Easy Smart Home Upgrade: Refurbished Wyze Smart Lock Deals
Easy Smart Home Upgrade with Refurbished Wyze Smart Lock
Upgrade your home security effortlessly with the Wyze Lock Bolt, a refurbished smart lock designed to bring convenience, safety, and modern technology right to your front door. Whether you’re tired of fumbling with keys or want to add a seamless smart home feature, the Wyze Lock Bolt offers an easy installation and intuitive control through your smartphone.
Wyze Lock Bolt: The Heart of Your Smart Home Security
The Wyze Lock Bolt is a Bluetooth-enabled smart lock that replaces your existing deadbolt with a sleek, modern design and advanced features. It’s perfect for anyone looking to enhance home security without complicated setups.
Key Features and Benefits
  • Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a quick fingerprint scan, eliminating the need for keys or codes.
  • Backlit Keypad with Anti-Peep: Enter your code securely even in the dark, with a keypad designed to prevent prying eyes.
  • Auto-Lock Function: Never worry about forgetting to lock your door again; the lock automatically secures itself after a set time.
  • Lock and Unlock History: Monitor who enters and leaves your home via the Wyze app, providing peace of mind and control.
  • Built-in Jam Detection Alarm: Alerts you if the lock mechanism is jammed or tampered with.
  • Emergency One-Time Codes: Share temporary access with guests or service providers safely.
  • Weather Resistant (IPX5): Durable enough to withstand outdoor conditions, from rain to dust.
  • Long Battery Life: Powered by 4 AA batteries included, lasting 10-12 months on a single set.
Specifications
  • Communication: Bluetooth 5.0 with a 16 ft range.
  • Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick with backset options of 2-3/8” or 2-3/4”.
  • Operating Temperature: Keypad works from -13°F to 122°F, suitable for most climates.
  • Colors Available: Matte Black and Satin Nickel to match your home’s style.
“Unlock your door in less than a second with the touch of a finger or a tap in the app.”
Wyze Lock Bolt Lifestyle Experience seamless smart home security with Wyze Lock Bolt at your front door.
Essential Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning perfectly or to replace worn components, Wyze offers a range of replacement parts designed specifically for this smart lock.
Wyze Lock Replacement Part Kit
  • Compatible only with Wyze Lock.
  • Includes essential parts to maintain or repair your lock.
  • Hassle-free 30-day return policy.
  • Affordable price at $19.99.
Wyze Lock Bolt Screws
  • Set of screws designed for secure installation.
  • Perfect for replacements or upgrades.
  • Priced at just $2.99.
Wyze Lock Bolt Interior Assembly Battery Cover
  • Replacement battery cover to protect your lock’s power source.
  • Ensures longevity and proper battery fit.
  • Available for $9.99.
Wyze Lock Bolt Interior Assembly Metal Plate
  • Metal plate anchors the interior assembly firmly to your door.
  • Adds stability and durability.
  • Available in quantities from 1 to 10, priced at $4.99 each.
These parts ensure your smart lock remains reliable and easy to maintain, extending the life of your smart home upgrade.
Enhance Your Security with The Front Porch Security Bundle
For a comprehensive smart home security solution, consider the Front Porch Security Bundle which pairs the Wyze Lock Bolt with Wyze’s smart video doorbells and chimes.
Bundle Highlights
  • Wyze Video Doorbell: View your front porch in crisp 1080p HD with two-way audio to greet visitors remotely.
  • Remote Lock/Unlock: Control your door lock from anywhere using the Wyze app.
  • Motion Detection & Lock History: Stay informed with real-time alerts and detailed logs.
  • Smart Assistant Compatibility: Works seamlessly with Alexa and Google Assistant for voice control.
This bundle offers an all-in-one security upgrade that’s easy to install and manage, perfect for busy homeowners who want peace of mind. Wyze Lock Bolt with Video Doorbell Secure your home with Wyze Lock Bolt and smart video doorbell integration.
Why Choose a Refurbished Wyze Smart Lock?
Opting for a refurbished Wyze Lock Bolt is a smart, eco-friendly choice that offers:
  • Cost Savings: Get premium smart lock features at a reduced price.
  • Certified Quality: Each refurbished unit is tested to meet Wyze’s high standards.
  • Sustainability: Reduce electronic waste by giving a smart lock a second life.
  • Full Functionality: Enjoy all the features of a new lock with warranty support.
Upgrade your home security easily and affordably with a refurbished Wyze Lock Bolt, backed by Wyze’s trusted technology.
Conclusion
The Wyze Lock Bolt and its accessories provide a simple, effective way to upgrade your home security with smart technology. Whether you want the convenience of keyless entry, the safety of auto-locking, or the peace of mind from remote monitoring, Wyze has you covered. Enhance your smart home today with the Wyze Lock Bolt and optional security bundles for a safer, smarter front door.
Product Summary
Wyze Lock Bolt Wyze Lock Replacement Part Kit Wyze Lock Bolt Screws Wyze Lock Bolt Interior Assembly Battery Cover Wyze Lock Bolt Interior Assembly Metal Plate The Front Porch Security Bundle
Feature / ProductWyze Lock BoltWyze Lock Replacement Part KitWyze Lock Bolt ScrewsWyze Lock Bolt Interior Assembly Battery CoverWyze Lock Bolt Interior Assembly Metal PlateThe Front Porch Security Bundle
TypeConnected Home Smart LockReplacement PartsReplacement PartsReplacement PartsReplacement PartsSecurity Bundle
Price$79.98$19.99 (Replacement Part Kit)$2.99$9.99$4.99$123.99 - $173.97 (varies by variant)
Key FeaturesBluetooth smart lock, fingerprint reader, backlit keypad, auto-lock, anti-peep tech, local Bluetooth app control, hardware encryption, 50 fingerprints max, 20 access codes maxReplacement parts kit for Wyze LockSet of screws for Wyze Lock BoltInterior battery cover replacement for Wyze Lock BoltMetal plate to anchor interior assembly to doorWyze Lock + Wyze Video Doorbell and Chime, remote lock/unlock, lock history, 1080p HD video, two-way audio, Alexa/Google support
CompatibilityReplaces existing deadboltWyze LockWyze Lock BoltWyze Lock BoltWyze Lock BoltIncludes Wyze Lock and Video Doorbell products
Installation Time~20 minutesN/AN/AN/AN/AN/A
Battery LifeUp to 12 months (4 AA batteries)N/AN/AN/AN/AWyze Lock uses 4 AA batteries included
Weather ResistanceIPX5N/AN/AN/AN/AVideo Doorbell IP65 rated
Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns30-day hassle-free returnsNot specified
Security FeaturesHardware encryption, two-factor authentication, local Bluetooth only, emergency one-time codesN/AN/AN/AN/AWorks with Alexa and Google Assistant
Included ComponentsSmart lock with fingerprint sensor and keypadReplacement parts (screws, cables, etc.)Set of screwsInterior battery coverMetal plate for interior assemblyWyze Lock, Wyze Video Doorbell, Chime
Additional FeaturesAuto-lock timer, anti-peep keypad, USB-C emergency charge portN/AN/AN/AN/A1080p HD video, two-way audio, remote lock/unlock
What is the Wyze Lock Bolt and how does it enhance home security?The Wyze Lock Bolt is a Bluetooth-enabled smart lock that replaces your existing deadbolt, offering advanced security features such as ultra-fast fingerprint unlocking, a backlit anti-peep keypad, auto-lock function, lock and unlock history, jam detection alarm, and emergency one-time codes. It provides a modern, convenient, and secure way to control access to your home.
How easy is it to install the Wyze Lock Bolt smart lock?The Wyze Lock Bolt is designed for easy installation, fitting standard doors 1-3/8” to 1-3/4” thick with backset options of 2-3/8” or 2-3/4”. It replaces your existing deadbolt and comes with all necessary hardware, making it a straightforward upgrade for most homeowners.
What are the key features of the Wyze Lock Bolt?Key features of the Wyze Lock Bolt include an ultra-fast fingerprint sensor, backlit anti-peep keypad, auto-lock function, lock and unlock history via the Wyze app, built-in jam detection alarm, emergency one-time codes, weather resistance (IPX5), and long battery life powered by 4 AA batteries.
Is the Wyze Lock Bolt weather resistant?Yes, the Wyze Lock Bolt is weather resistant with an IPX5 rating, making it durable enough to withstand outdoor conditions such as rain and dust.
How long does the Wyze Lock Bolt battery last?The Wyze Lock Bolt is powered by 4 AA batteries, which are included and typically last 10-12 months on a single set, depending on usage.
Can I monitor who enters and leaves my home with the Wyze Lock Bolt?Yes, the Wyze Lock Bolt provides lock and unlock history through the Wyze app, allowing you to monitor who enters and leaves your home for added peace of mind.
What replacement parts are available for the Wyze Lock Bolt?Wyze offers several replacement parts for the Lock Bolt, including the Wyze Lock Replacement Part Kit, Wyze Lock Bolt Screws, Wyze Lock Bolt Interior Assembly Battery Cover, and Wyze Lock Bolt Interior Assembly Metal Plate. These parts help maintain and extend the life of your smart lock.
What is included in the Wyze Lock Replacement Part Kit?The Wyze Lock Replacement Part Kit includes essential components to maintain or repair your Wyze Lock. It is compatible only with Wyze Lock and comes with a hassle-free 30-day return policy.
What is the Front Porch Security Bundle and what does it include?The Front Porch Security Bundle pairs the Wyze Lock Bolt with Wyze’s smart video doorbells and chimes. It offers features like 1080p HD video, two-way audio, remote lock/unlock via the Wyze app, motion detection, lock history, and compatibility with Alexa and Google Assistant for voice control.
Is the Wyze Lock Bolt compatible with smart home assistants?Yes, when purchased as part of the Front Porch Security Bundle, the Wyze Lock Bolt works seamlessly with Alexa and Google Assistant, allowing for convenient voice control.
Why should I choose a refurbished Wyze Lock Bolt?A refurbished Wyze Lock Bolt offers cost savings, certified quality, sustainability by reducing electronic waste, and full functionality with warranty support. It’s a smart, eco-friendly way to upgrade your home security.
What colors are available for the Wyze Lock Bolt?The Wyze Lock Bolt is available in Matte Black and Satin Nickel, allowing you to choose a finish that matches your home’s style.
What is the communication range of the Wyze Lock Bolt?The Wyze Lock Bolt uses Bluetooth 5.0 with a communication range of up to 16 feet, enabling you to control the lock conveniently from your smartphone within range.
What is the operating temperature range for the Wyze Lock Bolt keypad?The Wyze Lock Bolt keypad operates in temperatures ranging from -13°F to 122°F, making it suitable for most climates.
What are the key features of the Wyze Lock Bolt?How does the auto-lock function work on the Wyze Lock Bolt?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Lock Bolt?
