Wyze Cam Floodlight Pro vs 2K Floodlight: Which QHD Security Camera is Best?
When choosing a smart floodlight camera for your home security, understanding the difference between 2K and 2.5K QHD resolution models is key. Wyze offers two standout floodlight cameras: the
Wyze Cam Floodlight Pro with 2.5K QHD video and the
Wyze Cam Floodlight v2 featuring 2K video. This guide compares their specs, features, and installation options to help you decide which fits your needs best.
Wyze Cam Floodlight Pro: Superior 2.5K QHD Video and Intelligent Lighting
Crystal Clear 2.5K QHD Resolution with Wide-Angle Coverage
The Wyze Cam Floodlight Pro delivers stunning 2.5K QHD (2560 x 1440) video resolution, providing sharper and more detailed footage than standard 2K cameras. Its 180° diagonal field of view ensures you can monitor your entire yard or driveway with minimal blind spots.
Advanced AI-Powered Motion Detection
Equipped with evolutionary onboard AI computer vision, this camera intelligently detects motion from specific objects like people and vehicles. This smart detection triggers the adjustable 3,000 lumen LED floodlights only when necessary, reducing false alarms and saving energy.
Powerful Lighting and Night Vision
The Floodlight Pro features three dimmable light panels producing a total of 3,000 lumens at a crisp 5000K color temperature. Combined with color night vision, it ensures clear visibility even in complete darkness.
Flexible Installation and Connectivity
- Hardwired 110-120V AC power supply
- Mount options: wall or ceiling
- Dual-band WiFi support (2.4 & 5 GHz) for reliable connectivity
- Compatible with Android 9.0+ and iOS 15.0+
- Integrates seamlessly with Alexa, Google Assistant, and IFTTT
Rugged and Weather-Resistant
Built to withstand outdoor conditions with an IP65 water resistance rating and operating temperature range from -4°F to 140°F (-20°C to 60°C).
"Wyze Cam Floodlight Pro is like having a personal home security guard with bright, smart lights and crystal-clear 2.5K video."
Wyze Cam Floodlight Pro in action illuminating a home exterior with a woman and dog
Wyze Cam Floodlight Pro + Plug-In Mount: Easy Installation with Plug-n-Play Convenience
All the Benefits of Floodlight Pro with Simplified Setup
This bundle pairs the Wyze Cam Floodlight Pro with a plug-in mount, eliminating the need for complex wiring or installing a junction box. Perfect for renters or those who want a hassle-free floodlight camera solution.
Key Specs
- Same 2.5K QHD resolution and 180° ultra-wide field of view
- 3,000 lumens of bright light output
- 20-foot power cord for flexible placement
- Operates in temperatures from -22°F to 122°F
- IP65 water resistance
- Compatible with Alexa, Google Assistant, and IFTTT
This plug-in option offers the same high-quality video and lighting performance with the added benefit of easy installation and portability.
Wyze Cam Floodlight Pro with plug-in mount for easy outdoor security
Wyze Cam Floodlight v2: Reliable 2K Video with Enhanced Lighting Features
Crisp 2K Video with Color Night Vision
The Wyze Cam Floodlight v2 offers 2K resolution (2304 x 1296) video quality, delivering clear and vibrant footage day and night. Its 160° diagonal field of view covers a wide area, though slightly narrower than the Floodlight Pro.
Bright 2800 Lumens LED Lighting
Featuring two dimmable LED light panels producing 2800 lumens at 5000K color temperature, this model provides ample illumination for most outdoor security needs.
Smart Features and Integration
- AI-powered light control with ambient light mode
- Two-way audio with built-in speaker and microphone
- 105dB siren for deterrence
- Dusk-to-dawn automation
- IP65 weather resistance and operating range from -4°F to 140°F
- Wall or ceiling mount options
- 2.4 GHz WiFi connectivity
- Supports up to 256GB microSD local storage
"Wyze Cam Floodlight v2 is a budget-friendly option with solid 2K video and bright lighting for dependable home security."
Wyze Cam Floodlight v2 illuminating a driveway with motion detection
2K vs 2.5K QHD: Which Wyze Floodlight Camera Should You Choose?
Feature | Wyze Cam Floodlight Pro (2.5K) | Wyze Cam Floodlight v2 (2K) |
Video Resolution | 2.5K QHD (2560 x 1440) | 2K (2304 x 1296) |
Field of View | 180° diagonal, 170° horizontal | 160° diagonal |
Brightness | 3,000 lumens (3 dimmable panels) | 2,800 lumens (2 dimmable panels) |
Night Vision | Color Night Vision | Color Night Vision |
AI Motion Detection | Advanced AI computer vision | AI-powered light control |
Connectivity | Dual-band WiFi (2.4 & 5 GHz) | 2.4 GHz WiFi |
Installation | Hardwired (110-120V AC) | Hardwired (110-120V AC) |
Plug-In Mount Option | Yes (bundle available) | No |
Price | $149.98 (Pro), $169.96 (Pro + Plug-In) | $89.98 |
If you want the highest video clarity, widest field of view, and smartest AI lighting, the
Wyze Cam Floodlight Pro is the premium choice. For a more affordable option with solid 2K video and bright lighting, the
Wyze Cam Floodlight v2 remains a reliable pick.
Conclusion
Choosing between 2K and 2.5K QHD Wyze floodlight cameras depends on your security needs and budget. The
Wyze Cam Floodlight Pro stands out with its superior 2.5K resolution, ultra-wide 180° view, and intelligent AI lighting, making it ideal for comprehensive outdoor surveillance. The
Wyze Cam Floodlight Pro + Plug-In Mount adds installation flexibility without sacrificing performance. Meanwhile, the
Wyze Cam Floodlight v2 offers dependable 2K video and bright illumination at a more accessible price point.
Invest in the Wyze floodlight camera that best fits your home security goals and enjoy peace of mind with crystal-clear video and smart lighting.
# Product Tags Summary
What is the difference between Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2?
The Wyze Cam Floodlight Pro features a higher 2.5K QHD (2560 x 1440) video resolution, a wider 180° field of view, and advanced AI-powered motion detection. It also offers brighter lighting with 3,000 lumens from three dimmable panels and supports dual-band WiFi (2.4 & 5 GHz). The Wyze Cam Floodlight v2 provides 2K (2304 x 1296) video, a 160° field of view, 2,800 lumens from two panels, and 2.4 GHz WiFi connectivity. Both models have color night vision, IP65 weather resistance, and smart home integration.Which Wyze floodlight camera has the best video quality?
The Wyze Cam Floodlight Pro offers the best video quality with its 2.5K QHD (2560 x 1440) resolution, providing sharper and more detailed footage compared to the 2K (2304 x 1296) resolution of the Wyze Cam Floodlight v2.Does the Wyze Cam Floodlight Pro support easy installation?
Yes, the Wyze Cam Floodlight Pro is available in a bundle with a plug-in mount, allowing for easy installation without the need for hardwiring or a junction box. This plug-in option is ideal for renters or those seeking a hassle-free setup.What are the lighting capabilities of Wyze Cam Floodlight Pro vs v2?
The Wyze Cam Floodlight Pro features three dimmable LED panels producing a total of 3,000 lumens at a 5000K color temperature, while the Wyze Cam Floodlight v2 has two dimmable panels with 2,800 lumens at the same color temperature. Both provide bright illumination and color night vision.What smart features do Wyze floodlight cameras offer?
Both Wyze Cam Floodlight Pro and v2 offer AI-powered motion detection, color night vision, and integration with Alexa, Google Assistant, and IFTTT. The v2 also includes two-way audio, a 105dB siren, and dusk-to-dawn automation.Are Wyze floodlight cameras weather-resistant?
Yes, both Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2 are IP65 weather-resistant, making them suitable for outdoor use in various weather conditions.What are the installation options for Wyze Cam Floodlight Pro and v2?
Both cameras can be hardwired to a 110-120V AC power supply and mounted on a wall or ceiling. The Wyze Cam Floodlight Pro also offers a plug-in mount option for easy, tool-free installation.Which Wyze floodlight camera is more affordable?
The Wyze Cam Floodlight v2 is the more budget-friendly option, priced at $89.98, while the Wyze Cam Floodlight Pro is priced at $149.98 and the Pro + Plug-In Mount bundle at $169.96.Can I use Wyze floodlight cameras with my smart home devices?
Yes, both Wyze Cam Floodlight Pro and v2 are compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.What is the field of view for Wyze Cam Floodlight Pro and v2?
The Wyze Cam Floodlight Pro offers a 180° diagonal field of view (170° horizontal), while the Wyze Cam Floodlight v2 provides a 160° diagonal field of view.Do Wyze floodlight cameras support local video storage?
The Wyze Cam Floodlight v2 supports up to 256GB microSD local storage. The storage options for the Wyze Cam Floodlight Pro are not specified in the provided content.
