Refurbished Smart Outdoor Floodlight Cameras with 270° Motion Detection and 160° Wide Angle View
When it comes to securing your home or business outdoors, having a smart floodlight camera that offers wide coverage and customizable motion detection is essential. If you’re searching for a
refurbished smart outdoor floodlight camera featuring
270° customizable motion detection and a
160° wide-angle view, the Wyze lineup offers some of the best options on the market. Below, we explore the top Wyze cameras that meet these criteria, highlighting their specs and features to help you make an informed choice.
Wyze Cam Floodlight v2: The Ultimate Outdoor Security Solution
Alt: Wyze Cam Floodlight v2 lighting a driveway with person detected at night
The
Wyze Cam Floodlight v2 is a standout choice for anyone needing a powerful, smart outdoor floodlight camera with extensive motion detection and a wide field of view.
Key Features:
- 270° PIR Motion Detection: Covers a broad area with customizable zones to reduce false alerts and focus on what matters most.
- 160° Wide-Angle View: Capture double the visibility compared to previous models, ensuring no blind spots.
- 2800 Lumens LED Floodlights: Two adjustable, motion-activated floodlights that turn night into day, deterring intruders effectively.
- 2K Video Resolution with Color Night Vision: Crystal-clear footage day or night, capturing fine details for better security.
- 24/7 Local Recording: Continuous recording to a microSD card (up to 256GB) without subscription fees.
- Two-Way Talk & 105dB Siren: Communicate with visitors or scare off unwanted guests directly through the Wyze app.
- Ambient Light Mode: Provides a low-level light that brightens automatically when motion is detected.
- Dusk-to-Dawn Automation: Automatically turns on and off based on natural light conditions.
- IP65 Weather Resistance: Built to withstand rain, snow, and harsh outdoor conditions.
- Smart Assistant Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
Why Choose Wyze Cam Floodlight v2?
This model is perfect for homeowners who want a
robust, easy-to-install floodlight camera with excellent motion detection coverage and a wide field of view. Its AI-powered light control and smart notifications make it a reliable guardian for your property.
Wyze Cam Floodlight Pro: Enhanced Coverage and AI-Powered Detection
Alt: Woman with dog near Wyze Cam Floodlight Pro outdoor security camera
For those seeking even more advanced features, the
Wyze Cam Floodlight Pro offers a premium upgrade.
Highlights:
- 270° Motion Detection with AI Computer Vision: Detects and distinguishes people, vehicles, and other objects with precision.
- 180° Wide-Angle Lens: Wider than the Floodlight v2, providing end-to-end yard coverage.
- 2.5K QHD Video Quality: Higher resolution for sharper, more detailed footage.
- 3000 Lumens Brightness: Three dimmable LED panels deliver powerful illumination.
- Dual-Band Wi-Fi (2.4 & 5 GHz): Ensures stable connectivity even in crowded networks.
- Built-in 105dB Siren: Loud deterrent to keep intruders away.
- IP65 Weatherproof Rating: Durable for all weather conditions.
- Smart Home Compatibility: Works with Alexa, Google Assistant, and IFTTT.
Ideal For:
Users who want
top-tier video quality and AI-powered motion detection with a wider field of view and brighter lighting. The Floodlight Pro is a smart investment for comprehensive outdoor security.
Additional Wyze Cameras for Outdoor Security
While the Wyze Cam Floodlight v2 and Floodlight Pro are the best matches for your query, here are other Wyze cameras worth considering for outdoor use, though they differ in motion detection range or lighting features:
Wyze Cam Pan v3
- 360° Pan and 180° Tilt: Covers every angle with automatic motion tracking.
- IP65 Weather Resistance: Suitable for outdoor use with the Wyze Outdoor Power Adapter.
- Color Night Vision: Enhanced visibility in low light.
- Motion Detection: Custom zones but not a floodlight camera.
- Price-Friendly: Great for versatile outdoor monitoring without integrated floodlights.
Wyze Cam v4
- 2.5K QHD Resolution: Crisp video with enhanced color night vision.
- 115.8° Diagonal Field of View: Wide but less than Floodlight v2.
- Motion-Activated Spotlight: Provides lighting but less powerful than dedicated floodlights.
- IP65 Weatherproof: Reliable for outdoor use.
- Wi-Fi 6 Support: Future-proof connectivity.
Why Choose Refurbished Wyze Floodlight Cameras?
Opting for a
refurbished Wyze smart outdoor floodlight camera is a smart way to get premium security features at a reduced price. These cameras undergo rigorous testing to ensure they meet quality standards, offering you:
"Reliable performance, smart features, and excellent value for your home security needs."
Summary: Best Refurbished Smart Outdoor Floodlight Cameras
Model | Motion Detection | Field of View | Video Resolution | Floodlight Brightness | Weatherproof | Price Range (New) |
Wyze Cam Floodlight v2 | 270° PIR | 160° | 2K | 2800 Lumens | IP65 | $89.98 |
Wyze Cam Floodlight Pro | 270° AI-Powered | 180° | 2.5K QHD | 3000 Lumens | IP65 | $149.98 |
Conclusion
For a
refurbished smart outdoor floodlight camera with
Wyze Cam Floodlight v2 is the ideal choice, balancing advanced features, excellent video quality, and powerful lighting. If you want enhanced AI detection and wider coverage, consider the
Wyze Cam Floodlight Pro.
Both models offer weather resistance, smart home integration, and easy installation, making them perfect for securing your outdoor spaces day and night.
What are the benefits of choosing a refurbished Wyze smart outdoor floodlight camera?
Refurbished Wyze smart outdoor floodlight cameras offer premium security features at a reduced price. Each camera undergoes rigorous testing to ensure reliable performance and quality, providing excellent value for your home security needs.Which Wyze floodlight camera offers 270° motion detection and a 160° wide-angle view?
The Wyze Cam Floodlight v2 features 270° customizable PIR motion detection and a 160° wide-angle view, making it ideal for comprehensive outdoor security coverage.What are the key features of the Wyze Cam Floodlight v2?
The Wyze Cam Floodlight v2 offers 270° PIR motion detection, a 160° wide-angle view, 2800 lumens LED floodlights, 2K video resolution with color night vision, 24/7 local recording, two-way talk, a 105dB siren, ambient light mode, dusk-to-dawn automation, IP65 weather resistance, and smart assistant integration with Alexa, Google Assistant, and IFTTT.How does the Wyze Cam Floodlight Pro differ from the Floodlight v2?
The Wyze Cam Floodlight Pro provides 270° AI-powered motion detection, a wider 180° field of view, 2.5K QHD video quality, 3000 lumens brightness with three dimmable LED panels, dual-band Wi-Fi (2.4 & 5 GHz), a built-in 105dB siren, IP65 weatherproof rating, and smart home compatibility. It is ideal for users seeking top-tier video quality and advanced AI detection.Are Wyze floodlight cameras weatherproof?
Yes, both the Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro are rated IP65 weatherproof, making them suitable for use in rain, snow, and harsh outdoor conditions.Do Wyze floodlight cameras support smart home integration?
Yes, Wyze floodlight cameras work seamlessly with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.Is continuous local recording available on Wyze floodlight cameras?
Yes, the Wyze Cam Floodlight v2 supports 24/7 local recording to a microSD card (up to 256GB) without requiring a subscription.What is the video resolution of Wyze Cam Floodlight v2 and Floodlight Pro?
The Wyze Cam Floodlight v2 records in 2K video resolution, while the Wyze Cam Floodlight Pro offers higher 2.5K QHD video quality for sharper and more detailed footage.What is the brightness of the Wyze Cam Floodlight v2 and Floodlight Pro?
The Wyze Cam Floodlight v2 features 2800 lumens of LED brightness, while the Wyze Cam Floodlight Pro offers even brighter illumination at 3000 lumens with three dimmable LED panels.Are there other Wyze cameras suitable for outdoor security?
Yes, other Wyze cameras like the Wyze Cam Pan v3 and Wyze Cam v4 are suitable for outdoor use. The Pan v3 offers 360° pan and 180° tilt with motion tracking, while the Cam v4 provides 2.5K QHD resolution and a motion-activated spotlight. However, these models differ in motion detection range and lighting features compared to the floodlight cameras.
