2K HD Hardwired Outdoor Floodlight Camera Bundle for Complete Yard Security
When it comes to securing your yard with crystal-clear video and powerful lighting, a 2K HD hardwired outdoor floodlight camera bundle is the ultimate solution. Combining high-resolution video, bright floodlights, and smart features, these cameras provide comprehensive coverage and peace of mind. Below, we explore the top Wyze products designed specifically for outdoor security with hardwired floodlight cameras, perfect for illuminating and monitoring your entire yard.
Wyze Cam Floodlight v2: Bright, Smart, and Reliable Security
Powerful Illumination and Crisp 2K Video
The Wyze Cam Floodlight v2 is engineered to dominate the dark with its
2800 lumens of brightness from two dimmable LED light panels. It delivers
2K (2304 x 1296) resolution video with
Color Night Vision, ensuring you see every detail in vibrant color even at night. The wide
160° diagonal field of view covers a broad area, minimizing blind spots.
Smart Features for Enhanced Security
- AI-Powered Light Control automatically adjusts lighting based on detected motion.
- Dusk-to-dawn automation ensures your yard is always well-lit when needed.
- Two-way talk lets you communicate through the built-in speaker and microphone.
- 105dB siren for loud deterrence against intruders.
- Supports local recording with up to 256 GB microSD card.
- IP65 weather resistance guarantees durability in rain, snow, or shine.
- Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
Installation and Design
This floodlight camera is
hardwired (110-120V AC) for continuous power, with options for
wall or ceiling mounting. Its matte polycarbonate body and glass/plastic lens materials ensure a sturdy, weatherproof build.
Bright floodlight camera securing a driveway
Wyze Cam Floodlight Pro: Advanced 2.5K QHD Security with AI
Superior Video and Lighting Performance
Step up your yard security with the
Wyze Cam Floodlight Pro, featuring a
2.5K QHD (2560 x 1440) resolution and a massive
3000 lumens from three dimmable LED panels. Its
180° diagonal field of view offers end-to-end coverage of your property.
Intelligent Motion Detection and Voice Deterrence
- Uses evolutionary onboard AI computer vision to detect specific objects like people and vehicles.
- Motion-activated voice deterrence warns off unwanted visitors.
- Built-in 105dB siren adds an extra layer of protection.
- Supports dual-band WiFi (2.4 & 5 GHz) for reliable connectivity.
- Local storage up to 256 GB microSD with exFAT and FAT32 formatting.
- Weatherproof with IP65 rating, designed to withstand harsh outdoor conditions.
Easy Integration and Installation
Hardwired for consistent power, the Floodlight Pro supports both
wall and ceiling mounts. It integrates smoothly with
Alexa, Google Assistant, and IFTTT, making it a smart addition to any connected home.
Secure your yard with Wyze Cam Floodlight Pro
Floodlight Security Bundle: All-in-One Yard Protection
Bundle Features for Maximum Security
The
Floodlight Security Bundle combines the power of Wyze’s floodlight cameras into one package, offering:
2K HD resolution with Color Night Vision
- Super-bright LEDs with dimmable and adjustable lighting
- Wide field of view for comprehensive yard coverage
- 24/7 recording with microSD card support
- Motion-activated voice deterrence and ambient light mode
- IP65 water resistance for all-weather reliability
Versatile and Ready to Install
This bundle includes options for both the
Floodlight Pro (2.5K QHD) and
Floodlight v2 (2K) models, available in black or white finishes. Both are hardwired for dependable power and can be mounted on walls or ceilings.
Why Choose a Hardwired 2K HD Floodlight Camera Bundle?
Combining high-definition video with powerful floodlighting and smart features, these hardwired cameras provide continuous, reliable security for your yard. Unlike battery-powered options, hardwired floodlight cameras ensure you never run out of power, and their advanced AI capabilities help reduce false alerts while keeping your property safe day and night.
Additional Outdoor Security Camera Options
While the focus is on hardwired floodlight cameras, consider complementing your yard security with these Wyze outdoor cameras:
Wyze Cam v4
- 2.5K QHD resolution with enhanced color night vision.
- Motion-activated spotlight and Wi-Fi 6 support.
- Compact design with multiple mounting options.
- IP65 weather resistance for outdoor use.
Wyze Cam Pan v3
- 360° horizontal and 180° vertical coverage with pan and tilt.
- 1080p HD video with night vision.
- IP65 weatherproof rating.
- Requires separate outdoor power adapter for safe outdoor use.
Wyze Cam v3
- Award-winning 1080p camera with color night vision.
- IP65 weatherproofing for outdoor durability.
- Person, vehicle, pet, and package detection with Cam Plus subscription.
- Supports local microSD storage and cloud storage options.
Conclusion
For complete yard security with bright illumination and crystal-clear 2K HD video, the
Wyze Cam Floodlight v2,
Wyze Cam Floodlight Pro, and the
Floodlight Security Bundle are your best choices. These hardwired outdoor floodlight cameras combine powerful lighting, smart AI features, and weatherproof durability to keep your home safe around the clock.
Invest in a hardwired floodlight camera bundle today and enjoy peace of mind knowing your yard is protected with the latest in smart security technology.
Product Highlights Summary
- Wyze Cam Floodlight v2: 2800 lumens, 2K color night vision, AI light control, IP65, two-way talk.
- Wyze Cam Floodlight Pro: 3000 lumens, 2.5K QHD, AI object detection, voice deterrence, dual-band WiFi.
- Floodlight Security Bundle: Combines Floodlight Pro and v2 features, dimmable LEDs, 24/7 recording.
- Wyze Cam v4: 2.5K QHD, color night vision, Wi-Fi 6, motion spotlight.
- Wyze Cam Pan v3: 360° pan/tilt, 1080p, IP65, outdoor power adapter required.
- Wyze Cam v3: 1080p, color night vision, IP65, person and vehicle detection.
What is included in the Wyze 2K HD Hardwired Outdoor Floodlight Camera Bundle?
The Wyze 2K HD Hardwired Outdoor Floodlight Camera Bundle includes high-resolution floodlight cameras such as the Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro. These cameras offer 2K or 2.5K QHD video, super-bright dimmable LED floodlights, AI-powered motion detection, two-way talk, siren, and weatherproof IP65-rated construction. The bundle provides comprehensive yard coverage and 24/7 recording with microSD card support.What are the main features of the Wyze Cam Floodlight v2?
The Wyze Cam Floodlight v2 features 2800 lumens of brightness from two dimmable LED panels, 2K (2304 x 1296) resolution video with Color Night Vision, a 160° diagonal field of view, AI-powered light control, dusk-to-dawn automation, two-way talk, a 105dB siren, local recording up to 256 GB microSD, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT.How does the Wyze Cam Floodlight Pro differ from the Floodlight v2?
The Wyze Cam Floodlight Pro offers a higher 2.5K QHD (2560 x 1440) resolution, 3000 lumens from three dimmable LED panels, a wider 180° field of view, advanced AI computer vision for object detection, motion-activated voice deterrence, dual-band WiFi (2.4 & 5 GHz), and local storage up to 256 GB microSD. Like the v2, it is IP65 weatherproof and supports Alexa, Google Assistant, and IFTTT.Are Wyze floodlight cameras weatherproof for outdoor use?
Yes, both the Wyze Cam Floodlight v2 and Floodlight Pro are IP65 weather resistant, making them suitable for use in rain, snow, or shine. Their durable construction ensures reliable performance in harsh outdoor conditions.Do Wyze floodlight cameras require hardwiring?
Yes, Wyze floodlight cameras such as the Floodlight v2 and Floodlight Pro are hardwired (110-120V AC) for continuous, reliable power. This ensures uninterrupted operation and eliminates the need to recharge batteries.Can I record video locally on Wyze floodlight cameras?
Yes, both Wyze Cam Floodlight v2 and Floodlight Pro support local video recording with microSD cards up to 256 GB. This allows for 24/7 continuous recording and easy access to your footage.What smart home integrations are available with Wyze floodlight cameras?
Wyze floodlight cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing you to integrate them seamlessly into your smart home ecosystem for voice control and automation.What is the field of view for Wyze floodlight cameras?
The Wyze Cam Floodlight v2 offers a 160° diagonal field of view, while the Wyze Cam Floodlight Pro provides an even wider 180° diagonal field of view, ensuring comprehensive coverage of your yard.What security features do Wyze floodlight cameras offer?
Wyze floodlight cameras include AI-powered motion detection, two-way talk, a 105dB siren, motion-activated voice deterrence (Pro model), and bright floodlights to deter intruders and provide peace of mind.Are there different color options for Wyze floodlight cameras?
Yes, both the Wyze Cam Floodlight v2 and Floodlight Pro are available in black or white finishes, allowing you to choose the best match for your home’s exterior.Can I mount Wyze floodlight cameras on a wall or ceiling?
Yes, both Wyze Cam Floodlight v2 and Floodlight Pro support flexible installation options, including wall and ceiling mounting, to suit your specific security needs.What other Wyze outdoor security cameras can complement my floodlight camera setup?
You can enhance your yard security with additional Wyze cameras such as the Wyze Cam v4 (2.5K QHD, color night vision, Wi-Fi 6), Wyze Cam Pan v3 (360° pan/tilt, 1080p, IP65), and Wyze Cam v3 (1080p, color night vision, IP65, person and vehicle detection).Why choose a hardwired floodlight camera over a battery-powered one?
Hardwired floodlight cameras provide continuous, reliable power, ensuring your security system never runs out of battery. They also support advanced features like AI detection, bright floodlighting, and 24/7 recording, making them ideal for comprehensive yard security.
