Best Smart Home Security Hub for Wyze Sensors Integration
When it comes to building a smart home security system that seamlessly integrates with Wyze sensors, choosing the right security hub is essential. The Wyze Sense Hub stands out as the central brain that connects all your Wyze monitoring components, ensuring smooth communication and instant alerts. Alongside the hub, a range of Wyze sensors and accessories enhance your home’s safety and convenience.
Wyze Sense Hub: The Heart of Your Wyze Security System
The Wyze Sense Hub is designed to be the core controller for your Wyze sensors, providing reliable connectivity and alert management.
Key Features:
  • Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF communication.
  • Sensor Support: Connects up to 100 Wyze sensors, making it scalable for any home size.
  • Range: Offers a robust 500 ft (152 m) RF range to sensors, allowing placement in distant rooms or large properties.
  • Battery Backup: Built-in rechargeable 18650 battery with 10 hours of backup power ensures continuous operation during outages.
  • Siren: Integrated 88db siren at 2 feet for immediate audible alerts.
  • Design: Compact matte finish with a white base and grey speaker top, measuring 4.5” x 4” x 1”.
Included in the Box:
  • Wyze Sense Hub
  • Power Adapter
  • Ethernet Cable
  • Window Decals
  • Quick Start Guide
The Wyze Sense Hub is the essential "brains behind the brawn," connecting your entire Wyze security ecosystem with ease and reliability.
Essential Wyze Sensors for Enhanced Security
Wyze Sense Motion Sensor
Detect motion accurately with the Wyze Sense Motion Sensor, designed to work exclusively with the Wyze Sense Hub.
  • Detection Range: Up to 25 feet with a 120° field of view.
  • Adjustable Sensitivity: Customize detection sensitivity to reduce false alarms.
  • Battery Life: Long-lasting battery life of up to 18 months.
  • Installation: Easy adhesive back or screw mounting for secure placement.
  • Indoor Use: Perfect for monitoring entryways, hallways, or rooms.
Wyze Sense Keypad
Control your security system remotely with the Wyze Sense Keypad.
  • Functionality: Arm and disarm your system remotely and send first responders in emergencies.
  • Emergency Button: Quick access to emergency services.
  • Indoor Use: Designed for indoor placement with permanent adhesive mounting.
  • Compatibility: Requires Wyze Sense Hub and Wyze Home Monitoring subscription.
Wyze Sense Climate Sensor
Monitor your home's environment with the Wyze Sense Climate Sensor.
  • Measures: Tracks temperature and humidity in any room.
  • Range: 500 ft RF range for flexible placement.
  • Battery Life: Up to 1.5 years on a CR2032 battery.
  • Mounting: Peel-and-stick adhesive or optional screws.
  • Indoor Use: Sleek, unobtrusive design blends into any room.
These sensors work harmoniously with the Wyze Sense Hub to provide comprehensive home monitoring, from motion detection to environmental tracking.
Wyze Cam v4 Home Security Bundle: Visual Surveillance with Wyze Integration
For those looking to add high-quality video surveillance to their Wyze sensor network, the Wyze Cam v4 Home Security Bundle offers advanced features:
  • Resolution: Crystal-clear 2.5K QHD (2560x1440) video quality.
  • Night Vision: Enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected.
  • Person Detection: Smart alerts for human presence.
  • Weather Resistance: IP65 rating for indoor/outdoor use.
  • Connectivity: Supports Wi-Fi 6 for faster, more reliable streaming.
  • Storage: Supports microSD cards up to 128GB for local recording.
  • Compatibility: Works seamlessly with Alexa and Google Assistant.
This camera bundle complements the Wyze Sense Hub and sensors by providing real-time video monitoring and smart alerts, making your home security system more robust. Outdoor Wyze Cam v4 in Use Wyze Cam v4 providing vigilant outdoor security day and night.
Google Nest Hub (2nd Gen) + Wyze Bundles: Smart Home Control Meets Wyze Security
For users who want to integrate Wyze sensors with a smart display and voice assistant, the Google Nest Hub (2nd Gen) + Wyze Bundles offer a perfect solution.
Highlights:
  • Wyze Cam Control: View and control Wyze cameras directly on the Nest Hub screen.
  • Voice Commands: Use Google Assistant to manage Wyze smart home devices hands-free.
  • Entertainment & Monitoring: Combines smart home control with entertainment features.
  • Privacy: Mic switch to turn off the microphone anytime.
  • Improved Audio: 50% more bass than the original Nest Hub for richer sound.
  • Sleep Sense: Includes Google’s Sleep Sense assistant free until 2023.
This bundle is ideal for those who want a centralized smart home interface that integrates Wyze sensors and cameras with voice control and visual feedback. Family Using Google Nest Hub Control your Wyze smart home effortlessly with Google Nest Hub.
Why Choose Wyze for Your Smart Home Security Hub?
Wyze offers a comprehensive ecosystem that integrates sensors, cameras, and smart hubs designed to work flawlessly together. The Wyze Sense Hub is the cornerstone, enabling up to 100 sensors with a strong RF range and backup power. Paired with motion, climate, and keypad sensors, plus high-definition cameras like the Wyze Cam v4, you get a full-featured, scalable security system. Additionally, integration with smart assistants like Google Nest Hub enhances convenience, allowing voice control and real-time monitoring from anywhere.
With Wyze, you get affordable, reliable, and easy-to-use smart home security solutions tailored for seamless sensor integration.
Summary of Wyze Smart Home Security Products
ProductKey FeaturePrice (USD)
Wyze Sense HubCentral hub, supports 100 sensors$45.98
Wyze Sense Motion SensorMotion detection, 25 ft range$20.98
Wyze Sense KeypadRemote arm/disarm, emergency button$27.98
Wyze Sense Climate SensorTemperature & humidity tracking$41.98 (3-pack)
Wyze Cam v4 Bundle2.5K QHD camera, color night vision$169.99
Google Nest Hub + WyzeVoice control & smart displayFrom $99.00
Optimize your home security with the best Wyze smart home security hub and sensors, ensuring your home is safe, smart, and connected.
FeatureWyze Sense HubWyze Sense Motion SensorWyze Sense KeypadWyze Cam v4 Home Security BundleWyze Sense Climate SensorGoogle Nest Hub (2nd Gen) + Wyze Bundles
TypeHome MonitoringHome MonitoringHome MonitoringCamerasHome MonitoringConnected Home
Price (USD)45.9820.9827.98169.9941.98 (3 Pack)99.00 - 190.99 (varies by bundle)
Main FunctionConnects monitoring components, sends alertsDetects motion (up to 25 ft, 120° FOV)Arm/disarm system remotely, emergency button2.5K QHD camera, spotlight, night vision, 24/7 recordingTracks temperature & humidity (500 ft range)Smart home control + Wyze Cam integration
Requires-Wyze Sense HubWyze Sense Hub-Wyze Sense HubWyze Cam (varies by bundle)
Indoor/Outdoor UseIndoorIndoorIndoorIndoor/OutdoorIndoor onlyIndoor
ConnectivityCentral hub for sensorsWireless (adhesive or screws)Wireless (permanent adhesive)Wi-Fi 6, wired power915MHz RFWi-Fi, Google Assistant
CompatibilityWyze Sense componentsWyze Sense v2 or Wyze Home MonitoringWyze Home MonitoringAlexa, Google AssistantWyze Sense v2, Wyze Home MonitoringWyze Cam v3, Pan v3, v4
BatteryN/ABattery poweredBattery poweredPowered (wired)CR2032 (1.5 years)Powered (plug-in)
Special FeaturesCore hub for alertsAdjustable sensitivity, pet-friendlyEmergency button, arm/disarmEnhanced color night vision, spotlight, 2-way audioSleek design, adhesive or screwsEntertainment + smart home control, Sleep Sense trial
Weather ResistanceNot specifiedNot specifiedNot weatherproofIP65 ratedIndoor use onlyNot specified
WarrantyNot specifiedNot specifiedNot specified1 YearNot specifiedNot specified
What is the Wyze Sense Hub and why is it important for smart home security?The Wyze Sense Hub is the central controller for your Wyze smart home security system. It connects and manages up to 100 Wyze sensors, ensuring reliable communication, instant alerts, and seamless integration of all your Wyze security devices. Its robust connectivity options and backup battery make it essential for a dependable home security setup.
How many Wyze sensors can the Wyze Sense Hub support?The Wyze Sense Hub can connect and manage up to 100 Wyze sensors, making it scalable for homes of any size and allowing you to customize your security system as needed.
What connectivity options does the Wyze Sense Hub offer?The Wyze Sense Hub supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF communication, ensuring flexible and reliable connections for your smart home security devices.
Does the Wyze Sense Hub have a battery backup?Yes, the Wyze Sense Hub features a built-in rechargeable 18650 battery that provides up to 10 hours of backup power, ensuring your security system remains operational during power outages.
What is included in the Wyze Sense Hub package?The Wyze Sense Hub package includes the Wyze Sense Hub, a power adapter, an Ethernet cable, window decals, and a quick start guide for easy setup.
What are the key features of the Wyze Sense Motion Sensor?The Wyze Sense Motion Sensor offers a 25-foot detection range with a 120° field of view, adjustable sensitivity to reduce false alarms, up to 18 months of battery life, and easy installation with adhesive or screws. It is designed for indoor use and works exclusively with the Wyze Sense Hub.
How does the Wyze Sense Keypad enhance home security?The Wyze Sense Keypad allows you to arm and disarm your security system remotely and features an emergency button for quick access to first responders. It requires the Wyze Sense Hub and a Wyze Home Monitoring subscription for full functionality.
What does the Wyze Sense Climate Sensor monitor?The Wyze Sense Climate Sensor tracks temperature and humidity in any room, offering a 500 ft RF range, up to 1.5 years of battery life, and easy mounting options. It is ideal for monitoring your home's environment and works with the Wyze Sense Hub.
What are the benefits of the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle provides 2.5K QHD video quality, enhanced color night vision, motion-activated spotlight, person detection, IP65 weather resistance for indoor/outdoor use, Wi-Fi 6 connectivity, and local storage support. It integrates seamlessly with Wyze sensors and smart assistants for comprehensive home security.
Can Wyze devices be controlled with Google Nest Hub?Yes, Wyze devices can be integrated with the Google Nest Hub (2nd Gen), allowing you to view and control Wyze cameras, use voice commands via Google Assistant, and manage your smart home devices hands-free from a central smart display.
Is the Wyze Sense Hub compatible with Alexa and Google Assistant?Yes, the Wyze Sense Hub and compatible Wyze devices work seamlessly with both Alexa and Google Assistant, enabling voice control and smart home automation.
What makes Wyze a good choice for smart home security?Wyze offers an affordable, reliable, and easy-to-use ecosystem of smart home security products. With the Wyze Sense Hub at its core, you can integrate up to 100 sensors, high-definition cameras, and smart assistants for a scalable and comprehensive security solution.
Are Wyze sensors and cameras suitable for both indoor and outdoor use?Wyze sensors like the motion, climate, and keypad sensors are designed for indoor use, while the Wyze Cam v4 is IP65 rated for both indoor and outdoor surveillance, providing flexible security coverage for your entire property.
How do I expand my Wyze smart home security system?You can expand your Wyze smart home security system by adding more Wyze sensors (motion, climate, keypad), cameras like the Wyze Cam v4, and integrating with smart displays such as the Google Nest Hub for centralized control and monitoring.
What are the key features of the Wyze Sense Hub?How many Wyze sensors can the Wyze Sense Hub support?Do you have any deals, ongoing sales, discounts, or promotions?
