Best Professional Home Security Monitoring with Wyze Sensors
Best Professional Monitoring Home Security Service with Wyze Sensors
When it comes to securing your home with professional monitoring, Wyze offers a comprehensive and affordable solution that combines smart sensors, a central hub, and 24/7 professional monitoring through a trusted partner. Whether you want round-the-clock protection or prefer self-monitoring, Wyze’s ecosystem of sensors and devices ensures your home stays safe and connected.
Why Choose Wyze for Professional Home Security Monitoring?
Wyze partners with Noonlight to provide 24/7 professional monitoring services across the United States and Canada. This means that in the event of an emergency, trained professionals will verify alarms and dispatch emergency responders if needed. With no contracts and affordable subscription plans, Wyze Home Monitoring offers peace of mind with easy DIY installation and seamless integration through the Wyze app.
“Wyze Home Monitoring protects your home inside and out with a full suite of sensors, a central hub, and professional monitoring by real humans.”
Wyze Sense Sensors: The Backbone of Your Security System
Wyze’s line of Sense sensors work together to detect motion, entry, leaks, and environmental changes, all connected through the Wyze Sense Hub. These sensors are designed for indoor use, easy installation, and long battery life, making them ideal for any home.
Wyze Sense Motion Sensor
  • Detects motion within a 25-foot range and 120° field of view.
  • Adjustable sensitivity settings to reduce false alarms.
  • Easy installation with adhesive backing or screws for added security.
  • Battery life up to 18 months.
  • Compatible with Wyze Sense v2 and Wyze Home Monitoring.
This sensor is perfect for monitoring hallways, entryways, or any area where motion detection is critical.
Wyze Sense Entry Sensor
  • Detects when doors or windows open and close.
  • Sold in convenient 3-packs for comprehensive coverage.
  • Requires Wyze Sense Hub and compatible with Wyze Sense v2 and Wyze Home Monitoring.
  • Ideal for securing all access points in your home.
  • Alerts you immediately to water leaks to prevent costly damage.
  • Available in multiple styles including 2 probes or 3 sensors with 1 probe.
  • Operates within a 500-foot sensor range.
  • Indoor use only, compatible with Wyze Sense v2 and Wyze Home Monitoring.
Wyze Sense Climate Sensor
  • Monitors temperature and humidity in any room.
  • Sleek, unobtrusive design with adhesive or screw mounting options.
  • 500-foot communication range to the hub.
  • Battery life of 1.5 years.
  • Helps maintain optimal home environment and detect unusual climate changes.
Wyze Sense Hub: The Central Command
The Wyze Sense Hub is the essential brain of your home security system. It connects all your Wyze Sense sensors and communicates alerts to your phone and the professional monitoring center.
  • Supports up to 100 sensors.
  • Communicates via Ethernet, WiFi, Bluetooth, and 915MHz RF.
  • Built-in rechargeable battery with 10-hour backup.
  • Emits an 88db siren to deter intruders.
  • Includes window decals to alert visitors of your security system.
Wyze Sense Keypad: Arm and Disarm with Ease
For added convenience and security, the Wyze Sense Keypad allows you to arm or disarm your system remotely or on-site.
  • Requires Wyze Home Monitoring subscription.
  • Features an emergency button for quick alerts.
  • Permanent adhesive mounting for secure placement.
  • Supports up to 100 accessories.
  • Enables quick system control without needing your phone.
Wyze Sense Keypad in Home
How Wyze Professional Monitoring Works
With an active Wyze Home Monitoring subscription, your Wyze Sense Hub and sensors work together to detect emergencies such as break-ins, leaks, or environmental hazards. When an alarm triggers: 1. Noonlight’s professional monitoring team is notified immediately. 2. They contact you within 30 seconds to verify your safety. 3. If you cannot respond, they dispatch emergency services on your behalf. This system ensures rapid response without the need for contracts or complicated setups.
Self-Monitoring vs. Professional Monitoring
Wyze also supports self-monitoring through the Wyze app and Cam Plus subscription, allowing you to monitor your home yourself with real-time alerts and video verification. However, professional monitoring adds the critical layer of emergency dispatch and human verification, ideal for those seeking maximum security and peace of mind.
Conclusion: Secure Your Home with Wyze Sensors and Professional Monitoring
Wyze offers a robust, easy-to-install home security system with professional monitoring backed by Noonlight. From motion and entry sensors to leak and climate detection, the Wyze Sense product line covers all aspects of home safety. The Wyze Sense Hub and Keypad provide centralized control and seamless integration, making Wyze the best choice for professional home security monitoring with smart sensors. Wyze Home Security Lifestyle
Product Summary
ProductKey FeaturesPrice (USD)
Wyze Sense Motion Sensor25 ft range, 120° FOV, 18-month battery$20.98 (1 Pack)
Wyze Sense Entry SensorDetects open/close, 3-pack$41.98
Wyze Sense Leak SensorLeak alerts, up to 500 ft range$13.98 - $55.98
Wyze Sense Climate SensorTemp & humidity, 500 ft range, 1.5 years battery$41.98 (3 Pack)
Wyze Sense HubConnects sensors, 88db siren, backup battery$45.98
Wyze Sense KeypadArm/disarm remotely, emergency button$27.98
Secure your home today with Wyze’s professional monitoring and smart sensors for reliable, affordable protection.
FeatureWyze Sense Motion SensorWyze Sense Entry SensorWyze Sense Leak Sensor & ProbeWyze Sense KeypadWyze Sense Climate SensorWyze Sense Hub
FunctionDetects motionDetects open/closeDetects leaksDisarm home security remotelyTracks temperature and humidityConnects sensors and sends alerts
RequiresWyze Sense Hub, Wyze Sense v2 or Home MonitoringWyze Sense Hub, Wyze Sense v2 or Home MonitoringWyze Sense Hub, Wyze Sense v2 or Home MonitoringWyze Sense Hub, Wyze Home MonitoringWyze Sense Hub, Wyze Sense v2 or Home MonitoringNone (central hub)
Standalone FunctionNoNoNoNoNoYes
Detection Range / CoverageUp to 25 ft, 120° FOVN/AUp to 500 ftN/AUp to 500 ftRF range 500 ft to sensors
Sensitivity SettingsAdjustable, pet-friendly modeN/AN/AN/AN/AN/A
Mounting MethodAdhesive back, optional screwsN/AN/APermanent adhesiveAdhesive back, optional screwsN/A
Indoor/Outdoor UseIndoor onlyIndoor onlyIndoor onlyIndoor onlyIndoor onlyIndoor only
Battery Type / LifeNot specifiedNot specifiedNot specifiedNot specifiedCR2032, 1.5 yearsBuilt-in rechargeable, 10 hr backup
Communication Method915 MHz RF915 MHz RF915 MHz RF915 MHz RF915 MHz RFEthernet, WiFi 2.4 GHz, Bluetooth, 915 MHz RF
DimensionsNot specifiedNot specifiedNot specifiedNot specified1.4" x 1.4" x 0.5"4.5" x 4" x 1"
Price (USD)$20.98 (1 Pack)$41.98 (3 Pack)$13.98 (2 Probes) / $55.98 (3 Sensors + 1 Probe)$27.98$41.98 (3 Pack)$45.98
Additional FeaturesLarge pet installation instructionsN/AOperating temp 32-104°F, humidity ≤85%Arm/disarm system, emergency buttonTracks temp & humidity, sleek designSupports up to 100 sensors, 88db siren
What is Wyze Home Monitoring and how does it work?Wyze Home Monitoring is a professional home security service that uses Wyze sensors and a central hub to protect your home. With a subscription, your system is monitored 24/7 by Noonlight, a trusted monitoring partner. When an alarm is triggered, Noonlight’s team verifies the emergency and dispatches emergency responders if needed, ensuring rapid response and peace of mind.
Which Wyze sensors are included in the home security system?The Wyze home security system includes a range of sensors: Wyze Sense Motion Sensor (detects motion), Wyze Sense Entry Sensor (detects door/window openings), Wyze Sense Leak Sensor & Probe (alerts to water leaks), and Wyze Sense Climate Sensor (monitors temperature and humidity). All sensors connect to the Wyze Sense Hub for centralized control.
How does the Wyze Sense Motion Sensor enhance home security?The Wyze Sense Motion Sensor detects movement within a 25-foot range and a 120° field of view. It features adjustable sensitivity to reduce false alarms, easy installation, and a battery life of up to 18 months. It is ideal for monitoring hallways, entryways, or any area where motion detection is critical.
What is the function of the Wyze Sense Entry Sensor?The Wyze Sense Entry Sensor detects when doors or windows are opened or closed. Sold in convenient 3-packs, these sensors are perfect for securing all access points in your home and require the Wyze Sense Hub for operation.
How does the Wyze Sense Leak Sensor protect my home?The Wyze Sense Leak Sensor and Probe alert you immediately to water leaks, helping prevent costly water damage. With a 500-foot range and compatibility with the Wyze Sense Hub, these sensors are designed for indoor use and are available in multiple configurations.
What does the Wyze Sense Climate Sensor monitor?The Wyze Sense Climate Sensor monitors temperature and humidity in any room, helping you maintain an optimal home environment and detect unusual climate changes. It features a 500-foot communication range to the hub and a battery life of up to 1.5 years.
What is the Wyze Sense Hub and why is it important?The Wyze Sense Hub is the central command center for your Wyze home security system. It connects up to 100 sensors, communicates alerts to your phone and the professional monitoring center, and features a built-in 10-hour backup battery and an 88db siren to deter intruders.
How does the Wyze Sense Keypad improve security system control?The Wyze Sense Keypad allows you to arm or disarm your security system easily, either remotely or on-site. It features an emergency button for quick alerts and supports up to 100 accessories, providing convenient and secure system control without needing your phone.
What is the difference between self-monitoring and professional monitoring with Wyze?With self-monitoring, you use the Wyze app and Cam Plus subscription to receive real-time alerts and monitor your home yourself. Professional monitoring, available through a Wyze Home Monitoring subscription, adds 24/7 emergency dispatch and human verification for maximum security and peace of mind.
Is Wyze Home Monitoring available without a contract?Yes, Wyze Home Monitoring offers affordable subscription plans with no contracts required. You can enjoy professional monitoring and smart home security without long-term commitments.
How easy is it to install Wyze home security products?Wyze home security products are designed for easy DIY installation. Sensors and devices come with adhesive backing or screw mounting options, and the system integrates seamlessly through the Wyze app for quick setup.
Does Wyze Home Monitoring work in both the United States and Canada?Yes, Wyze partners with Noonlight to provide 24/7 professional monitoring services across the United States and Canada, ensuring your home is protected in both countries.
What happens if my Wyze Sense Hub loses power?The Wyze Sense Hub features a built-in rechargeable battery that provides up to 10 hours of backup power, ensuring your home security system remains operational during power outages.
How many sensors can the Wyze Sense Hub support?The Wyze Sense Hub can support up to 100 sensors, allowing you to customize and expand your home security system as needed.
What are the prices of Wyze home security products?Wyze home security products are affordably priced: Wyze Sense Motion Sensor ($20.98 per pack), Wyze Sense Entry Sensor ($41.98 for a 3-pack), Wyze Sense Leak Sensor ($13.98–$55.98), Wyze Sense Climate Sensor ($41.98 for a 3-pack), Wyze Sense Hub ($45.98), and Wyze Sense Keypad ($27.98).
What are the key features of the Wyze Sense Motion Sensor?How does the Wyze Sense Hub connect to the sensors?Do you have any deals, ongoing sales, discounts, or promotions?
