Wyze Outdoor Cameras: Year-Round Solar-Powered Security
Year-Round Outdoor Camera Operation with Wyze Solar Panel Integration
For reliable, year-round outdoor security, Wyze offers a range of cameras designed to withstand all weather conditions while providing crystal-clear video and smart features. Among these, the Wyze Battery Cam Pro stands out for its wireless freedom and seamless solar panel compatibility, making it ideal for continuous outdoor monitoring without the hassle of frequent recharging. Complementing it are other Wyze cameras like the Wyze Cam v4, Wyze Cam Pan v3, and the Wyze Duo Cam Battery Doorbell, each offering unique features to cover every security need.
Wyze Battery Cam Pro: The Ultimate Wire-Free Solar-Powered Security Camera
Key Features and Benefits
  • 2.5K HDR Video Resolution: Capture stunningly clear and detailed footage day and night with high dynamic range imaging.
  • Wireless and No Hub Required: Install anywhere without worrying about power outlets or complicated wiring.
  • Integrated Spotlight & Siren: Motion-activated 150-lumen LED spotlight and siren deter intruders effectively.
  • Radar + PIR Motion Detection: Dual sensors provide earlier and more accurate motion alerts.
  • Removable, Rechargeable Battery Packs: Hot-swap batteries to keep your camera running without downtime.
  • IP65 Weatherproof Rating: Built to endure rain, snow, and dust for year-round outdoor use.
  • Dual-Band Wi-Fi Support: Connects easily to both 2.4 GHz and 5 GHz networks for stable streaming.
  • Local Recording with MicroSD Card: Save motion events locally without a subscription.
  • Solar Panel Integration: Extend battery life indefinitely by pairing with the Wyze Battery Cam Solar Panel, converting sunlight into power for continuous operation.
Turn your Wyze Battery Cam Pro into a solar-powered security powerhouse and enjoy uninterrupted protection all year long.
Wyze Battery Cam Pro Solar Setup Wyze Battery Cam Pro in snowy outdoor setting, showcasing weather resistance and solar readiness.
Wyze Cam v4: Wired Outdoor Camera with Enhanced Night Vision and Wi-Fi 6
Why Choose Wyze Cam v4 for Outdoor Security?
  • 2.5K QHD Resolution with Wide Dynamic Range (WDR): See vibrant colors and sharp details even in challenging lighting.
  • Enhanced Color Night Vision: See more than just black and white at night with advanced low-light imaging.
  • Motion-Activated Spotlight & 99 dB Siren: Illuminate and alert to potential threats instantly.
  • IP65 Weather Resistance: Reliable performance in rain, snow, or shine.
  • 24/7 Local Recording: Continuous recording to microSD card (up to 256GB) without subscription fees.
  • Wi-Fi 6 Support: Faster, more reliable connection for smoother video streaming.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Easy Setup with Bluetooth: Hassle-free installation without QR code scanning.
  • Motion Detection Zones & AI Alerts: Customize alerts to focus on what matters most.
Ideal for users who prefer a wired solution with continuous power and advanced smart features.
Wyze Cam Pan v3: 360° Pan and 180° Tilt for Complete Outdoor Coverage
Features Tailored for Dynamic Outdoor Surveillance
  • Full 360° Horizontal and 180° Vertical View: Eliminate blind spots with smooth pan and tilt control.
  • 1080p HD Video with 4 IR LEDs for Night Vision: Clear video quality day and night.
  • IP65 Weatherproof Design: Built tough for outdoor environments.
  • Two-Way Audio with Noise & Echo Cancellation: Communicate clearly through the camera.
  • Magnetic Mount and Screw Mount Options: Flexible installation on walls or ceilings.
  • Supports up to 256GB microSD Card: Local storage for continuous or event-based recording.
  • Compatible with Alexa, Google Assistant, and IFTTT: Integrate into your smart home ecosystem.
  • Requires Wyze Outdoor Power Adapter for Outdoor Use: Ensures continuous power supply.
Perfect for those needing a versatile camera with wide coverage and pan-tilt flexibility.
Wyze Cam Pan v3 in Winter Wyze Cam Pan v3 enduring snowy weather, demonstrating robust outdoor performance.
Wyze Duo Cam Battery Doorbell: Advanced Battery-Powered Video Doorbell
Features for Front Door Security
  • Dual Camera Views: Front-facing 2K camera plus bottom 1080p camera for packages.
  • 2K Video Resolution with 8x Digital Zoom: Crisp video to identify visitors and packages.
  • Motion-Activated Voice Deterrence: Warn unwanted guests with a customizable voice message.
  • Two-Way Audio: Speak with visitors in real-time.
  • IP65 Weather Resistance: Reliable in all weather conditions.
  • Removable Rechargeable Battery Pack: Easy to swap and charge.
  • Supports Local Storage and Cloud Recording: Flexible video storage options.
  • Includes Wyze Wi-Fi Chime: Hear alerts inside your home.
  • Compatible with Alexa, Google Assistant, and IFTTT: Smart home integration for convenience.
A smart choice for securing your front door with battery-powered flexibility and advanced detection.
Wyze Duo Cam Battery Doorbell Wyze Duo Cam Battery Doorbell installed, blending security and convenience at your doorstep.
Why Choose Wyze for Year-Round Outdoor Security?
Wyze cameras combine affordability, advanced technology, and user-friendly features to provide comprehensive outdoor security solutions. Whether you want the wire-free freedom of the Wyze Battery Cam Pro with solar panel integration or the continuous power and enhanced night vision of the Wyze Cam v4, Wyze has you covered. The Wyze Cam Pan v3 offers dynamic coverage with pan and tilt, while the Wyze Duo Cam Battery Doorbell secures your entryway with dual cameras and smart alerts.
With IP65 weatherproof ratings across these models, you can trust Wyze cameras to perform reliably in rain, snow, or shine—365 days a year.
Summary of Wyze Outdoor Cameras for Solar-Powered and Year-Round Use
ProductPower TypeResolutionWeatherproofSolar Panel CompatibleKey Feature
Wyze Battery Cam ProBattery (Removable)2.5K HDRIP65YesWire-free, solar ready
Wyze Cam v4Wired2.5K QHDIP65NoEnhanced color night vision
Wyze Cam Pan v3Wired (adapter req.)1080p HDIP65No360° pan & tilt coverage
Wyze Duo Cam Battery DoorbellBattery2K + 1080pIP65NoDual camera views, voice deterrence
Protect your home and property year-round with Wyze’s innovative outdoor cameras, designed for easy installation, smart features, and seamless solar panel integration to keep your security system powered by the sun.
FeatureWyze Battery Cam ProWyze Cam v4Wyze Cam Pan v3Wyze Duo Cam Battery DoorbellWyze Cam v3
TypeBattery CameraWired CameraWired Camera (Pan/Tilt)Battery DoorbellWired Camera
Video Resolution2.5K HDR (2560 x 1440 approx.)2.5K QHD (2560 x 1440)1080p (1920 x 1080)Front: 2K (2048 x 1536), Bottom: 1080p1080p (1920 x 1080)
Field of View (FOV)Not specified exact115.9° (D) x 98.5° (H) x 53.1° (V)120° FOVFront: 132° H x 100° V, Bottom: 121° H x 60° V121° diagonal, 180° vertical range
Night VisionColor Night Vision, Integrated SpotlightEnhanced Color Night Vision, SpotlightIR LEDs (4x 850 nm), B&W Night VisionIR Light (6x 850 nm), Color Night VisionColor Night Vision
AudioTwo-way audio with mic and speakerEnhanced Two-Way TalkTwo-way audio with noise & echo cancellationTwo-way talk, siren 90 dBTwo-way talk
Motion DetectionRadar + PIR Motion Detection, Custom ZonesMotion & Sound Detection, Custom ZonesMotion Detection, Push NotificationsAI Detections & Alerts, Motion-activated voice deterrenceMotion and Sound Detection, Custom Zones
Power SourceRemovable Rechargeable Battery PacksWired (continuous power)Wired (continuous power)Battery or Hardwired (10-24V AC)Wired (continuous power)
Weather ResistanceIP65IP65IP65IP65IP65
Connectivity2.4 & 5 GHz Wi-Fi, Bluetooth setupWi-Fi 6 (2.4 & 5 GHz), Bluetooth setup2.4 GHz Wi-Fi only2.4 & 5 GHz Wi-Fi, Bluetooth 5.02.4 GHz Wi-Fi only
Local StorageMicroSD card support (up to 256GB)MicroSD card support (up to 256GB)MicroSD card support (up to 256GB)MicroSD card support (up to 256GB)MicroSD card support (up to 256GB)
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscription
Special FeaturesIntegrated Spotlight & Siren, Solar Panel compatible, Hot-swap batteriesWi-Fi 6 support, Auto-zoom with AI Smart Focus, Smoke & CO alerts360° pan, 180° tilt, 8x digital zoom, Noise & Echo cancellationDual camera views (front & package), Motion-activated voice deterrence, Wi-Fi Chime includedColor Night Vision, Person/Vehicle/Pet detection with Cam Plus
DimensionsNot specifiedNot specified124mm (H) x 60mm (W) x 63mm (D)150mm x 48mm x 30mm52mm (L) x 51mm (W) x 58.5mm (D)
WeightNot specifiedNot specified11.29 oz (320 g)0.92 lbs (416 g)<98.8 g
Price (1 Pack)$89.98$35.98$39.98$89.98$25.98 - $35.98
Colors AvailableBlack, WhiteBlack, White, Grey, Clear (Clear sold out)Black, WhiteBlack, SilverBlack, White
WarrantyNot specifiedNot specified1 Year1 Year1 Year
Which Wyze outdoor camera is compatible with a solar panel for year-round operation?The Wyze Battery Cam Pro is designed for seamless integration with the Wyze Battery Cam Solar Panel, allowing for continuous, solar-powered operation and eliminating the need for frequent battery recharging.
Are Wyze outdoor cameras weatherproof for all seasons?Yes, all featured Wyze outdoor cameras—including the Wyze Battery Cam Pro, Wyze Cam v4, Wyze Cam Pan v3, and Wyze Duo Cam Battery Doorbell—have an IP65 weatherproof rating, ensuring reliable performance in rain, snow, and dust throughout the year.
What are the key features of the Wyze Battery Cam Pro for outdoor security?The Wyze Battery Cam Pro offers 2.5K HDR video resolution, wireless installation with no hub required, integrated spotlight and siren, radar plus PIR motion detection, removable rechargeable battery packs, IP65 weatherproofing, dual-band Wi-Fi support, local microSD card recording, and solar panel compatibility for uninterrupted outdoor monitoring.
Does the Wyze Cam v4 support continuous recording and smart home integration?Yes, the Wyze Cam v4 supports 24/7 continuous local recording to a microSD card (up to 256GB) without subscription fees. It also integrates with Alexa, Google Assistant, and IFTTT for smart home automation and voice control.
What makes the Wyze Cam Pan v3 suitable for comprehensive outdoor surveillance?The Wyze Cam Pan v3 features full 360° horizontal and 180° vertical pan and tilt, 1080p HD video with enhanced night vision, IP65 weatherproof design, two-way audio, flexible mounting options, and compatibility with Alexa, Google Assistant, and IFTTT. It requires the Wyze Outdoor Power Adapter for outdoor use.
How does the Wyze Duo Cam Battery Doorbell enhance front door security?The Wyze Duo Cam Battery Doorbell offers dual camera views (front-facing 2K and bottom 1080p for packages), motion-activated voice deterrence, two-way audio, IP65 weather resistance, removable rechargeable battery, local and cloud storage options, and includes a Wyze Wi-Fi Chime for in-home alerts. It also supports Alexa, Google Assistant, and IFTTT.
Can Wyze outdoor cameras record video locally without a subscription?Yes, Wyze outdoor cameras such as the Wyze Battery Cam Pro, Wyze Cam v4, Wyze Cam Pan v3, and Wyze Duo Cam Battery Doorbell support local video recording to a microSD card, allowing you to save footage without the need for a subscription.
What are the power options for Wyze outdoor cameras?Wyze offers both battery-powered and wired outdoor cameras. The Wyze Battery Cam Pro and Wyze Duo Cam Battery Doorbell use removable rechargeable batteries, while the Wyze Cam v4 and Wyze Cam Pan v3 require wired power (the Pan v3 needs the Wyze Outdoor Power Adapter for outdoor use). Only the Wyze Battery Cam Pro supports solar panel integration.
Do Wyze outdoor cameras support dual-band Wi-Fi for better connectivity?The Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz Wi-Fi networks for stable and flexible streaming. The Wyze Cam v4 also features Wi-Fi 6 support for faster and more reliable connections.
Why choose Wyze for outdoor security cameras?Wyze outdoor cameras combine affordability, advanced features like high-resolution video, smart detection, weatherproofing, and easy installation. With options for solar power, wired or battery operation, and smart home integration, Wyze provides reliable, year-round security solutions for any outdoor environment.
What are the key features of the Wyze Battery Cam Pro?How does the solar panel integration work with the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions?
