Upgrade to a Smart Deadbolt Without Replacing Hardware
Upgrade Your Smart Deadbolt Without Replacing Existing Hardware
If you're looking to enhance your home security with a smart deadbolt upgrade without the hassle of replacing your existing hardware, the Wyze Lock Bolt is the perfect solution. Designed to fit seamlessly into your current door setup, this smart lock offers advanced features like fingerprint access and app control, all while maintaining your existing deadbolt hardware. For those wanting a comprehensive home security upgrade, the Essential Security Bundle includes the Wyze Lock Bolt along with other smart devices to protect your home from every angle.
Wyze Lock Bolt: Smart Deadbolt Upgrade Made Easy
Seamless Replacement for Existing Deadbolts
The Wyze Lock Bolt is engineered to replace your existing deadbolt effortlessly, fitting standard door specifications with:
  • Thru hole diameter: 2-1/8”
  • Backset options: 2-3/8” or 2-3/4”
  • Door thickness compatibility: 1-3/8” to 1-3/4”
  • Deadbolt diameter: 1”
This means no need to change your door hardware or drill new holes, making installation quick and straightforward.
Advanced Security Features
  • Ultra-fast fingerprint sensor: Unlock your door instantly with a touch of your finger.
  • Backlit keypad with anti-peep technology: Enter your code discreetly, even in low light.
  • Auto-lock function: Automatically locks your door if you forget, ensuring your home is always secure.
  • Built-in alarm for jam detection: Alerts you if the lock is tampered with or jammed.
  • Emergency one-time codes: Grant temporary access to guests or service providers safely.
  • Bluetooth 5.0 connectivity: Reliable wireless communication up to 16 feet.
Durable and Weather Resistant
  • Rated IPX5 for weather resistance, suitable for various climates.
  • Operates in temperatures from -13°F to 122°F on the keypad.
  • Powered by 4x AA batteries with a battery life of 10-12 months.
Stylish and Functional Design
Available in Matte Black and Satin Nickel, the Wyze Lock Bolt complements any door style with a sleek, modern look.
"Unlock your door in less than a second with the touch of a finger or a tap in the app."
Wyze Lock Bolt Lifestyle Experience effortless smart lock control with Wyze Lock Bolt.
Essential Security Bundle: All-in-One Smart Home Protection
For a more comprehensive upgrade that includes your smart deadbolt, consider the Essential Security Bundle. This package combines the Wyze Lock Bolt with multiple smart devices to secure your home inside and out.
Bundle Includes:
  • Wyze Lock Bolt: Smart deadbolt with fingerprint sensor and backlit keypad.
  • Wyze Video Doorbell v2: Crisp 1080p HD video with two-way audio to monitor your front door.
  • Wyze Cam Pan v3: Pan-and-tilt camera with 360° horizontal and 180° vertical coverage, automatic motion tracking, and color night vision.
  • Two Wyze Cam OG: Versatile plug-in cameras with motion-activated spotlights and color night vision for indoor or outdoor use.
Why Choose the Bundle?
  • Integrated app control: Manage all devices from the Wyze app for seamless home security.
  • Comprehensive coverage: Monitor entrances, large areas, and indoor/outdoor spaces.
  • Enhanced peace of mind: Real-time alerts and video history keep you connected to your home.
"Your all-in-one solution for comprehensive home protection."
Wyze Video Doorbell Lifestyle Stay connected and secure with smart cameras and video doorbells.
Why Upgrade Your Deadbolt with Wyze Lock Bolt?
  • No need to replace entire hardware: Fits your existing deadbolt setup.
  • Fast and secure access: Fingerprint and keypad options.
  • Smart automation: Auto-lock and app notifications.
  • Affordable and reliable: Priced under $80 with premium features.
  • Easy installation: DIY-friendly with included batteries and mounting hardware.
Wyze Lock Bolt App Control Control your smart lock remotely with the Wyze app.
Summary
Upgrading your smart deadbolt without replacing your existing hardware is simple and effective with the Wyze Lock Bolt. Whether you want a standalone smart lock or a full home security system, Wyze offers solutions that combine convenience, security, and smart technology.
  • Wyze Lock Bolt: Smart deadbolt replacement with fingerprint sensor and keypad.
  • Essential Security Bundle: Complete home protection including the Wyze Lock Bolt and multiple cameras.
Secure your home effortlessly and enjoy the benefits of smart access control today.
### Product Tags and Highlights
FeatureWyze Lock BoltEssential Security Bundle
Price$79.98$199.99
Product TypeBluetooth Smart LockSecurity Bundle
Included ProductsWyze Lock BoltWyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, 2× Wyze Cam OG
Keyless EntryYes (Fingerprint sensor & backlit keypad)Yes (via Wyze Lock Bolt)
Fingerprint SensorUltra-fast fingerprint readerIncluded (Wyze Lock Bolt)
Backlit KeypadYesIncluded (Wyze Lock Bolt)
Auto-lock FeatureYesIncluded (Wyze Lock Bolt)
App ControlYes (Bluetooth connection required)Yes (for all devices)
Video DoorbellNoWyze Video Doorbell v2 included
Security CamerasNoWyze Cam Pan v3 and 2× Wyze Cam OG included
Motion TrackingNoYes (Wyze Cam Pan v3)
Night VisionNoYes (Wyze Cam Pan v3 and Wyze Cam OG)
Two-way AudioNoYes (Wyze Video Doorbell v2, Wyze Cam Pan v3)
Battery LifeUp to 12 months (4 AA batteries)Varies by device
Weatherproof RatingIPX5Cameras have weather resistance (Wyze Cam OG IP65)
Installation TimeAbout 20 minutesVaries by device
Access CodesUp to 20 codesIncluded (Wyze Lock Bolt)
Fingerprints StoredUp to 50 fingerprintsIncluded (Wyze Lock Bolt)
Emergency One-Time CodesYesIncluded (Wyze Lock Bolt)
Auto-expiring CodesYesIncluded (Wyze Lock Bolt)
Hardware EncryptionYesIncluded (Wyze Lock Bolt)
Two-Factor AuthenticationYes (via Wyze app)Included (Wyze Lock Bolt)
ConnectivityBluetoothBluetooth (Lock), WiFi (Cameras and Doorbell)
Can I upgrade my deadbolt to a smart lock without replacing my existing hardware?Yes, the Wyze Lock Bolt is designed to upgrade your deadbolt to a smart lock without the need to replace your existing hardware. It fits standard door specifications and installs easily without drilling new holes.
What are the key features of the Wyze Lock Bolt smart deadbolt?The Wyze Lock Bolt offers advanced features such as an ultra-fast fingerprint sensor, backlit keypad with anti-peep technology, auto-lock function, built-in alarm for jam detection, emergency one-time codes, and Bluetooth 5.0 connectivity.
Is the Wyze Lock Bolt compatible with my door?The Wyze Lock Bolt is compatible with doors that have a thru hole diameter of 2-1/8”, backset options of 2-3/8” or 2-3/4”, door thickness between 1-3/8” and 1-3/4”, and a deadbolt diameter of 1”.
How weather resistant is the Wyze Lock Bolt?The Wyze Lock Bolt is rated IPX5 for weather resistance and operates in temperatures ranging from -13°F to 122°F, making it suitable for various climates.
How long does the Wyze Lock Bolt battery last?The Wyze Lock Bolt is powered by 4 AA batteries, which provide a battery life of 10-12 months under typical usage.
What is included in the Essential Security Bundle?The Essential Security Bundle includes the Wyze Lock Bolt, Wyze Video Doorbell v2, Wyze Cam Pan v3, and two Wyze Cam OG cameras, offering comprehensive smart home security.
Can I control the Wyze Lock Bolt and other devices from my phone?Yes, you can manage the Wyze Lock Bolt and all devices in the Essential Security Bundle through the Wyze app, allowing for seamless control and real-time alerts.
Does the Wyze Lock Bolt support temporary access for guests?Yes, the Wyze Lock Bolt allows you to generate emergency one-time codes, making it easy and secure to grant temporary access to guests or service providers.
What colors are available for the Wyze Lock Bolt?The Wyze Lock Bolt is available in Matte Black and Satin Nickel finishes, complementing a variety of door styles.
Is the Wyze Lock Bolt easy to install?Yes, the Wyze Lock Bolt is DIY-friendly and comes with all necessary batteries and mounting hardware for a quick and straightforward installation.
How secure is the Wyze Lock Bolt?The Wyze Lock Bolt provides enhanced security with features like fingerprint access, a backlit anti-peep keypad, auto-lock, jam detection alarm, and secure Bluetooth connectivity.
What is the price of the Wyze Lock Bolt?The Wyze Lock Bolt is affordably priced under $80, offering premium smart lock features at a budget-friendly cost.
What are the advanced security features of the Wyze Lock Bolt?Can you tell me more about the Essential Security Bundle?Do you have any deals, ongoing sales, discounts, or promotions?
