Smart Outdoor Lighting: Power Wyze Cam via Lamp Socket & Motion
Smart Outdoor Lighting with Lamp Sockets Powering Wyze Cam
Enhance your outdoor security and lighting setup with Wyze’s innovative smart lamp sockets designed to power Wyze cameras seamlessly. These lamp sockets eliminate the need for traditional power outlets, allowing you to integrate your Wyze Cam with your existing outdoor lighting fixtures. With motion activation, multi-link integration, and dusk-to-dawn scheduling, your exterior lighting becomes smarter, more efficient, and highly customizable.
Cam v4 + Lamp Socket v2 Bundle: Power and Protection in One
The Cam v4 + Lamp Socket v2 Bundle is the perfect solution for those looking to power their Wyze Cam v4 directly from a lamp socket without the hassle of extra wiring or outlets.
Key Features:
  • Convenient Power Source: Powers Wyze Cam v4 directly through an E26 lamp socket.
  • Motion-Activated Lights: Automatically turns on lights when motion is detected, enhancing security.
  • Unlimited Linkability: Connect multiple devices for synchronized smart lighting.
  • Dusk to Dawn Scheduling: Lights operate automatically based on ambient light levels.
  • Compact and Durable: Made from polycarbonate and plastic, measuring 56.5mm x 56.5mm x 65mm, weighing only 80g.
  • Compatibility: Works with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Power Input: Standard 120V~, 60Hz with a max lamp power of 20W (recommended CFL or LED bulbs).
  • Connectivity: Supports 802.11 b/g/n Wi-Fi (2.4GHz) and Bluetooth.
  • Operating Temperature: Suitable for outdoor damp locations from -4°F to 120°F (-20°C to 50°C).
  • Warranty: 1-Year limited warranty.
Note: Incandescent bulbs are not recommended due to thermal limitations.
This bundle is ideal for homeowners wanting a sleek, integrated solution to power their Wyze Cam v4 while upgrading their outdoor lighting to smart, motion-activated illumination. Outdoor smart lighting with Wyze Cam
Pan v3 + Lamp Socket v2 Bundle: Smart Pan Cam Meets Smart Lighting
For those who prefer the panoramic view and motion tracking of the Wyze Cam Pan v3, the Pan v3 + Lamp Socket v2 Bundle offers the same smart lamp socket convenience.
Highlights:
  • Power Without Outlet: Powers Wyze Cam Pan v3 directly from an E26 lamp socket.
  • Motion-Activated Lighting: Lights up your outdoor space when movement is detected.
  • Multi-Link Integration: Easily link with other Wyze devices for a comprehensive smart home system.
  • Dusk to Dawn Functionality: Automatically adjusts lighting based on natural light.
  • Durable Build: Polycarbonate and plastic construction, compact size (56.5mm x 56.5mm x 65mm), and lightweight (80g).
  • Color Options: Available in Black and White to match your outdoor decor.
  • Connectivity & Compatibility: Supports Wi-Fi 2.4GHz and Bluetooth; compatible with multiple Wyze Cam models.
  • Operating Conditions: Suitable for damp outdoor locations, temperature range -4°F to 120°F.
  • Warranty: 1-Year coverage.
This bundle is perfect for users who want the dynamic features of the Pan v3 camera combined with smart, motion-triggered outdoor lighting.
Wyze Lamp Socket v2: The Latest in Smart Power Solutions
The Wyze Lamp Socket v2 is the newest iteration of Wyze’s smart lamp sockets, designed to power a wide range of Wyze cameras without needing a power outlet.
Why Choose Lamp Socket v2?
  • Universal Compatibility: Powers Wyze Cam v3, v3 Pro, v4, Cam OG, Pan v3, and Duo Cam Pan.
  • Smart Features: Motion-activated lights, linkability with other Wyze devices, and dusk-to-dawn scheduling.
  • Compact and Lightweight: Same dimensions and weight as previous models for easy installation.
  • Safe and Certified: Certified by FCC, IC, UL496, CA65, TSCA, and RoHS.
  • Power Specs: 120V~, 60Hz input with max lamp power of 20W.
  • Connectivity: Supports 2.4GHz Wi-Fi and Bluetooth.
  • Durability: Suitable for damp locations but not fully weatherproof.
This lamp socket is ideal for upgrading your existing outdoor lighting fixtures to smart, camera-powered lighting without rewiring or additional outlets.
Why Choose Wyze Smart Lamp Sockets for Outdoor Lighting?
"Make your exterior lighting smarter and more secure with Wyze’s lamp sockets that power your cameras directly from lamp fixtures, enabling motion-activated lighting and seamless multi-device integration."
  • Easy Installation: Simply screw the lamp socket into your existing E26 fixture and connect your Wyze Cam.
  • Energy Efficient: Supports LED and CFL bulbs under 20W, reducing energy consumption.
  • Smart Home Integration: Works with Wyze app for scheduling, notifications, and device linking.
  • Enhanced Security: Motion-activated lights deter intruders while providing clear video footage.
  • Flexible Compatibility: Supports multiple Wyze Cam models, making it a versatile choice for any smart home setup.
Additional Smart Lighting Options: Wyze Bulb Color
Complement your smart outdoor lighting with the Wyze Bulb Color, a 16 million color smart bulb that adds ambiance and style to your home lighting.
Features:
  • Vibrant Colors: Choose from 16 million colors to set the perfect mood.
  • Dimmable: Adjust brightness to suit any occasion.
  • Smart Control: Compatible with Alexa, Google Assistant, and IFTTT.
  • Energy Efficient: 12 watts with 1100 lumens brightness.
  • Suitable for Damp Locations: Perfect for outdoor covered areas.
  • Long Life: 25,000 hours of use.
Use Wyze Bulb Color in your outdoor fixtures alongside the lamp sockets to create a fully customizable smart lighting environment. Wyze Bulb Color lifestyle
Conclusion
Wyze’s smart lamp sockets and camera bundles provide a seamless way to power your Wyze cameras through outdoor lamp sockets, eliminating the need for extra outlets and wiring. With motion-activated lighting, multi-link integration, and dusk-to-dawn scheduling, these products transform your outdoor lighting into a smart, secure, and energy-efficient system. Whether you choose the Cam v4 + Lamp Socket v2 Bundle, the Pan v3 + Lamp Socket v2 Bundle, or the standalone Lamp Socket v2, you’re investing in a smarter, safer home.
FeatureCam v4 + Lamp Socket v2 BundlePan v3 + Lamp Socket v2 BundleWyze Lamp Socket v2
Included DevicesWyze Cam v4 + Lamp Socket v2Wyze Cam Pan v3 + Lamp Socket v2Lamp Socket v2 only
Compatible CamerasWyze Cam v3/v3 Pro/v4, Cam OG/OG Tele, Pan v3Wyze Cam v3/v3 Pro/v4, Cam OG/OG Tele, Pan v3Wyze Cam v3/v3 Pro/v4, Cam OG, Pan v3
Price$49.96$53.96$16.98
Color VariantsBlack, Grey, WhiteBlack, WhiteWhite
Power SourcePowered via Lamp Socket v2 (no outlet needed)Powered via Lamp Socket v2 (no outlet needed)Powers cameras via lamp socket (no outlet)
Max Lamp Power20W (recommend CFL or LED under 20W)20W (recommend CFL or LED under 20W)20W max lamp power, CFL or LED recommended
Socket Connector TypeE26E26E26
ConnectivityN/A (camera connectivity varies)N/A (camera connectivity varies)802.11 b/g/n 2.4GHz Wi-Fi, Bluetooth
Weather ResistanceNot weatherproof, suitable for damp locationsNot weatherproof, suitable for damp locationsNot weatherproof, suitable for damp locations
InstallationAs easy as screwing in a lightbulbAs easy as screwing in a lightbulbAs easy as screwing in a lightbulb
FeaturesSmart lighting, motion-activated lights, dusk to dawn automation, link multiple socketsSmart lighting, motion-activated lights, dusk to dawn automation, link multiple socketsPowers Wyze cams without outlet, smart lighting features
Warranty30-day hassle-free returns30-day hassle-free returns1-Year warranty
What is the Wyze Lamp Socket v2 and how does it work?The Wyze Lamp Socket v2 is a smart lamp socket designed to power Wyze cameras directly from an E26 lamp socket, eliminating the need for traditional power outlets. It enables motion-activated lighting, dusk-to-dawn scheduling, and multi-device integration, making your outdoor lighting smarter and more efficient.
Which Wyze cameras are compatible with the Lamp Socket v2?The Wyze Lamp Socket v2 is compatible with Wyze Cam v3, v3 Pro, v4, Cam OG, Pan v3, and Duo Cam Pan, allowing you to power a wide range of Wyze cameras directly from your outdoor lighting fixtures.
Can I use incandescent bulbs with the Wyze Lamp Socket v2?Incandescent bulbs are not recommended for use with the Wyze Lamp Socket v2 due to thermal limitations. It is best to use LED or CFL bulbs with a maximum power of 20W for optimal performance and safety.
Is the Wyze Lamp Socket v2 suitable for outdoor use?Yes, the Wyze Lamp Socket v2 is designed for outdoor use in damp locations and can operate in temperatures ranging from -4°F to 120°F (-20°C to 50°C). However, it is not fully weatherproof and should be installed in covered outdoor fixtures.
What are the benefits of using Wyze smart lamp sockets for outdoor lighting?Wyze smart lamp sockets offer easy installation, energy efficiency, motion-activated lighting for enhanced security, dusk-to-dawn scheduling, and seamless integration with the Wyze app for smart home control. They also support multiple Wyze Cam models, making them a versatile choice for any smart home setup.
How do the Cam v4 + Lamp Socket v2 and Pan v3 + Lamp Socket v2 bundles differ?The Cam v4 + Lamp Socket v2 Bundle is designed for users who want to power their Wyze Cam v4 directly from a lamp socket, while the Pan v3 + Lamp Socket v2 Bundle is tailored for those who prefer the panoramic view and motion tracking of the Wyze Cam Pan v3. Both bundles offer motion-activated lighting, multi-link integration, and dusk-to-dawn functionality.
What smart features are included with the Wyze Lamp Socket v2?The Wyze Lamp Socket v2 includes motion-activated lighting, dusk-to-dawn scheduling, multi-link integration with other Wyze devices, and compatibility with the Wyze app for scheduling and notifications.
What is the power input and maximum lamp power supported by the Wyze Lamp Socket v2?The Wyze Lamp Socket v2 supports a standard power input of 120V~, 60Hz, and a maximum lamp power of 20W. It is recommended to use LED or CFL bulbs for best results.
Does the Wyze Lamp Socket v2 come with a warranty?Yes, the Wyze Lamp Socket v2 comes with a 1-year limited warranty, providing peace of mind for your smart outdoor lighting investment.
Can I link multiple Wyze Lamp Sockets together for synchronized lighting?Yes, the Wyze Lamp Socket v2 supports unlimited linkability, allowing you to connect multiple devices for synchronized smart lighting across your outdoor space.
What are the connectivity options for the Wyze Lamp Socket v2?The Wyze Lamp Socket v2 supports 802.11 b/g/n Wi-Fi (2.4GHz) and Bluetooth, ensuring reliable connectivity for smart home integration and remote control via the Wyze app.
What is the Wyze Bulb Color and how can it complement my outdoor lighting?The Wyze Bulb Color is a smart bulb offering 16 million colors, dimmable brightness, and compatibility with Alexa, Google Assistant, and IFTTT. It is energy efficient, suitable for damp locations, and can be used alongside Wyze lamp sockets to create a fully customizable smart lighting environment.
How easy is it to install the Wyze Lamp Socket v2?Installation is simple—just screw the Wyze Lamp Socket v2 into your existing E26 fixture and connect your compatible Wyze Cam. No additional wiring or power outlets are required.
Can you explain how the motion-activated lights work with the Wyze Cam?What is the installation process for the Wyze Lamp Socket v2?Do you have any ongoing sales or discounts for the Cam v4 + Lamp Socket v2 Bundle?
