Wyze Battery Cam Pro: Smart Home Monitoring with Auto Updates
Ultimate Home Monitoring Solution Featuring Wyze Battery Cam Pro
When it comes to securing your home with a smart, reliable, and easy-to-manage system, the Wyze Battery Cam Pro stands out as a top choice. This home monitoring solution offers automatic firmware updates, ensuring your camera stays up-to-date with the latest features and security enhancements without any hassle. Whether you want to monitor your front porch, backyard, or any remote location, Wyze Battery Cam Pro delivers pro-grade protection with wireless freedom.
Wyze Battery Cam Pro: Wireless, Powerful, and Smart
Stunning 2.5K HDR Video Quality
Experience crystal-clear video with 2.5K HDR resolution that captures every detail in vibrant color, day or night. The camera’s high dynamic range balances bright and dark areas, so you never miss a moment.
Wire-Free Convenience
No need for power outlets or complicated wiring. The Wyze Battery Cam Pro operates wire-free with removable, rechargeable battery packs, giving you the flexibility to place it anywhere around your home.
Advanced Motion Detection
Equipped with both Radar and PIR sensors, this camera offers superior motion detection accuracy. Customize detection zones in the Wyze app to receive precise alerts for people, packages, or vehicles.
Integrated Spotlight & Siren
The built-in 150-lumen spotlight and siren deter intruders effectively. You can manually control the spotlight via the app for added security during nighttime walks or outdoor activities.
Weatherproof Durability
Rated IP65, the Wyze Battery Cam Pro withstands rain, dust, and extreme temperatures, making it perfect for outdoor use in any season.
Dual-Band Wi-Fi & Easy Setup
Supports both 2.4 GHz and 5 GHz Wi-Fi networks for faster, more reliable connections. Setup is a breeze with instant BluetoothⓇ pairing—no QR codes needed.
Local and Cloud Storage Options
Record locally to a microSD card (sold separately) for continuous event capture without subscription fees. For enhanced smart detections and unlimited cloud storage, Cam Plus subscription is available.
Outdoor home security camera mounted on porch Wyze Battery Cam Pro providing wireless home security
Wyze Battery Cam Pro + Solar Panel: Continuous Power, Zero Worries
Solar-Powered Security for Extended Monitoring
Pair your Wyze Battery Cam Pro with the Wyze Solar Panel to keep your camera powered continuously by converting sunlight into energy. This bundle eliminates the need for frequent battery charging, perfect for remote or hard-to-reach locations.
All the Features of Wyze Battery Cam Pro
Enjoy the same 2.5K HDR video, integrated spotlight, radar + PIR motion detection, and IP65 weatherproof design with the added benefit of solar power.
Hassle-Free Installation
No electrician or power outlet needed. Simply mount the camera and solar panel where they can catch sunlight, and enjoy uninterrupted security coverage.
Accessories to Enhance Your Wyze Battery Cam Pro Experience
Wyze Removable Battery Pack
Extend your camera’s uptime with an extra 6200mAh rechargeable battery pack. Hot-swap batteries easily to avoid downtime and keep your home protected 24/7.
Wyze Battery Charging Dock
Charge two battery packs simultaneously with this compact charging dock, ensuring you always have a fully charged battery ready to go.
Wyze Universal Mount (Long)
For flexible mounting options, especially on ceilings or under eaves, the longer stem mount provides versatile placement to cover wider areas.
Evening outdoor security with Wyze Cam Floodlight Pro Enhance your home security with integrated lighting and cameras
Why Choose Wyze Battery Cam Pro for Your Home Monitoring?
"Wyze Battery Cam Pro combines wireless convenience, high-resolution video, and smart detection technology in a weatherproof design, making it the ultimate home security camera for any environment."
  • Automatic Firmware Updates: Stay protected with the latest security patches and feature improvements delivered automatically.
  • Flexible Power Options: Use rechargeable batteries or solar power for continuous operation.
  • Smart Alerts: Receive timely notifications with person, package, and vehicle detection.
  • Easy Setup & Integration: Compatible with the Wyze app for seamless control and monitoring from anywhere.
Summary of Key Specs
FeatureWyze Battery Cam Pro & Solar Bundle
Video Resolution2.5K HDR
PowerRechargeable Battery Packs + Optional Solar Panel
Motion DetectionRadar + PIR Sensors
Spotlight & SirenIntegrated, 150 lumens
Weatherproof RatingIP65
Wi-Fi SupportDual-band 2.4 & 5 GHz
Local StorageMicroSD card support (up to 256GB)
SetupBluetoothⓇ Instant Setup
Protect your home effortlessly with the Wyze Battery Cam Pro and its solar-powered bundle. Enjoy peace of mind with smart, automatic updates and flexible power options that keep your security system running smoothly—rain or shine.
Feature / ProductWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Removable Battery PackWyze Battery Charging Dock
TypeCameraCamera BundleAccessoryAccessory
Price$89.98 (1 Pack)$109.98$22.99$17.99
Video Resolution2.5K HDR2.5K HDRN/AN/A
Power SourceRemovable, Rechargeable Battery PacksBattery + Solar PanelRechargeable Battery Pack (6200mAh)Charges up to two battery packs simultaneously
Battery CapacityIncluded with cameraIncluded with camera6200mAh Lithium IonN/A
Battery Charging TimeN/AN/AApprox. 9 hours at 25°CApprox. 8.5 hours at 25°C
Weatherproof RatingIP65IP65N/AN/A
WiFi Support2.4 & 5 GHz2.4 & 5 GHzN/AN/A
Motion DetectionRadar + PIRRadar + PIRN/AN/A
Integrated Spotlight & SirenYesYesN/AN/A
Local Recording SupportYes (with microSD card)Yes (with microSD card)N/AN/A
Mounting OptionsFlexible, includes universal mount optionFlexible, includes universal mount optionN/AN/A
Solar Panel IncludedNoYesN/AN/A
USB-C Charging PortN/AN/AYesYes
Charging CapabilityN/AN/ASingle battery packDual battery packs simultaneously
Dimensions2.5" x 1.8" x 3.5" (camera)Same as Battery Cam Pro2.9" x 1.6" x 0.9" (battery pack)2.6" x 2" x 1" (dock)
Weight0.94 lb (camera)Same as Battery Cam Pro3.9 oz (110g)2.75 oz (78g)
Additional FeaturesBluetoothⓇ Setup, Two-Way Audio, Dual-band WiFiContinuous power via solar panelLong battery life (up to 6 months per charge)USB-A to USB-C power cable included
What is the Wyze Battery Cam Pro?The Wyze Battery Cam Pro is a wireless home security camera that offers 2.5K HDR video quality, advanced motion detection, integrated spotlight and siren, and weatherproof durability. It is designed for easy installation and flexible placement around your home.
How does the Wyze Battery Cam Pro provide wireless convenience?The Wyze Battery Cam Pro operates on removable, rechargeable battery packs, allowing you to install it anywhere without the need for power outlets or complicated wiring. You can also pair it with a Wyze Solar Panel for continuous, solar-powered operation.
What video quality does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro features stunning 2.5K HDR video resolution, delivering crystal-clear footage with vibrant color and balanced exposure, both day and night.
How does motion detection work on the Wyze Battery Cam Pro?The camera uses both Radar and PIR (Passive Infrared) sensors for superior motion detection accuracy. You can customize detection zones in the Wyze app to receive alerts for people, packages, or vehicles.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro is rated IP65, making it resistant to rain, dust, and extreme temperatures. It is suitable for outdoor use in any season.
What are the power options for the Wyze Battery Cam Pro?The camera can be powered by rechargeable battery packs or continuously by connecting it to the Wyze Solar Panel. This flexibility ensures your camera stays powered even in remote or hard-to-reach locations.
Does the Wyze Battery Cam Pro support local and cloud storage?Yes, you can record footage locally to a microSD card (up to 256GB, sold separately) for continuous event capture without subscription fees. For enhanced smart detections and unlimited cloud storage, you can subscribe to Cam Plus.
How easy is it to set up the Wyze Battery Cam Pro?Setup is quick and easy with instant BluetoothⓇ pairing—no QR codes required. The camera supports both 2.4 GHz and 5 GHz Wi-Fi networks for reliable connections.
What accessories are available for the Wyze Battery Cam Pro?Accessories include the Wyze Removable Battery Pack for extended uptime, the Wyze Battery Charging Dock for charging two batteries simultaneously, and the Wyze Universal Mount (Long) for flexible placement options.
What security features does the Wyze Battery Cam Pro offer?The camera includes an integrated 150-lumen spotlight and a siren to deter intruders. You can control these features manually via the Wyze app for added security.
Does the Wyze Battery Cam Pro receive automatic firmware updates?Yes, the Wyze Battery Cam Pro receives automatic firmware updates, ensuring your camera always has the latest features and security enhancements.
What are the benefits of pairing the Wyze Battery Cam Pro with the Wyze Solar Panel?Pairing the camera with the Wyze Solar Panel provides continuous, solar-powered operation, eliminating the need for frequent battery charging and making it ideal for remote or hard-to-reach locations.
What smart alert features does the Wyze Battery Cam Pro provide?The camera offers smart alerts for person, package, and vehicle detection, keeping you informed of important activity around your home.
What are the key features of the Wyze Battery Cam Pro?How does the Wyze Battery Cam Pro handle motion detection?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
