Refurbished 1080p Floodlight Camera Kits with Night Vision for Yards
Refurbished Floodlight Camera Kits with 1080p Night Vision for Your Yard
Enhance your yard’s security and visibility with advanced refurbished floodlight camera kits that combine powerful illumination with crystal-clear video, including 1080p and higher resolution night vision. Whether you want to monitor your driveway, backyard, or front porch, these smart floodlight cameras offer wide-angle views, AI-powered motion detection, and bright LED lighting to keep your property safe day and night. Explore the top Wyze floodlight camera kits designed for easy installation, smart home integration, and reliable performance in all weather conditions.
Wyze Cam Floodlight Pro: Premium 2.5K QHD Floodlight Camera Kit
Experience next-level yard security with the Wyze Cam Floodlight Pro, featuring a stunning 2.5K QHD resolution and a massive 180° ultra-wide field of view. This refurbished floodlight camera kit is perfect for those who want detailed, end-to-end coverage of their outdoor spaces.
Key Features:
  • 2.5K QHD Video & Color Night Vision: Capture crisp, vibrant video day and night with enhanced clarity that outperforms standard 1080p cameras.
  • 180° Ultra-Wide Lens: Covers a broad area with fewer blind spots, ideal for large yards or wide driveways.
  • 3,000 Lumens Adjustable LED Lights: Three independently articulating floodlight panels provide powerful, customizable illumination to deter intruders.
  • AI-Powered Motion Detection: Onboard AI computer vision detects people, vehicles, and packages, triggering lights and notifications only for selected objects.
  • Dual-Band Wi-Fi Support: Connects seamlessly to both 2.4 GHz and 5 GHz networks for faster, more reliable streaming.
  • Motion-Activated Voice Deterrence & 105 dB Siren: Scare off unwanted visitors with a loud siren and customizable voice prompts.
  • Weather Resistant (IP65): Built to withstand harsh outdoor conditions from -22°F to 122°F.
  • Easy DIY Installation: Replace your existing floodlight in under 20 minutes or use the optional plug-in mount for no-junction-box setup.
“Wyze Cam Floodlight Pro acts like a personal home security guard with bright lights and smart detection — no donuts required.”
Wyze Cam Floodlight Pro in action with bright yard lighting Bright and smart yard security with Wyze Cam Floodlight Pro
Wyze Cam Floodlight v2: Reliable 2K Floodlight Camera Kit
For a balance of performance and value, the Wyze Cam Floodlight v2 offers 2K HD video with color night vision and a 160° wide-angle lens, making it a great choice for standard yard security needs.
Highlights:
  • 2K HD Video with Color Night Vision: See clear, detailed footage even in low light conditions.
  • 160° Wide-Angle View: Covers a wide area to reduce blind spots around your home.
  • 2800 Lumens Motion-Activated LED Lights: Bright, adjustable floodlights that activate on motion to illuminate your yard.
  • Ambient Light Mode: Provides constant low-level lighting that brightens when motion is detected, deterring unwanted visitors.
  • 24/7 Local Recording: Supports microSD cards up to 256GB for continuous recording without subscription fees.
  • Two-Way Talk & 105 dB Siren: Communicate with visitors or scare off intruders directly through the camera.
  • IP65 Weatherproof: Durable for all weather conditions.
  • Easy Setup & Smart Assistant Integration: Works with Alexa and Google Assistant for voice control and smart home compatibility.
Wyze Cam Floodlight v2 illuminating a driveway at night Secure your driveway with Wyze Cam Floodlight v2’s bright LEDs and smart detection
Plug-In Mount Kits: Simplify Installation for Floodlight Cameras
If you want to avoid complex wiring or hiring an electrician, consider the Wyze Cam Floodlight Pro + Plug-In Mount or Wyze Cam Floodlight v2 + Plug-In Mount bundles. These kits include a convenient plug-in mount that allows you to power your floodlight camera through a standard outdoor outlet.
Benefits of Plug-In Mount Kits:
  • No Junction Box Needed: Easily install your floodlight camera without rewiring or electrical work.
  • 20-Foot Power Cord: Provides flexible placement options around your yard.
  • Compatible with Both Pro and v2 Models: Choose the camera that fits your security needs and get hassle-free power.
  • DIY Friendly: Perfect for renters or homeowners who want a quick, plug-and-play security solution.
Why Choose Refurbished Floodlight Camera Kits for Your Yard?
Refurbished Wyze floodlight cameras offer the same high-quality features as new models but at a more affordable price point. They undergo rigorous testing to ensure reliability and performance, making them a smart choice for budget-conscious homeowners who don’t want to compromise on security.
Advantages:
  • Cost-Effective Security: Save money while getting advanced video and lighting technology.
  • Eco-Friendly Choice: Reduce electronic waste by choosing refurbished products.
  • Full Feature Set: Enjoy AI motion detection, color night vision, and smart home compatibility.
  • Warranty & Support: Most refurbished kits come with a warranty for peace of mind.
Conclusion
For yard security with 1080p or better night vision, Wyze’s refurbished floodlight camera kits deliver exceptional value and performance. Whether you opt for the premium Wyze Cam Floodlight Pro with its 2.5K QHD resolution and ultra-wide 180° view, or the reliable Wyze Cam Floodlight v2 with 2K video and bright 2800 lumen LEDs, you’ll get smart lighting and clear video to protect your home. Add the plug-in mount option for easy installation without electrical work, and you have a complete, user-friendly security solution for your yard. Secure your home with smart floodlight cameras that see clearly, light brightly, and respond intelligently — day or night.
FeatureWyze Cam Floodlight ProWyze Cam Floodlight v2Wyze Cam Floodlight Pro + Plug-In MountWyze Cam Floodlight v2 + Plug-In Mount
Video Resolution2.5K QHD (2560x1440)2K HD2.5K QHD (2560x1440)2K HD
Field of View180° Ultra-Wide160° Wide-Angle180° Ultra-Wide160° Wide-Angle
LED Brightness (Lumens)3000 lumens2800 lumens3000 lumens2800 lumens
Number of Floodlight Heads3232
Color Night VisionYesYesYesYes
Motion Detection TechnologyAI Computer VisionAI-Powered Light Control + PIRAI Computer VisionAI-Powered Light Control + PIR
Motion-Activated Voice DeterrenceYesYesYesYes
Ambient Light ModeYesYesYesYes
Dusk-to-Dawn AutomationYesYesYesYes
Weather ResistanceIP65IP65IP65IP65
Wi-Fi SupportDual-band 2.4 & 5 GHz2.4 GHzDual-band 2.4 & 5 GHz2.4 GHz
Two-Way TalkNot specifiedYesNot specifiedYes
Siren105 dB105 dB105 dB105 dB
Local RecordingUp to 256 GB microSD (sold separately)Up to 256 GB microSD (sold separately)Up to 256 GB microSD (sold separately)Up to 256 GB microSD (sold separately)
SetupInstant Bluetooth SetupAccess Point Wi-Fi SetupInstant Bluetooth SetupAccess Point Wi-Fi Setup
InstallationDIY, under 20 minutesDIY, no junction box neededDIY, includes Plug-In MountDIY, includes Plug-In Mount
Plug-In Mount IncludedNoNoYesYes
Power Cord Length20 feet (6m)20 feet (6m)20 feet (6m)20 feet (6m)
Price (USD)$149.98$89.98$169.96$109.96
What are refurbished floodlight camera kits and how do they enhance yard security?Refurbished floodlight camera kits are pre-owned security devices that have been professionally restored to like-new condition. They combine powerful LED floodlights with high-definition cameras, offering features like 1080p or higher night vision, wide-angle views, and AI-powered motion detection. These kits enhance yard security by providing clear video footage, bright illumination, and smart alerts to help deter intruders and monitor your property day and night.
What is the difference between Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2?The Wyze Cam Floodlight Pro offers a premium 2.5K QHD resolution with a 180° ultra-wide field of view, 3,000 lumens of adjustable LED lighting, and advanced AI-powered motion detection. The Wyze Cam Floodlight v2 provides 2K HD video, a 160° wide-angle lens, 2,800 lumens of motion-activated lighting, and features like ambient light mode and 24/7 local recording. Both models are weather-resistant and support smart home integration, but the Pro model delivers higher resolution and a wider coverage area.
Do refurbished Wyze floodlight cameras support night vision?Yes, both the Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2 feature color night vision, allowing you to capture clear, detailed footage even in low-light or nighttime conditions. The Pro model offers enhanced clarity with its 2.5K QHD sensor, while the v2 provides sharp 2K HD video at night.
How easy is it to install a Wyze refurbished floodlight camera kit?Wyze refurbished floodlight camera kits are designed for easy DIY installation. You can replace your existing floodlight in under 20 minutes, or choose a plug-in mount kit to avoid electrical work entirely. The plug-in mount includes a 20-foot power cord, allowing you to power the camera from a standard outdoor outlet, making it ideal for renters or those without a junction box.
What are the benefits of choosing a plug-in mount kit for my floodlight camera?Plug-in mount kits simplify installation by eliminating the need for complex wiring or a junction box. They come with a 20-foot power cord for flexible placement and are compatible with both Wyze Cam Floodlight Pro and v2 models. This makes them a convenient, DIY-friendly option for homeowners and renters seeking hassle-free security solutions.
Are refurbished Wyze floodlight cameras reliable and do they come with a warranty?Yes, refurbished Wyze floodlight cameras undergo rigorous testing to ensure they meet high standards of reliability and performance. Most refurbished kits come with a warranty, providing peace of mind and support in case of any issues.
Can I integrate Wyze floodlight cameras with my smart home system?Absolutely. Both Wyze Cam Floodlight Pro and v2 support integration with popular smart home assistants like Alexa and Google Assistant. This allows you to control your cameras and receive alerts using voice commands or through your smart home ecosystem.
What are the advantages of buying a refurbished floodlight camera kit?Refurbished floodlight camera kits offer significant cost savings compared to new models while providing the same advanced features, such as AI motion detection, color night vision, and smart home compatibility. Choosing refurbished is also eco-friendly, as it helps reduce electronic waste.
How do the AI-powered features work on Wyze floodlight cameras?Wyze floodlight cameras use onboard AI computer vision to detect specific objects like people, vehicles, and packages. This smart detection triggers the floodlights and sends notifications only for selected events, reducing false alarms and enhancing security.
Are Wyze floodlight cameras weatherproof?Yes, both the Wyze Cam Floodlight Pro and v2 are rated IP65 weather resistant, meaning they are built to withstand harsh outdoor conditions, including rain, snow, and extreme temperatures ranging from -22°F to 122°F.
What are the key features of the Wyze Cam Floodlight Pro?How does the AI-powered motion detection work in the floodlight cameras?What is the warranty and returns policy for refurbished floodlight camera kits?
