Wireless Lamp Socket Bundles for Powering Smart Security Cameras
Enhance your home security setup with the convenience of wireless lamp socket bundles designed specifically to power smart security cameras. These innovative lamp sockets eliminate the need for traditional power outlets, making it easier than ever to install and operate your Wyze security cameras outdoors or in hard-to-reach places. Whether you want to upgrade your existing cameras or set up a new smart security system, these lamp socket bundles provide a seamless, smart lighting and power solution.
Wyze Lamp Socket: Power Your Wyze Cam v3 and v4 Wirelessly
The original
Wyze Lamp Socket is designed to make your exterior lighting smart by powering Wyze Cam v3 and v4 without the need for a plug. This compact and efficient device fits standard E26 sockets and supports up to 30W lamp power, making it perfect for powering your security cameras while also enabling motion-activated lighting.
Key Features:
- Convenient Power Supply: Powers Wyze Cam v3 and v4 directly from your lamp socket.
- Smart Lighting: Includes motion-activated lights and dusk-to-dawn scheduling for energy efficiency.
- Connectivity: Supports 2.4GHz Wi-Fi and Bluetooth for easy integration with your smart home.
- Compact Design: Measures 56.5mm x 56.5mm x 65mm and weighs only 80 grams.
- Compatibility: Works with Android 7.0+ and iOS 12.0+ devices.
- Safety Certifications: ETL, CETL, and UL certified for peace of mind.
This lamp socket is ideal for damp locations but is not weatherproof, so it’s best suited for covered outdoor areas like porches or garages.
Wyze Lamp Socket Bundle: Complete Kit for Multiple Cameras
For those looking to power multiple cameras, the
Wyze Lamp Socket Bundle offers a convenient package with four lamp sockets and two Wyze Cam v3 cameras. This bundle is perfect for securing larger areas such as front and backyards without the hassle of running power cords.
Bundle Highlights:
- Multiple Device Support: Powers multiple Wyze Cam v3 cameras simultaneously.
- Smart Home Integration: Motion-activated lights and linkability enhance your home security.
- Indoor and Outdoor Use: Suitable for indoor and covered outdoor locations.
- Easy Installation: Plug-in design simplifies setup without additional wiring.
This bundle is a cost-effective solution for homeowners wanting to expand their smart security camera network with wireless power options.
Wyze Lamp Socket v2: The Latest in Smart Power Solutions
The
Wyze Lamp Socket v2 takes smart exterior lighting to the next level by supporting a wider range of Wyze cameras, including Wyze Cam v3, v3 Pro, v4, Cam OG, and Pan v3. It offers the same wireless power convenience with enhanced compatibility.
Features of Lamp Socket v2:
- Broader Camera Compatibility: Supports multiple Wyze camera models.
- Compact and Lightweight: Same dimensions and weight as the original model.
- Power Input: 120V~, 60Hz with a max lamp power of 20W.
- Connectivity: 2.4GHz Wi-Fi and Bluetooth for seamless smart home integration.
- Certifications: FCC, IC, UL496, CA65, TSCA, and RoHS certified.
- Usage Note: Recommended for CFL or LED bulbs under 20W due to thermal limitations.
This version is perfect for users who want a versatile lamp socket that can power various Wyze cameras without needing a power outlet.
Wyze Cam v4: The Ideal Smart Security Camera for Your Wireless Lamp Socket
Pair your wireless lamp socket with the
Wyze Cam v4 for unmatched home security. This camera offers crystal-clear 2.5K QHD video resolution and enhanced color night vision, making it perfect for monitoring your property day and night.
Wyze Cam v4 Highlights:
- High-Resolution Video: 2.5K QHD (2560x1440) with 8x digital zoom.
- Advanced Night Vision: 4 IR LEDs plus 2 white spotlight LEDs for color night vision.
- Smart Features: Motion-activated spotlight, built-in siren, and two-way talk.
- Connectivity: Supports Wi-Fi 6 and Bluetooth 5.2.
- Weather Resistance: Rated IP65 for outdoor durability.
- Mounting Options: Stand, wall, ceiling, or magnetic mounts for flexible installation.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
- Storage Options: Local microSD card support up to 512GB and cloud storage with subscription.
This camera is the perfect companion for the Wyze Lamp Socket, providing reliable power and superior security features.
Why Choose Wireless Lamp Socket Bundles for Smart Security Cameras?
Wireless lamp socket bundles offer a hassle-free way to power your smart security cameras without the need for additional wiring or power outlets. They combine smart lighting with camera power, enhancing security and convenience.
- Easy Installation: No need to run new power lines or outlets.
- Smart Lighting Integration: Motion-activated and scheduled lighting improves security and energy efficiency.
- Versatile Compatibility: Supports multiple Wyze camera models.
- Cost-Effective: Bundles provide savings when purchasing multiple units.
Enhance your home security with wireless lamp sockets powering smart cameras.
Conclusion
For anyone looking to power smart security cameras wirelessly, the Wyze Lamp Socket series and bundles paired with the Wyze Cam v4 offer a powerful, flexible, and smart solution. Whether securing a small porch or an entire yard, these products provide reliable power, smart lighting features, and seamless integration with your smart home ecosystem.
Upgrade your home security today with these innovative wireless lamp socket bundles and enjoy peace of mind with smart, hassle-free camera power.
What is a wireless lamp socket bundle for smart security cameras?
A wireless lamp socket bundle is a convenient solution designed to power smart security cameras, such as Wyze Cam v3 and v4, directly from your existing lamp sockets. This eliminates the need for traditional power outlets or additional wiring, making it easier to install cameras in outdoor or hard-to-reach locations.How does the Wyze Lamp Socket power my Wyze Cam v3 or v4?
The Wyze Lamp Socket fits into a standard E26 lamp socket and provides direct power to your Wyze Cam v3 or v4. It also enables smart lighting features like motion-activated lights and dusk-to-dawn scheduling, all while supporting 2.4GHz Wi-Fi and Bluetooth connectivity for seamless smart home integration.What are the key features of the Wyze Lamp Socket?
Key features of the Wyze Lamp Socket include convenient power supply for Wyze Cam v3 and v4, motion-activated and scheduled smart lighting, 2.4GHz Wi-Fi and Bluetooth support, compact design, compatibility with Android 7.0+ and iOS 12.0+ devices, and safety certifications such as ETL, CETL, and UL.Is the Wyze Lamp Socket weatherproof?
The Wyze Lamp Socket is ideal for damp locations but is not fully weatherproof. It is best suited for covered outdoor areas like porches or garages to ensure safe and reliable operation.What is included in the Wyze Lamp Socket Bundle?
The Wyze Lamp Socket Bundle includes four lamp sockets and two Wyze Cam v3 cameras, allowing you to power multiple cameras simultaneously. This bundle is perfect for securing larger areas such as front and backyards without the hassle of running power cords.What are the benefits of using a Wyze Lamp Socket Bundle?
Benefits of using a Wyze Lamp Socket Bundle include easy installation without additional wiring, the ability to power multiple cameras, smart lighting integration with motion-activated lights, and cost savings when purchasing multiple units together.What improvements does the Wyze Lamp Socket v2 offer?
The Wyze Lamp Socket v2 offers broader camera compatibility, supporting Wyze Cam v3, v3 Pro, v4, Cam OG, and Pan v3. It maintains a compact and lightweight design, supports 2.4GHz Wi-Fi and Bluetooth, and is certified by FCC, IC, UL496, CA65, TSCA, and RoHS. It is recommended for use with CFL or LED bulbs under 20W.Which Wyze cameras are compatible with the Wyze Lamp Socket v2?
The Wyze Lamp Socket v2 is compatible with Wyze Cam v3, v3 Pro, v4, Cam OG, and Pan v3, making it a versatile power solution for various Wyze camera models.What are the main features of the Wyze Cam v4 when used with a wireless lamp socket?
The Wyze Cam v4 offers 2.5K QHD video resolution, enhanced color night vision, motion-activated spotlight, built-in siren, two-way talk, Wi-Fi 6 and Bluetooth 5.2 connectivity, IP65 weather resistance, flexible mounting options, and compatibility with Alexa, Google Assistant, and IFTTT. It also supports local microSD card storage up to 512GB and cloud storage with a subscription.Can I use the Wyze Lamp Socket for both indoor and outdoor security cameras?
Yes, the Wyze Lamp Socket and its bundles are suitable for both indoor and covered outdoor locations. However, for outdoor use, it should be installed in areas protected from direct exposure to weather, such as porches or garages.Why should I choose a wireless lamp socket bundle for my smart security cameras?
Wireless lamp socket bundles offer hassle-free installation, eliminate the need for new power lines or outlets, integrate smart lighting features for enhanced security and energy efficiency, support multiple Wyze camera models, and provide cost-effective solutions for expanding your home security system.Are there any bulb requirements for the Wyze Lamp Socket v2?
Yes, the Wyze Lamp Socket v2 is recommended for use with CFL or LED bulbs under 20W due to thermal limitations. This ensures safe and efficient operation of both the lamp socket and your connected security cameras.
