Smart Lighting Kits to Power Wyze Cam Outdoors Easily
Smart Lighting Modification Kits to Power Wyze Cam Outdoors Easily
If you're looking to power your Wyze Cam outdoors without hassle, while enhancing your home's smart lighting setup, Wyze offers innovative solutions designed specifically for this purpose. Whether you want to power your Wyze Cam v3 or v4 without relying on traditional plugs or outlets, or you want to upgrade your outdoor security with integrated lighting and camera systems, these products provide seamless, smart, and efficient options.
Wyze Lamp Socket: Power Your Wyze Cam v3 and v4 Without a Plug
Convenient Outdoor Power Solution
The Wyze Lamp Socket is the original and trusted solution to power your Wyze Cam v3 or v4 without needing a nearby electrical outlet. This smart lamp socket replaces your existing outdoor light socket, allowing you to plug in your Wyze Cam directly and power it effortlessly.
  • Compatibility: Works perfectly with Wyze Cam v3 and v4 models.
  • Power Input: Standard 120V, 60Hz with E26 socket connector.
  • Features: Motion-activated lights, dusk-to-dawn scheduling, and linkability with other Wyze devices.
  • Build: Durable polycarbonate and plastic construction, suitable for damp outdoor locations (not fully waterproof).
  • Connectivity: Supports 2.4GHz WiFi and Bluetooth for easy setup and control.
  • Dimensions & Weight: Compact size (56.5mm x 56.5mm x 65mm) and lightweight (80g).
This lamp socket transforms your exterior lighting into a smart hub, powering your camera while providing automated lighting control for enhanced security and convenience.
Cam v4 + Lamp Socket v2 Bundle: The Ultimate Smart Lighting and Camera Duo
Simplify Outdoor Setup with a Power Duo
For those who want an all-in-one solution, the Cam v4 + Lamp Socket v2 Bundle offers the latest Wyze Cam v4 paired with the newest lamp socket version. This bundle makes your exterior lighting smarter and your camera setup easier than ever.
  • Power Without Outlet: No need for an external plug; the lamp socket powers the camera directly.
  • Motion-Activated Lighting: Lights turn on automatically when motion is detected, enhancing security.
  • Linkability: Connect multiple devices without limits for a comprehensive smart home ecosystem.
  • Dusk to Dawn Scheduling: Automate your lighting based on natural light cycles.
  • Compatibility: Supports multiple Wyze Cam models including v3, v3 Pro, v4, OG, and Pan v3.
  • Safety Note: Use only CFL or LED bulbs under 20W due to thermal limitations.
This bundle is perfect for users who want a streamlined, smart outdoor camera and lighting setup that’s easy to install and manage.
Wyze Cam Floodlight v2: Brighten and Secure Your Outdoors
Wyze Cam Floodlight v2 in action Brighten your driveway with Wyze Cam Floodlight v2
Powerful Lighting Meets Smart Security
The Wyze Cam Floodlight v2 combines a high-powered 2800 lumens LED floodlight with a 2K resolution camera featuring color night vision. It’s designed to dominate the dark and keep your outdoor spaces safe.
  • Lighting: Two dimmable LED panels with 2800 total lumens at 5000K color temperature.
  • Video Quality: Crisp 2K (2304 x 1296) video with a wide 160° diagonal field of view.
  • Smart Features: AI-powered light control, ambient light mode, two-way talk, and motion detection.
  • Weather Resistance: IP65 rating ensures durability in outdoor conditions.
  • Connectivity: 2.4 GHz WiFi compatible with Android 9.0+ and iOS 15.0+.
  • Storage: Supports up to 256GB microSD card for local recording.
  • Installation: Hardwired power supply (110-120V AC).
This floodlight camera is ideal for users who want a robust security camera with integrated bright lighting and smart automation for their outdoor areas.
Wyze Cam Floodlight Pro: Advanced Security with AI-Powered Lighting
Wyze Cam Floodlight Pro lifestyle Stay connected and secure with Wyze Cam Floodlight Pro
Next-Level Outdoor Security and Lighting
The Wyze Cam Floodlight Pro takes outdoor security to the next level with a 180° wide-angle lens, 2.5K QHD video, and AI computer vision that intelligently detects people and vehicles.
  • Lighting: Three dimmable LED panels delivering 3000 lumens at 5000K color temperature.
  • Video Quality: Ultra-clear 2.5K QHD (2560 x 1440) with color night vision.
  • AI Detection: Onboard AI selectively triggers lights and alerts based on object type.
  • Connectivity: Dual-band WiFi (2.4 & 5 GHz) for reliable performance.
  • Weatherproof: IP65 water resistance for all-weather durability.
  • Audio & Alarm: Built-in siren (105dB) and two-way audio for communication and deterrence.
  • Storage: Supports up to 256GB microSD card (exFAT, FAT32).
  • Compatibility: Works with Alexa, Google Assistant, and IFTTT integrations.
This floodlight camera is perfect for homeowners seeking a smart, high-performance security system with intelligent lighting control and superior video quality.
Why Choose Wyze Smart Lighting Kits for Your Outdoor Wyze Cam?
"Make your exterior lighting smart and power your Wyze Cam effortlessly with Wyze’s innovative lamp sockets and floodlight cameras."
  • Easy Installation: Replace your existing outdoor light socket with a Wyze Lamp Socket to power your camera without extra wiring.
  • Smart Automation: Motion-activated lights and dusk-to-dawn scheduling enhance security and convenience.
  • Seamless Integration: Compatible with Wyze Cam models and smart home assistants like Alexa and Google Assistant.
  • Weather-Ready: Floodlight cameras come with IP65 ratings to withstand outdoor elements.
  • Enhanced Security: Bright LED lighting combined with high-resolution cameras and AI detection keeps your property safe day and night.
Conclusion
For powering your Wyze Cam outdoors easily and smartly, the Wyze Lamp Socket and Cam v4 + Lamp Socket v2 Bundle provide simple, plug-free solutions. For enhanced security with integrated lighting, the Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro offer powerful illumination, advanced video quality, and intelligent features. Choose the right Wyze smart lighting modification kit to transform your outdoor security setup today.
Product Highlights Summary
FeatureWyze Lamp Socket + Cam v4 BundleWyze Cam Floodlight v2Wyze Cam Floodlight Pro
Product TypeCamera + Lamp Socket BundleCamera with FloodlightCamera with Floodlight
Price$49.98$89.98$149.98
Camera ModelWyze Cam v4Wyze Cam Floodlight v2Wyze Cam Floodlight Pro
Video Resolution2K (2304 x 1296)2K HD2.5K QHD (2560 x 1440)
Field of ViewNot specified (Cam v4 standard)160° wide-angle180° wide-angle
LightingPowered via Lamp Socket (no plug needed)2800 Lumens LEDs, 2 dimmable LED panels3000 Lumens LEDs, 3 dimmable LED panels
Color TemperatureNot specified5000K5000K
Night VisionColor Night VisionColor Night VisionColor Night Vision
Motion DetectionYes (via Cam v4)Advanced motion detectionAI computer vision with object selection
AudioTwo-way audio (Cam v4)Built-in speaker and microphone, 2-way audioSiren 105dB, 2-way audio
Power SupplyLamp Socket v2 (uses outdoor light fixture power)Hardwired 110-120V ACHardwired 110-120V AC
ConnectivityWi-Fi 2.4 GHz, Bluetooth802.11 b/g/n, 2.4 GHz802.11 b/g/n, 2.4 GHz & 5 GHz dual-band
Weather ResistanceNot specified (Lamp Socket v2 suitable for damp locations)IP65IP65
Dusk to Dawn AutomationYesYesYes
StorageLocal microSD support (up to 256 GB)Supports up to 256 GB microSDSupports up to 256 GB microSD
App ControlYes (Wyze app)Yes (Wyze app)Yes (Wyze app)
Compatible DevicesWyze Cam v4Wyze Cam Floodlight v2Wyze Cam Floodlight Pro
InstallationAs easy as screwing in a lightbulbEasy install, no junction box neededDIY installation under 20 minutes
Warranty30-day hassle-free returns1 year1 year
How can I power my Wyze Cam outdoors without using a traditional electrical outlet?You can power your Wyze Cam v3 or v4 outdoors without a traditional outlet by using the Wyze Lamp Socket. This smart socket replaces your existing outdoor light socket, allowing you to plug in your Wyze Cam directly and power it effortlessly through your exterior lighting fixture.
What Wyze Cam models are compatible with the Wyze Lamp Socket?The Wyze Lamp Socket is compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models, making it a versatile solution for various Wyze cameras.
What are the main features of the Wyze Lamp Socket for outdoor camera power?The Wyze Lamp Socket offers motion-activated lights, dusk-to-dawn scheduling, linkability with other Wyze devices, and supports 2.4GHz WiFi and Bluetooth for easy setup. It is built with durable materials suitable for damp outdoor locations.
What is included in the Cam v4 + Lamp Socket v2 Bundle?The Cam v4 + Lamp Socket v2 Bundle includes the latest Wyze Cam v4 and the newest version of the Wyze Lamp Socket, providing a streamlined, all-in-one solution for smart outdoor lighting and camera setup.
Can I connect multiple Wyze Lamp Sockets together for a smart home ecosystem?Yes, the Wyze Lamp Socket supports linkability, allowing you to connect multiple devices without limits for a comprehensive smart home ecosystem.
What type of bulbs can I use with the Wyze Lamp Socket?For safety and optimal performance, use only CFL or LED bulbs under 20W with the Wyze Lamp Socket due to thermal limitations.
What are the key features of the Wyze Cam Floodlight v2?The Wyze Cam Floodlight v2 features two dimmable LED panels with 2800 lumens, 2K resolution video with color night vision, AI-powered light control, motion detection, two-way talk, IP65 weather resistance, and supports up to 256GB microSD card for local storage.
How is the Wyze Cam Floodlight Pro different from the Floodlight v2?The Wyze Cam Floodlight Pro offers a 180° wide-angle lens, 2.5K QHD video, three dimmable LED panels with 3000 lumens, onboard AI for people and vehicle detection, dual-band WiFi, built-in siren, two-way audio, and compatibility with Alexa, Google Assistant, and IFTTT.
Are Wyze floodlight cameras weatherproof for outdoor use?Yes, both the Wyze Cam Floodlight v2 and Floodlight Pro have an IP65 weather resistance rating, ensuring durability and reliable performance in outdoor conditions.
Can I use Wyze smart lighting kits with voice assistants?Yes, Wyze smart lighting kits, including the Floodlight Pro, are compatible with popular smart home assistants such as Alexa and Google Assistant for seamless integration and voice control.
What are the benefits of using Wyze smart lighting modification kits for outdoor security?Wyze smart lighting kits offer easy installation, smart automation with motion-activated lights and dusk-to-dawn scheduling, seamless integration with Wyze Cams and smart home assistants, weather-ready designs, and enhanced security with bright LED lighting and AI-powered detection.
How do I store video footage from Wyze Cam Floodlight v2 and Pro?Both Wyze Cam Floodlight v2 and Floodlight Pro support local storage with microSD cards up to 256GB (exFAT, FAT32), allowing you to record and review footage directly from the device.
What are the features of the Wyze Lamp Socket?How does the Wyze Lamp Socket enhance outdoor security?Are there any discounts or promotions available for the Wyze products?
