Easy to Install Smart Lock Using Existing Deadbolt Hardware
If you're searching for a smart lock that is simple to install and works seamlessly with your existing deadbolt hardware, the
Wyze Lock Bolt is an excellent choice. Designed to replace your current deadbolt without complicated modifications, this smart lock offers advanced features, security, and convenience all in one sleek package.
Wyze Lock Bolt: Smart Security Meets Effortless Installation
Seamless Deadbolt Replacement
The Wyze Lock Bolt is engineered to replace your existing deadbolt, making installation straightforward and hassle-free. It fits standard door thicknesses (1-3/8” to 1-3/4”) and backsets (2-3/8” or 2-3/4”), so you don’t need to change your door hardware. This means you can upgrade to a smart lock without drilling new holes or buying additional parts.
Advanced Features for Modern Living
- Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a quick fingerprint scan.
- Backlit Keypad with Anti-Peep: Enter your code easily even in the dark, with privacy protection against onlookers.
- Auto-Lock Function: Never worry about forgetting to lock your door; it locks automatically after a set time.
- Lock and Unlock History: Monitor access through the Wyze app to see who enters and when.
- Built-in Jam Detection Alarm: Alerts you if the lock is jammed or tampered with.
- Emergency One-Time Codes: Provide temporary access to guests or service providers securely.
Durable and Reliable
- Weather Resistance: Rated IPX5, the lock withstands rain and outdoor conditions.
- Battery Life: Powered by 4 AA batteries (included), lasting 10-12 months on a single set.
- Operating Temperature: Works reliably in temperatures from -13°F to 122°F, suitable for most climates.
Stylish and Functional
Available in
Matte Black and
Satin Nickel, the Wyze Lock Bolt complements any door style with a modern, minimalist look.
Experience smart home security with the Wyze Lock Bolt installed on your front door.
Essential Replacement Parts for Your Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning perfectly or to assist with installation, several replacement parts are available:
Wyze Lock Bolt Interior Assembly Metal Plate
A sturdy metal plate that anchors the interior assembly securely to your door, ensuring stability and durability.
Wyze Lock Bolt Screws
A set of replacement screws compatible with the Wyze Lock Bolt, perfect for installation or maintenance.
Wyze Lock Bolt Interior Assembly Battery Cover
Replacement battery cover designed specifically for the interior assembly, protecting your batteries and internal components.
Wyze Lock Replacement Part Kit
Includes essential parts for repair or replacement, ensuring your smart lock stays in top condition.
Enhance Your Smart Home with Wyze Switch
While the Wyze Lock Bolt secures your home, the
Wyze Switch lets you control your lighting effortlessly, turning any standard light switch into a smart switch. Control your lights from anywhere using the Wyze app, create automations, and integrate with other Wyze devices like cameras and robot vacuums for a fully connected home experience.
- Multi-tap Controls: Customize single, double, or triple taps to trigger different actions.
- Timers and Schedules: Automate your lighting to fit your lifestyle.
- Vacation Mode: Make your home look occupied when you're away.
- Power Loss Recovery: Automatically restores settings after outages.
Available in 1-pack or 3-pack options, the Wyze Switch is a perfect complement to your smart lock for a smarter, safer home.
Control your home lighting easily with the Wyze Switch, enhancing your smart home ecosystem.
Upgrade your home security and convenience with the Wyze Lock Bolt — a smart lock that installs easily using your existing deadbolt hardware, packed with features to keep your home safe and accessible.
Manage your Wyze Lock Bolt remotely with the Wyze app for ultimate control and peace of mind.
Summary of Products Mentioned
What is the Wyze Lock Bolt and how does it work with existing deadbolt hardware?
The Wyze Lock Bolt is a smart lock designed to replace your existing deadbolt without the need for complicated modifications. It fits standard door thicknesses (1-3/8” to 1-3/4”) and backsets (2-3/8” or 2-3/4”), allowing for easy installation using your current door hardware.How easy is it to install the Wyze Lock Bolt smart lock?
The Wyze Lock Bolt is engineered for straightforward, hassle-free installation. It replaces your current deadbolt and fits most standard doors, so you don’t need to drill new holes or purchase additional parts.What advanced security features does the Wyze Lock Bolt offer?
The Wyze Lock Bolt features an ultra-fast fingerprint sensor, a backlit keypad with anti-peep technology, auto-lock function, lock and unlock history tracking via the Wyze app, built-in jam detection alarm, and emergency one-time codes for secure guest access.Is the Wyze Lock Bolt weather resistant and suitable for outdoor use?
Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance, making it suitable for outdoor use. It operates reliably in temperatures ranging from -13°F to 122°F.How long does the Wyze Lock Bolt battery last and what type of batteries does it use?
The Wyze Lock Bolt is powered by 4 AA batteries (included) and typically lasts 10-12 months on a single set, depending on usage.What replacement parts are available for the Wyze Lock Bolt?
Replacement parts for the Wyze Lock Bolt include the interior assembly metal plate, replacement screws, interior assembly battery cover, and a comprehensive replacement part kit to keep your smart lock in top condition.In what finishes is the Wyze Lock Bolt available?
The Wyze Lock Bolt is available in Matte Black and Satin Nickel finishes, offering a modern, minimalist look to complement any door style.How can I monitor and control the Wyze Lock Bolt remotely?
You can monitor access history and control the Wyze Lock Bolt remotely using the Wyze app, giving you ultimate control and peace of mind over your home security.What is the Wyze Switch and how does it enhance my smart home?
The Wyze Switch is a smart light switch that allows you to control your lighting from anywhere using the Wyze app. It features multi-tap controls, timers, schedules, vacation mode, and power loss recovery, making it a perfect complement to the Wyze Lock Bolt for a fully connected smart home.Can I automate my home lighting with the Wyze Switch?
Yes, the Wyze Switch allows you to automate your lighting with customizable timers, schedules, and multi-tap controls, helping you create a smarter and more convenient home environment.
