Pan v3: Pan-and-tilt camera with 360° horizontal and 180° vertical coverage, motion tracking, and color night vision.
- Two Wyze Cam OG Cameras: Plug-in cameras with motion-activated spotlights and color night vision for indoor or outdoor use.
Why Choose the Bundle?
- Integrated Security: Manage all devices from one app for seamless monitoring.
- Real-Time Alerts: Receive notifications for door activity, motion detection, and open door alerts.
- Weather Resistant Devices: Cameras and locks rated for outdoor use (IP65 for cameras, IPX5 for lock).
- Value Pack: Save compared to buying devices separately, with everything you need for smart home security.
This bundle is ideal for homeowners seeking a turnkey solution that includes smart locks with alarm notifications and comprehensive video surveillance.
Alt text: Outdoor home with Wyze security cameras monitoring front porch
Replacement Parts for Wyze Lock Bolt
Maintain your smart lock’s performance with genuine replacement parts designed specifically for the Wyze Lock Bolt.
Available Parts
- Wyze Lock Bolt Interior Assembly Metal Plate: Anchors the interior assembly securely to your door.
- Wyze Lock Bolt Screws: Replacement screw set compatible with the Wyze Lock Bolt.
- Wyze Lock Bolt Interior Assembly Battery Cover: Protects the battery compartment inside the lock.
- Wyze Lock Replacement Part Kit: Includes essential components for repair and maintenance.
Keep your smart lock functioning flawlessly with these easy-to-install replacement parts, backed by hassle-free 30-day returns.
Why Choose Wyze Smart Locks with Alarm Notifications?
"Smart locks with alarm notifications provide an extra layer of security by alerting you immediately if your door is left open or if someone attempts to tamper with the lock. Wyze Lock Bolt stands out with its fingerprint sensor, app integration, and built-in alarm, making it a top choice for modern home security."
- Convenience: Keyless entry via fingerprint or app.
- Security: Real-time alerts and auto-lock prevent unauthorized access.
- Durability: Weather-resistant design suitable for various climates.
- Integration: Works seamlessly with other Wyze smart home devices.
Alt text: Person using fingerprint sensor on Wyze Lock Bolt smart lock
Conclusion
For those searching for a
smart lock with alarm notification for open door alerts, the Wyze Lock Bolt offers a perfect blend of speed, security, and smart features. Whether purchased alone or as part of the Essential Security Bundle, it ensures your home stays protected with instant notifications and convenient access control.
Product Tags Summary
What is a smart lock with alarm notification for open door alerts?
A smart lock with alarm notification for open door alerts is a security device that provides keyless entry and instantly notifies you if your door is left open or if someone attempts to tamper with the lock. These locks often feature biometric access, app connectivity, and built-in alarms to enhance home security and convenience.What are the key features of the Wyze Lock Bolt smart lock?
The Wyze Lock Bolt offers ultra-fast fingerprint recognition, a backlit keypad with anti-peep technology, auto-lock functionality, a built-in alarm for jam detection, lock and unlock history via the Wyze app, emergency one-time codes, weather resistance (IPX5), and a battery life of 10-12 months using 4 AA batteries.How does the Wyze Lock Bolt provide alarm notifications?
The Wyze Lock Bolt has a built-in alarm that alerts you immediately if the lock is jammed or tampered with. It also sends real-time notifications to your smartphone through the Wyze app, keeping you informed about door activity and open door alerts.Can I monitor who accesses my door with the Wyze Lock Bolt?
Yes, the Wyze Lock Bolt allows you to monitor lock and unlock history directly from the Wyze app, so you can see who accessed your door and when.Is the Wyze Lock Bolt weather resistant?
Yes, the Wyze Lock Bolt is weather resistant with an IPX5 rating, making it suitable for outdoor use in temperatures ranging from -13°F to 122°F.What is included in the Essential Security Bundle?
The Essential Security Bundle includes the Wyze Lock Bolt, Wyze Video Doorbell v2, Wyze Cam Pan v3, and two Wyze Cam OG Cameras. This bundle provides comprehensive home protection with integrated app control and real-time alerts for door activity and motion detection.How do I control and monitor all Wyze security devices?
All Wyze security devices, including the Lock Bolt and cameras, can be managed and monitored from a single Wyze app, allowing for seamless integration and real-time notifications.Are replacement parts available for the Wyze Lock Bolt?
Yes, genuine replacement parts for the Wyze Lock Bolt are available, including the interior assembly metal plate, screws, battery cover, and a replacement part kit. These parts are easy to install and come with a 30-day hassle-free return policy.What are the benefits of choosing Wyze smart locks with alarm notifications?
Wyze smart locks with alarm notifications offer keyless convenience, real-time security alerts, durable weather-resistant design, and seamless integration with other Wyze smart home devices, making them an excellent choice for modern home security.What door types are compatible with the Wyze Lock Bolt?
The Wyze Lock Bolt fits doors that are 1-3/8” to 1-3/4” thick and have standard deadbolt dimensions, making it compatible with most residential doors.How long does the Wyze Lock Bolt battery last and what type does it use?
The Wyze Lock Bolt is powered by 4 AA batteries, which typically last between 10 to 12 months depending on usage.
