Upgrade to Wyze Video Doorbell v2 for Mechanical Chime Systems
Upgrade Your Mechanical Home Chime System with Wyze Video Doorbell v2
If you're looking to upgrade your existing mechanical home chime system with a modern, smart video doorbell, the Wyze Video Doorbell v2 is the perfect solution. Designed to seamlessly replace traditional wired doorbells while enhancing your home security, this device offers crystal-clear 2K video, two-way audio, and smart alerts — all compatible with your current wiring setup.
Wyze Video Doorbell v2: The Ultimate Wired Doorbell Upgrade
Stunning 2K Video Quality and Wide Field of View
The Wyze Video Doorbell v2 captures every detail with a 2K (2048 x 1536) resolution, providing sharper and clearer video than standard 1080p models. Its advanced CMOS Starlight Sensor and F2.0 aperture ensure excellent image quality even in low light. With a wide 135° horizontal and 103° vertical field of view, you get comprehensive coverage of your front porch and entryway.
Seamless Integration with Mechanical Chimes
Unlike many wired doorbells that disable your existing mechanical chime, the Wyze Video Doorbell v2 includes a Chime Controller that allows you to keep your mechanical chime working perfectly. This means you can enjoy smart video doorbell features without losing the familiar sound of your home’s doorbell.
Smart Features for Enhanced Security
  • Two-way audio lets you speak with visitors or delivery personnel from anywhere via your smartphone.
  • Motion-activated voice deterrence helps ward off unwanted guests by playing a warning message when motion is detected.
  • Local microSD storage supports up to 256GB, so you can save video clips without relying solely on cloud storage.
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
Durable and Weather-Resistant
Built with polycarbonate and resin materials, the doorbell is IP65 rated for weather resistance, ensuring reliable performance in rain, snow, or heat. It operates in temperatures ranging from -4°F to 122°F (-20°C to 50°C).
Upgrade your home’s entryway with a smart doorbell that respects your existing mechanical chime system while delivering next-level security and convenience.
Family welcoming guest at front door with smart doorbell Alt text: Family using smart video doorbell at home entrance
Wyze Universal Wi-Fi Chime: Add Wireless Convenience to Your Setup
If you want to add a wireless chime option to your home, the Wyze Universal Wi-Fi Chime is an excellent accessory. It plugs into any standard outlet and connects via Wi-Fi, allowing you to hear your doorbell ring anywhere in the house without complicated wiring.
Key Features
  • Compatible with all Wyze cameras and doorbells, including the Video Doorbell v2.
  • Offers 17 different chime tones to customize your alert sound.
  • Supports smart automations, such as chiming when a Wyze camera detects a person.
  • Easy plug-and-play installation with no wiring needed.
This chime is perfect for homes where the existing mechanical chime is hard to hear or for those who want additional chime alerts in different rooms.
Wyze Video Doorbell v2 Wedge Kit: Perfect Angle for Maximum Coverage
For homes with angled door frames or porches with stairs, the Wyze Video Doorbell v2 Wedge Kit is a must-have accessory. It allows you to adjust the doorbell’s viewing angle to eliminate blind spots and capture the best possible view of your front porch.
What’s Included?
  • 15° horizontal bracket and two 7.5° vertical brackets for flexible mounting.
  • All necessary screws and a quick start guide for easy installation.
  • Weather-resistant design to withstand outdoor conditions.
This kit ensures your Wyze Video Doorbell v2 delivers superior security coverage tailored to your home’s unique layout.
Why Choose Wyze for Your Video Doorbell Upgrade?
Wyze offers a comprehensive ecosystem of smart home security products designed to work together seamlessly. The Video Doorbell v2 upgrade kit is specifically engineered to support existing mechanical chimes, making it an ideal choice for homeowners who want to modernize without losing traditional features. With Wyze, you get:
  • High-resolution video and reliable performance.
  • Smart home compatibility with Alexa, Google Assistant, and IFTTT.
  • Local and cloud storage options for your video footage.
  • Durable, weather-resistant hardware built to last.
Summary of Relevant Products for Your Upgrade
Product NameKey FeaturesPrice (USD)
Wyze Video Doorbell v22K video, mechanical chime compatible, 2-way audio, local storage$44.98
Wyze Universal Wi-Fi ChimeWireless chime, 17 tones, easy plug-in$19.98
Wyze Video Doorbell v2 Wedge KitAdjustable mounting angles, weather-resistant$8.99
Wyze Video Doorbell (Wired)1080p HD, wired, mechanical chime disables after install$29.99
Upgrade your home’s doorbell system today with the Wyze Video Doorbell v2 and accessories to enjoy smart security without sacrificing your existing mechanical chime. Smart home front porch with video doorbell and chime Alt text: Modern front porch with smart video doorbell and wireless chime
FeatureWyze Video Doorbell v2Wyze Universal Wi-Fi ChimeWyze Video Doorbell v2 Wedge KitWyze Video Doorbell (Wired)
TypeWired Video DoorbellDoorbell Accessory (Chime)Doorbell Accessory (Wedge Kit)Wired Video Doorbell
Video Resolution2K (2048 x 1536)N/AN/A1080p Full HD (1080p, 480p)
Field of View135° Horizontal x 103° VerticalN/AN/A120° Vertical x 88° Horizontal
Local StoragemicroSD slot, up to 256GBN/AN/AN/A
Cloud StorageOptional with Cam Plus subscriptionN/AN/AN/A
Two-Way AudioYesN/AN/AYes
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect)N/AN/ANo
Pre-roll Motion Recording3-6 secondsN/AN/ANo
Works with Existing ChimeYes, includes chime controllerNo wiring needed, plugs inN/ANo, existing chime will not work after install
Weather ResistanceIP65N/AWeather resistantIP65
PowerWired (16V-24V AC, ≥10VA)Powered by removable battery pack or wired ACN/AWired
InstallationScrew mountingPlug-in, 3M adhesive or screw mountingQuick installationScrew mounting
CompatibilityWorks with Alexa, Google Assistant, IFTTTWorks with all Wyze camerasCompatible with Doorbell v2 onlyWorks with Alexa, Google Assistant, IFTTT
Included ItemsDoorbell, Chime Controller, Wall Plate, Wedge, Installation Kit, Wire Caps, Screws, Extension Wires, Fuse, Quick Start GuideUniversal Wi-Fi Chime device1x 15° Horizontal Bracket, 2x 7.5° Vertical Brackets, Screws, Quick Start GuideDoorbell, Wall Plate, 30° Wedge, Wire Caps, Screws, Extension Wires, Fuse, Quick Start Guide
Price$44.98$19.98$8.99 (Wedge Kit Only) / $51.97 (Doorbell + Wedge Kit)$29.99 (Doorbell Only), $34.99 (Doorbell + Chime)
Special Features2K video, local microSD storage, motion alerts, voice deterrence, two-way talk, pre-roll recordingWi-Fi enabled chime alerts, automation with Wyze camerasAdjust viewing angle for Doorbell v2, reduces blind spots1080p HD video, built-in speaker & mic, 8x digital zoom, night IR LEDs
Warranty1 yearNot specified1 yearNot specified
What makes the Wyze Video Doorbell v2 a good upgrade for mechanical chime systems?The Wyze Video Doorbell v2 is designed to seamlessly replace traditional wired doorbells while keeping your existing mechanical chime fully functional. It includes a Chime Controller that allows your mechanical chime to work perfectly, so you can enjoy smart features without losing the familiar sound of your home’s doorbell.
Does the Wyze Video Doorbell v2 work with my existing mechanical chime?Yes, the Wyze Video Doorbell v2 is specifically engineered to be compatible with existing mechanical chime systems. It comes with a Chime Controller that ensures your mechanical chime continues to work after installation.
What video quality does the Wyze Video Doorbell v2 offer?The Wyze Video Doorbell v2 provides stunning 2K (2048 x 1536) video resolution, which is sharper and clearer than standard 1080p models. It also features an advanced CMOS Starlight Sensor and F2.0 aperture for excellent image quality, even in low light conditions.
Can I talk to visitors using the Wyze Video Doorbell v2?Yes, the Wyze Video Doorbell v2 features two-way audio, allowing you to speak with visitors or delivery personnel directly from your smartphone, no matter where you are.
Is the Wyze Video Doorbell v2 weather-resistant?Absolutely. The Wyze Video Doorbell v2 is built with durable polycarbonate and resin materials and is IP65 rated for weather resistance. It operates reliably in temperatures ranging from -4°F to 122°F (-20°C to 50°C), making it suitable for various climates.
Does the Wyze Video Doorbell v2 support local video storage?Yes, the Wyze Video Doorbell v2 supports local microSD storage of up to 256GB, allowing you to save video clips without relying solely on cloud storage.
Is the Wyze Video Doorbell v2 compatible with smart home systems?Yes, the Wyze Video Doorbell v2 is compatible with Alexa, Google Assistant, and IFTTT, making it easy to integrate with your existing smart home ecosystem.
What is the Wyze Universal Wi-Fi Chime and how does it work?The Wyze Universal Wi-Fi Chime is a wireless accessory that plugs into any standard outlet and connects via Wi-Fi. It works with all Wyze cameras and doorbells, including the Video Doorbell v2, and offers 17 different chime tones. It’s perfect for homes where the mechanical chime is hard to hear or for adding chime alerts in additional rooms.
Can I customize the chime sound with the Wyze Universal Wi-Fi Chime?Yes, the Wyze Universal Wi-Fi Chime offers 17 different chime tones, allowing you to customize your doorbell alert sound to your preference.
What is included in the Wyze Video Doorbell v2 Wedge Kit?The Wyze Video Doorbell v2 Wedge Kit includes a 15° horizontal bracket, two 7.5° vertical brackets, all necessary screws, and a quick start guide. The kit is weather-resistant and allows you to adjust the doorbell’s viewing angle for maximum coverage.
Why should I choose Wyze for my video doorbell upgrade?Wyze offers a comprehensive ecosystem of smart home security products that work together seamlessly. The Video Doorbell v2 is designed to support existing mechanical chimes, provides high-resolution video, smart home compatibility, local and cloud storage options, and durable, weather-resistant hardware—all at an affordable price.
How much does the Wyze Video Doorbell v2 and its accessories cost?The Wyze Video Doorbell v2 is priced at $44.98. The Wyze Universal Wi-Fi Chime costs $19.98, and the Wyze Video Doorbell v2 Wedge Kit is available for $8.99.
Is installation of the Wyze Video Doorbell v2 and accessories easy?Yes, the Wyze Video Doorbell v2 and its accessories are designed for easy installation. The doorbell is compatible with existing wiring, the Universal Wi-Fi Chime is plug-and-play with no wiring needed, and the Wedge Kit includes all necessary hardware and a quick start guide.
What are the key features of the Wyze Video Doorbell v2?How does the Wyze Video Doorbell v2 integrate with existing mechanical chimes?Do you have any deals, ongoing sales, discounts, or promotions?
