Best Home Monitoring Service with Customizable Wyze Sensors
Best Home Monitoring Service with Customizable Wyze Sensor Integration
When it comes to securing your home with a smart, customizable, and reliable monitoring system, Wyze offers an exceptional lineup of sensors and devices designed to work seamlessly together. Whether you want to detect motion, monitor entry points, track climate conditions, or get alerts for leaks, Wyze’s Home Monitoring ecosystem provides comprehensive coverage with easy integration through the Wyze Sense Hub.
Wyze’s Home Monitoring Service combines smart sensors with a professional monitoring provider to keep your home safe and connected, offering customizable alerts and remote control through the Wyze app.
Core Components of Wyze Home Monitoring
Wyze Sense Hub: The Central Brain
The Wyze Sense Hub is the essential hub that connects all your Wyze sensors and manages communication between devices and your smartphone. It supports up to 100 sensors, ensuring scalability for any home size.
  • Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1+ BLE 5.1, and 915MHz RF communication.
  • Range: Up to 500 feet to sensors, allowing placement in distant rooms or outbuildings.
  • Battery Backup: Built-in rechargeable battery with 10 hours of backup power.
  • Siren: Loud 88db siren to alert you locally.
  • Dimensions: Compact 4.5” x 4” x 1” size with a sleek matte finish.
  • Indoor Use: Designed for indoor environments.
The hub is the backbone of your Wyze Home Monitoring system, enabling real-time alerts and integration with Wyze’s professional monitoring service.
Essential Wyze Sensors for Customizable Monitoring
Wyze Sense Entry Sensor: Monitor Doors and Windows
Keep track of all entry points with the Wyze Sense Entry Sensor. It detects when doors or windows open or close, providing instant notifications to your phone.
  • Compatibility: Requires Wyze Sense Hub and works with Wyze Sense v2 or Wyze Home Monitoring.
  • Pack Size: Available in convenient 3-packs.
  • Use Cases: Ideal for front doors, back doors, windows, cabinets, and more.
  • Installation: Easy to install with adhesive backing.
This sensor is perfect for alerting you to unexpected access, enhancing your home’s security perimeter.
Wyze Sense Motion Sensor: Detect Movement with Precision
The Wyze Sense Motion Sensor adds an extra layer of security by detecting motion within a 25-foot range and a 120° field of view.
  • Adjustable Sensitivity: Customize detection sensitivity to reduce false alarms.
  • Installation: Comes with adhesive backing and optional screws for secure mounting.
  • Battery Life: Long-lasting battery life of up to 18 months.
  • Indoor Use: Designed specifically for indoor monitoring.
  • Compatibility: Works with Wyze Sense Hub and Wyze Home Monitoring.
This sensor is ideal for monitoring hallways, living rooms, or any area where motion detection is critical.
Wyze Sense Climate Sensor: Track Temperature and Humidity
Maintain comfort and protect your home environment with the Wyze Sense Climate Sensor. It monitors temperature and humidity levels, helping you prevent issues like mold or frozen pipes.
  • Range: Communicates up to 500 feet from the hub.
  • Design: Sleek, unobtrusive white matte finish blends into any room.
  • Mounting: Place on surfaces or use peel-and-stick adhesive for walls.
  • Battery Life: Up to 1.5 years on a CR2032 battery.
  • Pack Size: Available in 3-packs for whole-home coverage.
  • Indoor Use: Suitable for basements, attics, or any indoor space.
This sensor is perfect for homeowners who want to maintain optimal indoor conditions and receive alerts if climate changes unexpectedly.
Wyze Sense Leak Sensor & Probe: Early Leak Detection
Protect your home from water damage with the Wyze Sense Leak Sensor & Probe. It alerts you immediately if leaks or flooding are detected.
  • Variants: Available with 2 probes or 3 sensors and 1 probe.
  • Range: Up to 500 feet communication distance.
  • Indoor Use: Designed for indoor placement near water sources.
  • Operating Conditions: Works reliably between 32°F to 104°F and up to 85% humidity.
Place these sensors near water heaters, sinks, or basements to catch leaks early and avoid costly repairs.
Convenient Control with Wyze Sense Keypad
The Wyze Sense Keypad allows you to arm or disarm your home security system remotely and quickly. It also features an emergency button to send alerts instantly.
  • Functionality: Arm/disarm system and send first responder alerts.
  • Indoor Use: Designed for indoor placement.
  • Installation: Permanent adhesive backing for secure mounting.
  • Compatibility: Requires Wyze Sense Hub and Wyze Home Monitoring subscription.
  • Emergency Button: Provides quick access to emergency services.
This keypad adds an extra layer of convenience and safety, especially for families or multi-user households.
Why Choose Wyze Home Monitoring Service?
Wyze’s Home Monitoring Service offers professional monitoring through a trusted third-party provider, ensuring that emergency responders can be dispatched when needed. The system is highly customizable, allowing you to integrate multiple sensor types tailored to your home’s unique needs.
“Wyze Home Monitoring is designed for single-family residences in the U.S., providing peace of mind with real-time alerts, emergency dispatch, and easy-to-use app controls.”
Key Benefits:
  • Customizable Sensor Integration: Mix and match entry, motion, climate, and leak sensors.
  • Scalable System: Support for up to 100 sensors per hub.
  • Professional Monitoring: 24/7 monitoring with emergency dispatch capabilities.
  • Long Battery Life: Sensors designed to last months or years without frequent battery changes.
  • Easy Installation: Adhesive or screw mounting options for flexible placement.
  • Remote Control: Arm, disarm, and receive alerts from anywhere via the Wyze app.
Enhance Your Home Security with Wyze
Wyze’s ecosystem of sensors combined with the Wyze Sense Hub and Home Monitoring Service creates a powerful, customizable home security solution. Whether you want to monitor doors, detect motion, track climate, or prevent water damage, Wyze has you covered with affordable, reliable technology. Family enjoying secure home environment Experience peace of mind with Wyze’s smart home monitoring. Wyze Sense Keypad for easy control Convenient keypad control for your Wyze security system.
Conclusion
For the best home monitoring service with customizable Wyze sensor integration, the combination of Wyze Sense Hub, Entry Sensors, Motion Sensors, Climate Sensors, Leak Sensors, and the Keypad offers a comprehensive, scalable, and user-friendly solution. Backed by professional monitoring and a robust app interface, Wyze ensures your home stays safe, comfortable, and connected.
FeatureWyze Sense Entry SensorWyze Sense Motion SensorWyze Sense HubWyze Sense Climate SensorWyze Sense KeypadWyze Sense Leak Sensor & Probe
TypeEntry SensorMotion SensorHubClimate SensorKeypadLeak Sensor & Probe
FunctionDetects when things open/closeDetects motionConnects sensors and sends alertsTracks temperature and humidityArm/disarm security remotelyDetects leaks
RequiresWyze Sense HubWyze Sense HubN/AWyze Sense HubWyze Sense HubWyze Sense Hub
CompatibilityWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home MonitoringSupports up to 100 sensorsWyze Sense v2, Wyze Home MonitoringWyze Home MonitoringWyze Sense v2, Wyze Home Monitoring
Standalone FunctionNoNoYesNoNoNo
Pack Size / Variants3 Pack1 PackDefault3 PackDefault2 Probes, 3 Sensors + 1 Probe
Price$41.98$20.98$45.98$41.98$27.98$13.98 (2 Probes), $55.98 (3 Sensors + 1 Probe)
Communication Method915 MHz RF915 MHz RFEthernet, WiFi 2.4 GHz, Bluetooth 4.1+ BLE 5.1, 915 MHz RF915 MHz RFNot specified915 MHz RF
Operating Temperature32°F - 104°F (0°C - 40°C)Not specified32°F - 104°F (0°C - 40°C)32°F - 104°F (0°C - 40°C)Not specified32°F - 104°F (0°C - 40°C)
Operating Humidity≤ 85% at 86°F (30°C)Not specified≤ 85% at 86°F (30°C)≤ 85% at 86°F (30°C)Not specified≤ 85% at 86°F (30°C)
Indoor/Outdoor UseIndoor onlyIndoor onlyIndoor onlyIndoor onlyIndoor onlyIndoor only
BatteryNot specifiedNot specifiedBuilt-in rechargeable (3.7V, 2600mAh)CR2032 (1.5 years)Not specifiedNot specified
MountingAdhesive back (implied)Adhesive back, screws optionN/AAdhesive back, optional screwsPermanent adhesiveNot specified
Additional FeaturesInstant discount with Wyze Home Monitoring Annual planAdjustable sensitivity, pet installation instructionsSiren 88db @ 2 ft, supports up to 100 sensorsSleek white design, 500 ft rangeEmergency button, arm/disarm, send first respondersSensor range up to 500 ft, leak notification
Included ItemsNot specifiedNot specifiedHub, power adapter, ethernet cable, window decals, quick start guideNot specifiedNot specifiedNot specified
What is Wyze Home Monitoring Service and how does it work?Wyze Home Monitoring Service is a smart home security solution that integrates Wyze sensors and devices with professional monitoring. It provides real-time alerts, customizable notifications, and remote control through the Wyze app. The system uses the Wyze Sense Hub to connect up to 100 sensors, offering comprehensive coverage for your home.
What sensors are compatible with Wyze Home Monitoring?Wyze Home Monitoring is compatible with Wyze Sense Entry Sensors, Motion Sensors, Climate Sensors, and Leak Sensors. All these sensors require the Wyze Sense Hub for integration and can be mixed and matched to create a customized security setup for your home.
How does the Wyze Sense Hub enhance home security?The Wyze Sense Hub acts as the central brain of the Wyze Home Monitoring system, connecting all sensors and managing communication with your smartphone. It supports up to 100 sensors, offers a 500-foot range, has a built-in 10-hour battery backup, and features a loud 88db siren for local alerts.
What are the benefits of using Wyze Entry Sensors?Wyze Entry Sensors monitor doors, windows, and other entry points, sending instant notifications to your phone when they are opened or closed. They are easy to install with adhesive backing and are ideal for enhancing your home’s security perimeter.
How does the Wyze Motion Sensor work?The Wyze Motion Sensor detects movement within a 25-foot range and a 120° field of view. It features adjustable sensitivity to reduce false alarms, long battery life up to 18 months, and is designed for indoor use. It is perfect for monitoring hallways, living rooms, or any area where motion detection is needed.
What is the purpose of the Wyze Climate Sensor?The Wyze Climate Sensor tracks temperature and humidity levels in your home, helping you maintain comfort and prevent issues like mold or frozen pipes. It communicates up to 500 feet from the hub, has a battery life of up to 1.5 years, and is suitable for indoor spaces like basements and attics.
How does the Wyze Leak Sensor protect my home?The Wyze Leak Sensor and Probe detect water leaks or flooding and send immediate alerts to your phone. They are designed for indoor use near water sources such as water heaters, sinks, or basements, helping you prevent costly water damage.
What features does the Wyze Sense Keypad offer?The Wyze Sense Keypad allows you to arm or disarm your home security system quickly and remotely. It includes an emergency button for instant alerts to first responders and is easy to install with permanent adhesive backing. The keypad requires the Wyze Sense Hub and a Wyze Home Monitoring subscription.
Is Wyze Home Monitoring Service professionally monitored?Yes, Wyze Home Monitoring Service offers 24/7 professional monitoring through a trusted third-party provider. This ensures that emergency responders can be dispatched when needed, providing peace of mind for homeowners.
Can I control my Wyze Home Monitoring system remotely?Yes, you can control your Wyze Home Monitoring system remotely using the Wyze app. The app allows you to arm or disarm the system, receive real-time alerts, and monitor the status of all connected sensors from anywhere.
How easy is it to install Wyze sensors and devices?Wyze sensors and devices are designed for easy installation, featuring adhesive or screw mounting options. Most sensors can be set up in minutes without the need for professional installation, making it simple to customize your home security system.
Is Wyze Home Monitoring suitable for all types of homes?Wyze Home Monitoring is designed primarily for single-family residences in the U.S. It offers scalable coverage, supporting up to 100 sensors per hub, making it suitable for homes of various sizes.
What are the key features of the Wyze Sense Hub?How many sensors can the Wyze Sense Hub support?Do you have any deals, ongoing sales, discounts, or promotions?
