Dusk to Dawn Scheduling with Wyze Lamp Socket
Enhance your outdoor lighting with smart automation using the
Wyze Lamp Socket series. Designed to power your Wyze Cam v3 and v4 without the need for a plug, these lamp sockets bring convenience and security to your exterior lighting setup. One of the standout features is the
dusk to dawn scheduling, which automatically turns your lights on at sunset and off at sunrise, ensuring your home is well-lit during nighttime hours without manual intervention.
Wyze Lamp Socket (Original Model)
The original Wyze Lamp Socket is a compact, easy-to-install device that transforms your outdoor lighting into a smart system. It supports motion-activated lights and linkability with other Wyze devices, making it perfect for home security and smart home enthusiasts.
- Compatibility: Powers Wyze Cam v3 and v4
- Power Input: 120V, 60Hz
- Max Lamp Power: 30W
- Connectivity: 802.11 b/g/n (2.4GHz), Bluetooth
- Operating Temperature: -4°F to 120°F (-20°C to 50°C)
- Weather Resistance: Suitable for damp locations (not waterproof)
- Dimensions: 56.5mm x 56.5mm x 65mm
- USB Port: 1 Type-A (5W/5V1A)
- Certifications: ETL, CETL, UL
This lamp socket is ideal for powering your Wyze cameras while enabling smart lighting features like dusk to dawn scheduling and motion activation, enhancing your home's security and energy efficiency.
Wyze Lamp Socket v2 – Smarter and More Compatible
The
Wyze Lamp Socket v2 takes smart outdoor lighting to the next level. It supports a wider range of Wyze cameras, including Wyze Cam v3 Pro, Cam OG, and Pan v3, in addition to v3 and v4 models. This version is designed for improved compatibility and safer bulb usage.
- Compatibility: Wyze Cam v3, v3 Pro, v4, Cam OG, Pan v3
- Max Lamp Power: 20W (recommended CFL or LED bulbs only; no incandescent bulbs)
- Power Input: 120V~, 60Hz
- Dimensions & Weight: Same as original (56.5mm x 56.5mm x 65mm, 80g)
- Certifications: FCC, IC, UL496, CA65, TSCA, RoHS
- Warranty: 1 Year
With the v2 model, you get the same dusk to dawn scheduling and motion-activated lighting features, but with enhanced device compatibility and safety for your bulbs. This makes it a perfect choice for those looking to upgrade or expand their smart outdoor lighting system.
Wyze Lamp Socket Bundle – Complete Smart Lighting Kit
For those who want a comprehensive solution, the
Wyze Lamp Socket Bundle offers multiple lamp sockets paired with Wyze Cam v3 cameras. This bundle is perfect for securing larger outdoor areas like front and backyards with smart lighting and surveillance.
- Includes: 4x Wyze Lamp Sockets + 2x Wyze Cam v3
- Features: Dusk to dawn scheduling, motion-activated lights, linkability
- Use Case: Home security, smart home automation
This bundle simplifies installation and setup, providing everything you need to create a smart, automated outdoor lighting and security system.
Why Choose Wyze Lamp Sockets for Outdoor Lighting?
"Make your exterior lighting smart and effortless with Wyze Lamp Sockets. Enjoy automated dusk to dawn scheduling that saves energy and enhances security by ensuring your outdoor lights are on when you need them most."
- Energy Efficiency: Automatically turns lights on/off based on natural light conditions.
- Enhanced Security: Motion-activated lighting deters intruders and alerts you to activity.
- Easy Installation: Fits standard E26 sockets and powers Wyze cameras without extra plugs.
- Smart Connectivity: Control and schedule lighting from your phone via Wyze app.
- Durability: Designed for damp outdoor locations with reliable certifications.
Additional Smart Lighting Options
While the Wyze Lamp Socket series is perfect for dusk to dawn outdoor lighting, consider complementing your setup with other Wyze smart lighting products for indoor or accent lighting:
- Wyze Bulb Color: Offers 16 million colors with dimmable options, perfect for creating ambiance inside your home.
- Wyze Light Strip: Brilliant LED accent lighting for indoor use, ideal for kitchens, living rooms, or behind furniture.
By integrating Wyze Lamp Sockets with your outdoor lighting, you gain a smart, automated system that enhances your home's security and convenience. Whether you choose the original model, the advanced v2, or the complete bundle, dusk to dawn scheduling ensures your outdoor lights work seamlessly with your lifestyle.
What is dusk to dawn scheduling on Wyze Lamp Socket?
Dusk to dawn scheduling is a smart automation feature on Wyze Lamp Sockets that automatically turns your outdoor lights on at sunset and off at sunrise. This ensures your home is well-lit during nighttime hours without manual intervention, enhancing both security and energy efficiency.Which Wyze cameras are compatible with Wyze Lamp Socket and Wyze Lamp Socket v2?
The original Wyze Lamp Socket is compatible with Wyze Cam v3 and v4. Wyze Lamp Socket v2 supports a wider range of cameras, including Wyze Cam v3, v3 Pro, v4, Cam OG, and Pan v3.Can Wyze Lamp Socket power my Wyze Cam without a plug?
Yes, Wyze Lamp Sockets are designed to power your Wyze Cam v3 and v4 (and additional models with v2) directly through the lamp socket, eliminating the need for a separate plug.Are Wyze Lamp Sockets weatherproof for outdoor use?
Wyze Lamp Sockets are suitable for damp outdoor locations but are not fully waterproof. They are designed to withstand outdoor conditions within an operating temperature range of -4°F to 120°F (-20°C to 50°C).What types of bulbs can I use with Wyze Lamp Socket v2?
Wyze Lamp Socket v2 is recommended for use with CFL or LED bulbs only, with a maximum lamp power of 20W. Incandescent bulbs are not supported for safety reasons.How do I control and schedule my Wyze Lamp Socket?
You can control and schedule your Wyze Lamp Socket using the Wyze app on your smartphone. The app allows you to set up dusk to dawn scheduling, motion-activated lighting, and linkability with other Wyze devices.What is included in the Wyze Lamp Socket Bundle?
The Wyze Lamp Socket Bundle includes 4 Wyze Lamp Sockets and 2 Wyze Cam v3 cameras. This bundle is ideal for securing larger outdoor areas with smart lighting and surveillance.What certifications do Wyze Lamp Sockets have?
The original Wyze Lamp Socket is ETL, CETL, and UL certified. Wyze Lamp Socket v2 is certified by FCC, IC, UL496, CA65, TSCA, and RoHS, ensuring safety and reliability.Can I use Wyze Lamp Sockets for both indoor and outdoor lighting?
Yes, Wyze Lamp Sockets are suitable for both indoor and outdoor use, making them versatile for front yards, backyards, and other areas where smart lighting and security are needed.What are the benefits of using Wyze Lamp Sockets for outdoor lighting?
Wyze Lamp Sockets offer automated dusk to dawn scheduling, motion-activated lighting for enhanced security, easy installation in standard E26 sockets, smart connectivity via the Wyze app, and energy efficiency by only lighting when needed.
