How to Upgrade Your Deadbolt to a Smart Lock with Backup Key
Upgrading your traditional deadbolt to a smart lock offers convenience, enhanced security, and modern features like fingerprint access and app control. If you want a seamless transition with the option of a backup key, the
Wyze Lock Bolt is an excellent choice. This guide will walk you through the features of the Wyze Lock Bolt and its compatible replacement parts, ensuring your upgrade is smooth and reliable.
Wyze Lock Bolt: The Ultimate Smart Deadbolt Replacement
The
Wyze Lock Bolt is designed to replace your existing deadbolt effortlessly while adding smart technology to your home security. It combines a sleek design with advanced features to give you keyless convenience without sacrificing backup key access.
Key Features:
- Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a touch of your finger.
- Backlit Keypad with Anti-Peep: Enter your code securely even in the dark, with protection against prying eyes.
- Bluetooth 5.0 Connectivity: Control your lock remotely within a 16 ft range using the Wyze app.
- Auto-Lock Function: The lock automatically secures your door if you forget to lock it.
- Built-in Jam Detection Alarm: Alerts you if the lock mechanism is obstructed.
- Emergency One-Time Codes: Share temporary access codes with guests or service providers.
- Backup Key Access: Retains traditional key functionality for emergencies or power outages.
Technical Specifications:
- Power Source: 4x AA batteries (included) with 10-12 months battery life.
- Weather Resistance: Rated IPX5, suitable for various climates.
- Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick with standard deadbolt hole sizes.
- Color Options: Matte Black and Satin Nickel to match your door hardware.
Upgrade your home security with a smart lock that blends convenience and reliability, ensuring you never get locked out.
Experience smart home security with Wyze Lock Bolt on your front door.
Essential Replacement Parts for a Perfect Installation
To ensure your Wyze Lock Bolt functions flawlessly and lasts long, consider these compatible replacement parts. They help maintain your lock’s performance and simplify repairs or upgrades.
Wyze Lock Bolt Screws
- A set of replacement screws designed specifically for the Wyze Lock Bolt.
- Ideal for securing the lock firmly during installation or if you lose original screws.
- Affordable and easy to replace with a 30-day hassle-free return policy.
Wyze Lock Bolt Interior Assembly Metal Plate
- A sturdy metal plate that anchors the interior assembly to your door.
- Provides extra stability and durability for the lock mechanism.
- Available in multiple quantities to suit your needs.
Wyze Lock Bolt Interior Assembly Battery Cover
- Replacement battery cover for the interior assembly.
- Keeps batteries secure and protected from dust or moisture.
- Compatible only with the Wyze Lock Bolt, ensuring a perfect fit.
Wyze Lock Replacement Part Kit
- Comprehensive kit including essential parts for repair or replacement.
- Available in two styles: Adapter Replacement Kit and Replacement Part Kit.
- Helps extend the life of your smart lock with genuine Wyze components.
Keeping these parts handy ensures your smart lock remains in top condition, providing peace of mind and uninterrupted security.
Enhance Your Home Security with the Essential Security Bundle
For those looking to upgrade their entire home security system alongside their smart lock, the
Essential Security Bundle offers a complete solution. This bundle includes:
- Wyze Lock Bolt: Smart deadbolt with fingerprint sensor and keypad.
- Wyze Video Doorbell v2: 1080p HD video with two-way audio to monitor your front door.
- Wyze Cam Pan v3: Pan-and-tilt camera with 360° horizontal and 180° vertical coverage.
- Two Wyze Cam OG Cameras: Indoor/outdoor cameras with motion-activated spotlights and color night vision.
This all-in-one package provides comprehensive protection, allowing you to monitor and control access to your home from anywhere.
Control your Wyze Lock Bolt remotely via smartphone app for ultimate convenience.
Why Choose Wyze Lock Bolt for Your Deadbolt Upgrade?
- Easy Installation: Designed to replace your existing deadbolt without complicated tools or professional help.
- Backup Key Included: Never worry about losing power or connectivity; the traditional key option is always available.
- Long Battery Life: Up to a year of use on standard AA batteries, reducing maintenance.
- Robust Security Features: Fingerprint access, auto-lock, and alarm systems keep your home safe.
- Weather Resistant: Suitable for a variety of climates and door types.
Transitioning to a smart lock has never been easier or more secure with Wyze Lock Bolt.
Upgrade your home security today by replacing your deadbolt with the Wyze Lock Bolt and enjoy the perfect blend of smart technology and traditional backup key access.
Product Summary
Wyze Lock Bolt
What is the Wyze Lock Bolt and how does it upgrade my deadbolt?
The Wyze Lock Bolt is a smart deadbolt replacement designed to upgrade your traditional lock with advanced features like fingerprint access, a backlit keypad, Bluetooth connectivity, and auto-lock. It offers keyless convenience while retaining a backup key option for emergencies, making your home security more modern and reliable.Does the Wyze Lock Bolt support backup key access?
Yes, the Wyze Lock Bolt retains traditional key functionality, allowing you to use a backup key in case of emergencies or power outages. This ensures you never get locked out, even if the smart features are unavailable.What are the main features of the Wyze Lock Bolt?
Key features of the Wyze Lock Bolt include an ultra-fast fingerprint sensor, backlit anti-peep keypad, Bluetooth 5.0 connectivity, auto-lock function, built-in jam detection alarm, emergency one-time codes, and backup key access. It is also weather resistant and offers long battery life.How long does the Wyze Lock Bolt battery last and what type does it use?
The Wyze Lock Bolt uses 4 AA batteries, which are included with the lock. The battery life typically lasts between 10 to 12 months, reducing the need for frequent replacements.Is the Wyze Lock Bolt weather resistant?
Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance, making it suitable for various climates and outdoor conditions.What doors are compatible with the Wyze Lock Bolt?
The Wyze Lock Bolt fits doors that are 1-3/8” to 1-3/4” thick and have standard deadbolt hole sizes, making it compatible with most residential doors.What replacement parts are available for the Wyze Lock Bolt?
Available replacement parts for the Wyze Lock Bolt include Wyze Lock Bolt Screws, Interior Assembly Metal Plate, Interior Assembly Battery Cover, and the Wyze Lock Replacement Part Kit. These parts help maintain and repair your lock for long-lasting performance.What is included in the Wyze Lock Replacement Part Kit?
The Wyze Lock Replacement Part Kit is a comprehensive set that includes essential components for repair or replacement. It is available in two styles: Adapter Replacement Kit and Replacement Part Kit, both designed to extend the life of your smart lock with genuine Wyze parts.How easy is it to install the Wyze Lock Bolt?
The Wyze Lock Bolt is designed for easy installation, allowing you to replace your existing deadbolt without complicated tools or professional assistance. The process is straightforward and user-friendly.What is the Essential Security Bundle and what does it include?
The Essential Security Bundle is a comprehensive home security package that includes the Wyze Lock Bolt, Wyze Video Doorbell v2, Wyze Cam Pan v3, and two Wyze Cam OG Cameras. This bundle provides complete protection, allowing you to monitor and control access to your home from anywhere.Can I control the Wyze Lock Bolt remotely?
Yes, you can control the Wyze Lock Bolt remotely within a 16 ft range using Bluetooth 5.0 and the Wyze app. This allows you to lock or unlock your door and manage access codes conveniently from your smartphone.What color options are available for the Wyze Lock Bolt?
The Wyze Lock Bolt is available in Matte Black and Satin Nickel finishes, allowing you to choose the color that best matches your door hardware.
