Wyze Refurbished Smart Lock Retrofit for Existing Deadbolt
Upgrade your home security effortlessly with Wyze’s refurbished smart lock options designed specifically to retrofit your existing deadbolt. Whether you want to replace your deadbolt entirely or add smart functionality while keeping your current lock, Wyze offers reliable, affordable, and feature-rich smart locks that blend convenience, security, and modern technology.
Experience keyless entry, ultra-fast fingerprint access, and seamless app control — all while saving money with certified refurbished products that work like new.
Wyze Lock Bolt (Refurbished) – Smart Deadbolt Replacement
Key Features and Benefits
- Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a touch of your finger.
- Backlit Keypad with Anti-Peep: Enter your code discreetly even in the dark.
- Replaces Existing Deadbolt: Simple retrofit that swaps out your old deadbolt for a smart one.
- Auto-Lock Function: Automatically locks your door if you forget.
- Built-in Alarm: Detects jams and alerts you immediately.
- Emergency One-Time Codes: Share temporary access securely.
- Local Bluetooth Connection & Hardware Encryption: Ensures your data and access are safe.
- Two-Factor Authentication: Adds an extra layer of security.
- Installation Time: Approximately 20 minutes.
- Maximum Fingerprints: Store up to 50 fingerprints.
- Maximum Access Codes: Supports 20 access codes with auto-expiring options.
Specifications
- Color: Matte Black (refurbished model)
- Power Source: 4x AA batteries (included) with 10-12 months battery life
- Communication: Bluetooth 5.0 with 16 ft range
- Weather Resistance: IPX5 rated for outdoor durability
- Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick, backset 2-3/8” or 2-3/4”
- Deadbolt Diameter: 1”
This refurbished Wyze Lock Bolt offers all the premium features of the new model at a reduced price, making it an excellent choice for budget-conscious homeowners who want smart security without compromise.
Stylish and secure smart lock for your front door
(Refurbished) Wyze Lock – Retrofit Smart Lock Add-On
Overview
If you prefer to keep your existing deadbolt but want to add smart capabilities, the refurbished Wyze Lock is the perfect retrofit solution. This product adds the "brains" to your current lock, enabling remote control and monitoring without replacing your hardware.
Features
- Lock + Gateway Included: Connects via Bluetooth, Zigbee, and WiFi for versatile smart home integration.
- Smartphone Control: Lock and unlock remotely using the Wyze app.
- Compatibility: Works with Alexa, Google Assistant, and Wyze Switch.
- Installation: Quick and easy, installs in under 15 minutes.
- Shared Access: Share access with up to 50 people.
- Battery Life: 5-6 months on 4x AA batteries (included).
- Indoor Use: Designed for indoor installation with operating temperatures from 14°F to 131°F.
Dimensions & Specs
- Lock Size: 4.9" L x 2.5" W x 1.3" D
- Keypad Size: 3.7" L x 1.3" W x 1.0" D
- Gateway Size: 2.1" L x 2.1" W x 1.2" D
- Communication Range: Up to 50 ft from gateway to lock, 16 ft Bluetooth to phone
This refurbished Wyze Lock is ideal for those who want to keep their current deadbolt but gain smart lock convenience and security.
Backlit keypad with fingerprint sensor for easy access
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning perfectly, Wyze offers essential replacement parts:
- Wyze Lock Bolt Screws: Set of screws compatible with Wyze Lock Bolt for secure installation.
Price: $2.99
- Wyze Lock Bolt Interior Assembly Metal Plate: Metal plate to anchor the interior assembly firmly to your door.
Price: $4.99
- Wyze Lock Bolt Interior Assembly Battery Cover: Replacement battery cover for the interior assembly.
Price: $9.99
These parts ensure your smart lock stays reliable and easy to maintain over time.
Why Choose Wyze Refurbished Smart Locks?
Wyze refurbished products are fully tested, certified like-new, and come at a significantly reduced price. They offer the same advanced features and reliability as new units, making smart home upgrades more accessible.
- Save money without sacrificing quality.
- Enjoy the latest smart lock technology.
- Easy installation and retrofit options for existing deadbolts.
- Trusted Wyze brand with strong security features.
Upgrade your home security today with Wyze refurbished smart locks — the perfect retrofit solution for your existing deadbolt, combining convenience, safety, and smart technology at an unbeatable value.
What is a Wyze Refurbished Smart Lock and how does it work with my existing deadbolt?
A Wyze Refurbished Smart Lock is a certified like-new smart lock that retrofits your existing deadbolt, allowing you to upgrade your home security without replacing your entire lock. You can choose to either fully replace your deadbolt with the Wyze Lock Bolt or add smart functionality to your current lock with the Wyze Lock add-on. Both options offer keyless entry, app control, and advanced security features.What are the main features of the Wyze Lock Bolt (Refurbished) Smart Deadbolt Replacement?
The Wyze Lock Bolt (Refurbished) features an ultra-fast fingerprint sensor, backlit anti-peep keypad, auto-lock function, built-in alarm for jam detection, emergency one-time codes, local Bluetooth connection with hardware encryption, and two-factor authentication. It supports up to 50 fingerprints and 20 access codes, and installs in about 20 minutes.How do I install the Wyze Lock Bolt (Refurbished) on my door?
The Wyze Lock Bolt (Refurbished) is designed for easy installation, replacing your existing deadbolt in approximately 20 minutes. It fits doors 1-3/8” to 1-3/4” thick with a backset of 2-3/8” or 2-3/4”, and a deadbolt diameter of 1”. All necessary hardware and batteries are included.What is the difference between the Wyze Lock Bolt and the Wyze Lock (Refurbished) Add-On?
The Wyze Lock Bolt replaces your existing deadbolt with a smart deadbolt featuring a fingerprint sensor and keypad. The Wyze Lock (Refurbished) Add-On retrofits your current deadbolt, adding smart capabilities like remote app control and voice assistant integration without changing your existing hardware.Can I control the Wyze Lock (Refurbished) remotely with my smartphone?
Yes, the Wyze Lock (Refurbished) connects to your home via Bluetooth, Zigbee, and WiFi through the included gateway, allowing you to lock and unlock your door remotely using the Wyze app. It also supports Alexa, Google Assistant, and Wyze Switch for voice control.How secure are Wyze refurbished smart locks?
Wyze refurbished smart locks offer robust security features, including hardware encryption, two-factor authentication, and local Bluetooth connections. The Wyze Lock Bolt also includes a built-in alarm for jam detection and anti-peep keypad technology for added safety.How long do the batteries last in Wyze refurbished smart locks?
The Wyze Lock Bolt (Refurbished) uses 4x AA batteries with a battery life of 10-12 months. The Wyze Lock (Refurbished) Add-On also uses 4x AA batteries, lasting approximately 5-6 months depending on usage.Are replacement parts available for Wyze Lock Bolt?
Yes, Wyze offers essential replacement parts for the Lock Bolt, including screws, an interior assembly metal plate, and a battery cover. These parts help maintain your smart lock’s reliability and performance.What are the benefits of choosing a Wyze refurbished smart lock?
Wyze refurbished smart locks are fully tested and certified to work like new, offering the same advanced features and reliability as new units at a significantly reduced price. They provide an affordable way to upgrade your home security with easy installation and trusted Wyze quality.How many users can access a Wyze refurbished smart lock?
The Wyze Lock Bolt (Refurbished) supports up to 50 fingerprints and 20 access codes, while the Wyze Lock (Refurbished) Add-On allows you to share access with up to 50 people through the Wyze app.Is the Wyze Lock Bolt (Refurbished) weather resistant?
Yes, the Wyze Lock Bolt (Refurbished) is IPX5 rated for outdoor durability, making it suitable for use on exterior doors.How long does it take to install the Wyze Lock (Refurbished) Add-On?
The Wyze Lock (Refurbished) Add-On is designed for quick and easy installation, typically taking less than 15 minutes to retrofit your existing deadbolt.
