Budget Refurbished Floodlight Cameras for Full Property Coverage
Budget Friendly Refurbished Floodlight Cameras for Full Property Coverage
When it comes to securing your entire property without breaking the bank, choosing the right floodlight camera is essential. Refurbished and budget-friendly options can offer powerful features, wide coverage, and smart technology to keep your home safe day and night. Below, we explore the best Wyze floodlight cameras that combine affordability, advanced specs, and easy installation for full property protection.
Wyze Cam Floodlight Pro: Premium Coverage with Smart AI
Wyze Cam Floodlight Pro stands out as a top-tier floodlight camera that offers an impressive 180° ultra-wide field of view, ensuring you can monitor your yard end-to-end with minimal blind spots. This model is perfect for those who want high-resolution video and intelligent lighting without a hefty price tag.
Key Features:
  • 2.5K QHD Video Resolution: Capture crystal-clear footage with Quad High Definition clarity, day or night, enhanced by color night vision.
  • 180° Wide-Angle Lens: Covers a broad area, reducing the number of cameras needed for full property surveillance.
  • AI-Powered Motion Detection: Onboard AI computer vision detects people, vehicles, and other objects you select, triggering the 3,000 lumen LED lights only when necessary.
  • Adjustable and Dimmable LEDs: Three independently articulating floodlight panels allow you to customize light coverage to your exact needs.
  • Dual-Band Wi-Fi Support: Connects seamlessly to both 2.4 GHz and 5 GHz networks for faster, more reliable streaming.
  • Ambient Light Mode: Provides constant low-level lighting that brightens automatically when motion is detected.
  • Motion-Activated Voice Deterrence & 105 dB Siren: Scare off unwanted visitors with voice prompts and a loud siren.
  • Weather Resistant (IP65): Built to withstand harsh outdoor conditions.
  • Easy DIY Installation: Replace your existing floodlight in under 20 minutes, with an optional plug-in mount for renters or those without junction boxes.
This floodlight camera is an excellent choice for homeowners seeking a smart, powerful security solution with full property coverage. Wyze Cam Floodlight Pro in action with bright lighting Wyze Cam Floodlight Pro providing bright, smart security lighting
Wyze Cam Floodlight v2: Affordable 2K Video with Wide Coverage
For those on a tighter budget, the Wyze Cam Floodlight v2 offers a compelling balance of features and price. It delivers 2K HD video and a 160° wide-angle view, making it ideal for covering large outdoor areas with clear visuals.
Highlights:
  • 2K HD Video with Color Night Vision: See more details in vibrant color, even in low light.
  • 160° Wide-Angle Lens: Provides broad coverage to reduce blind spots.
  • 2800 Lumens LED Lights: Bright, adjustable, and motion-activated to illuminate your property effectively.
  • Ambient Light Mode: Keeps a low-level light on, increasing brightness when motion is detected.
  • 24/7 Local Recording: Supports continuous recording to a microSD card (up to 256GB) without subscription fees.
  • Two-Way Talk & 105 dB Siren: Communicate with visitors or deter intruders remotely.
  • 270° PIR Motion Detection: Covers a wide detection area for faster alerts.
  • Dusk-to-Dawn Automation & IP65 Weatherproofing: Automatically adjusts lighting based on daylight and withstands all weather conditions.
  • Smart Assistant Integration: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Easy Installation: Includes a plug-in mount option for simple setup without electrical work.
This model is perfect for budget-conscious users who want reliable, smart floodlight security with full property coverage. Wyze Cam Floodlight v2 illuminating a driveway at night Wyze Cam Floodlight v2 lighting up a driveway with smart detection
Refurbished Wyze Cam v2: Classic Security Camera on a Budget
If you are looking for a very budget-friendly refurbished option to complement your floodlight cameras or cover smaller areas, the Wyze Cam v2 is a solid choice. While it is not a floodlight camera, it offers dependable 1080p Full HD video and night vision at an unbeatable price.
Features:
  • 1080p Full HD Video: Clear live streaming and recording.
  • Night Vision: Infrared LEDs provide visibility up to 30 feet in the dark.
  • Motion Tagging & Custom Zones: Receive alerts only for important motion events.
  • Two-Way Audio: Built-in microphone and speaker for communication.
  • Works with Alexa and Google Assistant: Integrate into your smart home ecosystem.
  • Continuous Recording & Time Lapse: Supports microSD card storage for ongoing surveillance.
This refurbished camera is ideal for adding extra coverage to blind spots or indoor/outdoor areas where floodlight illumination is not necessary.
Convenient Plug-In Mount Bundles for Easy Installation
For those who want the power and features of the Wyze Cam Floodlight Pro or Floodlight v2 but prefer a hassle-free installation without electrical wiring, Wyze offers plug-in mount bundles.
Benefits:
  • No Junction Box Needed: Simply plug into an outdoor outlet.
  • Includes Floodlight Camera + Plug-In Mount: Ready to install out of the box.
  • Flexible Power Solution: Perfect for renters or homes without existing floodlight wiring.
  • Same Features as Wired Versions: Enjoy all the smart detection, lighting, and video capabilities.
These bundles provide a budget-friendly, DIY-friendly way to secure your property with minimal effort.
Why Choose Wyze Floodlight Cameras for Full Property Coverage?
"Wyze floodlight cameras combine affordability, advanced AI detection, and wide-angle coverage to keep your entire property safe and well-lit. Whether you choose the premium Floodlight Pro or the budget-friendly Floodlight v2, you get smart lighting, crisp video, and easy installation that fits your needs."
  • Wide Field of View: From 160° to 180°, cover large areas with fewer cameras.
  • High-Resolution Video: Up to 2.5K QHD for detailed monitoring.
  • Smart AI Detection: Motion-triggered lights and alerts for people, vehicles, and packages.
  • Weatherproof & Durable: IP65 rating ensures reliable outdoor performance.
  • Flexible Installation: Wired or plug-in options for any home setup.
  • Budget Friendly: Options starting under $100, with refurbished models even more affordable.
Secure your home smartly and affordably with Wyze floodlight cameras designed for full property coverage. Choose the model that fits your budget and enjoy peace of mind with bright, intelligent security lighting and crystal-clear video.
Product Summary
Product NameResolutionField of ViewLighting (Lumens)Price RangeInstallation
Wyze Cam Floodlight Pro2.5K QHD180°3000$149.98Wired or Plug-In Mount
Wyze Cam Floodlight v22K HD160°2800$89.98Wired or Plug-In Mount
Refurbished Wyze Cam v21080p Full HD110°N/A$19.99Wired (Indoor/Outdoor)
FeatureWyze Cam Floodlight ProWyze Cam Floodlight v2 (Refurbished)Wyze Cam v2 (Refurbished)Wyze Cam Floodlight Pro + Plug-In MountWyze Cam Floodlight v2 + Plug-In Mount
Price (USD)149.98109.96 (bundle price)19.99169.96109.96
Video Resolution2.5K QHD (2560x1440)2K HD (2304x1296)1080p (1920x1080)2.5K QHD (2560x1440)2K HD (2304x1296)
Field of View180°160°110°180°160°
Night VisionColor Night VisionVibrant Color Night VisionNight Vision (up to 30 ft)Color Night VisionVibrant Color Night Vision
LED Brightness (Lumens)3000 lumens2800 lumensN/A3000 lumens2800 lumens
Light Panels3 adjustable panels2 dimmable LED panelsN/A3 adjustable panels2 dimmable LED panels
Motion DetectionAI computer vision, person & vehicle focusAdvanced motion detectionCustom zone detection & sensitivityAI computer vision, person & vehicle focusAdvanced motion detection
Audio2-way audio, 105 dB siren2-way audio, 105 dB siren2-way audio2-way audio, 105 dB siren2-way audio, 105 dB siren
Power SupplyHardwired or Plug-In MountHardwired or Plug-In MountUSB poweredPlug-In Mount includedPlug-In Mount included
Wi-Fi SupportDual-band 2.4 & 5 GHz2.4 GHz2.4 GHzDual-band 2.4 & 5 GHz2.4 GHz
Weather ResistanceIP65IP65N/AIP65IP65
Local StoragemicroSD up to 256GBmicroSD up to 256GB14-day cloud storagemicroSD up to 256GBmicroSD up to 256GB
InstallationDIY, under 20 minutesDIY, easy with plug-in mountEasy, multiple mounting optionsDIY, plug-n-play with mountDIY, plug-n-play with mount
Cable Length (Plug-In Mount)N/A20 ftN/A20 ft20 ft
Additional FeaturesAmbient Light Mode, Motion-Activated Voice Deterrence, Dusk to Dawn AutomationAmbient Light Mode, Dusk to Dawn AutomationMotion Tagging, Works with Alexa & Google AssistantBundle includes Plug-In Mount for easy installationBundle includes Plug-In Mount for easy installation
What are the best budget-friendly floodlight cameras for full property coverage?The best budget-friendly floodlight cameras for full property coverage are the Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2. Both offer wide-angle views, high-resolution video, smart AI detection, and easy installation options. Refurbished Wyze Cam v2 cameras are also available for those seeking the most affordable security solution.
What features does the Wyze Cam Floodlight Pro offer?The Wyze Cam Floodlight Pro features a 2.5K QHD video resolution, 180° ultra-wide field of view, AI-powered motion detection, adjustable and dimmable 3,000 lumen LED lights, dual-band Wi-Fi support, ambient light mode, motion-activated voice deterrence, a 105 dB siren, IP65 weather resistance, and easy DIY installation with wired or plug-in mount options.
How does the Wyze Cam Floodlight v2 compare to the Pro model?The Wyze Cam Floodlight v2 offers 2K HD video, a 160° wide-angle lens, 2,800 lumen LED lights, ambient light mode, 24/7 local recording, two-way talk, a 105 dB siren, 270° PIR motion detection, dusk-to-dawn automation, IP65 weatherproofing, smart assistant integration, and easy installation with a plug-in mount option. It is a more affordable alternative to the Pro model, with slightly reduced specs but excellent value.
Are there refurbished Wyze cameras available for budget security?Yes, refurbished Wyze Cam v2 cameras are available for those seeking a very budget-friendly security solution. While not a floodlight camera, the Wyze Cam v2 offers 1080p Full HD video, night vision, motion tagging, custom zones, two-way audio, smart assistant compatibility, and continuous recording, making it ideal for supplementing floodlight cameras or covering smaller areas.
Can I install Wyze floodlight cameras without electrical wiring?Yes, Wyze offers convenient plug-in mount bundles for both the Floodlight Pro and Floodlight v2 models. These bundles allow you to install the cameras by simply plugging them into an outdoor outlet, making them perfect for renters or homes without existing floodlight wiring. All features of the wired versions are included.
What is the field of view and video resolution of Wyze floodlight cameras?The Wyze Cam Floodlight Pro provides a 180° field of view with 2.5K QHD video resolution, while the Wyze Cam Floodlight v2 offers a 160° field of view with 2K HD video. The refurbished Wyze Cam v2 has a 110° field of view and 1080p Full HD resolution.
Are Wyze floodlight cameras weatherproof?Yes, both the Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2 are IP65 weather resistant, making them suitable for reliable outdoor use in various weather conditions.
Do Wyze floodlight cameras support smart home integration?Yes, Wyze floodlight cameras work with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
Is continuous local recording available on Wyze floodlight cameras?Yes, the Wyze Cam Floodlight v2 supports 24/7 local recording to a microSD card (up to 256GB) without subscription fees. The refurbished Wyze Cam v2 also supports continuous recording and time lapse features.
What is the price range for Wyze floodlight cameras?The Wyze Cam Floodlight Pro is priced at $149.98, the Wyze Cam Floodlight v2 at $89.98, and the refurbished Wyze Cam v2 at $19.99, making them affordable options for full property security coverage.
What are the key features of the Wyze Cam Floodlight Pro?How does the AI-powered motion detection work in the Wyze floodlight cameras?Are there any ongoing sales or discounts for Wyze floodlight cameras?
