Refurbished Wyze Cam Floodlight Installation with Wall Mounting Kit
Enhance your home security effortlessly with refurbished Wyze Cam Floodlight models paired with easy-to-install wall mounting kits. Whether you want a plug-and-play solution or a high-powered wired floodlight, Wyze offers versatile options that simplify installation and deliver advanced security features. This guide highlights the best Wyze Cam Floodlight products with wall mounting kits, focusing on installation ease, performance, and smart home integration.
Easy Installation with Wyze Cam Floodlight Plug-In Mount
Plug-and-Play Convenience
The
Wyze Cam Floodlight Plug-In Mount is designed to eliminate the hassle of complex wiring or installing a junction box. This accessory is compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro models, providing a flexible and outdoor-safe mounting solution.
- Power Cord Length: 20 ft (6m) for flexible placement
- Operating Temperature: -22°F to 122°F, suitable for various climates
- Input Voltage: 110 - 120V AC
- Included Items: Mount, silicone ring, screws, foam tape, and quick start guide
- Colors Available: Black and White
This mount allows you to plug your floodlight directly into an outdoor outlet, making installation quick and cost-effective without professional electrical work.
Say goodbye to the complexity and cost of installing a junction box with this simple plug-in mount.
Easy outdoor installation of Wyze Cam Floodlight with plug-in mount
Wyze Cam Floodlight v2 + Plug-In Mount Bundle
Smart Security with 2K HD Video and Vibrant Night Vision
The
Wyze Cam Floodlight v2 + Plug-In Mount bundle offers a complete package for those seeking a reliable, easy-to-install floodlight camera with advanced features:
- Video Quality: 2K HD with vibrant color night vision
- Field of View: 160° wide-angle for broad coverage
- Lighting: 2800 lumens with dimmable LEDs
- Siren: 105dB built-in siren for deterrence
- Installation: No junction box needed; includes 20 ft cable and velcro strap for cable management
- Power Solution: Flexible plug-in mount compatible with all Wyze Cam Floodlights
This bundle is perfect for users who want a balance of high-quality video, bright lighting, and simple installation.
Wyze Cam Floodlight v2 with two-way audio and smart home integration
Wyze Cam Floodlight Pro + Plug-In Mount Bundle
Professional Grade Security with 2.5K QHD and AI-Powered Lighting
For those who want top-tier security, the
Wyze Cam Floodlight Pro + Plug-In Mount bundle combines powerful hardware with intelligent software:
- Resolution: 2.5K QHD (2560 x 1440) for crystal-clear video
- Field of View: 180° ultra-wide lens covers large areas
- Light Output: 3000 lumens with adjustable brightness
- AI Computer Vision: Detects people and vehicles, activating lights only when needed
- Color Night Vision: See in full color even in low light
- Power Cord: 20 ft plug-in mount for easy installation
- Weather Resistance: IP65 rated for outdoor durability
- Smart Integrations: Works with Alexa, Google Assistant, and IFTTT
This bundle is ideal for users who want a high-powered floodlight camera that acts like a personal security guard, with smart detection and bright, responsive lighting.
Wyze Cam Floodlight Pro illuminating a deck area at dusk
Additional Wyze Floodlight Options for Wall Mounting
Wyze Cam Floodlight Pro (Standalone)
If you already have a mounting solution or want to hardwire your floodlight, the
Wyze Cam Floodlight Pro offers:
3 dimmable light panels with 3000 lumens brightness
2.5K QHD video with color night vision
180° diagonal field of view
Built-in 105dB siren
Dual-band WiFi (2.4 & 5 GHz)
Wall or ceiling mount compatible
IP65 weather resistance
Wyze Cam Floodlight v2 (Standalone)
The
Wyze Cam Floodlight v2 is a solid choice for wired floodlight security with:
2K video resolution with color night vision
2800 lumens LED lighting
160° diagonal field of view
105dB siren and two-way audio
Dusk-to-dawn automation and IP65 rating
Both models support microSD cards up to 256GB for local storage and integrate seamlessly with smart home assistants.
Why Choose Refurbished Wyze Cam Floodlight with Wall Mounting Kit?
Refurbished Wyze Cam Floodlights provide an affordable, eco-friendly way to secure your home with trusted technology. Paired with the plug-in wall mounting kits, installation is straightforward, saving you time and money.
- Cost-Effective: Save on installation and product costs
- Easy Setup: Plug-in mounts avoid complex wiring
- Reliable Performance: Tested and certified for outdoor use
- Smart Features: AI detection, color night vision, and voice assistant compatibility
- Flexible Mounting: Wall or ceiling options with included hardware
Conclusion
Installing a refurbished Wyze Cam Floodlight with a wall mounting kit is the perfect solution for homeowners seeking smart, bright, and easy-to-install outdoor security. Whether you choose the budget-friendly Wyze Cam Floodlight v2 bundle or the advanced Floodlight Pro with AI capabilities, these products deliver excellent value and peace of mind.
Upgrade your home security today with Wyze’s plug-in mounts and floodlight cameras — simple installation, powerful features, and smart home integration all in one.
Product Tags Summary
What are the benefits of choosing a refurbished Wyze Cam Floodlight with a wall mounting kit?
Refurbished Wyze Cam Floodlights with wall mounting kits offer a cost-effective and eco-friendly way to enhance your home security. These products are tested and certified for reliable outdoor use, and the included plug-in mounts make installation easy by eliminating the need for complex wiring or a junction box.How easy is it to install a Wyze Cam Floodlight with a plug-in wall mounting kit?
Installing a Wyze Cam Floodlight with a plug-in wall mounting kit is quick and straightforward. The kit includes a 20 ft power cord, silicone ring, screws, foam tape, and a quick start guide. Simply mount the floodlight, plug it into an outdoor outlet, and manage the cable with the included velcro strap—no professional electrical work required.Which Wyze Cam Floodlight models are compatible with the plug-in wall mounting kit?
The plug-in wall mounting kit is compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro models. This ensures flexible installation options for a variety of Wyze floodlight cameras.What advanced features do Wyze Cam Floodlight v2 and Pro offer?
Wyze Cam Floodlight v2 features 2K HD video, vibrant color night vision, a 160° wide-angle field of view, 2800 lumens of dimmable LED lighting, a 105dB siren, and two-way audio. The Floodlight Pro offers 2.5K QHD video, 180° ultra-wide lens, 3000 lumens of adjustable lighting, AI-powered person and vehicle detection, color night vision, and smart home integration with Alexa, Google Assistant, and IFTTT.Can Wyze Cam Floodlights be integrated with smart home systems?
Yes, Wyze Cam Floodlight Pro and v2 models support smart home integration. They work with Alexa, Google Assistant, and IFTTT, allowing you to control your security system with voice commands and automate routines.Are Wyze Cam Floodlights weather resistant for outdoor use?
All Wyze Cam Floodlight models mentioned are IP65 rated for weather resistance, making them suitable for outdoor installation in various climates, with operating temperatures ranging from -22°F to 122°F.Do Wyze Cam Floodlights support local video storage?
Yes, both Wyze Cam Floodlight v2 and Pro models support microSD cards up to 256GB for local video storage, allowing you to record and review footage without a subscription.What is included in the Wyze Cam Floodlight plug-in mount kit?
The Wyze Cam Floodlight plug-in mount kit includes the mount itself, a 20 ft (6m) power cord, silicone ring, screws, foam tape, and a quick start guide. It is available in black and white to match your home’s exterior.Can Wyze Cam Floodlights be mounted on both walls and ceilings?
Yes, Wyze Cam Floodlight v2 and Pro models are compatible with both wall and ceiling mounting, providing flexibility for different installation needs.Why should I consider a plug-in mount instead of hardwiring my Wyze Cam Floodlight?
A plug-in mount allows for easy, tool-free installation without the need for a junction box or professional electrical work. This saves time and money, making it ideal for renters or homeowners seeking a hassle-free security upgrade.
