Affordable Wyze Floodlight Mounts Requiring No Electrician Installation
Looking for an affordable, easy-to-install floodlight mount for your Wyze Cam Floodlight that requires no electrician? You’ve come to the right place. Wyze offers innovative plug-in mounts designed to eliminate the hassle and cost of hardwired junction boxes. These mounts provide flexible, plug-and-play solutions that anyone can install quickly and safely, without professional help.
Wyze Cam Floodlight Plug-In Mount: Simple, Safe, and Affordable
Effortless Installation Without Electricians
Say goodbye to complicated wiring and expensive electrician fees. The
Wyze Cam Floodlight Plug-In Mount is designed for easy installation by simply plugging into any outdoor-rated outlet. No junction box or cutting into your home’s exterior is needed.
- 20-foot durable cable for flexible placement
- Includes a velcro strap for neat cable management
- Compatible with all Wyze Cam Floodlight models
- Available in Black and White at just $19.98
“If you can plug in a cable, then you can enjoy the security of a Wyze Floodlight.”
Perfect for Any Outdoor Space
This mount frees you from the limitations of fixed junction boxes, allowing you to position your floodlight exactly where you need it for optimal security and lighting.
Easy plug-in installation for outdoor floodlights
Wyze Cam Floodlight Pro + Plug-In Mount Bundle: Premium Security, No Fuss
Advanced Floodlight with Plug-In Convenience
For those wanting the best in floodlight security with no electrician installation, the
Wyze Cam Floodlight Pro + Plug-In Mount bundle is the ideal choice. This package combines the powerful Wyze Cam Floodlight Pro with the easy plug-in mount.
- 2.5K QHD resolution with ultra-wide 180° field of view
- 3000 lumens of bright, adjustable lighting
- 20-foot power cord for flexible placement
- IP65 weather resistance for all-season durability
- Compatible with Alexa, Google Assistant, and IFTTT
- Available in Black or White for $169.96
“Say goodbye to the complexity and cost of installing a junction box.”
This bundle offers a premium security solution with the convenience of plug-in power, making it perfect for renters or homeowners who want to avoid electrical work.
Bright, smart floodlight with plug-in mount for easy setup
Wyze Cam Floodlight v2: Wired Excellence with Smart Features
Hardwired Floodlight with Advanced Security
If you prefer a hardwired option but still want a smart floodlight with excellent features, the
Wyze Cam Floodlight v2 is a top contender. While it requires wiring, it offers:
- 2K video resolution with color night vision
- 2800 lumens of dimmable LED lighting
- 160° wide-angle field of view
- AI-powered light control and motion warnings
- IP65 weather resistance and dusk-to-dawn automation
- Available in Black or White for $89.98
This model is perfect for those who want a wired floodlight with advanced smart features but don’t mind professional installation.
Smart floodlight with color night vision and wide-angle view
Why Choose a Plug-In Mount for Your Wyze Floodlight?
Installing a floodlight traditionally means dealing with junction boxes, electrical wiring, and costly electrician visits. Wyze’s plug-in mounts eliminate these barriers, making home security accessible, affordable, and DIY-friendly.
- No electrician needed: Just plug into an outdoor outlet.
- Flexible placement: 20-foot cable lets you position your floodlight where it’s most effective.
- Cost-effective: Save money on installation and equipment.
- Compatible with multiple Wyze floodlight models: Upgrade or replace easily.
Summary of Affordable No-Electrician Wyze Floodlight Mount Options
Product | Installation Type | Price | Key Features |
Wyze Cam Floodlight Plug-In Mount | Plug-in | $19.98 | 20ft cable, no junction box needed |
Wyze Cam Floodlight Pro + Plug-In Mount Bundle | Plug-in + Floodlight | $169.96 | 2.5K QHD, 3000 lumens, 180° view |
Wyze Cam Floodlight v2 | Hardwired | $89.98 | 2K video, color night vision, AI |
Enhance your home security today with Wyze’s affordable, easy-to-install floodlight mounts that require no electrician. Whether you want a simple plug-in mount or a premium floodlight bundle, Wyze has you covered with smart, reliable, and budget-friendly options.
# Product Tags and Highlights
What is the Wyze Cam Floodlight Plug-In Mount and how does it work?
The Wyze Cam Floodlight Plug-In Mount is an affordable, easy-to-install mounting solution for Wyze Cam Floodlights. It allows you to install your floodlight by simply plugging it into any outdoor-rated outlet, eliminating the need for hardwired junction boxes or professional electrician installation. The mount comes with a 20-foot durable cable and a velcro strap for cable management, making it flexible and convenient for any outdoor space.Do I need an electrician to install Wyze floodlight mounts?
No, you do not need an electrician to install Wyze floodlight plug-in mounts. These mounts are designed for DIY installation and can be set up by plugging them into an outdoor-rated outlet, saving you time and money on professional installation.Are Wyze floodlight plug-in mounts compatible with all Wyze Cam Floodlight models?
Yes, the Wyze Cam Floodlight Plug-In Mount is compatible with all Wyze Cam Floodlight models, making it easy to upgrade or replace your existing setup without worrying about compatibility.What are the benefits of using a plug-in mount for Wyze floodlights?
Plug-in mounts for Wyze floodlights offer several benefits: no electrician or hardwiring required, flexible placement with a 20-foot cable, cost-effective installation, and compatibility with multiple Wyze floodlight models. This makes home security more accessible and affordable for everyone.What is included in the Wyze Cam Floodlight Pro + Plug-In Mount Bundle?
The Wyze Cam Floodlight Pro + Plug-In Mount Bundle includes the advanced Wyze Cam Floodlight Pro and a plug-in mount for easy installation. The floodlight features 2.5K QHD resolution, a 180° ultra-wide field of view, 3000 lumens of adjustable lighting, a 20-foot power cord, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT.How much does the Wyze Cam Floodlight Plug-In Mount cost?
The Wyze Cam Floodlight Plug-In Mount is available for just $19.98, making it an affordable solution for upgrading your home security without the need for professional installation.Is the Wyze Cam Floodlight v2 a plug-in or hardwired model?
The Wyze Cam Floodlight v2 is a hardwired model that requires electrical wiring for installation. It offers advanced features such as 2K video resolution, color night vision, 2800 lumens of dimmable LED lighting, AI-powered light control, and compatibility with Alexa, Google Assistant, and IFTTT.Can renters use Wyze floodlight plug-in mounts?
Yes, Wyze floodlight plug-in mounts are perfect for renters because they do not require any permanent installation or electrical work. You can easily install and remove the floodlight by plugging it into an outdoor-rated outlet, making it a flexible and renter-friendly security solution.What colors are available for Wyze floodlight mounts and bundles?
Wyze floodlight mounts and bundles are available in both Black and White, allowing you to choose the color that best matches your home’s exterior.Are Wyze floodlights weather resistant?
Yes, Wyze floodlights and their mounts are IP65 weather resistant, ensuring reliable performance and durability in all seasons and weather conditions.
