Wyze Cam v3 & Wyze Lamp Socket Compatibility Guide
Wyze Cam v3 Compatibility with Wyze Lamp Socket
If you're looking to enhance your Wyze Cam v3 setup with smart lighting and convenient power options, understanding the compatibility between the Wyze Cam v3 and the Wyze Lamp Socket is essential. This guide will walk you through the features and compatibility details of these products, helping you create a seamless smart home security system.
Wyze Cam v3 and v4 Overview
While your query specifically mentions the Wyze Cam v3, it’s important to note that the Wyze Lamp Socket is designed to power both Wyze Cam v3 and Wyze Cam v4 models. Here’s a quick overview of the cameras:
Wyze Cam v3 Highlights
  • Resolution: 1080p Full HD video quality.
  • Field of View: Wide 121° diagonal, 102° horizontal, and 54° vertical.
  • Night Vision: Both Black & White and Color Night Vision capabilities.
  • Sound: Two-way talk feature for clear communication.
  • Siren: 80 dB built-in siren for deterrence.
  • MicroSD Support: Up to 256GB for local continuous recording.
  • Spotlight: Not included by default but available as a separate Spotlight Kit accessory.
  • Release Year: 2020.
The Wyze Cam v3 is a versatile indoor/outdoor camera that can be enhanced with accessories like the Wyze Lamp Socket for smarter power management.
Wyze Lamp Socket: Power and Smart Lighting for Wyze Cams
The Wyze Lamp Socket is a smart accessory designed to power your Wyze Cam v3 or v4 without needing a traditional plug outlet. It transforms your exterior lighting into a smart device, providing both power and lighting control.
Key Features of Wyze Lamp Socket
  • Compatibility: Specifically made to power Wyze Cam v3 and Wyze Cam v4.
  • Power Input: Standard 120V, 60Hz.
  • Max Lamp Power: Supports up to 30W bulbs.
  • USB Port: Includes 1 Type-A USB port (5W/5V1A) for additional device charging.
  • Connectivity: Works over 2.4GHz Wi-Fi and Bluetooth.
  • Smart Features: Motion-activated lights and dusk-to-dawn scheduling.
  • Material & Size: Durable polycarbonate and plastic construction, compact size (56.5mm x 56.5mm x 65mm).
  • Operating Temperature: Suitable for temperatures from -4°F to 120°F (-20°C to 50°C).
  • Certifications: ETL, CETL, UL certified.
  • Weather Suitability: Not fully weatherproof but suitable for damp locations like covered porches.
Why Use Wyze Lamp Socket with Wyze Cam v3?
The Wyze Lamp Socket allows you to power your Wyze Cam v3 in locations where a plug outlet is not available, such as outdoor lamp fixtures. This setup not only powers your camera but also adds smart lighting features that enhance security and convenience.
Wyze Cam v4: The Next Generation with Enhanced Features
If you are considering an upgrade or want to future-proof your setup, the Wyze Cam v4 offers significant improvements over the v3 and is fully compatible with the Wyze Lamp Socket.
Wyze Cam v4 Key Specifications
  • Resolution: 2.5K Quad HD (2560x1440) for crystal-clear video.
  • Field of View: 115.9° diagonal, 98.5° horizontal, 53.1° vertical.
  • Night Vision: Enhanced Color Night Vision with 4 IR LEDs and 2 white spotlight LEDs.
  • Audio: Enhanced two-way talk with noise and echo cancellation.
  • Siren: Loud 99 dB siren for effective deterrence.
  • Spotlight: Built-in motion-activated spotlight.
  • MicroSD Support: Up to 512GB for continuous local recording.
  • Connectivity: Supports Wi-Fi 6 for stronger, more reliable connections.
  • Smart Assistant Integration: Works with Alexa, Google Assistant, and IFTTT.
  • Weather Resistance: IP65 rating for outdoor durability.
  • Mounting Options: Stand, wall mount, ceiling mount, and magnetic mounts.
Outdoor Security with Wyze Cam v4 Outdoor Bundle
For outdoor use, the Wyze Cam v4 Outdoor Bundle includes the camera, an outdoor power adapter, and a 128GB microSD card, making it a complete solution for robust home security.
How Wyze Lamp Socket Enhances Your Wyze Cam Experience
By pairing the Wyze Lamp Socket with either the Wyze Cam v3 or v4, you gain:
  • Flexible Installation: Power your camera from any standard lamp socket without needing an outlet.
  • Smart Lighting: Motion-activated lights improve visibility and security around your home.
  • Energy Efficiency: Dusk-to-dawn scheduling automates lighting based on natural light conditions.
  • Simplified Setup: Connects easily via Wi-Fi and Bluetooth for seamless integration with your Wyze ecosystem.
Summary: Compatibility and Benefits
ProductCompatible WithKey Benefits
Wyze Cam v3Wyze Lamp SocketPowers camera without plug, smart lighting
Wyze Cam v4Wyze Lamp SocketHigher resolution, built-in spotlight, Wi-Fi 6
Wyze Lamp SocketWyze Cam v3 & v4Motion-activated light, USB charging, easy setup
Conclusion
The Wyze Lamp Socket is an excellent accessory to power your Wyze Cam v3 or v4, especially in outdoor or hard-to-reach locations where traditional power outlets are unavailable. It not only powers your camera but also adds smart lighting features that enhance your home security system. Whether you stick with the Wyze Cam v3 or upgrade to the advanced Wyze Cam v4, the Wyze Lamp Socket ensures a convenient and efficient setup.
Wyze Cam v4 in Outdoor Setting Wyze Cam v4 providing clear security footage day and night. Wyze Lamp Socket Installed on Porch Light Wyze Lamp Socket powering a Wyze Cam with smart lighting on a porch. Wyze Cam v3 with Spotlight Kit Wyze Cam v3 enhanced with a spotlight kit for better night security.
FeatureWyze Lamp SocketWyze Cam v4Wyze Cam v4 + FREE 32GB MicroSD Card
TypeAccessoryCameraCamera
Price$16.98$107.94 (1 Pack)$35.98
DescriptionPowers Wyze Cam v3/v4 without a plug2.5K QHD resolution, Enhanced Color Night Vision, motion-activated spotlight, Wi-Fi 6, Alexa/Google Assistant compatibleSame as Wyze Cam v4 plus free 32GB microSD card
Power SourceUses outdoor light fixture electricityWiredWired
CompatibilityWyze Cam v3, v4Works standaloneWorks standalone
Weather ResistanceNot weatherproof, suitable for damp locationsIP65 ratedIP65 rated
SetupScrew-in lamp socketBluetooth setup, magnetic mountBluetooth setup, magnetic mount
Smart FeaturesMotion/sound activated light control, dusk to dawn automation, link up to 5 socketsMotion & sound detection, person detection, smoke & CO alerts, AI auto-zoomSame as Wyze Cam v4
MicroSD Card SupportN/AUp to 512GB microSD cardIncludes free 32GB microSD card
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision
SpotlightN/AMotion-activated spotlightMotion-activated spotlight
AudioN/AEnhanced two-way talk, 99dB sirenEnhanced two-way talk, 99dB siren
Dimensions56.5mm x 56.5mm x 65mm2in x 2in x 2 3/8in2in x 2in x 2 3/8in
Weight80 g0.49 lb (222 g)0.49 lb (222 g)
Warranty1 Year1 Year1 Year
Is the Wyze Lamp Socket compatible with Wyze Cam v3?Yes, the Wyze Lamp Socket is specifically designed to power the Wyze Cam v3, allowing you to install your camera in locations without a traditional plug outlet, such as outdoor lamp fixtures.
Can the Wyze Lamp Socket power the Wyze Cam v4?Yes, the Wyze Lamp Socket is fully compatible with both Wyze Cam v3 and Wyze Cam v4 models, providing convenient power and smart lighting features.
What are the main benefits of using the Wyze Lamp Socket with Wyze Cam v3 or v4?Using the Wyze Lamp Socket with Wyze Cam v3 or v4 allows you to power your camera from any standard lamp socket, adds motion-activated smart lighting, enables dusk-to-dawn scheduling, and offers a USB port for additional device charging.
Does the Wyze Lamp Socket require a Wi-Fi connection?Yes, the Wyze Lamp Socket connects via 2.4GHz Wi-Fi and Bluetooth, ensuring seamless integration with your Wyze smart home ecosystem.
Is the Wyze Lamp Socket weatherproof for outdoor use?The Wyze Lamp Socket is not fully weatherproof but is suitable for damp locations such as covered porches. It is made from durable polycarbonate and plastic materials.
What type of bulbs can I use with the Wyze Lamp Socket?The Wyze Lamp Socket supports bulbs up to 30W and operates on a standard 120V, 60Hz power input.
What are the key features of the Wyze Cam v3?The Wyze Cam v3 offers 1080p Full HD video, wide field of view, color and black & white night vision, two-way talk, an 80 dB siren, microSD support up to 256GB, and is suitable for both indoor and outdoor use.
What improvements does the Wyze Cam v4 offer over the v3?The Wyze Cam v4 features 2.5K Quad HD resolution, enhanced color night vision, a built-in motion-activated spotlight, a louder 99 dB siren, Wi-Fi 6 support, IP65 weather resistance, and microSD support up to 512GB.
Can I use the Wyze Lamp Socket to charge other devices?Yes, the Wyze Lamp Socket includes a Type-A USB port (5W/5V1A) that can be used to charge additional devices.
What smart features does the Wyze Lamp Socket provide?The Wyze Lamp Socket offers motion-activated lighting, dusk-to-dawn scheduling, and easy setup through Wi-Fi and Bluetooth connectivity.
Can you tell me more about the features of the Wyze Cam v4?What are the benefits of using the Wyze Lamp Socket with the Wyze Cam v3?Do you have any deals, ongoing sales, discounts, or promotions?
