2K HD Outdoor Camera with Wide Angle Lens and Floodlight Bundle
When it comes to securing your outdoor spaces, having a high-resolution camera paired with powerful floodlights is essential. Whether you want to monitor your driveway, backyard, or front porch, a 2K HD camera with a wide-angle lens and integrated floodlight ensures you capture every detail with clarity and brightness. Below, we explore the top Wyze products designed to meet these needs, including individual floodlight cameras and an exclusive bundle that combines the best of both worlds.
Wyze Cam Floodlight v2: Bright, Clear, and Wide
Key Features
- 2K HD Video Quality: Capture sharp 2304 x 1296 resolution footage with vibrant color night vision.
- 160° Wide-Angle Lens: Covers a broad field of view to monitor large outdoor areas effectively.
- 2800 Lumens LED Floodlight: Two dimmable LED panels provide bright, adjustable lighting with a crisp 5000K color temperature.
- AI-Powered Light Control: Automatically adjusts lighting based on motion and ambient conditions.
- 24/7 Local Recording: Supports up to 256GB microSD card for continuous video storage.
- Two-Way Audio: Built-in speaker and microphone allow real-time communication.
- Weather Resistant: IP65 rating ensures reliable performance in rain, snow, or dust.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless automation.
Why Choose Wyze Cam Floodlight v2?
This model is perfect for homeowners seeking a balance of high-quality video and powerful lighting. Its wide 160° diagonal view ensures you won’t miss any activity, while the color night vision keeps your property illuminated and visible even in the darkest conditions. The dusk-to-dawn automation and AI-powered light control make it a smart, energy-efficient choice.
Bright floodlight with wide-angle camera monitoring driveway
Wyze Cam Floodlight Pro: Ultra-Wide 2.5K QHD Security
Key Features
- 2.5K QHD Resolution: Ultra-clear 2560 x 1440 video with enhanced color night vision.
- 180° Ultra-Wide Lens: Expansive field of view (180° diagonal, 170° horizontal) covers your entire yard.
- 3000 Lumens Brightness: Three dimmable LED panels deliver intense, adjustable lighting.
- AI-Powered Motion Detection: Onboard AI detects people and vehicles, triggering lights and alerts only when necessary.
- Dual-Band WiFi: Supports both 2.4 GHz and 5 GHz for stable connectivity.
- Siren and Two-Way Audio: 105dB siren and built-in mic/speaker for deterrence and communication.
- Weatherproof Design: IP65 rating for all-weather durability.
- Smart Assistant Compatible: Works with Alexa, Google Assistant, and IFTTT.
Ideal For
If you want the most comprehensive coverage with crystal-clear video and intelligent lighting, the Floodlight Pro is your go-to. Its 180° ultra-wide lens and 2.5K resolution provide unmatched detail and coverage, while AI-powered features reduce false alerts and save energy.
Ultra-wide floodlight camera securing outdoor space with smart AI
Floodlight Security Bundle: Best Value for Complete Coverage
Bundle Highlights
Includes Wyze Cam Floodlight Pro + Wyze Cam Floodlight v2
- Combined Lumen Output: 5800 lumens total for superior brightness.
- Dual Resolution: 2.5K QHD on Floodlight Pro and 2K HD on Floodlight v2.
- Wide Field of View: 180° and 160° diagonal views for maximum coverage.
- 24/7 Recording: Supports microSD cards up to 256GB for continuous local storage.
- Motion-Activated Voice Deterrence: Scare off intruders with motion-triggered sirens and voice alerts.
- Dimmable & Adjustable Lights: Customize brightness to suit your environment.
- IP65 Water Resistance: Reliable in all weather conditions.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
Why Get the Bundle?
This bundle offers the ultimate outdoor security solution by combining two powerful floodlight cameras. It’s perfect for larger properties or those wanting layered security coverage. The synergy of 2K and 2.5K cameras with wide-angle lenses and bright floodlights ensures no blind spots and clear footage day or night.
Additional Accessories: Wyze Cam Floodlight Plug-In Mount
For those who want an easier installation without the need for a junction box, the
Wyze Cam Floodlight Plug-In Mount is an excellent accessory. It supports all Wyze floodlight cameras and offers:
- Plug-n-Play Setup: No complex wiring required.
- 20-Foot Power Cord: Flexible placement options.
- Outdoor Safe: Built to withstand outdoor conditions.
Compatible with Wyze Cam Floodlight v1, v2, and Pro.
This mount simplifies upgrading your home security with floodlight cameras, making it accessible for any homeowner.
Why Choose Wyze for Your Outdoor Security?
Wyze combines cutting-edge camera technology with powerful floodlighting to deliver smart, reliable, and affordable outdoor security solutions. With features like AI-powered motion detection, color night vision, wide-angle lenses, and seamless smart home integration, Wyze floodlight cameras provide peace of mind and enhanced safety for your home.
Summary Table of Key Specs
Feature | Wyze Cam Floodlight v2 | Wyze Cam Floodlight Pro | Floodlight Security Bundle |
Resolution | 2K HD (2304 x 1296) | 2.5K QHD (2560 x 1440) | 2K & 2.5K Combined |
Field of View | 160° Diagonal | 180° Diagonal | 160° & 180° Wide Angles |
Lumens | 2800 | 3000 | 5800 Total Lumens |
Night Vision | Color Night Vision | Color Night Vision | Color Night Vision |
AI Motion Detection | Yes | Advanced AI | Advanced AI |
Audio | Two-Way Audio + Siren | Two-Way Audio + Siren | Two-Way Audio + Siren |
Storage | Up to 256GB microSD | Up to 256GB microSD | Up to 256GB microSD |
Weather Resistance | IP65 | IP65 | IP65 |
Smart Home Integration | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT |
Power Supply | Hardwired 110-120V AC | Hardwired 110-120V AC | Hardwired 110-120V AC |
Secure your home with the best 2K HD outdoor cameras featuring wide-angle lenses and powerful floodlights. Whether you choose the Wyze Cam Floodlight v2, the advanced Floodlight Pro, or the comprehensive Floodlight Security Bundle, you’ll enjoy crystal-clear video, bright illumination, and smart features designed to keep your property safe day and night.
What is included in the Wyze Floodlight Security Bundle?
The Wyze Floodlight Security Bundle includes both the Wyze Cam Floodlight Pro and the Wyze Cam Floodlight v2. This combination provides a total of 5800 lumens of brightness, dual camera resolutions (2.5K QHD and 2K HD), wide-angle coverage (180° and 160°), 24/7 local recording support, motion-activated voice deterrence, and full smart home integration with Alexa, Google Assistant, and IFTTT.What are the main differences between Wyze Cam Floodlight v2 and Floodlight Pro?
Wyze Cam Floodlight v2 offers 2K HD resolution, a 160° wide-angle lens, and 2800 lumens of brightness, while the Floodlight Pro features 2.5K QHD resolution, a 180° ultra-wide lens, and 3000 lumens. The Pro model also includes advanced AI-powered motion detection, dual-band WiFi, and a 105dB siren for enhanced security.How does the color night vision work on Wyze floodlight cameras?
Wyze floodlight cameras use advanced sensors and powerful LED floodlights to provide vibrant color night vision. This technology ensures that your outdoor areas are clearly visible and detailed, even in low-light or nighttime conditions.Are Wyze floodlight cameras weatherproof?
Yes, all Wyze floodlight cameras, including the v2, Pro, and those in the Security Bundle, are rated IP65 for weather resistance. This means they are designed to withstand rain, snow, dust, and other outdoor elements.Can Wyze floodlight cameras record continuously?
Yes, Wyze floodlight cameras support 24/7 local recording when a microSD card (up to 256GB) is installed. This allows for continuous video storage and playback directly from the camera.Do Wyze floodlight cameras support smart home integration?
Absolutely. Wyze floodlight cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing you to integrate them seamlessly into your smart home ecosystem for automation and voice control.What is the field of view for Wyze Cam Floodlight v2 and Pro?
The Wyze Cam Floodlight v2 has a 160° diagonal wide-angle lens, while the Floodlight Pro offers an ultra-wide 180° diagonal (170° horizontal) field of view. This ensures broad coverage of your outdoor spaces.Is there an easy installation option for Wyze floodlight cameras?
Yes, the Wyze Cam Floodlight Plug-In Mount accessory allows for plug-and-play installation without the need for a junction box. It features a 20-foot power cord and is compatible with Wyze Cam Floodlight v1, v2, and Pro.How does AI-powered motion detection work on Wyze floodlight cameras?
Wyze floodlight cameras use onboard AI to detect people and vehicles, triggering lights and alerts only when necessary. This reduces false alarms and ensures you are notified of important activity around your property.What power supply is required for Wyze floodlight cameras?
Wyze Cam Floodlight v2, Floodlight Pro, and the Security Bundle require a hardwired 110-120V AC power supply. The Plug-In Mount accessory offers an alternative for those who prefer not to hardwire their cameras.
