Smart Lock System with Auto Unlock and Remote Access Notifications
Upgrade your home security with the latest smart lock technology designed for convenience, safety, and seamless control. Whether you want to unlock your door with a fingerprint, receive instant notifications remotely, or automate your door locking, these smart lock solutions deliver advanced features tailored to modern living.
Wyze Lock Bolt: The Ultimate Smart Lock for Effortless Access
Experience keyless entry like never before with the
Wyze Lock Bolt, a Bluetooth-enabled smart lock that replaces your traditional deadbolt. Designed for quick and secure access, it features an ultra-fast fingerprint reader and a luxurious backlit keypad.
Key Features
Fingerprint Unlock & Backlit Keypad
Unlock your door in less than a second with just a tap of your finger or by entering your code on the illuminated keypad, perfect for nighttime use.
Auto-Lock for Peace of Mind
Never worry about leaving your door unlocked. The Wyze Lock Bolt automatically locks after a set delay, configurable through the Wyze app.
Monitor your door’s status and receive alerts on your smartphone. The app shows who unlocked the door, when, and how, including failed attempts.
Anti-Peep Technology
Enter extra digits before or after your code to prevent onlookers from guessing your passcode.
Robust Security & Weatherproof Design
Crafted from solid metal with IPX5 weatherproofing, it’s pick-proof and built to withstand the elements.
Long Battery Life with Backup Charging
Powered by 4 AA batteries lasting up to 12 months, with a USB-C port for emergency charging if batteries run low.
Easy Installation
Replaces your existing deadbolt in about 20 minutes, compatible with most exterior doors.
App Control & Access Management
The Wyze app acts as your command center, allowing you to:
- Create and store up to 20 access codes and 50 fingerprints for family and guests.
- Generate emergency one-time codes remotely, even without Bluetooth connection.
- Set auto-expiring codes and access schedules for temporary visitors.
- View detailed lock/unlock history with timestamps.
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Wyze Lock Bolt with app control for smart access
Essential Security Bundle: Comprehensive Home Protection
For those seeking an all-in-one smart home security solution, the
Essential Security Bundle combines the Wyze Lock Bolt with other advanced devices to safeguard your home from every angle.
Bundle Includes:
Wyze Lock Bolt
Fast fingerprint sensor and backlit keypad for secure, keyless entry.
Wyze Video Doorbell v2
Crisp 1080p HD video with two-way audio to monitor and communicate with visitors.
Wyze Cam Pan v3
Pan-and-tilt camera with 360° horizontal and 180° vertical coverage, automatic motion tracking, and color night vision.
Two Wyze Cam OG Cameras
Plug-in security cameras with motion-activated spotlights and color night vision for indoor or outdoor use.
Why Choose the Bundle?
- Real-time alerts and remote monitoring keep you connected wherever you are.
- Integrated devices work together to provide layered security.
- Weather-resistant cameras and smart lock ensure durability and reliability.
Comprehensive home security with Wyze smart cameras and lock
Replacement Parts for Wyze Lock Bolt
Maintain your smart lock’s performance with genuine replacement parts designed specifically for the Wyze Lock Bolt:
Wyze Lock Bolt Screws
Secure your lock firmly with replacement screws.
Wyze Lock Bolt Interior Assembly Battery Cover
Protect the battery compartment with a durable cover.
Wyze Lock Bolt Interior Assembly Metal Plate
Anchor the interior assembly securely to your door.
Wyze Lock Replacement Part Kit
Comprehensive kit for repairs and maintenance (adapter kit also available).
These parts ensure your smart lock remains reliable and functional for years to come.
Why Choose Wyze Smart Lock Systems?
- Fast and Secure Access with fingerprint and keypad entry.
- Remote Notifications keep you informed about your door’s status.
- Auto-Lock and Auto-Unlock Features (available in Wyze Lock models) enhance convenience.
- Easy Installation compatible with most doors.
- Robust Security with hardware encryption and two-factor authentication.
- Long Battery Life with emergency charging options.
Secure your home effortlessly with Wyze’s smart lock technology — the perfect blend of convenience, security, and smart home integration.
Wyze Lock Bolt installed on a stylish front door
What is the Wyze Lock Bolt and how does it work?
The Wyze Lock Bolt is a Bluetooth-enabled smart lock that replaces your traditional deadbolt, offering keyless entry through an ultra-fast fingerprint reader and a backlit keypad. It allows you to unlock your door in less than a second using your fingerprint or a code, and can be managed via the Wyze app for added convenience and security.How do I unlock my door with the Wyze Lock Bolt?
You can unlock your door using the Wyze Lock Bolt by either scanning your fingerprint on the ultra-fast reader or entering your code on the illuminated keypad. Both methods provide quick and secure access, even in low-light conditions.Does the Wyze Lock Bolt have an auto-lock feature?
Yes, the Wyze Lock Bolt features an auto-lock function that automatically locks your door after a set delay, which you can configure through the Wyze app. This ensures your door is always secure, even if you forget to lock it manually.Can I receive remote notifications with the Wyze Lock Bolt?
Yes, the Wyze Lock Bolt sends instant notifications to your smartphone via the Wyze app. You can monitor your door’s status, see who unlocked the door and when, and receive alerts for failed unlock attempts, keeping you informed wherever you are.What is anti-peep technology on the Wyze Lock Bolt?
Anti-peep technology allows you to enter extra digits before or after your actual passcode on the keypad. This prevents onlookers from guessing your code, enhancing your home’s security.Is the Wyze Lock Bolt weatherproof and secure?
Yes, the Wyze Lock Bolt is crafted from solid metal and features IPX5 weatherproofing, making it suitable for outdoor use. It is also pick-proof and built to withstand harsh weather conditions, ensuring robust security for your home.How long does the Wyze Lock Bolt battery last and what happens if it runs low?
The Wyze Lock Bolt is powered by 4 AA batteries that can last up to 12 months. If the batteries run low, you can use the built-in USB-C port for emergency charging to ensure you’re never locked out.How easy is it to install the Wyze Lock Bolt?
The Wyze Lock Bolt is designed for easy installation and can replace your existing deadbolt in about 20 minutes. It is compatible with most exterior doors, making it a convenient upgrade for your home security.What access management features does the Wyze app provide?
The Wyze app allows you to create and store up to 20 access codes and 50 fingerprints, generate emergency one-time codes remotely, set auto-expiring codes and access schedules for guests, and view detailed lock/unlock history with timestamps.What is included in the Wyze Essential Security Bundle?
The Wyze Essential Security Bundle includes the Wyze Lock Bolt, Wyze Video Doorbell v2, Wyze Cam Pan v3, and two Wyze Cam OG Cameras. This bundle provides comprehensive home protection with real-time alerts, remote monitoring, and integrated smart devices.Are there replacement parts available for the Wyze Lock Bolt?
Yes, genuine replacement parts for the Wyze Lock Bolt are available, including screws, interior assembly battery covers, metal plates, and a comprehensive replacement part kit. These parts help maintain your smart lock’s performance and reliability.Why should I choose Wyze smart lock systems for my home?
Wyze smart lock systems offer fast and secure access with fingerprint and keypad entry, remote notifications, auto-lock and auto-unlock features, easy installation, robust security with hardware encryption and two-factor authentication, and long battery life with emergency charging options.
