Doorbell Chimes Compatible With Existing Home Systems | Wyze
Compatible Doorbell Chimes for Your Home
When upgrading your home’s doorbell system, compatibility with your existing doorbell chimes is essential for a seamless and hassle-free experience. Whether you want a smart chime that works wirelessly or a wired video doorbell with integrated chime support, Wyze offers a range of products designed to fit your needs perfectly. Explore the best Wyze doorbell chimes and accessories that ensure you never miss a visitor while maintaining compatibility with your current setup.
Wyze Universal Wi-Fi Chime: Wireless Convenience Without Wiring Hassles
Key Features:
  • Plug-and-play setup: No complicated wiring required; simply plug it in and start receiving alerts.
  • Smart automations: Customize chimes to ring when your Wyze cameras detect people, even if they don’t press the doorbell.
  • Works with existing doorbell systems: Designed to complement your current doorbell chimes without rewiring.
  • Affordable and compact: Priced at $19.98, this black chime fits discreetly into any home environment.
Never miss a ding-dong again with this fuss-free, universal Wi-Fi chime that keeps you informed no matter where you are.
Wyze Video Doorbell v2: Wired Doorbell with Built-In Chime Compatibility
Why Choose Wyze Video Doorbell v2?
  • 2K HD video quality: Capture every detail with crystal-clear resolution.
  • Local microSD storage: Save footage locally for easy access and privacy.
  • Two-way audio & real-time alerts: Communicate with visitors instantly and get notified the moment someone approaches.
  • Chime controller included: Comes with a chime controller that integrates smoothly with your existing wired chimes.
  • Price: $44.98 for the doorbell plus chime controller bundle.
This wired video doorbell is perfect for homeowners who want a high-quality video feed combined with seamless chime compatibility.
Wyze Chime Controller: Enhance Your Doorbell’s Sound System
Product Highlights:
  • Standalone chime controller unit: Designed exclusively for Wyze Video Doorbell v2 and Duo Cam Doorbell.
  • Easy wiring installation: Simple to install with your existing doorbell wiring.
  • Compact size: Measures just 47mm x 32mm x 15mm, fitting easily inside your chime box.
  • Affordable: Priced at $17.99, it’s a cost-effective way to add or improve chime functionality.
Use this controller to ensure your Wyze doorbell works flawlessly with your home’s chime system.
Wyze Chime: Standalone Wired Chime for Older Doorbell Models
Compatibility Details:
  • Works with: Wyze Video Doorbell (Wired) and Wyze Video Doorbell v1.
  • Does not work with: Wyze Video Doorbell Pro or Wyze Video Doorbell v2.
  • Price: $13.99.
If you have an older wired Wyze doorbell model, this standalone chime is a simple and reliable way to add audible alerts to your system.
The Front Porch Security Bundle: Complete Smart Home Entry Solution
What’s Included:
  • Wyze Video Doorbell with 1080p HD video.
  • Wyze Chime for clear audible alerts.
  • Wyze Lock for remote door locking and unlocking.
  • Integration with Alexa and Google Assistant for voice control.
Benefits:
  • View your front porch in real-time with two-way audio.
  • Lock and unlock your door remotely via the Wyze app.
  • Monitor motion events and lock history for enhanced security.
  • Price ranges from $123.99 to $173.97 depending on bundle options.
This all-in-one bundle is ideal for those seeking a comprehensive smart home security upgrade with compatible chimes included.
Wyze Video Doorbell v2 Wedge Kit: Perfect Angle for Perfect Coverage
Features:
  • Designed specifically for the Wyze Video Doorbell v2.
  • Adjusts the doorbell’s viewing angle to cover angled door frames or porches with stairs.
  • Eliminates blind spots for superior security.
  • Available as a kit with the doorbell or as a standalone accessory.
  • Price: $8.99 for the wedge kit only, $51.97 bundled with the doorbell.
Enhance your doorbell’s field of view while maintaining full compatibility with your existing chime system.
Summary
Choosing the right doorbell chime compatible with your existing system is crucial for a smooth upgrade. Wyze offers versatile options from the Universal Wi-Fi Chime for wireless convenience to the Video Doorbell v2 with integrated chime controller for wired setups. For those with older models, the Wyze Chime standalone unit fits perfectly, while the Front Porch Security Bundle provides a full smart home entry solution. Don’t forget the Wedge Kit to optimize your doorbell’s viewing angle.
With Wyze, enjoy smart, reliable, and compatible doorbell chimes that keep you connected and secure.
Smart Home Doorbell in Use Enhance your home security with Wyze’s compatible doorbell chimes. Front Porch Security Bundle Setup Complete smart home security with Wyze’s Front Porch Security Bundle. Doorbell with Wedge Kit Installed Adjust your doorbell’s angle for maximum coverage with the Wedge Kit.
FeatureWyze Universal Wi-Fi ChimeWyze Video Doorbell v2The Front Porch Security BundleWyze Chime ControllerWyze ChimeWyze Video Doorbell v2 Wedge Kit
TypeAccessoryCameraCamera BundleAccessoryAccessoryAccessory
Price$19.98$44.98$123.99 - $173.97$17.99$13.99$8.99 (Wedge Kit Only) / $51.97 (Doorbell + Wedge Kit)
DescriptionPlug-in Wi-Fi chime, no wiring, smart automationsWired video doorbell, 2K video, two-way audio, local microSD storageVideo Doorbell + Chime + Wyze Lock, porch security, remote lock/unlockStandalone chime controller for Doorbell v2 & Duo Cam DoorbellStandalone chime for Wyze Video Doorbell (Wired) onlyAngle adjustment wedge kit for Doorbell v2
Video ResolutionN/A2K (2048 x 1536)1080p HD (Video Doorbell in bundle)N/AN/AN/A
AudioDing-dong alertsTwo-way audio, noise/echo cancellationTwo-way audio (Video Doorbell)N/AN/AN/A
PowerStandard US power outlet (plug-in)Wired (16V-24V AC, ≥10VA)Doorbell: 16V-24V AC, Lock: 4x AA batteriesAC16V/AC24V, ≥10VAStandard US power outletN/A
InstallationPlug-in, no wiringWired installation, includes chime controllerIncludes Doorbell, Chime, Lock, accessoriesEasy wiring installationWired installationQuick installation
CompatibilityWorks with all Wyze cameras and doorbellsWorks with Wyze Chime ControllerIncludes compatible devicesCompatible with Wyze Video Doorbell v2 & Duo Cam DoorbellOnly works with Wyze Video Doorbell (Wired)Compatible with Doorbell v2 only
Chime SoundsMultiple chime sounds, automation soundsUses chime controller to keep existing chimeIncludes Wyze Chime with multiple soundsCompatible with nearly every mechanical chime5 modern, 4 classic, 3 animal, 6 automation, 1 intruder alarmN/A
Smart FeaturesSmart Automations, chime on person detectionMotion-activated voice deterrence, pre-roll recording, AI detections with Cam PlusRemote lock/unlock, motion events, lock history, Alexa/Google AssistantN/AN/AN/A
Weather ResistanceIndoor (plug-in)IP65 WeatherproofIP65 Weather-resistant (Doorbell)-20°C to 50°C working tempN/AWeather resistant
Dimensions2" x 2" x 1.4"4.3" x 1.7" x 0.9"Doorbell: 1.5" x 3.25" x 0.625" (approx.)47mm x 32mm x 15mm2" x 2" x 1.4"Includes 15° horizontal bracket, 7.5° vertical brackets
Weight2.0 oz (56g)1.7 oz (49g)Doorbell: 1.7 oz (49g), Chime: 2.0 oz (56g), Lock: 0.67 lbN/A2.0 oz (56g)N/A
StorageN/ALocal microSD (up to 256GB), cloud with Cam PlusLocal storage on doorbell, cloud optionalN/AN/AN/A
Included Items1x Wyze Universal Wi-Fi ChimeDoorbell + Chime Controller, wall plate, wedge, installation kitWyze Lock, Lock Gateway, Batteries, Video Doorbell, Chime, accessories1x Chime controller unit1x Wyze ChimeBrackets, screws, quick start guide
What Wyze doorbell chimes are compatible with my existing doorbell system?Wyze offers several doorbell chime options compatible with most home setups. The Wyze Universal Wi-Fi Chime works wirelessly with existing systems, while the Wyze Video Doorbell v2 includes a chime controller for seamless integration with wired chimes. For older models, the Wyze Chime standalone unit is available.
How does the Wyze Universal Wi-Fi Chime work?The Wyze Universal Wi-Fi Chime is a plug-and-play device that requires no wiring. Simply plug it into a power outlet, and it will receive alerts from your Wyze doorbell or cameras. It can also be customized to ring when Wyze cameras detect people, even if the doorbell isn’t pressed.
Is the Wyze Video Doorbell v2 compatible with my wired chime?Yes, the Wyze Video Doorbell v2 comes with a chime controller that integrates smoothly with your existing wired doorbell chimes, ensuring you receive audible alerts throughout your home.
What is the Wyze Chime Controller and which doorbells does it support?The Wyze Chime Controller is a standalone unit designed exclusively for the Wyze Video Doorbell v2 and Duo Cam Doorbell. It connects easily to your existing doorbell wiring and fits inside your chime box to enhance or add chime functionality.
Which Wyze chime should I use with older Wyze doorbell models?For older Wyze doorbell models, such as the Wyze Video Doorbell (Wired) and Wyze Video Doorbell v1, the Wyze Chime standalone wired chime is recommended. It is not compatible with the Wyze Video Doorbell Pro or v2.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a Wyze Video Doorbell with 1080p HD video, a Wyze Chime for audible alerts, and a Wyze Lock for remote locking and unlocking. It also integrates with Alexa and Google Assistant for voice control.
How can I improve the viewing angle of my Wyze Video Doorbell v2?You can use the Wyze Video Doorbell v2 Wedge Kit to adjust the doorbell’s viewing angle. This accessory is designed to eliminate blind spots and provide optimal coverage for angled door frames or porches with stairs.
Are Wyze doorbell chimes easy to install?Yes, Wyze doorbell chimes are designed for easy installation. The Universal Wi-Fi Chime is plug-and-play, while the Chime Controller and standalone chimes require simple wiring compatible with most existing doorbell systems.
Can I use Wyze doorbell chimes with smart home assistants?Yes, Wyze doorbell chimes and bundles, such as the Front Porch Security Bundle, are compatible with Alexa and Google Assistant, allowing for voice control and smart home integration.
What is the price range for Wyze doorbell chimes and accessories?Wyze doorbell chimes and accessories are affordably priced: the Universal Wi-Fi Chime is $19.98, the Chime Controller is $17.99, the standalone Wyze Chime is $13.99, and the Wedge Kit is $8.99. The Video Doorbell v2 with chime controller bundle is $44.98, and the Front Porch Security Bundle ranges from $123.99 to $173.97.
What are the key features of the Wyze Universal Wi-Fi Chime?Can you tell me more about the Wyze Video Doorbell v2 and its compatibility with existing chimes?Do you have any ongoing sales or discounts for the Wyze products?
