Can Wyze Cam v4 Run on Battery or Does It Need Continuous Power?
If you're considering the Wyze Cam v4 for your home or outdoor security, a common question is whether this camera can run on battery power or if it requires continuous power. Understanding the power requirements is essential for proper installation and uninterrupted security coverage.
Wyze Cam v4 Power Requirements
The Wyze Cam v4 is designed as a
plug-in wired camera. This means it
requires continuous power through a USB connection to operate. It does
not have an internal battery for standalone battery-powered use. The camera comes with a 6-foot flat micro USB to USB-A cable and requires a power adapter with an input of 110-240V AC and output of 5V/1A.
Important: The Wyze Cam v4 must be plugged into a power source at all times to function properly, including for live streaming, recording, and smart features.
Outdoor Use and Power Options
For outdoor installations, Wyze offers the
Wyze Outdoor Power Adapter (sold separately), which is weather-resistant and designed to keep your Wyze Cam v4 powered safely in all weather conditions. This adapter ensures the camera remains continuously powered outdoors without interruption.
No Battery Operation, But Continuous Recording
Because the Wyze Cam v4 is wired, it supports
24/7 continuous local recording to a microSD card (up to 512GB). This means you won't miss any moment, day or night, as long as the camera remains plugged in.
Wyze Cam v4 Product Highlights
Crystal-Clear 2.5K Quad HD Resolution
Wyze Cam v4 delivers stunning video quality with 2.5K Quad High Definition clarity, capturing every detail with precision. This is a significant upgrade over previous models, ensuring you get the clearest view of your home or property.
Enhanced Color Night Vision
Unlike traditional black-and-white night vision, the Wyze Cam v4 features
Enhanced Color Night Vision. Its advanced hardware and integrated spotlight reveal vibrant colors even in low-light conditions, giving you superhero-like vision after dark.
Weather-Resistant for Indoor and Outdoor Use
With an
IP65 weather resistance rating, the Wyze Cam v4 is built to withstand rain, snow, and dust, making it perfect for both indoor and outdoor security needs.
Smart Features and Connectivity
- Wi-Fi 6 support for a stronger, more reliable connection.
- Bluetooth 5.2 for easy setup without QR codes.
- Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
- Motion and sound detection with customizable detection zones.
- Smoke and CO alarm alerts with video recording triggered automatically.
Easy Installation
The camera includes a
screw-free magnetic mount and metal mounting plate, allowing for quick and flexible placement on walls, ceilings, or flat surfaces.
Wyze Cam v4 Outdoor Bundle
For those looking for a complete outdoor security solution, the
Wyze Cam v4 Outdoor Bundle is an excellent choice. It includes:
- Wyze Cam v4 camera with all the features above.
- Wyze Outdoor Power Adapter for weatherproof continuous power.
- 128GB Wyze MicroSD Card for local 24/7 recording.
This bundle offers unmatched value and convenience for outdoor security setups, ensuring your camera stays powered and recording no matter the weather.
The
Wyze Cam v4 Home Security Bundle is designed for comprehensive home protection. It features:
- Multiple mounting options (stand, wall, ceiling, magnetic).
- Improved two-way audio with noise and echo cancellation.
- A powerful 99dB siren and motion-activated spotlight for deterrence.
- 128GB microSD card included for extended local storage.
- IP65 weather resistance for indoor/outdoor versatility.
This bundle is perfect for users who want a ready-to-go security system with all essential accessories included.
Summary: Powering Your Wyze Cam v4
Wyze Cam v4 requires continuous power via USB cable.
- It does not operate on battery power.
- For outdoor use, a dedicated Wyze Outdoor Power Adapter is recommended.
- Supports 24/7 local recording with a microSD card (sold separately or included in bundles).
- Offers advanced features like color night vision, Wi-Fi 6, and smart home compatibility.
If you need a battery-powered camera, Wyze offers other models designed specifically for cordless use, but the v4 excels as a wired, high-performance security camera.
Wyze Cam v4 installed outdoors with clear night vision
Experience vibrant colors with Wide Dynamic Range (WDR)
Easy mounting and continuous power for indoor security
Frequently Asked Question
Q: Can I use Wyze Cam v4 without plugging it in?
A: No, Wyze Cam v4 requires continuous power through a USB connection and does not have an internal battery.
Q: Is there a battery accessory for Wyze Cam v4?
A: Currently, Wyze Cam v4 does not support battery operation or battery accessories. For battery-powered options, consider other Wyze models.
Q: Can I use Wyze Cam v4 outdoors?
A: Yes, with the Wyze Outdoor Power Adapter and its IP65 rating, the camera is suitable for outdoor use.
Does the Wyze Cam v4 require continuous power or can it run on battery?
The Wyze Cam v4 requires continuous power via a USB connection and does not have an internal battery. It must be plugged into a power source at all times to function properly.Can I use Wyze Cam v4 without plugging it in?
No, the Wyze Cam v4 cannot operate without being plugged in. It does not support battery operation and must remain connected to a power source for live streaming, recording, and smart features.Is there a battery accessory available for Wyze Cam v4?
No, there is currently no battery accessory for the Wyze Cam v4. If you need a battery-powered camera, consider other Wyze models designed for cordless use.What are the power requirements for Wyze Cam v4?
Wyze Cam v4 requires a continuous power supply via a micro USB to USB-A cable and a power adapter with an input of 110-240V AC and output of 5V/1A. A 6-foot cable is included with the camera.Can Wyze Cam v4 be used outdoors?
Yes, Wyze Cam v4 is IP65 weather-resistant and can be used outdoors. For outdoor installations, it is recommended to use the Wyze Outdoor Power Adapter, which is weather-resistant and sold separately.Does Wyze Cam v4 support 24/7 continuous recording?
Yes, Wyze Cam v4 supports 24/7 continuous local recording to a microSD card (up to 512GB), as long as the camera remains plugged in.What video quality does Wyze Cam v4 offer?
Wyze Cam v4 delivers 2.5K Quad HD resolution, providing crystal-clear video quality and capturing every detail with precision.Does Wyze Cam v4 have color night vision?
Yes, Wyze Cam v4 features Enhanced Color Night Vision with an integrated spotlight, allowing you to see vibrant colors even in low-light conditions.What smart features are included with Wyze Cam v4?
Wyze Cam v4 includes Wi-Fi 6 support, Bluetooth 5.2 for easy setup, compatibility with Alexa, Google Assistant, and IFTTT, motion and sound detection with customizable zones, and smoke and CO alarm alerts with automatic video recording.How easy is it to install Wyze Cam v4?
Wyze Cam v4 is easy to install with its screw-free magnetic mount and metal mounting plate, allowing for flexible placement on walls, ceilings, or flat surfaces.What is included in the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4 camera, Wyze Outdoor Power Adapter for weatherproof continuous power, and a 128GB Wyze MicroSD Card for local 24/7 recording.What is included in the Wyze Cam v4 Home Security Bundle?
The Wyze Cam v4 Home Security Bundle features multiple mounting options, improved two-way audio, a 99dB siren, motion-activated spotlight, a 128GB microSD card, and IP65 weather resistance for both indoor and outdoor use.
