Best External Chime Options for Upgrading Your Wyze Doorbell
Upgrading your Wyze doorbell with the right external chime can enhance your home’s security and convenience. Whether you want a simple plug-and-play chime or a comprehensive security bundle, Wyze offers several excellent options tailored to different needs. Below, we explore the best external chime products compatible with Wyze doorbells, highlighting their features and benefits to help you make the perfect choice.
Wyze Universal Wi-Fi Chime: Simple, Smart, and Wireless
Key Features
- Plug-and-Play Setup: No complicated wiring needed. Just plug it into any standard power outlet and instantly get notified when someone rings your doorbell.
- Wide Compatibility: Works seamlessly with all Wyze Cams and doorbells, making it a versatile choice for any Wyze smart home setup.
- Multiple Tones: Choose from 17 different chime tones to suit your preference.
- Smart Automations: Integrate with your Wyze cameras to trigger chimes for motion detection events, such as someone approaching your kitchen or front porch.
- Compact Design: Measuring 81 x 53 x 38 mm, it fits discreetly in your home without taking up much space.
- Connectivity: Uses Wi-Fi (2.4 GHz) and Bluetooth BLE 5.0 for reliable communication.
Why Choose Wyze Universal Wi-Fi Chime?
This chime is perfect for those who want a fuss-free, wireless solution that integrates well with existing Wyze devices. Its smart automation capabilities mean you can customize alerts beyond just doorbell rings, enhancing your home’s awareness.
The Front Porch Security Bundle: All-in-One Smart Home Solution
What’s Included?
- Wyze Video Doorbell (1080p HD)
- Wyze Chime
- Wyze Lock for remote door locking/unlocking
Highlights
- 1080p HD Video & Two-Way Audio: See and speak to visitors clearly from anywhere.
- Remote Lock Control: Manage your front door lock remotely and monitor lock history via the Wyze app.
- Multiple Chime Sounds: Includes 5 modern, 4 classic, 3 animal, 6 automation, and 1 intruder alarm sounds for versatile notifications.
- Smart Assistant Compatibility: Works with Alexa and Google Assistant for voice control.
- Weather-Resistant Doorbell: Rated IP65, suitable for outdoor use in various climates.
- Comprehensive Security: Combines video, audio, and lock control for a robust front porch security system.
Ideal For
Homeowners looking for a complete front porch security upgrade with integrated chime functionality and smart lock control. This bundle offers convenience and peace of mind in one package.
Wyze Video Doorbell v2 with Chime Controller: High-Definition Clarity and Custom Alerts
Features of Wyze Video Doorbell v2
- 2K Video Resolution: Crystal-clear video with a wide 135° horizontal and 103° vertical field of view.
- Local and Cloud Storage: Supports microSD cards up to 256GB and optional cloud storage with Wyze Security Plan.
- Two-Way Audio & Voice Deterrence: Communicate with visitors and deter unwanted guests with motion-activated voice alerts.
- Weatherproof Design: IP65 rating ensures durability in outdoor conditions.
- Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT.
Wyze Chime Controller
- Standalone Unit: Works exclusively with Wyze Video Doorbell v2 and Duo Cam Doorbell.
- Easy Wiring: Simple installation with compatibility for nearly every mechanical chime.
- Compact Size: Small footprint (47mm x 32mm x 15mm) fits easily behind your existing chime.
Why This Combo?
If you want the clearest video quality and a customizable chime experience, the Wyze Video Doorbell v2 paired with the Chime Controller is an excellent choice. It allows you to keep your existing mechanical chime while upgrading to smart notifications.
Wyze Chime: Dedicated Wired Doorbell Chime
Overview
- Standalone Chime: Designed specifically for Wyze Video Doorbell (Wired) models.
- Compatibility: Works with Wyze Video Doorbell v1 and Wyze Wired Doorbell.
- Limitations: Not compatible with Wyze Video Doorbell Pro or Wyze Video Doorbell v2.
Why Consider This?
For users with the original Wyze wired doorbell, this standalone chime offers a straightforward external chime solution without the need for additional smart features.
Conclusion: Choosing the Right External Chime for Your Wyze Doorbell
When upgrading your Wyze doorbell, consider your home setup and desired features:
- For wireless, easy installation and smart automations, the Wyze Universal Wi-Fi Chime is ideal.
- If you want a complete security upgrade with video, chime, and smart lock, the Front Porch Security Bundle offers unmatched value.
- For high-definition video and integration with existing mechanical chimes, the Wyze Video Doorbell v2 with Chime Controller is the best fit.
- If you have the original wired Wyze doorbell, the Wyze Chime standalone unit is a simple external chime solution.
Upgrade your home’s doorbell experience today with these top Wyze-compatible chime options and never miss a visitor again!
Enhance your home security with smart chimes and video doorbells.
Complete front porch security with Wyze Video Doorbell and Chime.
Stay connected to your front door from anywhere with Wyze Video Doorbell v2.
What are the best external chime options for Wyze doorbells?
The best external chime options for Wyze doorbells include the Wyze Universal Wi-Fi Chime, the Front Porch Security Bundle (which includes a Wyze Chime), the Wyze Video Doorbell v2 with Chime Controller, and the standalone Wyze Chime for wired doorbells. Each option offers unique features to suit different home setups and preferences.Is the Wyze Universal Wi-Fi Chime compatible with all Wyze doorbells?
Yes, the Wyze Universal Wi-Fi Chime is designed for wide compatibility and works seamlessly with all Wyze Cams and doorbells, making it a versatile choice for any Wyze smart home setup.How do I install the Wyze Universal Wi-Fi Chime?
The Wyze Universal Wi-Fi Chime features a plug-and-play setup. Simply plug it into any standard power outlet, connect it to your Wyze app, and you’ll receive notifications when someone rings your doorbell. No complicated wiring is required.What features does the Wyze Universal Wi-Fi Chime offer?
The Wyze Universal Wi-Fi Chime offers 17 different chime tones, smart automation with Wyze cameras for motion detection alerts, a compact design, and reliable connectivity via Wi-Fi (2.4 GHz) and Bluetooth BLE 5.0.What is included in the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes a Wyze Video Doorbell (1080p HD), a Wyze Chime, and a Wyze Lock for remote door locking and unlocking. This bundle provides comprehensive front porch security with video, audio, and smart lock control.Can I control the Wyze Front Porch Security Bundle with smart assistants?
Yes, the Wyze Front Porch Security Bundle is compatible with Alexa and Google Assistant, allowing you to control your doorbell and lock with voice commands.What are the benefits of the Wyze Video Doorbell v2 with Chime Controller?
The Wyze Video Doorbell v2 with Chime Controller offers 2K video resolution, a wide field of view, local and cloud storage options, two-way audio, voice deterrence, weatherproof design, and compatibility with Alexa, Google Assistant, and IFTTT. The Chime Controller allows you to use your existing mechanical chime for notifications.Is the Wyze Chime Controller compatible with all Wyze doorbells?
No, the Wyze Chime Controller is designed to work exclusively with the Wyze Video Doorbell v2 and Duo Cam Doorbell. It is not compatible with other Wyze doorbell models.Which Wyze chime should I use with the original Wyze wired doorbell?
For the original Wyze wired doorbell (Wyze Video Doorbell v1 and Wyze Wired Doorbell), the standalone Wyze Chime is the recommended external chime solution. It is not compatible with Wyze Video Doorbell Pro or Wyze Video Doorbell v2.How do I choose the right external chime for my Wyze doorbell?
To choose the right external chime for your Wyze doorbell, consider your home setup and desired features. For wireless installation and smart automations, choose the Wyze Universal Wi-Fi Chime. For a complete security upgrade, select the Front Porch Security Bundle. For high-definition video and integration with existing mechanical chimes, opt for the Wyze Video Doorbell v2 with Chime Controller. For the original wired Wyze doorbell, use the standalone Wyze Chime.
