Convert Your Standard Outdoor Light to Smart with Wyze Lamp Bundle
Transform your ordinary outdoor lighting into a smart, connected system effortlessly with the Wyze Lamp Bundle. Whether you want vibrant color-changing bulbs, integrated security cameras, or smart sockets to power your devices, Wyze offers versatile solutions to upgrade your outdoor lighting setup. Discover how these products combine convenience, security, and style to make your home smarter and safer.
Wyze Bulb Color: Brilliant Smart Lighting for Outdoors
Upgrade your outdoor light bulbs with the
Wyze Bulb Color, the ultimate 16 million color smart bulb that brings life and personality to your exterior spaces.
Key Features:
- Vibrant Colors & Tunable White: Choose from 16 million colors or adjust the white light temperature from warm 1800K to cool 6500K to match any mood or occasion.
- Extra Bright: Delivers up to 1100 lumens, bright enough to illuminate patios, porches, or garden areas.
- Dimmable: Customize brightness levels to create the perfect ambiance.
- Connectivity: Works seamlessly with 2.4GHz Wi-Fi and Bluetooth, compatible with Android 9.0+ and iOS 15.0+.
- Smart Integrations: Supports Alexa, Google Assistant, and IFTTT for voice control and automation.
- Durability: Suitable for damp locations and built to last 25,000 hours.
With the Wyze Bulb Color, your outdoor lighting becomes a dynamic part of your smart home, perfect for parties, relaxing evenings, or enhancing curb appeal.
Alt: Outdoor patio lit with colorful Wyze Bulb Color smart lighting
Wyze Bulb Cam + Accessory Bulbs: Smart Security Meets Lighting
For those who want to combine smart lighting with home security, the
Wyze Bulb Cam + Accessory Bulbs bundle is an ideal choice.
Why Choose This Bundle?
- 2K HD Video with Color Night Vision: Keep an eye on your property day and night with crystal-clear video and color night vision.
- Motion-Activated Lighting: The bulb cam lights up automatically when motion is detected, deterring intruders and illuminating your path.
- Accessory Bulbs: Add up to 5 Wyze Accessory Bulbs to extend your smart lighting coverage around your home.
- Local Video Storage: No subscription needed; store footage on microSD cards up to 256GB.
- Easy Installation: Fits most standard E26 fixtures, perfect for replacing existing outdoor bulbs.
- Weather Resistant: Rated IP65, built to withstand outdoor conditions.
This bundle not only brightens your outdoor space but also enhances your home’s security with smart surveillance and lighting working together.
Alt: Wyze Bulb Cam installed on outdoor light fixture for home security
Wyze Lamp Socket: Power Your Wyze Cam v3/v4 Without a Plug
Make your existing outdoor light fixture smarter by powering your Wyze Cam v3 or v4 directly through the
Wyze Lamp Socket.
Features:
- Smart Power Solution: Powers Wyze Cam v3/v4 without needing a separate plug or outlet.
- Motion-Activated Lights & Scheduling: Automate your outdoor lighting with dusk-to-dawn scheduling and motion activation.
- Linkability: Connect multiple Wyze devices for a cohesive smart home experience.
- Compact & Durable: Made from polycarbonate and plastic, designed for damp locations (not fully waterproof).
- Easy Setup: Fits standard E26 sockets and supports 120V AC power input.
- USB Port Included: 5W/5V USB Type-A port for additional device charging.
The Wyze Lamp Socket is perfect for converting your traditional outdoor light fixtures into smart hubs that power cameras and lights simultaneously, enhancing security and convenience.
Why Choose Wyze for Your Smart Outdoor Lighting?
Wyze offers a comprehensive ecosystem that makes upgrading your outdoor lighting simple and affordable. From vibrant color bulbs to smart security cameras and innovative lamp sockets, Wyze products are designed to work together seamlessly through the Wyze app, giving you full control from anywhere.
"With Wyze, converting your standard outdoor light to smart is not just about illumination—it's about enhancing security, convenience, and style in one smart bundle."
Summary of Wyze Smart Outdoor Lighting Products
Product | Highlights | Ideal For |
Wyze Bulb Color | 16 million colors, dimmable, 1100 lumens | Colorful, customizable lighting |
Wyze Bulb Cam + Accessory Bulbs | 2K HD video, color night vision, motion-activated light | Security + lighting combo |
Wyze Lamp Socket | Powers Wyze Cam v3/v4, motion-activated, USB port | Smart power for cameras & lights |
How can I convert my standard outdoor light to a smart light with Wyze?
You can easily convert your standard outdoor light to a smart light by using the Wyze Lamp Bundle. This bundle includes smart bulbs, security cameras, and smart sockets that work together to upgrade your outdoor lighting setup, providing convenience, security, and style.What features does the Wyze Bulb Color offer for outdoor lighting?
The Wyze Bulb Color offers 16 million vibrant colors, tunable white light from 1800K to 6500K, up to 1100 lumens of brightness, dimmable settings, and compatibility with Alexa, Google Assistant, and IFTTT. It is suitable for damp locations and lasts up to 25,000 hours, making it ideal for patios, porches, and gardens.Is the Wyze Bulb Color compatible with my smart home system?
Yes, the Wyze Bulb Color works with 2.4GHz Wi-Fi and Bluetooth, and is compatible with Android 9.0+ and iOS 15.0+. It also supports voice control and automation through Alexa, Google Assistant, and IFTTT.How does the Wyze Bulb Cam + Accessory Bulbs bundle enhance outdoor security?
The Wyze Bulb Cam + Accessory Bulbs bundle combines 2K HD video with color night vision and motion-activated lighting. The camera lights up automatically when motion is detected, deterring intruders and illuminating your property. You can add up to 5 accessory bulbs for extended coverage, and store video locally on microSD cards up to 256GB without a subscription.Are Wyze outdoor lighting products weather resistant?
Yes, Wyze outdoor lighting products like the Wyze Bulb Cam are rated IP65 for weather resistance, making them suitable for outdoor use in various conditions. The Wyze Bulb Color is also designed for damp locations.What is the Wyze Lamp Socket and how does it work?
The Wyze Lamp Socket allows you to power your Wyze Cam v3 or v4 directly from your existing outdoor light fixture, eliminating the need for a separate plug or outlet. It features motion-activated lighting, dusk-to-dawn scheduling, a USB port for device charging, and supports linking multiple Wyze devices for a seamless smart home experience.Can I control Wyze outdoor lighting products remotely?
Yes, all Wyze outdoor lighting products can be controlled remotely through the Wyze app. This allows you to adjust lighting, monitor security cameras, and manage schedules from anywhere.Do I need a subscription to use Wyze Bulb Cam’s video storage?
No, you do not need a subscription to use Wyze Bulb Cam’s video storage. You can store footage locally on microSD cards up to 256GB.What types of outdoor fixtures are compatible with Wyze smart bulbs and sockets?
Wyze smart bulbs and lamp sockets are designed to fit most standard E26 light fixtures, making them easy to install as replacements for existing outdoor bulbs.Why should I choose Wyze for my smart outdoor lighting needs?
Wyze offers a comprehensive and affordable ecosystem for smart outdoor lighting, including vibrant color bulbs, security cameras, and innovative lamp sockets. All products work seamlessly together through the Wyze app, providing enhanced security, convenience, and style for your home.
