Best Wyze Sense Hub Sensors for Home Climate Monitoring
Best Home Monitoring Sensor Using Wyze Sense Hub for Climate Updates
When it comes to monitoring your home's climate efficiently, the Wyze Sense Hub paired with the Wyze Sense Climate Sensor offers a smart, reliable solution. Designed to provide real-time temperature and humidity updates, this combination ensures you stay informed about your indoor environment, helping you maintain comfort and protect your home from potential climate-related issues.
Wyze Sense Hub: The Central Brain of Your Home Monitoring System
The Wyze Sense Hub acts as the core controller for all Wyze Sense sensors, including climate and entry sensors. It connects each monitoring component and sends instant alerts to your smartphone, making it indispensable for a comprehensive home monitoring setup.
Key Features:
  • Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF communication.
  • Range: Up to 500 feet (152 meters) to sensors, allowing placement in distant rooms, basements, or attics.
  • Battery: Built-in rechargeable 3.7V, 2600mAh battery with 10 hours backup.
  • Siren: Loud 88db siren at 2 feet for immediate alerts.
  • Capacity: Supports up to 100 sensors simultaneously.
  • Design: Compact matte finish (4.5” x 4” x 1”) with a white base and grey speaker top, blending seamlessly into any home décor.
  • Indoor Use: Designed for indoor environments with operating temperature from 32°F to 104°F (0°C to 40°C).
The Wyze Sense Hub is the "brains behind the brawn," ensuring all your sensors work in harmony for a smarter, safer home.
Wyze Sense Climate Sensor: Precise Climate Monitoring Anywhere in Your Home
The Wyze Sense Climate Sensor is specifically designed to track temperature and humidity levels throughout your home. When paired with the Wyze Sense Hub, it provides continuous climate updates directly to your Wyze app.
Why Choose Wyze Sense Climate Sensor?
  • Accurate Monitoring: Measures temperature and humidity with precision.
  • Long Range: Communicates up to 500 feet from the hub, perfect for large homes or hard-to-reach areas.
  • Battery Life: Uses a CR2032 battery lasting up to 1.5 years.
  • Installation: Sleek, unobtrusive white design with peel-and-stick adhesive or optional screws for easy mounting.
  • Indoor Use Only: Operates reliably within 32°F to 104°F (0°C to 40°C) and humidity ≤ 85% at 86°F (30°C).
Place these sensors in any room, basement, or attic to get a comprehensive view of your home's climate conditions, helping you optimize heating, cooling, and ventilation. Wyze Sense Climate Sensor in Home Monitor your home's environment effortlessly with Wyze Sense Climate Sensor.
Wyze Sense Entry Sensor v2: Complement Your Climate Monitoring with Security
While primarily designed for security, the Wyze Sense Entry Sensor v2 works seamlessly with the Wyze Sense Hub to detect when doors or windows open or close. This sensor adds an extra layer of awareness to your home environment, alerting you to any unexpected access that could affect your home's climate or security.
Highlights:
  • Simple Detection: Alerts you instantly when doors or windows open or close.
  • Compatibility: Requires Wyze Sense Hub v2; does not function standalone.
  • Flexible Packs: Available in 1, 2, or 3 packs to cover multiple entry points.
Using entry sensors alongside climate sensors helps maintain your home's energy efficiency by notifying you if a door or window is left open, potentially impacting your indoor temperature and humidity.
Why Choose Wyze Sense Hub with Climate and Entry Sensors?
Combining the Wyze Sense Hub, Climate Sensor, and Entry Sensor v2 creates a powerful home monitoring system that not only tracks your home's climate but also enhances security and energy management. This integrated approach ensures you receive timely alerts and actionable insights to maintain a comfortable and safe living environment.
With Wyze Sense, you get a scalable, easy-to-install system that adapts to your home's needs, providing peace of mind and smarter climate control.
Summary of Key Specs
ProductCommunicationBattery LifeRangeDimensions (in)Use Case
Wyze Sense HubEthernet, WiFi, BLE, RFRechargeable, 10 hrs backup500 ft to sensors4.5 x 4 x 1Central hub for sensors
Wyze Sense Climate Sensor915MHz RFCR2032, 1.5 years500 ft1.4 x 1.4 x 0.5Temperature & humidity
Wyze Sense Entry Sensor v2915MHz RFBattery-powered500 ftCompact, small form factorDoor/window open detection
Enhance Your Home Monitoring Experience
By choosing Wyze Sense Hub with the Climate Sensor and Entry Sensor v2, you create a smart home ecosystem that keeps you informed about your home's environment and security status. Whether you want to monitor temperature fluctuations, humidity levels, or entry points, this system offers reliable performance and seamless integration through the Wyze app.
FeatureWyze Sense HubWyze Sense Climate SensorWyze Sense Entry Sensor v2
TypeHome Monitoring HubHome Monitoring SensorHome Monitoring Sensor
DescriptionConnects monitoring components and sends alerts. Core of Wyze Home Monitoring System.Tracks temperature and humidity. Requires Wyze Sense Hub.Detects when things open/close. Requires Wyze Sense Hub.
Standalone FunctionalityYesNoNo
CompatibilityWyze Home Monitoring SystemWyze Sense v2 onlyWyze Sense Hub v2 and Wyze Home Monitoring
RangeNot specified500 ftNot specified
DesignNot specifiedSleek, white, unobtrusiveNot specified
MountingNot specifiedSet on surface or peel-and-stick adhesiveNot specified
Pack Variants1 unit3 Pack1 Pack, 2 Pack, 3 Pack
Price$45.98$41.98 (3 Pack)$14.99 (1 Pack), $27.98 (2 Pack), $41.98 (3 Pack)
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
Additional NotesCore hub deviceWill NOT function standalone or with Wyze Sense v1Will NOT function standalone or with Wyze Sense v1
What is the Wyze Sense Hub and how does it work?The Wyze Sense Hub is the central controller for all Wyze Sense sensors, including climate and entry sensors. It connects to your home network via Ethernet, WiFi, Bluetooth, or RF communication and sends instant alerts to your smartphone through the Wyze app. The hub supports up to 100 sensors and features a built-in rechargeable battery with 10 hours of backup, making it essential for comprehensive home monitoring.
How does the Wyze Sense Climate Sensor monitor temperature and humidity?The Wyze Sense Climate Sensor is designed to provide accurate, real-time temperature and humidity updates throughout your home. When paired with the Wyze Sense Hub, it continuously tracks climate conditions and sends updates directly to your Wyze app, helping you maintain comfort and protect your home from climate-related issues.
What is the range of the Wyze Sense Hub and Climate Sensor?Both the Wyze Sense Hub and the Wyze Sense Climate Sensor have a communication range of up to 500 feet (152 meters), allowing you to place sensors in distant rooms, basements, or attics for comprehensive home coverage.
How long does the Wyze Sense Climate Sensor battery last?The Wyze Sense Climate Sensor uses a CR2032 battery that lasts up to 1.5 years, providing long-term, maintenance-free climate monitoring.
Can the Wyze Sense Hub and sensors be used outdoors?No, the Wyze Sense Hub and its sensors, including the Climate Sensor and Entry Sensor v2, are designed for indoor use only. They operate reliably within a temperature range of 32°F to 104°F (0°C to 40°C) and humidity up to 85% at 86°F (30°C).
What is the Wyze Sense Entry Sensor v2 and how does it enhance home security?The Wyze Sense Entry Sensor v2 detects when doors or windows open or close and sends instant alerts to your smartphone via the Wyze app. It works seamlessly with the Wyze Sense Hub to add an extra layer of security and helps maintain energy efficiency by notifying you if a door or window is left open.
How many sensors can the Wyze Sense Hub support?The Wyze Sense Hub can support up to 100 sensors simultaneously, allowing you to monitor multiple rooms and entry points throughout your home.
How do I install the Wyze Sense Climate Sensor?The Wyze Sense Climate Sensor features a sleek, unobtrusive design and can be easily installed using the included peel-and-stick adhesive or optional screws. Simply place the sensor in any room, basement, or attic to start monitoring temperature and humidity.
What are the key benefits of using Wyze Sense Hub with Climate and Entry Sensors?Combining the Wyze Sense Hub with Climate and Entry Sensors creates a powerful home monitoring system that tracks your home's climate, enhances security, and improves energy management. This integrated system provides timely alerts and actionable insights to help you maintain a comfortable, safe, and energy-efficient home.
Is the Wyze Sense Entry Sensor v2 compatible with all Wyze Hubs?The Wyze Sense Entry Sensor v2 requires the Wyze Sense Hub v2 for operation and does not function as a standalone device.
How does the Wyze Sense Hub connect to other sensors in my home?What is the maximum range of the Wyze Sense Climate Sensor from the hub?Do you have any deals, ongoing sales, discounts, or promotions?
