Convert Outdoor Fixtures to Smart Security Lights with Lamp Sockets
Convert Your Outdoor Fixture to a Smart Security Light with Lamp Socket
Transform your existing outdoor lighting into a smart security system effortlessly by using specialized lamp sockets designed to power Wyze smart cameras without the need for additional outlets. These innovative lamp sockets enable you to upgrade your outdoor fixtures into intelligent security lights that offer motion-activated lighting, dusk-to-dawn scheduling, and seamless connectivity with your smart home devices.
Smart Lamp Socket Solutions for Outdoor Security Lighting
Cam v4 + Lamp Socket v2 Bundle
Make your exterior lighting smarter with the Cam v4 + Lamp Socket v2 Bundle. This power duo allows you to install the Wyze Cam v4 directly into your outdoor lamp socket, eliminating the need for a nearby power outlet.
  • Device Compatibility: Supports Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Power Input: 120V~, 60Hz with a max lamp power of 20W.
  • Connectivity: 2.4GHz Wi-Fi (802.11 b/g/n) and Bluetooth.
  • Features: Motion-activated lights, linkability without limits, and dusk-to-dawn scheduling.
  • Materials & Dimensions: Durable polycarbonate and plastic, compact size (56.5mm x 56.5mm x 65mm).
  • Operating Temperature: Suitable for damp locations with a range from -4°F to 120°F (-20°C to 50°C).
  • Note: Use CFL or LED bulbs under 20W; incandescent bulbs are not recommended due to thermal limitations.
  • Warranty: 1 year.
This bundle is perfect for those who want a sleek, integrated security camera powered directly from their outdoor lamp fixture, enhancing both lighting and surveillance.
Pan v3 + Lamp Socket v2 Bundle
For wider coverage and dynamic monitoring, the Pan v3 + Lamp Socket v2 Bundle offers a smart solution that powers the Wyze Cam Pan v3 through your existing lamp socket.
  • Device Compatibility: Compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Power & Connectivity: Same power specs as the Cam v4 bundle with 20W max lamp power and 2.4GHz Wi-Fi.
  • Features: Pan-and-tilt camera with 360° horizontal and 180° vertical coverage, motion-activated lights, and dusk-to-dawn scheduling.
  • Materials & Dimensions: Polycarbonate and plastic construction, compact and lightweight.
  • Operating Environment: Suitable for damp locations, temperature range -4°F to 120°F.
  • Warranty: 1 year.
  • Note: Use CFL or LED bulbs under 20W for optimal performance.
This bundle is ideal for users who want to monitor large outdoor areas with a pan-and-tilt camera powered conveniently by their lamp socket.
Wyze Lamp Socket v2 – The Latest in Smart Powering
Upgrade your outdoor lighting with the Wyze Lamp Socket v2, the latest lamp socket designed to power multiple Wyze cameras without requiring a power outlet.
  • Compatibility: Powers Wyze Cam v3, v3 Pro, v4, Cam OG, Pan v3, and Duo Cam Pan.
  • Connectivity: Supports 2.4GHz Wi-Fi and Bluetooth.
  • Features: Motion-activated lighting, linkability, and dusk-to-dawn scheduling.
  • Durability: Suitable for damp locations but not fully weatherproof.
  • Dimensions & Weight: Compact 56.5mm x 56.5mm x 65mm, weighing 80g.
  • Warranty: 1 year.
  • Important: Use CFL or LED bulbs under 20W; incandescent bulbs are not supported.
This lamp socket is a versatile accessory that makes it easy to convert any outdoor fixture into a smart security light compatible with a wide range of Wyze cameras.
Wyze Original Lamp Socket – Simple and Effective
The Wyze Lamp Socket is the original model that started it all, enabling you to power Wyze Cam v3 and v4 cameras directly from your outdoor lamp fixture.
  • Power Input: 120V, 60Hz with a max lamp power of 30W.
  • Connectivity: 2.4GHz Wi-Fi and Bluetooth.
  • Features: Motion-activated lights, linkability, and dusk-to-dawn scheduling.
  • Compatibility: Designed for Wyze Cam v3 and v4.
  • Materials & Size: Polycarbonate and plastic, 56.5mm x 56.5mm x 65mm.
  • Operating Temperature: -4°F to 120°F, suitable for damp locations.
  • Certifications: ETL, CETL, UL.
  • Note: Not weatherproof; recommended for damp locations only.
This lamp socket is a cost-effective way to add smart functionality to your outdoor lighting and security setup.
Why Convert Your Outdoor Fixture to a Smart Security Light?
Upgrading your outdoor lighting with a smart lamp socket and Wyze cameras offers enhanced security, convenience, and energy efficiency. Motion-activated lights deter intruders, while integrated cameras provide real-time monitoring and alerts directly to your smartphone. The dusk-to-dawn scheduling ensures your outdoor areas are always well-lit during nighttime hours without manual intervention.
Benefits at a Glance
  • No Need for Additional Outlets: Power your cameras directly from existing lamp sockets.
  • Smart Features: Motion detection, scheduling, and seamless app integration.
  • Wide Compatibility: Supports multiple Wyze camera models.
  • Energy Efficient: Use LED or CFL bulbs under 20W to save energy.
  • Easy Installation: Simple screw-in design fits standard E26 lamp sockets.
  • Weather-Resistant: Suitable for damp outdoor locations.
Enhance Your Home Security with Smart Lighting
By combining Wyze smart cameras with these lamp sockets, you can convert any outdoor fixture into a powerful security light that not only illuminates your property but also keeps an eye on it 24/7. Whether you prefer the compact Cam v4 or the versatile Pan v3, these bundles and accessories provide a seamless way to upgrade your home security system. Outdoor smart security light in use
Summary of Products for Smart Outdoor Lighting Conversion
Product NameCompatible CamerasMax Lamp PowerFeaturesPrice (USD)
Cam v4 + Lamp Socket v2 BundleWyze Cam v3, v3 Pro, v4, OG, Pan v320WMotion-activated lights, scheduling49.96
Pan v3 + Lamp Socket v2 BundleWyze Cam v3, v3 Pro, v4, OG, Pan v320WPan & tilt, motion lights, scheduling53.96
Wyze Lamp Socket v2Wyze Cam v3, v3 Pro, v4, OG, Pan v3, Duo Cam Pan20WMotion lights, linkability, scheduling16.98
Wyze Lamp Socket (Original)Wyze Cam v3, v430WMotion lights, linkability, scheduling16.98
Convert your outdoor fixture today with these smart lamp sockets and enjoy enhanced security, convenience, and peace of mind. Home exterior with smart security lighting
Embrace the future of home security by turning your outdoor lighting into a smart security light with Wyze lamp sockets and cameras. Easy to install, energy-efficient, and packed with smart features, these products are the perfect upgrade for any home.
Smart home security camera installation
FeatureCam v4 + Lamp Socket v2 BundlePan v3 + Lamp Socket v2 BundleWyze Lamp Socket v2Wyze Lamp Socket
Included DevicesWyze Cam v4 + Lamp Socket v2Wyze Cam Pan v3 + Lamp Socket v2Lamp Socket v2 onlyLamp Socket only
Compatible CamerasWyze Cam v3/v3 Pro/v4, Cam OG/OG Tele, Pan v3Wyze Cam v3/v3 Pro/v4, Cam OG/OG Tele, Pan v3Wyze Cam v3/v3 Pro/v4, Cam OG, Pan v3Wyze Cam v3, Wyze Cam v4
Price$49.96$53.96$16.98$16.98
Color VariantsBlack, Grey, WhiteBlack, WhiteWhiteWhite
Max Lamp Power20W20W20W30W
Power Input120V~, 60Hz120V~, 60Hz120V~, 60Hz120V, 60Hz
ConnectivityN/A (camera connectivity varies)N/A (camera connectivity varies)802.11 b/g/n 2.4GHz, Bluetooth802.11 b/g/n 2.4GHz, Bluetooth
DimensionsN/AN/A56.5mm x 56.5mm x 65mm56.5mm x 56.5mm x 65mm
WeightN/AN/A80 g80 g
Weather ResistanceN/AN/ANot weatherproof, suitable for damp locationsNot weatherproof, suitable for damp locations
Installation EaseAs easy as screwing in a lightbulbAs easy as screwing in a lightbulbAs easy as screwing in a lightbulbAs easy as screwing in a lightbulb
Motion-Activated LightsYesYesYesYes
Dusk to Dawn AutomationYesYesYesYes
Link Multiple SocketsYesYesYesYes
Incandescent Bulb UsageNot recommended (thermal limitations)Not recommended (thermal limitations)Not recommended (thermal limitations)Not recommended (thermal limitations)
Recommended Bulb TypeCFL or LED under 20WCFL or LED under 20WCFL or LED under 20WCFL or LED under 20W
USB PortNoNoNo1 Type-A USB port (5W/5V1A)
CertificationsN/AN/AFCC, IC, UL496, CA65, TSCA, RoHSETL, CETL, UL
How do I convert my outdoor light fixture into a smart security light?You can easily convert your outdoor light fixture into a smart security light by using a Wyze Lamp Socket. These specialized lamp sockets allow you to power Wyze smart cameras directly from your existing outdoor lamp socket, eliminating the need for additional power outlets. Simply screw the lamp socket into your fixture, connect your compatible Wyze camera, and enjoy features like motion-activated lighting and dusk-to-dawn scheduling.
Which Wyze cameras are compatible with the Lamp Socket v2?The Wyze Lamp Socket v2 is compatible with Wyze Cam v3, v3 Pro, v4, Cam OG, Pan v3, and Duo Cam Pan. This wide compatibility makes it easy to upgrade your outdoor security system with the camera of your choice.
What are the main features of the Wyze Lamp Socket v2?The Wyze Lamp Socket v2 offers motion-activated lighting, dusk-to-dawn scheduling, unlimited linkability with other sockets, and seamless integration with your smart home devices. It supports 2.4GHz Wi-Fi and Bluetooth connectivity, is suitable for damp locations, and is designed for use with CFL or LED bulbs under 20W.
Can I use incandescent bulbs with Wyze Lamp Sockets?No, it is not recommended to use incandescent bulbs with Wyze Lamp Sockets due to thermal limitations. For optimal performance and safety, use CFL or LED bulbs under 20W.
Are Wyze Lamp Sockets weatherproof?Wyze Lamp Sockets are suitable for damp locations but are not fully weatherproof. They are designed for outdoor use in covered or protected areas where they are not directly exposed to heavy rain or water.
What is the maximum lamp power supported by Wyze Lamp Sockets?The Wyze Lamp Socket v2 supports a maximum lamp power of 20W, while the original Wyze Lamp Socket supports up to 30W. Always use compatible bulbs to ensure safe operation.
Do I need a power outlet to install a Wyze smart camera with a lamp socket?No, you do not need an additional power outlet. Wyze Lamp Sockets are designed to power your compatible Wyze cameras directly from your existing outdoor lamp socket, making installation simple and convenient.
What are the benefits of upgrading my outdoor lighting with a smart lamp socket?Upgrading your outdoor lighting with a smart lamp socket and Wyze cameras enhances your home security with motion-activated lights, real-time monitoring, and smartphone alerts. It also offers energy efficiency with dusk-to-dawn scheduling and easy installation without the need for extra outlets.
How do I install a Wyze Lamp Socket?Installation is simple: screw the Wyze Lamp Socket into your standard E26 outdoor fixture, connect your compatible Wyze camera, and follow the setup instructions in the Wyze app. No special tools or wiring are required.
What is the warranty on Wyze Lamp Sockets and bundles?All Wyze Lamp Sockets and bundles come with a 1-year warranty, ensuring peace of mind and reliable performance for your smart outdoor lighting and security setup.
Can I link multiple Wyze Lamp Sockets together?Yes, Wyze Lamp Sockets support unlimited linkability, allowing you to connect multiple sockets for synchronized motion-activated lighting and scheduling across your outdoor fixtures.
What is the operating temperature range for Wyze Lamp Sockets?Wyze Lamp Sockets are designed to operate in temperatures ranging from -4°F to 120°F (-20°C to 50°C), making them suitable for most outdoor environments.
What smart features do Wyze Lamp Sockets offer?Wyze Lamp Sockets provide smart features such as motion-activated lighting, dusk-to-dawn scheduling, seamless app integration, and compatibility with a range of Wyze cameras for enhanced security and convenience.
What are the features of the Cam v4 + Lamp Socket v2 Bundle?Can the Wyze Lamp Socket v2 be used with other Wyze camera models?Do you have any deals, ongoing sales, discounts, or promotions?
