Wyze Lamp Socket: Smart Scheduling for Sunset and Sunrise
If you're looking to automate your exterior lighting with smart scheduling based on sunset and sunrise times, the
Wyze Lamp Socket family offers powerful solutions. These devices not only power your Wyze cameras but also enable convenient dusk-to-dawn scheduling, motion-activated lighting, and seamless integration with the Wyze app automations.
Explore Wyze Lamp Socket Models for Smart Lighting Automation
Wyze Lamp Socket (Original Model)
The original
Wyze Lamp Socket is designed to make your exterior lighting smart and efficient. It powers Wyze Cam v3 and v4 without needing a plug, making it perfect for outdoor lighting setups.
- Dusk to Dawn Scheduling: Automatically turns your lights on at sunset and off at sunrise, customizable with offsets.
- Motion-Activated Lights: Lights up your space when motion is detected, enhancing security.
- Connectivity: Supports 2.4GHz Wi-Fi and Bluetooth for reliable control.
- Compatibility: Works with Android 7.0+ and iOS 12.0+ devices.
- Power Specs: Supports up to 30W lamp power with an E26 socket connector.
- Weather Suitability: Suitable for damp locations but not fully waterproof.
- Dimensions & Weight: Compact 56.5mm x 56.5mm x 65mm, weighing 80g.
This lamp socket is ideal for powering your Wyze Cam while automating your outdoor lighting schedule effortlessly.
Wyze Lamp Socket v2: Enhanced Compatibility and Features
The
Wyze Lamp Socket v2 takes smart exterior lighting to the next level with broader camera compatibility and improved features.
- Device Compatibility: Powers Wyze Cam v3, v3 Pro, v4, Cam OG, and Pan v3.
- Dusk to Dawn Scheduling: Schedule your lights to turn on/off automatically at sunset and sunrise.
- Thermal Limitations: Supports LED or CFL bulbs under 20W; incandescent bulbs are not recommended.
- Connectivity: 802.11 b/g/n Wi-Fi (2.4GHz) and Bluetooth.
- Certifications: FCC, IC, UL496, CA65, TSCA, RoHS.
- Warranty: 1-year limited warranty.
- Compact Design: Same size and weight as the original model for easy installation.
This version is perfect if you want to power multiple Wyze camera models and enjoy smart scheduling features with your lighting.
Wyze Cam v4 + Lamp Socket v2 Bundle: Smart Security and Lighting Combo
For a complete smart home upgrade, the
Wyze Cam v4 + Lamp Socket v2 Bundle offers a powerful duo that combines smart security with automated lighting.
- Convenient Power: Powers Wyze Cam v4 without a plug.
- Motion-Activated Lights: Lights turn on automatically when motion is detected.
- Dusk to Dawn Scheduling: Lights can be scheduled to turn on at sunset and off at sunrise.
- Linkability: Connect multiple devices for synchronized automation.
- Color Options: Available in Black, Grey, and White.
- Connectivity & Compatibility: Same as Lamp Socket v2 with broad phone and camera support.
This bundle is ideal for those who want to secure their home with a smart camera while automating outdoor lighting schedules effortlessly.
Automate Your Wyze Lamp Socket with Sunset and Sunrise Scheduling
Using the Wyze app, you can easily create automations to schedule your lamp socket to turn on at sunset and off at sunrise, enhancing convenience and energy efficiency.
"To create a schedule to turn on your Wyze Lamp Socket every day at sunset:
- Open the Wyze app and go to Automation > Schedule.
- Name your schedule (e.g., 'Turn on outside lamp').
- Add an action to turn on the lamp socket.
- Set the start time to Sunset and confirm your location.
- Optionally, adjust the time offset before or after sunset.
- Save your schedule."
You can also create device triggers, shortcuts, and location-based automations to control your lamp socket with ease.
Wyze Bulb White: Perfect Companion for Your Lamp Socket
Pair your Wyze Lamp Socket with the
Wyze Bulb White for customizable lighting that complements your smart schedule.
- Dimmable Controls: Adjust brightness to suit your mood or time of day.
- Color Temperature: Choose between warm 2700K and cool 6500K light.
- Long Life: 25,000 hours of usage.
- Connectivity: Works with Alexa, Google Assistant, and IFTTT.
- Weather Compatibility: Suitable for damp locations.
- Energy Efficient: Uses only 9.5 watts with a wide 230° beam angle.
This smart bulb enhances your dusk-to-dawn lighting experience, making your home safer and more inviting.
Why Choose Wyze Lamp Socket for Sunset and Sunrise Scheduling?
- Easy Setup: Plug into any standard E26 socket and connect via the Wyze app.
- Smart Automations: Schedule lighting based on natural light cycles or motion detection.
- Energy Savings: Lights only operate when needed, reducing electricity use.
- Versatile Compatibility: Works with multiple Wyze cameras and smart bulbs.
- Reliable Performance: Certified and tested for safe indoor and damp location use.
Summary
The Wyze Lamp Socket lineup, including the original model, v2, and bundled options with Wyze cameras, offers a smart, convenient way to automate your exterior lighting with sunset and sunrise schedules. Combined with the Wyze Bulb White, you get a complete smart lighting solution that enhances home security, convenience, and energy efficiency.
Start automating your outdoor lighting today with Wyze and enjoy the benefits of smart dusk-to-dawn scheduling.
What is the Wyze Lamp Socket and how does it work?
The Wyze Lamp Socket is a smart device that automates your exterior lighting by allowing you to schedule lights to turn on at sunset and off at sunrise. It also powers Wyze cameras directly from your light socket, supports motion-activated lighting, and integrates seamlessly with the Wyze app for easy automation and control.What are the main differences between Wyze Lamp Socket (Original) and Wyze Lamp Socket v2?
The original Wyze Lamp Socket is designed to power Wyze Cam v3 and v4, while the Wyze Lamp Socket v2 offers broader compatibility, supporting Wyze Cam v3, v3 Pro, v4, Cam OG, and Pan v3. The v2 model also features enhanced certifications, a 1-year limited warranty, and supports only LED or CFL bulbs under 20W (incandescent bulbs are not recommended). Both models offer dusk-to-dawn scheduling and motion-activated lighting.How do I set up sunset and sunrise scheduling with Wyze Lamp Socket?
To set up sunset and sunrise scheduling, open the Wyze app and go to Automation > Schedule. Name your schedule, add an action to turn on the lamp socket, set the start time to Sunset, confirm your location, and optionally adjust the time offset. Save your schedule to automate your lighting based on natural light cycles.Can I use Wyze Lamp Socket outdoors?
Yes, Wyze Lamp Socket is suitable for damp locations, making it ideal for outdoor use. However, it is not fully waterproof, so it should be installed in areas protected from direct exposure to water.Which Wyze cameras are compatible with Wyze Lamp Socket v2?
Wyze Lamp Socket v2 is compatible with Wyze Cam v3, v3 Pro, v4, Cam OG, and Pan v3, allowing you to power these cameras directly from your light socket.What types of bulbs can I use with Wyze Lamp Socket v2?
Wyze Lamp Socket v2 supports LED or CFL bulbs under 20W. Incandescent bulbs are not recommended due to thermal limitations.Does Wyze Lamp Socket support motion-activated lighting?
Yes, both the original and v2 Wyze Lamp Socket models support motion-activated lighting, turning your lights on automatically when motion is detected to enhance security.Is the Wyze Lamp Socket easy to install?
Yes, the Wyze Lamp Socket is designed for easy installation. Simply plug it into any standard E26 socket and connect it to the Wyze app for setup and automation.What is included in the Wyze Cam v4 + Lamp Socket v2 Bundle?
The Wyze Cam v4 + Lamp Socket v2 Bundle includes a Wyze Cam v4 and a Lamp Socket v2, providing a complete smart security and lighting solution with dusk-to-dawn scheduling, motion-activated lighting, and the ability to power your camera without a plug.Can I control Wyze Lamp Socket with voice assistants?
While the Wyze Lamp Socket itself is controlled via the Wyze app, you can pair it with the Wyze Bulb White, which is compatible with Alexa, Google Assistant, and IFTTT for voice control and smart home integration.What are the benefits of using Wyze Lamp Socket for dusk-to-dawn lighting?
Using Wyze Lamp Socket for dusk-to-dawn lighting offers convenience, energy savings, enhanced security, and the ability to automate your outdoor lighting based on natural light cycles or motion detection. It also integrates with Wyze cameras and smart bulbs for a complete smart home solution.Is there a warranty for Wyze Lamp Socket v2?
Yes, Wyze Lamp Socket v2 comes with a 1-year limited warranty, ensuring reliable performance and customer support.What is the Wyze Bulb White and how does it complement the Lamp Socket?
The Wyze Bulb White is a smart, dimmable bulb with adjustable color temperature (2700K to 6500K), long life (25,000 hours), and energy efficiency. It pairs perfectly with the Wyze Lamp Socket to provide customizable, automated lighting that enhances your dusk-to-dawn schedule.
