Wyze Home Monitoring Sensors for Customizable Home Security Automation
Enhance your home security with Wyze’s comprehensive line of home monitoring sensors designed for customizable automation. Whether you want to detect motion, monitor entry points, track climate conditions, or get alerts for leaks, Wyze offers a smart, connected ecosystem that integrates seamlessly to keep your home safe and smart.
Wyze Sense Hub – The Central Brain of Your Home Security
The
Wyze Sense Hub is the core of your home monitoring system, connecting all your sensors and sending real-time alerts directly to your phone. This compact yet powerful hub supports up to 100 sensors, making it perfect for homes of all sizes.
Key Features:
- Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1+ BLE 5.1, and 915MHz RF communication.
- Range: Up to 500 feet to sensors, ensuring wide coverage.
- Battery Backup: Built-in rechargeable battery with 10 hours of backup power.
- Siren: Loud 88db siren to deter intruders.
- Indoor Use: Designed for indoor environments with a sleek matte white and grey finish.
- Included Accessories: Power adapter, Ethernet cable, window decals, and quick start guide.
The Wyze Sense Hub is the “brains behind the brawn,” orchestrating your entire home security network with reliability and ease.
Wyze Sense Hub integrates seamlessly with your home automation system
Wyze Sense Motion Sensor – Smart Motion Detection
Detect movement instantly with the
Wyze Sense Motion Sensor, designed to work exclusively with the Wyze Sense Hub or Wyze Home Monitoring system.
Highlights:
- Detection Range: Up to 25 feet with a wide 120° field of view.
- Adjustable Sensitivity: Customize detection sensitivity to reduce false alarms.
- Installation: Easy adhesive back or optional screws for secure mounting.
- Battery Life: Long-lasting battery life of up to 18 months.
- Indoor Use: Perfect for monitoring rooms, hallways, or entryways.
This sensor is ideal for automating lights, triggering alerts, or activating cameras when motion is detected.
Wyze Sense Keypad – Remote Arm & Disarm Your System
Control your home security remotely with the
Wyze Sense Keypad. This device allows you to arm or disarm your system conveniently without needing to use your phone.
Features:
- Remote Control: Arm/disarm your system from anywhere.
- Emergency Button: Quickly send alerts to first responders in case of emergency.
- Indoor Use: Designed for indoor placement with permanent adhesive mounting.
- Compatibility: Requires Wyze Sense Hub and Wyze Home Monitoring subscription.
The keypad adds an extra layer of convenience and safety, perfect for families and multi-user households.
Wyze Sense Leak Sensor & Probe – Early Leak Detection
Protect your home from water damage with the
Wyze Sense Leak Sensor & Probe. This sensor alerts you immediately if it detects leaks or flooding.
Specifications:
- Compatibility: Works with Wyze Sense v2 and Wyze Home Monitoring.
- Operating Conditions: 32°F to 104°F, indoor use only.
- Range: Up to 500 feet from the hub.
- Variants: Available with multiple probes for versatile placement.
Ideal for basements, kitchens, bathrooms, or near appliances prone to leaks.
Wyze Climate Sensor – Monitor Temperature & Humidity
Maintain optimal comfort and protect your home environment with the
Wyze Climate Sensor. Track temperature and humidity levels in any room via the Wyze app.
Benefits:
- Battery Life: Up to 1.5 years on a CR2032 battery.
- Mounting: Peel-and-stick adhesive or optional screws.
- Design: Sleek, unobtrusive white matte finish blends into any room.
- Indoor Use: Perfect for basements, attics, or distant rooms.
Use this sensor to automate HVAC systems or receive alerts when conditions fall outside your preferred range.
Wyze Sense Entry Sensor v2 – Door & Window Monitoring
Keep tabs on your doors and windows with the
Wyze Sense Entry Sensor v2. It detects when entry points open or close, enhancing your home’s security perimeter.
Features:
- Detection Zone: 25 feet with a 120° field of vision.
- Battery Life: Up to 18 months.
- Installation: Easy indoor mounting with adhesive.
- Compatibility: Requires Wyze Sense Hub and Wyze Home Monitoring.
This sensor is essential for alerting you to unauthorized access or simply monitoring comings and goings.
Wyze sensors work together to create a smart, secure home environment
Why Choose Wyze Home Monitoring Sensors?
Wyze offers a flexible, scalable home security solution that adapts to your unique needs. With a robust hub and a variety of specialized sensors, you can customize your home automation to detect motion, monitor entries, track environmental conditions, and even detect leaks — all controlled from a single app.
Experience peace of mind with Wyze’s affordable, reliable, and easy-to-install home monitoring sensors designed for modern smart homes.
Summary of Wyze Home Monitoring Sensors:
Product | Key Function | Battery Life | Range to Hub | Indoor Use | Requires Hub |
Wyze Sense Hub | Central hub & siren | Rechargeable, 10h backup | N/A | Yes | N/A |
Wyze Sense Motion Sensor | Motion detection | Up to 18 months | 500 ft | Yes | Yes |
Wyze Sense Keypad | Arm/disarm & emergency button | N/A | N/A | Yes | Yes |
Wyze Sense Leak Sensor & Probe | Leak detection | N/A | 500 ft | Yes | Yes |
Wyze Climate Sensor | Temperature & humidity tracking | Up to 1.5 years | 500 ft | Yes | Yes |
Wyze Sense Entry Sensor v2 | Door/window open/close detection | Up to 18 months | 500 ft | Yes | Yes |
Invest in Wyze home monitoring sensors today to build a customizable, automated home security system that fits your lifestyle and keeps your loved ones safe.
What is the Wyze Sense Hub and how does it work?
The Wyze Sense Hub is the central brain of your Wyze home monitoring system. It connects and manages up to 100 Wyze sensors, sending real-time alerts directly to your phone. The hub supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1+ BLE 5.1, and 915MHz RF communication, and features a built-in rechargeable battery with 10 hours of backup power. It also includes an 88db siren to deter intruders and is designed for indoor use.How do Wyze home monitoring sensors enhance home security?
Wyze home monitoring sensors provide comprehensive security by detecting motion, monitoring entry points, tracking climate conditions, and alerting you to leaks. These sensors integrate seamlessly with the Wyze Sense Hub, allowing you to customize automation and receive instant notifications through the Wyze app, ensuring your home stays safe and smart.What is the range of Wyze home monitoring sensors?
Most Wyze home monitoring sensors, including the motion sensor, leak sensor, climate sensor, and entry sensor v2, have a range of up to 500 feet from the Wyze Sense Hub. This wide coverage makes them suitable for homes of all sizes.How do I install Wyze home monitoring sensors?
Wyze sensors are designed for easy indoor installation. Most sensors come with adhesive backing for quick mounting, and some offer optional screws for added security. Simply follow the included quick start guide to connect each sensor to your Wyze Sense Hub and place them in your desired locations.What is the battery life of Wyze home monitoring sensors?
Wyze sensors are built for long-lasting performance. The Wyze Sense Motion Sensor and Entry Sensor v2 offer up to 18 months of battery life, while the Wyze Climate Sensor lasts up to 1.5 years on a CR2032 battery. The Wyze Sense Hub itself features a rechargeable battery with 10 hours of backup power.Can I monitor temperature and humidity with Wyze sensors?
Yes, the Wyze Climate Sensor allows you to monitor temperature and humidity levels in any room. You can track these conditions via the Wyze app and receive alerts if they fall outside your preferred range, helping you maintain optimal comfort and protect your home environment.How does the Wyze Sense Leak Sensor & Probe help prevent water damage?
The Wyze Sense Leak Sensor & Probe detects leaks or flooding and sends immediate alerts to your phone, allowing you to take action before water damage occurs. It is ideal for placement in basements, kitchens, bathrooms, or near appliances prone to leaks, and works with the Wyze Sense Hub for reliable monitoring.What is the Wyze Sense Keypad and what are its benefits?
The Wyze Sense Keypad allows you to arm or disarm your Wyze home security system remotely, without needing your phone. It features an emergency button to quickly alert first responders and is perfect for families or multi-user households. The keypad requires the Wyze Sense Hub and a Wyze Home Monitoring subscription.Do Wyze home monitoring sensors require a subscription?
Some Wyze sensors, such as the Wyze Sense Keypad, require a Wyze Home Monitoring subscription for full functionality. The subscription enables features like remote arming/disarming and emergency alerts, providing enhanced security and convenience.Are Wyze home monitoring sensors suitable for all homes?
Yes, Wyze home monitoring sensors are scalable and flexible, making them suitable for homes of all sizes. With support for up to 100 sensors per hub and a wide range of sensor types, you can customize your home security and automation to fit your unique needs.
