Smart Wired Floodlight Security Cameras with Two-Way Talk & Siren
Smart Wired Motion Activated Floodlight Security Cameras
When it comes to securing your home with smart, wired floodlight security cameras, Wyze offers top-tier options that combine powerful illumination, high-resolution video, two-way talk, and siren features. These cameras are designed to keep your property safe day and night with intelligent motion activation and adjustable LED floodlights. Explore the Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro — two standout models that deliver exceptional security performance with smart features tailored for wired installation.
Wyze Cam Floodlight v2: Bright, Smart, and Reliable Security
Powerful Illumination and Wide-Angle Coverage
The Wyze Cam Floodlight v2 dominates the dark with two adjustable 2800 lumen LEDs that activate with motion, effectively lighting up your outdoor spaces. Its 160° wide-angle lens captures a broad view, ensuring fewer blind spots around your home.
Crystal-Clear 2K Video with Color Night Vision
Enjoy sharp 2K resolution video that captures fine details, even at night, thanks to color night vision technology. This clarity helps you identify visitors or potential intruders with ease.
Two-Way Talk and Loud Siren
Communicate directly through the camera using the Wyze app’s two-way talk feature. If needed, activate the 105dB siren to deter unwanted guests instantly.
Smart Features and Weather Resistance
  • AI-Powered Light Control and Ambient Light Mode provide constant low-level lighting that brightens upon motion detection.
  • Dusk-to-dawn automation means the floodlight turns on and off automatically with the sun.
  • IP65 weatherproof rating ensures durability in rain, snow, or shine.
  • 24/7 local recording via microSD card (up to 256GB) with no subscription required.
  • Compatible with Alexa and Google Assistant for seamless smart home integration.
"Wyze Cam Floodlight v2 lights the way to smarter home security."
Wyze Cam Floodlight v2 in action illuminating a driveway at night Alt text: Wyze Cam Floodlight v2 illuminating driveway with motion detection
Wyze Cam Floodlight Pro: Advanced AI and Ultra-Bright Security
Industry-Leading 180° Field of View
The Floodlight Pro offers the widest coverage in its class with a 180° wide-angle lens, allowing you to monitor your entire yard with fewer blind spots.
Stunning 2.5K QHD Video and Color Night Vision
Capture ultra-clear video in Quad HD resolution, providing crisp images day and night. The enhanced color night vision ensures you never miss a detail.
AI-Powered Motion Detection and Selective Lighting
Unlike traditional PIR sensors, this model uses onboard AI computer vision to detect motion from specific objects like people and vehicles. The adjustable 3000 lumen LEDs activate only when necessary, reducing false alarms and energy waste.
Enhanced Two-Way Talk and Siren with Voice Deterrence
The Floodlight Pro features motion-activated voice deterrence that plays a custom voice prompt when a person is detected, alongside a powerful 105dB siren to scare off intruders.
Dual-Band Wi-Fi and Weatherproof Design
  • Supports both 2.4 GHz and 5 GHz Wi-Fi for faster, more reliable connections.
  • IP65 weather resistance protects against harsh outdoor conditions.
  • Dusk-to-dawn automation for effortless lighting control.
  • 24/7 recording with microSD card support up to 256GB.
  • Easy DIY installation replaces existing floodlights in under 20 minutes.
"Wyze Cam Floodlight Pro acts like a personal home security guard with bright, smart lights."
Wyze Cam Floodlight Pro installed on a side door with a woman and dog nearby Alt text: Wyze Cam Floodlight Pro installed outdoors with woman and dog
Why Choose a Wired Floodlight Security Camera?
Wired floodlight cameras like the Wyze Cam Floodlight v2 and Pro models offer consistent power without the need for battery changes, ensuring your security system is always active. Their motion-activated LEDs provide both illumination and deterrence, while integrated two-way talk and sirens give you direct control to respond to visitors or threats instantly. Both models support local storage options and smart assistant integrations, making them versatile additions to any smart home security setup.
Summary of Key Features
FeatureWyze Cam Floodlight v2Wyze Cam Floodlight Pro
Video Resolution2K (2560x1440)2.5K QHD (2560x1440)
Field of View160°180°
LED Brightness2800 lumens (2 LEDs)3000 lumens (3 adjustable LEDs)
Night VisionColor Night VisionColor Night Vision
Motion DetectionPIR + AI Light ControlAI Computer Vision
Two-Way TalkYesYes
Siren Volume105 dB105 dB
Wi-Fi Support2.4 GHzDual-band 2.4 & 5 GHz
Weather ResistanceIP65IP65
Local StoragemicroSD up to 256GBmicroSD up to 256GB
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Price$89.98$149.98
Conclusion
For a smart wired motion-activated floodlight security camera with adjustable LED lights, two-way talk, and a siren, the Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro stand out as excellent choices. Whether you want a reliable, bright, and affordable option or a premium model with advanced AI and wider coverage, Wyze has you covered. Secure your home with smart lighting and crystal-clear video that keeps you connected and in control, day and night.
Video Resolution2K HD (1920 x 1080 approx.)2.5K QHD (2560 x 1440)
Field of View160° wide-angle180° ultra-wide
LED Brightness2800 lumens3000 lumens
Number of Floodlight Heads23 (independently articulating)
Motion DetectionAdvanced PIR with 270° coverageAI computer vision (onboard)
Motion WarningYes (with Cam Plus)Yes (AI-powered, no subscription required)
Two-Way TalkYesYes
Siren105 dB105 dB
Ambient Light ModeYesYes
Dusk-to-Dawn AutomationYesYes
Local Recording24/7 local recording via microSD (up to 256GB)24/7 local recording via microSD (up to 256GB)
Cloud Storage & AI DetectionOptional Cam Plus subscription for Person, Package, Vehicle detectionOptional Cam Plus subscription for Person, Package, Vehicle detection
Wi-Fi Compatibility2.4 GHzDual-band 2.4 & 5 GHz
InstallationDIY, no junction box needed; plug-in mount availableDIY, no junction box needed; plug-in mount available
Power Cord Length20 ft20 ft
Operating Temperature RangeNot specified-4°F to 140°F (-20°C to 60°C)
Price (Regular)$89.98$149.98
What are the main differences between Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro?The Wyze Cam Floodlight v2 features 2K video resolution, a 160° field of view, and 2800 lumen adjustable LEDs, while the Wyze Cam Floodlight Pro offers 2.5K QHD video, a wider 180° field of view, and 3000 lumen adjustable LEDs. The Pro model also includes advanced AI computer vision for motion detection, dual-band Wi-Fi (2.4 GHz and 5 GHz), and motion-activated voice deterrence.
How does motion detection work on Wyze Cam Floodlight security cameras?Wyze Cam Floodlight v2 uses a combination of PIR (Passive Infrared) sensors and AI-powered light control to detect motion and activate the floodlights. The Wyze Cam Floodlight Pro uses onboard AI computer vision to detect specific objects like people and vehicles, reducing false alarms and ensuring the lights only activate when necessary.
Do Wyze Cam Floodlight security cameras support color night vision?Yes, both the Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro offer color night vision, allowing you to capture clear, detailed video footage even in low-light or nighttime conditions.
Can I use two-way talk and a siren with Wyze Cam Floodlight cameras?Yes, both models feature two-way talk, allowing you to communicate directly through the camera using the Wyze app. They also include a powerful 105dB siren to deter unwanted visitors. The Pro model adds motion-activated voice deterrence for extra security.
Are Wyze Cam Floodlight security cameras weatherproof?Yes, both the Wyze Cam Floodlight v2 and Pro are rated IP65 weatherproof, making them suitable for outdoor use in rain, snow, or shine.
Do Wyze Cam Floodlight cameras require a subscription for 24/7 recording?No, both models support 24/7 local recording via a microSD card (up to 256GB) with no subscription required.
Are Wyze Cam Floodlight cameras compatible with smart home assistants?Yes, both the Wyze Cam Floodlight v2 and Pro are compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
How bright are the Wyze Cam Floodlight LEDs?The Wyze Cam Floodlight v2 features two adjustable LEDs with a combined brightness of 2800 lumens, while the Wyze Cam Floodlight Pro has three adjustable LEDs with a total brightness of 3000 lumens.
What Wi-Fi networks do Wyze Cam Floodlight cameras support?The Wyze Cam Floodlight v2 supports 2.4 GHz Wi-Fi networks, while the Wyze Cam Floodlight Pro supports both 2.4 GHz and 5 GHz dual-band Wi-Fi for faster and more reliable connections.
How easy is it to install Wyze Cam Floodlight security cameras?Both models are designed for easy DIY installation and can replace existing wired floodlights. The Wyze Cam Floodlight Pro can typically be installed in under 20 minutes.
Why choose a wired floodlight security camera over a battery-powered one?Wired floodlight security cameras like the Wyze Cam Floodlight v2 and Pro offer consistent power without the need for battery changes, ensuring your security system is always active and reliable.
What are the main differences between the Wyze Cam Floodlight v2 and the Wyze Cam Floodlight Pro?Can you explain how the two-way talk feature works on these cameras?Are there any ongoing promotions or discounts for the Wyze Cam Floodlight cameras?
