Wyze Bulb Color: Smart Outdoor Lighting for Vibrant Spaces
Wyze Bulb Color for Outdoor Use: Vibrant Smart Lighting Solutions
When it comes to smart lighting that can brighten your outdoor spaces with vivid colors and reliable performance, the Wyze Bulb Color and Wyze Bulb Color BR30 stand out as top choices. Designed to deliver 16 million colors and tunable white light, these bulbs are perfect for creating the ideal ambiance in your garden, patio, or porch. Plus, they are suitable for damp locations, making them a smart option for outdoor use where moisture might be a concern.
Experience the power of smart lighting that adapts to your lifestyle and outdoor environment with Wyze’s innovative bulbs.
Outdoor patio with colorful smart lighting Colorful smart lighting enhancing outdoor living spaces
Wyze Bulb Color: Ultimate Versatility and Brightness
The Wyze Bulb Color is a smart bulb that offers:
  • 16 million colors to choose from, allowing you to customize your outdoor lighting to any mood or occasion.
  • Extra bright output of up to 1100 lumens, ensuring your outdoor areas are well-lit.
  • Tunable white light ranging from 1800K to 6500K, perfect for both warm and cool lighting needs.
  • Dimmable feature (though it prefers to shine bright!).
  • Suitable for damp locations, making it safe for covered outdoor areas like porches and patios.
  • Long life expectancy of 25,000 hours.
  • Connectivity via 2.4GHz Wi-Fi and Bluetooth, compatible with Android 9.0+ and iOS 15.0+.
  • Smart integrations with Alexa, Google Assistant, and IFTTT for voice and automation control.
  • Operating temperature range from -4°F to 104°F, ideal for most outdoor climates.
This bulb’s A19 shape and E26 base make it compatible with most standard outdoor fixtures that are not fully enclosed.
Wyze Bulb Color BR30: Perfect for Recessed Outdoor Fixtures
If your outdoor lighting setup includes recessed fixtures, the Wyze Bulb Color BR30 is designed specifically for you:
  • Works seamlessly in recessed lighting fixtures with an E26 base.
  • Offers 16 million ultra-accurate colors and a wide lumen range from 30 to 950 lumens.
  • Dimmable and color-changing smart bulb with custom lighting scenes.
  • Features like voice control, sleep routines, vacation mode, and music mode enhance your smart home experience.
  • Rated for damp locations, suitable for covered outdoor areas.
  • Operating temperature range from -4°F to 104°F.
  • Life expectancy of 25,000 hours.
  • Connectivity includes 2.4GHz Wi-Fi and Bluetooth.
  • Not compatible with dimmer switches, so use in standard fixtures.
This bulb’s BR30 shape is ideal for outdoor recessed lighting, providing a broad beam angle and excellent color rendering (CRI 90+).
Wyze Bulb White: Reliable Outdoor White Lighting Option
For those who prefer classic white lighting outdoors, the Wyze Bulb White is a dependable choice:
  • Brightness range from 30 to 800 lumens with dimmable controls.
  • Color temperature options of 2700K (warm white) and 6500K (cool white).
  • Suitable for damp locations, perfect for porches, patios, and other covered outdoor areas.
  • Long lifespan of 25,000 hours.
  • Compatible with Alexa, Google Assistant, and IFTTT.
  • Connectivity via 2.4GHz Wi-Fi and Bluetooth.
  • Operating temperature from -4°F to 104°F.
  • A19 bulb shape with E26 base fits most outdoor fixtures.
This bulb is ideal for those who want simple, bright, and energy-efficient outdoor lighting without the color-changing features. Outdoor porch with warm white smart lighting Warm white smart lighting creating cozy outdoor ambiance
Outdoor Lighting Accessories: Enhance Your Setup
To make your outdoor smart lighting even smarter, consider the Wyze Lamp Socket v2 bundles that allow you to power Wyze cameras and bulbs without needing an outlet nearby. These sockets are suitable for damp locations and support E26 base bulbs up to 20W, perfect for integrating your Wyze Bulb Color or White bulbs into your outdoor lighting system.
  • Compatible with Wyze Cam v3, v4, and Pan v3.
  • Features motion-activated lights and dusk-to-dawn scheduling.
  • Weather-resistant for damp environments (not fully waterproof).
  • Easy to install and control via the Wyze app.
Why Choose Wyze Bulbs for Outdoor Use?
Wyze smart bulbs combine vibrant color options, reliable brightness, and smart home integration with outdoor durability. Their suitability for damp locations and wide operating temperature range make them excellent choices for enhancing your outdoor living spaces with customizable lighting.
Whether you want to set a festive mood with millions of colors or keep it simple with warm white light, Wyze offers smart bulbs that fit your outdoor lighting needs perfectly.
Summary of Wyze Outdoor-Compatible Bulbs
ProductColor OptionsBrightness (Lumens)ShapeBaseDamp Location RatedConnectivitySpecial Features
Wyze Bulb Color16 million colors30 - 1100A19E26YesWi-Fi (2.4GHz), BTDimmable, Voice control, CRI 90+
Wyze Bulb Color BR3016 million colors30 - 950BR30E26YesWi-Fi (2.4GHz), BTRecessed fixtures, Music mode
Wyze Bulb WhiteWhite (2700K-6500K)30 - 800A19E26YesWi-Fi (2.4GHz), BTDimmable, Voice control
Enhance your outdoor spaces with Wyze smart bulbs that offer brilliant colors, smart features, and outdoor durability — all controlled effortlessly from your smartphone or voice assistant.
FeatureWyze Bulb ColorWyze Bulb Color BR30Wyze Bulb White
TypeSmart Lighting (A19 shape)Connected Home (BR30 shape)Connected Home (A19 shape)
Base TypeE26E26E26
ShapeA19BR30A19
Pack Variants2 Pack, 4 Pack, 6 Pack2-Pack, 4-Pack2 Pack, 4 Pack, 6 Pack
Price Range (USD)$26.26 - $64.98$27.98 - $49.98$23.99 - $59.99
Lumen Output30 lm (dim) - 1100 lm (bright)30 lm (dim) - 950 lm (bright)30 lm - 800 lm
Wattage Equivalent75W75W9.5W
Color Options16 million colors16 million colorsWhite light only
Color Temperature RangeTunable white (1800K - 6500K approx.)Tunable white (Sun Match feature)2700K - 6500K
CRI Rating90+90+90+
DimmableYes (but "takes offense" humorously)Yes (not for use with dimmer switches)Yes
Special FeaturesCustom presets, notifications, sleep routines, music mode, voice control, vacation mode, groupingCustom scenes, Sun Match, notifications, sleep routines, music mode, voice control, vacation mode, groupingDimmable, bright white light, voice control, Alexa/Google/IFTTT integration
ConnectivityWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, Bluetooth
Phone CompatibilityAndroid 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+
Suitable for Damp LocationsYesNot specifiedYes
Life Expectancy25,000 hours (implied)Not specified25,000 hours
Are Wyze Bulb Color and Wyze Bulb Color BR30 suitable for outdoor use?Yes, both Wyze Bulb Color and Wyze Bulb Color BR30 are rated for damp locations, making them suitable for covered outdoor areas such as porches, patios, and gardens. However, they should not be used in fully exposed or waterproof-required environments.
What are the main differences between Wyze Bulb Color and Wyze Bulb Color BR30 for outdoor lighting?Wyze Bulb Color features an A19 shape and is ideal for most standard outdoor fixtures, while Wyze Bulb Color BR30 is designed specifically for recessed lighting fixtures. Both offer 16 million colors, but the BR30 provides a broad beam angle and is perfect for outdoor recessed lighting setups.
Can Wyze smart bulbs be used in fully enclosed outdoor fixtures?Wyze Bulb Color and Wyze Bulb White are not recommended for use in fully enclosed fixtures. They are best suited for covered outdoor areas with open or partially open fixtures to ensure proper heat dissipation and performance.
What is the brightness range of Wyze outdoor-compatible smart bulbs?Wyze Bulb Color offers a brightness range from 30 to 1100 lumens, Wyze Bulb Color BR30 ranges from 30 to 950 lumens, and Wyze Bulb White provides 30 to 800 lumens. All bulbs are dimmable for customizable outdoor lighting.
Do Wyze smart bulbs support voice control and smart home integration?Yes, Wyze Bulb Color, Wyze Bulb Color BR30, and Wyze Bulb White all support voice control and smart home integration with Alexa, Google Assistant, and IFTTT, allowing you to control your outdoor lighting with ease.
What is the lifespan of Wyze smart bulbs used outdoors?All Wyze outdoor-compatible smart bulbs, including Wyze Bulb Color, Wyze Bulb Color BR30, and Wyze Bulb White, have a long life expectancy of up to 25,000 hours.
What color options are available for Wyze outdoor smart bulbs?Wyze Bulb Color and Wyze Bulb Color BR30 offer 16 million color options and tunable white light (1800K to 6500K), while Wyze Bulb White provides adjustable white light from warm (2700K) to cool (6500K) temperatures.
Can Wyze smart bulbs operate in extreme outdoor temperatures?Yes, Wyze smart bulbs are designed to operate in temperatures ranging from -4°F to 104°F, making them suitable for most outdoor climates.
Are Wyze smart bulbs compatible with outdoor accessories like lamp sockets?Yes, Wyze Lamp Socket v2 is compatible with Wyze Bulb Color and Wyze Bulb White, allowing you to power bulbs and Wyze cameras in outdoor settings without needing a nearby outlet. The socket is rated for damp locations and supports E26 base bulbs up to 20W.
Can I use Wyze Bulb White for outdoor lighting if I only want white light?Absolutely. Wyze Bulb White is a reliable choice for outdoor white lighting, offering adjustable brightness and color temperature, and is rated for damp locations such as porches and patios.
What connectivity options do Wyze outdoor smart bulbs offer?Wyze outdoor smart bulbs connect via 2.4GHz Wi-Fi and Bluetooth, and are compatible with Android 9.0+ and iOS 15.0+ devices for easy control through the Wyze app.
Are Wyze Bulb Color BR30 bulbs compatible with dimmer switches?No, Wyze Bulb Color BR30 bulbs are not compatible with dimmer switches. They should be used in standard fixtures for optimal performance.
What are the special features of the Wyze Bulb Color?Can the Wyze Bulb Color be used in fully enclosed fixtures?Are there any ongoing sales or discounts for Wyze products?
