Best Value Home Monitoring Kit with Wyze Sense Hub Offer
When it comes to securing your home efficiently and affordably, Wyze offers a comprehensive range of home monitoring products centered around the Wyze Sense Hub. This hub acts as the brain of your home security system, connecting all sensors and sending instant alerts to keep you informed and protected. Whether you want to detect motion, monitor entry points, or control your system remotely, Wyze’s lineup provides excellent value and seamless integration.
Wyze Sense Hub: The Central Command for Your Home Security
The Wyze Sense Hub is the essential core of your home monitoring setup. It connects all Wyze Sense sensors and ensures you receive real-time alerts on your phone or through the Wyze app.
- Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF communication.
- Range: Covers up to 500 feet (152 meters) to sensors, allowing flexible placement throughout your home.
- Battery Backup: Built-in rechargeable battery with up to 10 hours of backup power.
- Siren: Loud 88db siren at 2 feet to deter intruders.
- Capacity: Supports up to 100 sensors for scalable security.
- Indoor Use: Designed for indoor environments with operating temperature from 32°F to 104°F (0°C to 40°C).
This hub is indispensable for any Wyze Sense sensor to function, making it the backbone of your home monitoring system.
Wyze Sense Motion Sensor: Smart Motion Detection
Detect movement with precision using the Wyze Sense Motion Sensor, designed to alert you when motion is detected within a 25-foot range and a 120° field of view.
- Pet-Friendly: Adjustable sensitivity and “large pet installation” options to avoid false alarms caused by pets.
- Easy Installation: Comes with adhesive backing for quick wall mounting or optional screws for added security.
- Compatibility: Requires Wyze Sense Hub or Wyze Home Monitoring system (v2 sensors only).
- Battery Life: Long-lasting battery designed to operate for up to 18 months.
Place these sensors strategically around your home to monitor hallways, entryways, or any area where motion detection is critical.
Wyze Sense Motion Sensor providing wide field detection in your home
Wyze Sense Entry Sensor: Monitor Doors and Windows
Keep track of your doors and windows with the Wyze Sense Entry Sensor, which notifies you instantly when an entry point is opened or closed.
- Multi-Pack Value: Available in 3-packs for comprehensive coverage of multiple entry points.
- Wireless & Reliable: Connects seamlessly with the Wyze Sense Hub.
- Battery Life: Up to 18 months on a single battery.
- Features: Includes open/close detection and left-open alerts to prevent accidental security lapses.
Ideal for front doors, back doors, windows, cabinets, or any access point you want to monitor closely.
Wyze Sense Entry Sensor keeping your home secure with no tools required
Wyze Sense Keypad: Arm and Disarm with Ease
The Wyze Sense Keypad offers convenient remote control of your home security system.
- Remote Disarm: Arm or disarm your system without needing your phone.
- Emergency Button: Quickly send alerts to first responders in case of emergency.
- Wireless & Compact: Easy to place anywhere indoors with permanent adhesive backing.
- Requires: Works only with Wyze Sense Hub and Wyze Home Monitoring.
This keypad adds an extra layer of control and peace of mind, especially for families or multi-user households.
Wyze Sense Keypad for quick and easy home security control
Wyze Home Monitoring Core Starter Kit: All-in-One Security Solution
For those seeking the best value and convenience, the Wyze Home Monitoring Core Starter Kit bundles everything you need to get started:
- Includes: 1 Wyze Sense Hub, 2 Wyze Entry Sensors, 1 Wyze Motion Sensor, and 1 Wyze Keypad.
- Professional Monitoring: Comes with 3 months of professional monitoring included.
- Comprehensive Coverage: Protects your home from unwanted guests and hazards 24/7.
- Easy Setup: Simple installation with no tools required.
- Battery Backup: Ensures your system stays active even during power outages.
This kit is perfect for new users who want a ready-to-go, reliable home monitoring system with excellent value.
Why Choose Wyze Sense Home Monitoring?
Wyze Sense products combine affordability, ease of use, and smart technology to deliver a home monitoring system that fits any budget without compromising on security.
- Scalable: Add up to 100 sensors to customize your system.
- Smart Alerts: Receive instant notifications on your phone.
- Pet-Friendly Motion Detection: Avoid false alarms.
- Long Battery Life: Minimal maintenance required.
- Professional Monitoring Option: For added peace of mind.
With the Wyze Sense Hub at the center, you can build a tailored home security system that grows with your needs.
Summary of Wyze Sense Home Monitoring Products
Product | Key Features | Price Range |
Wyze Sense Hub | Central hub, 500 ft range, 88db siren | $45.98 |
Wyze Sense Motion Sensor | 25 ft range, pet-friendly, easy install | $20.98 (1 pack) |
Wyze Sense Entry Sensor | Open/close detection, 3-pack available | $41.98 (3 pack) |
Wyze Sense Keypad | Arm/disarm remotely, emergency button | $27.98 |
Wyze Home Monitoring Core Kit | Hub + sensors + keypad + 3 months monitoring | $111.98 |
Build your best value home monitoring kit today with Wyze Sense Hub and sensors to keep your home safe, smart, and secure.
What is the Wyze Sense Hub and why is it essential for home monitoring?
The Wyze Sense Hub is the central command unit for your Wyze home security system. It connects all Wyze Sense sensors, sends real-time alerts to your phone or Wyze app, and features a built-in siren and battery backup. The hub is required for any Wyze Sense sensor to function, making it the backbone of your home monitoring setup.How does the Wyze Sense Motion Sensor work and where should I install it?
The Wyze Sense Motion Sensor detects movement within a 25-foot range and a 120° field of view. It is pet-friendly with adjustable sensitivity to avoid false alarms and can be easily installed using adhesive backing or screws. Place it in hallways, entryways, or any area where motion detection is important for your home security.What features does the Wyze Sense Entry Sensor offer for door and window monitoring?
The Wyze Sense Entry Sensor monitors doors, windows, and other entry points, sending instant notifications when they are opened or closed. It features open/close detection, left-open alerts, and comes in multi-packs for comprehensive coverage. The sensor offers up to 18 months of battery life and requires the Wyze Sense Hub for operation.How does the Wyze Sense Keypad enhance home security control?
The Wyze Sense Keypad allows you to arm or disarm your home security system without using your phone. It features an emergency button for quick alerts to first responders and is easy to install with adhesive backing. The keypad works exclusively with the Wyze Sense Hub and Wyze Home Monitoring system.What is included in the Wyze Home Monitoring Core Starter Kit?
The Wyze Home Monitoring Core Starter Kit includes 1 Wyze Sense Hub, 2 Wyze Entry Sensors, 1 Wyze Motion Sensor, and 1 Wyze Keypad. It also comes with 3 months of professional monitoring, providing a comprehensive and easy-to-install home security solution.Is professional monitoring available with Wyze home security systems?
Yes, Wyze offers professional monitoring as an option with its home security systems. The Wyze Home Monitoring Core Starter Kit includes 3 months of professional monitoring, ensuring 24/7 protection and peace of mind.How many sensors can the Wyze Sense Hub support?
The Wyze Sense Hub can support up to 100 sensors, allowing you to scale and customize your home security system to fit your needs.What is the battery life of Wyze Sense sensors and the hub?
Wyze Sense Motion and Entry Sensors are designed to last up to 18 months on a single battery. The Wyze Sense Hub features a built-in rechargeable battery that provides up to 10 hours of backup power during outages.Are Wyze Sense Motion Sensors pet-friendly?
Yes, Wyze Sense Motion Sensors are pet-friendly. They offer adjustable sensitivity and installation options to help avoid false alarms caused by pets.How easy is it to install Wyze home monitoring products?
Wyze home monitoring products are designed for easy installation, often requiring no tools. Sensors and keypads come with adhesive backing for quick setup, and the system can be managed through the Wyze app for user-friendly control.What connectivity options does the Wyze Sense Hub offer?
The Wyze Sense Hub supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF communication, ensuring reliable and flexible connectivity for your home security system.
