Upgrade Your Outdoor Fixtures to Smart Security with Wyze Lamp and Cam – Smart Lighting & Surveillance Solutions
Upgrade Your Outdoor Fixture to Smart Security with Wyze Lamp and Cam
Looking to transform your outdoor lighting into a powerful smart security solution? Wyze offers innovative products that combine bright, energy-efficient lighting with advanced security cameras, giving you peace of mind and total control over your home's exterior. Discover how the Wyze Bulb Cam and Wyze Battery Cam Pro can help you upgrade your outdoor fixtures for smarter, safer living.
Why Upgrade to Wyze Smart Outdoor Security?
"Smart outdoor security means more than just lighting up your yard. With Wyze, you get real-time monitoring, instant alerts, and the ability to deter intruders—all from your smartphone."
Upgrading your outdoor fixtures with Wyze's smart solutions brings together the best of both worlds: brilliant illumination and high-definition surveillance. Whether you want to keep an eye on your front porch, driveway, or backyard, Wyze makes it easy to enhance your home's security and convenience.
Wyze Bulb Cam: The 2-in-1 Outdoor Security Camera and Smart LED Bulb
Wyze Bulb Cam installed in an outdoor light fixture, providing both illumination and security monitoring.
Key Features
  • 2K HD Video with Color Night Vision: Capture every detail, day or night, with crisp 2K resolution and enhanced color night vision.
  • Smart LED Lighting: Up to 800 lumens of brightness with adjustable color temperature (3000K) for warm, welcoming light.
  • Motion-Activated Alerts: Receive instant notifications when motion is detected, and trigger the light or built-in 95 dB siren to deter unwanted visitors.
  • Easy Installation: Fits standard E26 sockets—just screw it in like a regular bulb and connect to Wi-Fi.
  • Local & Cloud Storage: Supports up to 256GB microSD cards for continuous or event-based recording, plus optional cloud storage.
  • Weather Resistant: IP65 rating ensures reliable performance in rain, snow, or heat.
"Wyze Bulb Cam is perfect for porches, garages, and entryways—anywhere you want both light and security in one smart device."
Wyze Battery Cam Pro: Wire-Free, Pro-Grade Outdoor Security
Wyze Battery Cam Pro mounted outside, wire-free, monitoring a backyard gathering.
Key Features
  • 2.5K HDR Video Resolution: See everything in stunning detail, even in challenging lighting conditions.
  • Wire-Free Installation: No need for outlets or complicated wiring—place it anywhere with ease.
  • Integrated Spotlight & Siren: Motion-activated 150-lumen LED spotlight and 100 dB siren help deter intruders.
  • Radar + PIR Motion Detection: Dual sensors reduce false alerts and provide accurate detection of people, vehicles, and packages.
  • Removable, Rechargeable Battery Packs: Up to 6 months of battery life per charge, with easy hot-swap capability.
  • IP65 Weatherproof: Built to withstand the elements, from -4°F to 122°F.
  • Dual-Band Wi-Fi: Supports both 2.4 GHz and 5 GHz networks for fast, reliable connectivity.
  • Flexible Mounting: Wall mount included; optional ceiling mount available.
"With Wyze Battery Cam Pro, you can protect any area of your property—no wires, no hassle, just pro-grade security wherever you need it."
Smarter Security, Seamless Control
Both Wyze Bulb Cam and Wyze Battery Cam Pro integrate with the Wyze app, giving you:
  • Live View & Two-Way Audio: Check in anytime and communicate with visitors or delivery drivers.
  • Customizable Detection Zones: Focus on the areas that matter most to you.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Deter Intruders: Activate lights, sirens, or voice warnings remotely to keep your home safe.
Real-Life Peace of Mind
Wyze Bulb Cam providing security and lighting for a garage at night.
"Upgrade your outdoor fixtures with Wyze and enjoy the confidence of knowing your home is always protected—brightly lit, monitored, and under your control."
Conclusion: The Smartest Way to Secure Your Outdoors
Transform your existing outdoor fixtures into a smart security powerhouse with Wyze Bulb Cam and Wyze Battery Cam Pro. Enjoy brilliant lighting, crystal-clear video, and advanced motion detection—all in easy-to-install, weatherproof designs. Take control of your home's security and lighting from anywhere, and experience the next level of outdoor protection.
Ready to upgrade? Choose Wyze for smarter, safer outdoor living.
FeatureWyze Battery Cam ProWyze Bulb Cam
Power SourceRemovable, rechargeable battery (up to 6 months)120V AC (standard E26 socket)
Video Resolution2.5K HDR (2560 x 1440)2K HD (2304 x 1296)
Field of View134° Diagonal160° Diagonal
Night VisionColor Night Vision, IR + White LEDsColor Night Vision, IR LEDs
Motion DetectionRadar + PIR (Person, Package, Vehicle)Motion Detection (Person, Package with Cam Plus)
Integrated Lighting150 lumen LED spotlight800 lumen dimmable LED bulb
Siren100 dB95 dB
Weather ResistanceIP65 (indoor/outdoor)IP65 (camera portion)
WiFi2.4 & 5 GHz2.4 GHz
Local StoragemicroSD up to 256GBmicroSD up to 256GB
Cloud StorageYes (Cam Plus)Yes (Cam Plus)
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Two-Way AudioYesYes
Mounting OptionsWall (included), Ceiling (with accessory)Fits most E26 light fixtures
Operating Temperature-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C) (camera)
Notable FeaturesWire-free, hot-swappable battery, solar option2-in-1 camera + smart bulb, group lighting, easy install
What is the Wyze Bulb Cam and how does it enhance outdoor security?The Wyze Bulb Cam is a 2-in-1 smart device that combines a high-definition outdoor security camera with a smart LED bulb. It provides 2K HD video with color night vision, motion-activated alerts, and a built-in 95 dB siren. The bulb offers up to 800 lumens of adjustable lighting and fits standard E26 sockets, making it easy to upgrade your outdoor fixtures for enhanced security and illumination.
How easy is it to install the Wyze Bulb Cam?The Wyze Bulb Cam is designed for easy installation. Simply screw it into any standard E26 light socket, connect it to your Wi-Fi network using the Wyze app, and you’re ready to enjoy smart lighting and security monitoring.
What are the key features of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro offers 2.5K HDR video resolution, wire-free installation, a motion-activated 150-lumen LED spotlight, a 100 dB siren, radar and PIR motion detection, removable rechargeable battery packs with up to 6 months of battery life, IP65 weatherproofing, dual-band Wi-Fi support, and flexible mounting options.
Can Wyze outdoor security cameras withstand harsh weather conditions?Yes, both the Wyze Bulb Cam and Wyze Battery Cam Pro are IP65 weather resistant, ensuring reliable performance in rain, snow, heat, and temperatures ranging from -4°F to 122°F.
How do Wyze outdoor security products help deter intruders?Wyze outdoor security products feature motion-activated lights, built-in sirens, and instant alerts to your smartphone. You can also activate lights, sirens, or voice warnings remotely through the Wyze app to deter unwanted visitors.
Do Wyze outdoor cameras support local and cloud storage?Yes, the Wyze Bulb Cam supports up to 256GB microSD cards for local continuous or event-based recording, and both devices offer optional cloud storage for added convenience and security.
Are Wyze outdoor security devices compatible with smart home systems?Yes, Wyze Bulb Cam and Wyze Battery Cam Pro work with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
What app features are available for Wyze outdoor security cameras?The Wyze app provides live view, two-way audio for communicating with visitors, customizable detection zones, instant motion alerts, and remote control of lights and sirens for both Wyze Bulb Cam and Wyze Battery Cam Pro.
How long does the Wyze Battery Cam Pro battery last and how is it recharged?The Wyze Battery Cam Pro features removable, rechargeable battery packs that can last up to 6 months per charge. The batteries are easy to hot-swap, ensuring minimal downtime.
What areas are best suited for installing Wyze Bulb Cam and Wyze Battery Cam Pro?The Wyze Bulb Cam is ideal for porches, garages, and entryways where you want both lighting and security. The Wyze Battery Cam Pro is perfect for any area of your property, including driveways, backyards, and remote locations, thanks to its wire-free, flexible installation.
What are the key features of the Wyze Bulb Cam?How does the Wyze Battery Cam Pro compare to the Wyze Bulb Cam in terms of video resolution?Are there any ongoing promotions or discounts for the Wyze Battery Cam Pro?
