Long-Range Wyze Outdoor Security: Battery Cam & Solar Panel
Long Range Outdoor Security Coverage with Wyze Battery Cam and Solar Panel
For those seeking reliable, long-range outdoor security coverage powered sustainably by solar energy, Wyze offers an ideal solution with its Wyze Battery Cam Pro and the Wyze Battery Cam Solar Panel. This combination ensures continuous monitoring without frequent battery changes, perfect for outdoor environments where power outlets are scarce.
Wyze Battery Cam Pro: Advanced Wireless Security Camera
High-Resolution Video and Smart Detection
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution (2560 x 1440), providing crystal-clear footage day and night. Equipped with a CMOS-Starlight sensor and an F1.6 lens aperture, it captures vibrant details even in low light. The camera features integrated radar and PIR motion detection, enhancing accuracy by reducing false alerts.
Long-Lasting Battery and Weatherproof Design
Powered by removable, rechargeable 6200mAh battery packs, the Wyze Battery Cam Pro can last up to 6 months on a single charge, depending on usage. It supports both 2.4 GHz and 5 GHz WiFi for flexible connectivity. With an IP65 weatherproof rating, it withstands harsh outdoor conditions, operating reliably between -20°C to 50°C (-4°F to 122°F).
Additional Features
  • Integrated spotlight and 100 dB siren for deterrence
  • Two-way audio with built-in microphone and speaker
  • Local storage support up to 256 GB microSD cards and cloud recording options
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration
  • Compact and lightweight design (0.94 lbs, 2.5 x 1.8 x 3.5 inches)
Wyze Battery Cam Solar Panel: Sustainable Power for Extended Coverage
Extend Battery Life with Solar Energy
The Wyze Battery Cam Solar Panel is designed to keep your Wyze Battery Cam Pro powered continuously by harnessing solar energy. This accessory is perfect for outdoor setups where running power cables is impractical.
Durable and Easy to Install
  • IP65 weather-resistant construction ensures durability in rain, snow, and sun
  • Compact dimensions (173 mm x 120 mm x 17 mm) with a sleek white frame and black solar cells
  • Includes a 13-foot (4m) micro USB-C power cable for flexible mounting options
  • Comes with a 360° adjustable mount, screws, wall anchors, and a quick start guide for hassle-free installation
Compatibility
Works seamlessly with Wyze Cam Outdoor v1, v2, and Wyze Battery Cam Pro, making it a versatile accessory for various Wyze outdoor cameras.
Wyze Battery Cam Pro + Solar Panel Bundle: Complete Outdoor Security Solution
For users looking for an all-in-one package, the Wyze Battery Cam Pro + Solar Panel bundle offers the convenience of a high-performance security camera paired with sustainable solar power. This bundle ensures your camera stays charged and operational for extended periods without manual intervention.
Key Benefits of the Bundle
  • Wire-free setup with no hub required
  • 2.5K HDR video with color night vision and integrated spotlight
  • Radar + PIR motion detection for precise alerts
  • IP65 weatherproof rating for all-season outdoor use
  • Solar panel provides continuous power, reducing battery recharge frequency
Why Choose Wyze for Long-Range Outdoor Security?
Wyze combines cutting-edge technology with user-friendly design to deliver outdoor security cameras that are both powerful and easy to maintain. The integration of solar power accessories means you can enjoy uninterrupted surveillance without worrying about battery life or wiring constraints.
Ideal Use Cases
  • Remote properties and vacation homes
  • RVs, campers, and travel trailers
  • Front porch and backyard monitoring
  • Areas without easy access to electrical outlets
Outdoor Security Camera Mounted on Home Exterior Alt text: Wyze Battery Cam Pro mounted outdoors with solar panel in sunlight
Summary of Product Specifications
FeatureWyze Battery Cam ProWyze Battery Cam Solar PanelWyze Battery Cam Pro + Solar Panel Bundle
Video Resolution2560 x 1440 (2.5K HDR)N/A2560 x 1440 (2.5K HDR)
Battery Capacity6200mAhPowered by solar panel6200mAh + solar panel
Battery LifeUp to 6 monthsExtends battery lifeExtended battery life
Weather ResistanceIP65IP65IP65
Motion DetectionRadar + PIRN/ARadar + PIR
Connectivity2.4 & 5 GHz WiFiN/A2.4 & 5 GHz WiFi
Dimensions2.5 x 1.8 x 3.5 inches173 mm x 120 mm x 17 mmCamera + Solar Panel
Mounting1/4” - 20 standard mount360° adjustable mountIncluded
Enhance Your Outdoor Security with Wyze Today
Investing in the Wyze Battery Cam Pro combined with the Wyze Battery Cam Solar Panel is a smart choice for anyone wanting reliable, long-range outdoor security powered sustainably. Enjoy peace of mind with continuous video monitoring, smart alerts, and eco-friendly solar charging.
FeatureWyze Battery Cam Solar PanelWyze Battery Cam ProWyze Battery Cam Pro + Solar Panel
TypeAccessoryCameraCamera Bundle
Video ResolutionN/A2.5K HDR (2560 x 1440)2.5K HDR (2560 x 1440)
WirelessN/AYesYes
Power SourceSolar Panel (extends battery life)Removable, Rechargeable Battery Packs (6200mAh)Removable, Rechargeable Battery Packs (6200mAh)
Battery LifeExtends battery lifeUp to 6 monthsUp to 6 months
Charging TimeN/AApproximately 9 hoursApproximately 9 hours
Weather ResistanceIP65 (weatherproof and dustproof)IP65IP65
Compatible CamerasWyze Cam Outdoor v1/v2, Wyze Battery Cam ProN/AN/A
Mounting360° Freestyle Mount, mountable anywhere1/4” - 20 standard mount1/4” - 20 standard mount
Power Cable Length13-foot weatherproof power cableN/AN/A
Integrated Spotlight & SirenNoYesYes
Motion DetectionN/ARadar + PIR Motion DetectionRadar + PIR Motion Detection
Night VisionN/AColor Night VisionColor Night Vision
Local Storage SupportN/ASupports up to 256 GB microSD cardsSupports up to 256 GB microSD cards
WiFi SupportN/A2.4 & 5 GHz2.4 & 5 GHz
Dimensions173 mm x 120 mm x 17 mm2.5 x 1.8 x 3.5 inches2.5 x 1.8 x 3.5 inches
WeightN/A0.94 lbs0.94 lbs
Price$24.99 (sold out)$89.98 (1 Pack)$109.98
What is the Wyze Battery Cam Pro and how does it enhance outdoor security?The Wyze Battery Cam Pro is an advanced wireless outdoor security camera that delivers 2.5K HDR video resolution for clear footage day and night. It features radar and PIR motion detection for accurate alerts, a long-lasting rechargeable battery, and an IP65 weatherproof design, making it ideal for reliable, long-range outdoor security coverage.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro is powered by removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge, depending on usage and environmental conditions.
Is the Wyze Battery Cam Pro weatherproof and suitable for all seasons?Yes, the Wyze Battery Cam Pro has an IP65 weatherproof rating, allowing it to operate reliably in harsh outdoor conditions, including rain, snow, and temperatures ranging from -20°C to 50°C (-4°F to 122°F).
What are the key features of the Wyze Battery Cam Pro?Key features of the Wyze Battery Cam Pro include 2.5K HDR video resolution, color night vision, radar and PIR motion detection, integrated spotlight and 100 dB siren, two-way audio, local and cloud storage options, compatibility with Alexa, Google Assistant, and IFTTT, and a compact, lightweight design.
How does the Wyze Battery Cam Solar Panel work with the Wyze Battery Cam Pro?The Wyze Battery Cam Solar Panel provides sustainable power to the Wyze Battery Cam Pro by harnessing solar energy. This accessory keeps the camera charged continuously, reducing the need for manual battery recharging and making it ideal for outdoor locations without easy access to electrical outlets.
Is the Wyze Battery Cam Solar Panel weather-resistant?Yes, the Wyze Battery Cam Solar Panel is built with IP65 weather-resistant construction, ensuring durability and reliable performance in rain, snow, and direct sunlight.
What Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is compatible with Wyze Cam Outdoor v1, v2, and Wyze Battery Cam Pro, making it a versatile power solution for various Wyze outdoor cameras.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes the Wyze Battery Cam Pro security camera and the Wyze Battery Cam Solar Panel, providing a complete, wire-free outdoor security solution with continuous solar-powered charging and advanced monitoring features.
What are the benefits of using the Wyze Battery Cam Pro with the Solar Panel?Using the Wyze Battery Cam Pro with the Solar Panel offers benefits such as continuous power supply, reduced battery recharge frequency, wire-free installation, 2.5K HDR video with color night vision, precise radar and PIR motion detection, and all-season weatherproof performance.
Can I use the Wyze Battery Cam Pro in areas without power outlets?Yes, the Wyze Battery Cam Pro, especially when paired with the Wyze Battery Cam Solar Panel, is ideal for areas without easy access to electrical outlets, such as remote properties, vacation homes, RVs, campers, and backyards.
Does the Wyze Battery Cam Pro support smart home integration?Yes, the Wyze Battery Cam Pro is compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration into your smart home ecosystem.
What storage options are available for the Wyze Battery Cam Pro?The Wyze Battery Cam Pro supports local storage with microSD cards up to 256 GB and also offers cloud recording options for flexible video storage and playback.
How easy is it to install the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is easy to install, featuring a 360° adjustable mount, a 13-foot (4m) micro USB-C power cable for flexible placement, and all necessary mounting hardware and a quick start guide included in the package.
What are the installation requirements for the Wyze Battery Cam Solar Panel?Can the Wyze Battery Cam Pro be used without the solar panel?Are there any ongoing promotions or discounts for the Wyze Battery Cam Pro and Solar Panel bundle?
