Wyze Home Monitoring System: Free Hub Subscription Discount
Wyze Home Monitoring System with Free Hub Subscription Discount
Protecting your home has never been easier or more affordable. The Wyze Home Monitoring System offers a comprehensive, easy-to-install security solution that keeps your property safe 24/7. With a free hub subscription discount included, you get professional monitoring without the hassle or high costs. Explore the key components of this smart home security ecosystem designed to safeguard your home and loved ones.
Core Starter Kit: Your First Line of Defense
The Wyze Home Monitoring Core Starter Kit is the foundation of your home security setup. This all-in-one bundle includes essential sensors and a free 3-month subscription to professional monitoring, giving you peace of mind right from the start.
  • 24/7 Professional Monitoring Included: Enjoy three months of free professional monitoring with emergency dispatch services.
  • Entry Sensor: Easily installed on doors or windows, it instantly notifies you via phone and the Sense Hub when an entry point is opened.
  • Motion Sensor: Detects movement inside your home without needing to access camera footage, preserving privacy while alerting you to activity.
  • Simple Setup: No tools required; install sensors in minutes and control everything through the Wyze app.
  • Potential Insurance Discounts: Subscribing to professional monitoring may qualify you for home insurance savings.
"Keep your home safe with Wyze Home Monitoring Core Starter Kit. This clever system safeguards against unwanted guests and identifies potential hazards around the clock."
Wyze Home Monitoring Lifestyle Easy installation and reliable entry sensors for your home security.
Wyze Sense Hub: The Smart System Brain
At the heart of the Wyze Home Monitoring System is the Wyze Sense Hub. This device connects all your sensors and ensures you receive instant alerts on your phone.
  • Centralized Control: Links all monitoring components seamlessly.
  • Reliable Alerts: Sends notifications immediately when sensors detect activity.
  • Compact & Efficient: Designed to be the core of every Wyze Home Monitoring setup.
  • Easy Integration: Works with all Wyze Sense sensors and accessories.
"The brains behind the brawn. It connects each of the monitoring components and sends alerts."
Expand Your Security with Wyze Sense Sensors
Customize your home monitoring system with a variety of Wyze Sense sensors that enhance safety and convenience.
Wyze Sense Motion Sensor
  • Detects Motion: Covers up to 25 feet with a 120° field of view.
  • Adjustable Sensitivity: Tailor detection to your home's needs.
  • Long Battery Life: Up to 18 months on a single battery.
  • Easy Installation: Adhesive backing or screws for secure placement.
  • Compatibility: Requires Wyze Sense Hub or Wyze Home Monitoring.
Wyze Sense Climate Sensor
  • Monitors Temperature & Humidity: Track indoor climate in any room.
  • Long Range: Up to 500 feet communication distance.
  • Sleek Design: Compact and unobtrusive white matte finish.
  • Flexible Mounting: Place on surfaces or stick to walls.
  • Battery Life: Lasts up to 1.5 years.
Wyze Sense Keypad
  • Remote Disarm: Arm or disarm your system from anywhere.
  • Emergency Button: Quickly send alerts to first responders.
  • Indoor Use: Designed for convenient placement inside your home.
  • Permanent Adhesive: Securely mounts where you need it.
Requires Wyze Sense Hub.
  • Leak Detection: Get notified immediately of water leaks.
  • Extended Range: Up to 500 feet from the hub.
  • Indoor Use Only: Ideal for basements, kitchens, or bathrooms.
Compatible with Wyze Sense v2 and Wyze Home Monitoring. Wyze Sense Keypad Lifestyle Control your home security remotely with the Wyze Sense Keypad.
Why Choose Wyze Home Monitoring?
"Be worry-free, 24/7, and secure your space with this simple system."
  • Affordable Security: Get professional-grade monitoring without breaking the bank.
  • Flexible Subscription: Use the system without a subscription or upgrade for full monitoring benefits.
  • Smartphone Control: Manage your entire system from the Wyze app anytime, anywhere.
  • Expandable: Add sensors and accessories as your security needs grow.
  • Easy Installation: No complicated wiring or tools needed.
Summary of Wyze Home Monitoring Products
ProductKey FeaturesPrice (Approx.)
Wyze Home Monitoring Core Starter KitEntry & motion sensors, 3 months free monitoring$111.98
Wyze Sense HubCentral hub connecting all sensors$45.98
Wyze Sense Motion SensorMotion detection, adjustable sensitivity$20.98
Wyze Sense Climate SensorTemperature & humidity tracking$41.98 (3-pack)
Wyze Sense KeypadRemote arm/disarm, emergency button$27.98
Wyze Sense Leak Sensor & ProbeLeak detection with probes$13.98+
Secure your home today with the Wyze Home Monitoring System and enjoy the benefits of a free hub subscription discount. Whether you’re starting fresh or expanding your current setup, Wyze offers reliable, smart, and affordable home security solutions tailored to your needs.
FeatureWyze Home Monitoring Core Starter KitWyze Sense HubWyze Sense Motion SensorWyze Sense Climate SensorWyze Sense KeypadWyze Sense Leak Sensor & Probe
TypeHome MonitoringHome MonitoringHome MonitoringHome MonitoringHome MonitoringHome Monitoring
Price$111.98 (Bundle with 3 months Professional Monitoring)$45.98$20.98 (1 Pack)$41.98 (3 Pack)$27.98$13.98 (2 Probes) / $55.98 (3 Sensors + 1 Probe)
Requires-Core of Wyze Home Monitoring SystemWyze Sense HubWyze Sense HubWyze Sense HubWyze Sense Hub
Main FunctionHome security system with sensors and monitoringConnects monitoring components & sends alertsDetects motionTracks temperature & humidityArm/disarm security remotelyLeak detection
Sensors IncludedEntry Sensor, Motion SensorNoneMotion SensorClimate SensorKeypad deviceLeak Sensor & Probe
Detection Range--25 ft500 ft-Up to 500 ft
Field of View--120°---
Sensitivity Settings--Adjustable---
Battery Life--Up to 18 months1.5 years--
Indoor UseYesYesYesYesYesYes
Mounting Method--Adhesive back, screwsAdhesive back, optional screwsPermanent adhesive-
CompatibilityWyze Home MonitoringWyze Home Monitoring SystemWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home MonitoringWyze Home MonitoringWyze Sense v2, Wyze Home Monitoring
Max Sensors per Hub--100-100-
Emergency Features24/7 professional monitoring (with subscription)Sends alerts--Emergency button, first responder alert-
Weather Resistance--Indoor use onlyIndoor use onlyIndoor use onlyIndoor use only
Additional NotesSubscription optional for monitoring & insurance discountsCore device for system connectivityMotion detection without camera feedTracks temp & humidity remotelyArm/disarm system remotelyLeak detection with probes
What is included in the Wyze Home Monitoring Core Starter Kit?The Wyze Home Monitoring Core Starter Kit includes essential entry and motion sensors, the Wyze Sense Hub, and a free 3-month subscription to professional monitoring. This all-in-one bundle provides 24/7 security and is easy to install without any tools.
How does the free hub subscription discount work with Wyze Home Monitoring?When you purchase the Wyze Home Monitoring System, you receive a free 3-month subscription to professional monitoring. This allows you to experience emergency dispatch services and real-time alerts at no additional cost during the trial period.
What is the Wyze Sense Hub and why is it important?The Wyze Sense Hub is the central device that connects all your Wyze sensors and accessories. It ensures you receive instant alerts on your phone when activity is detected, providing centralized control and reliable notifications for your home security system.
Can I expand my Wyze Home Monitoring System with additional sensors?Yes, the Wyze Home Monitoring System is fully expandable. You can add Wyze Sense Motion Sensors, Climate Sensors, Keypads, and Leak Sensors to customize and enhance your home security as your needs grow.
How easy is it to install the Wyze Home Monitoring System?The Wyze Home Monitoring System is designed for easy, tool-free installation. Sensors can be set up in minutes using adhesive backing or screws, and the entire system is managed through the Wyze app for convenience.
Does Wyze Home Monitoring offer professional monitoring services?Yes, Wyze Home Monitoring offers 24/7 professional monitoring with emergency dispatch services. The Core Starter Kit includes a free 3-month subscription, and you can continue the service with a paid subscription after the trial period.
Can I control my Wyze Home Monitoring System from my smartphone?Absolutely. The Wyze Home Monitoring System is fully controllable through the Wyze app, allowing you to manage sensors, receive alerts, and arm or disarm your system from anywhere.
Are there any potential insurance discounts for using Wyze Home Monitoring?Yes, subscribing to Wyze's professional monitoring service may qualify you for home insurance discounts. Check with your insurance provider for eligibility and details.
What types of sensors are available for Wyze Home Monitoring?Wyze offers a variety of sensors including Entry Sensors, Motion Sensors, Climate Sensors (for temperature and humidity), Keypads for remote control, and Leak Sensors with probes for water leak detection.
Is a subscription required to use Wyze Home Monitoring?A subscription is not required to use the Wyze Home Monitoring System, but subscribing unlocks full professional monitoring benefits, including emergency dispatch and potential insurance discounts.
How much does the Wyze Home Monitoring System cost?The Wyze Home Monitoring Core Starter Kit is approximately $111.98. Additional components such as the Wyze Sense Hub, Motion Sensor, Climate Sensor, Keypad, and Leak Sensor are available separately at various prices.
What are the key features of the Wyze Home Monitoring Core Starter Kit?How does the Wyze Sense Hub work with the other sensors?Do you have any ongoing sales or discounts for the Wyze Home Monitoring System?
