Refurbished Wyze Cam Floodlight with Dusk to Dawn Automation and Siren
Looking for a smart, reliable, and powerful outdoor security solution? The refurbished Wyze Cam Floodlight series offers advanced features like dusk-to-dawn automation, loud sirens, and intelligent lighting to keep your home safe and well-lit. Whether you want a high-resolution camera with wide-angle views or AI-powered motion detection, Wyze has you covered with options tailored to your needs.
Wyze Cam Floodlight v2: Bright, Smart, and Affordable
Powerful Illumination and Crisp 2K Video
The Wyze Cam Floodlight v2 dominates the dark with two 2800 lumen LEDs and a crystal-clear 2K resolution camera. Its 160° wide-angle lens captures more of your property, reducing blind spots and giving you peace of mind.
Intelligent Lighting with Dusk-to-Dawn Automation
This floodlight automatically turns on at dusk and off at dawn, so you never have to worry about manual switches. The Ambient Light Mode provides a gentle glow all night, brightening instantly when motion is detected to deter unwanted visitors.
Enhanced Security Features
- Two-way talk: Communicate directly through the camera using the Wyze app.
- 105dB siren: Scare off intruders with a loud, built-in siren.
- 270° PIR motion detection: Covers a wide area to trigger lights and alerts faster.
- 24/7 local recording: Save continuous footage on a microSD card (up to 256GB) without subscription fees.
- IP65 weather resistance: Built to withstand rain, snow, and harsh outdoor conditions.
- Smart assistant integration: Works seamlessly with Alexa and Google Home for voice control and live feed viewing.
Easy DIY Installation
No electrician needed! The floodlight can be installed using a floodlight plug-in mount, perfect for renters or those with outdoor outlets.
Wyze Cam Floodlight v2 lighting up a driveway with motion detection
Wyze Cam Floodlight Pro: The Ultimate Outdoor Security Guard
Ultra-Wide 180° View with 2.5K QHD Video
Step up your security with the Wyze Cam Floodlight Pro, featuring a massive 180° field of view and stunning 2.5K Quad HD resolution. See every corner of your yard in vivid detail, day or night.
AI-Powered Motion Detection and Lighting
Unlike traditional PIR sensors, this floodlight uses onboard AI computer vision to detect specific objects like people and vehicles. The lights activate only when necessary, reducing false alarms and saving energy.
Superior Lighting and Customization
- 3,000 lumen LEDs: Three adjustable floodlight heads provide bright, customizable coverage.
- Ambient Light Mode: Provides constant low-level lighting that brightens on motion.
- Motion-Activated Voice Deterrence: Plays a voice prompt when a person is detected, plus a 105dB siren for extra security.
Advanced Connectivity and Convenience
- Supports both 2.4 GHz and 5 GHz Wi-Fi for faster, more reliable connections.
- Easy BluetoothⓇ setup without QR codes.
- Dusk-to-dawn automation ensures your property is always illuminated when needed.
- IP65 weatherproof rating for all-season durability.
- 24/7 recording with microSD card support (up to 256GB).
Quick and Simple Installation
Replace your existing floodlight in under 20 minutes with the DIY installation guide. A plug-in mount option is also available for easy setup without electrical work.
Wyze Cam Floodlight Pro providing bright security lighting and alerts
Why Choose a Refurbished Wyze Cam Floodlight?
Refurbished Wyze Cam Floodlights offer the same high-quality features and performance as new units but at a more affordable price point. Each device undergoes rigorous testing to ensure reliability and functionality, making them a smart choice for budget-conscious homeowners who want premium security.
Summary: Which Wyze Floodlight Camera Fits Your Needs?
Feature | Wyze Cam Floodlight v2 | Wyze Cam Floodlight Pro |
Camera Resolution | 2K | 2.5K QHD |
Field of View | 160° | 180° |
LED Brightness | 2800 lumens | 3000 lumens (3 heads) |
AI Motion Detection | Yes (with Cam Plus) | Advanced onboard AI |
Siren | 105dB loud siren | 105dB loud siren + voice deterrence |
Dusk-to-Dawn Automation | Yes | Yes |
Weather Resistance | IP65 | IP65 |
Wi-Fi Support | 2.4 GHz | Dual-band 2.4 & 5 GHz |
Installation | DIY with plug-in mount option | DIY with plug-in mount option |
Price | Affordable | Premium |
Invest in a refurbished Wyze Cam Floodlight today to enjoy smart, automated lighting and security that protects your home around the clock.
### Product Tags and Highlights
What features does the refurbished Wyze Cam Floodlight offer?
The refurbished Wyze Cam Floodlight series provides advanced features such as dusk-to-dawn automation, loud 105dB sirens, intelligent lighting, two-way talk, AI-powered motion detection, and high-resolution cameras. These features help keep your home safe and well-lit while offering reliable outdoor security.What is the difference between Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro?
Wyze Cam Floodlight v2 features a 2K camera with a 160° field of view, 2800 lumen LEDs, and PIR motion detection. The Wyze Cam Floodlight Pro offers a 2.5K QHD camera, a wider 180° field of view, 3000 lumen LEDs with three adjustable heads, advanced onboard AI motion detection, dual-band Wi-Fi support, and motion-activated voice deterrence in addition to the siren.How does dusk-to-dawn automation work on Wyze Cam Floodlights?
Dusk-to-dawn automation automatically turns the floodlight on at dusk and off at dawn, ensuring your property is always illuminated when needed. This feature eliminates the need for manual operation and helps save energy.Are refurbished Wyze Cam Floodlights reliable?
Yes, refurbished Wyze Cam Floodlights undergo rigorous testing to ensure they meet the same quality and performance standards as new units. They are a cost-effective choice for homeowners seeking premium security at a lower price.Can I install Wyze Cam Floodlights myself?
Yes, both Wyze Cam Floodlight v2 and Pro are designed for easy DIY installation. They offer plug-in mount options, making them suitable for renters or anyone with outdoor outlets. The Pro model can also replace existing floodlights in under 20 minutes.Do Wyze Cam Floodlights support continuous recording?
Yes, both models support 24/7 local recording to a microSD card (up to 256GB), allowing you to save continuous footage without subscription fees.Are Wyze Cam Floodlights weatherproof?
Yes, both the Wyze Cam Floodlight v2 and Pro have an IP65 weather resistance rating, making them suitable for use in rain, snow, and harsh outdoor conditions.Do Wyze Cam Floodlights work with smart home assistants?
Yes, Wyze Cam Floodlights are compatible with Alexa and Google Home, allowing for voice control and live feed viewing through your smart home devices.What type of motion detection do Wyze Cam Floodlights use?
Wyze Cam Floodlight v2 uses 270° PIR motion detection, while the Pro model features advanced onboard AI computer vision to detect specific objects like people and vehicles, reducing false alarms.What are the lighting options on Wyze Cam Floodlights?
Both models offer powerful LED floodlights with ambient light modes. The v2 provides 2800 lumens, while the Pro offers 3000 lumens with three adjustable heads. Ambient Light Mode provides a gentle glow all night and brightens instantly when motion is detected.
