Uninterrupted Video Evidence Recording with Wyze Cam and Solar Charging
When it comes to reliable home or outdoor security, continuous video recording is essential. Wyze offers a powerful combination of advanced cameras and solar charging accessories designed to keep your surveillance running longer without interruption. Whether you want to monitor your front porch, backyard, or RV, Wyze’s Battery Cam Pro paired with the Solar Panel ensures you never miss a moment.
Wyze Battery Cam Pro: High-Resolution, Wire-Free Security
Stunning 2.5K HDR Video Quality
The Wyze Battery Cam Pro delivers crystal-clear 2.5K HDR video resolution (2560 x 1440), providing sharp and detailed footage day or night. Its CMOS-Starlight sensor combined with an F1.6 lens captures vibrant color night vision enhanced by two IR LEDs and two white spotlight LEDs, ensuring excellent visibility even in low light conditions.
Wire-Free and Weatherproof
Designed for true wireless convenience, this camera operates on removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge. The IP65 weather resistance rating means it withstands rain, snow, and dust, making it perfect for outdoor use in temperatures ranging from -20°C to 50°C (-4°F to 122°F).
Smart Motion Detection and Alerts
Equipped with integrated radar and PIR motion detection, the Wyze Battery Cam Pro accurately detects movement and sends instant alerts to your smartphone. The built-in 100 dB siren and spotlight add an extra layer of security by deterring unwanted visitors.
Seamless Connectivity and Integration
Supporting both 2.4 GHz and 5 GHz WiFi bands, this camera ensures stable connections. It integrates smoothly with Alexa, Google Assistant, and IFTTT, allowing voice control and automation. Two-way audio with a built-in microphone and speaker lets you communicate directly through the camera.
Wyze Battery Cam Solar Panel: Extend Your Camera’s Runtime
Harness the Power of the Sun
The Wyze Battery Cam Solar Panel is a weather-resistant accessory designed to keep your Wyze Battery Cam Pro powered continuously by solar energy. With a 2.5W, 5VDC solar power rating and a 13-foot USB-C power cable, it can be mounted anywhere with optimal sun exposure to extend your camera’s battery life indefinitely.
Durable and Easy to Install
Built with an IP65 waterproof rating, the solar panel withstands harsh outdoor conditions. Its 360° adjustable mount allows flexible positioning for maximum sunlight capture. The package includes everything needed for installation: wall mount, screws, anchors, and USB-C adapter cable.
Compatibility
This solar panel works seamlessly with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro, making it a versatile accessory for various Wyze outdoor cameras.
Wyze Battery Cam Pro + Solar Panel Bundle: Ultimate Continuous Surveillance
All-in-One Solution
For those seeking uninterrupted video evidence recording, the Wyze Battery Cam Pro + Solar Panel bundle offers the perfect combination. Enjoy the advanced features of the Battery Cam Pro with the added benefit of solar charging to minimize downtime and manual recharging.
Features at a Glance
- 2.5K HDR video with color night vision
- Radar + PIR motion detection for precise alerts
- Up to 6 months battery life, extended by solar power
- IP65 weatherproof design for all-season use
- Supports local storage up to 256 GB microSD and cloud recording with Cam Plus
- Compatible with Alexa, Google Assistant, and IFTTT
This bundle is ideal for users who want reliable, wire-free security with minimal maintenance.
Why Choose Wyze for Your Security Needs?
Wyze combines cutting-edge technology with user-friendly design to provide affordable, high-quality security solutions. The Battery Cam Pro’s long battery life and smart features, paired with the Solar Panel’s eco-friendly power extension, ensure your video evidence is recorded continuously without interruption.
“With Wyze’s solar charging solution, you can enjoy peace of mind knowing your camera stays powered and ready to capture every important moment, rain or shine.”
Summary of Key Specifications
Feature | Wyze Battery Cam Pro | Wyze Battery Cam Solar Panel | Wyze Battery Cam Pro + Solar Panel Bundle |
Video Resolution | 2560 x 1440 (2.5K HDR) | N/A | 2560 x 1440 (2.5K HDR) |
Battery Life | Up to 6 months | Extends battery life indefinitely | Up to 6 months + solar extension |
Weather Resistance | IP65 | IP65 | IP65 |
Motion Detection | Radar + PIR | N/A | Radar + PIR |
Night Vision | Color Night Vision (IR + White LEDs) | N/A | Color Night Vision |
Connectivity | 2.4 & 5 GHz WiFi, BLE 5.1 | USB-C cable powered by solar | 2.4 & 5 GHz WiFi, BLE 5.1 |
Compatibility | Android 9.0+, iOS 15.0+ | Wyze Battery Cam Pro, Outdoor v1/v2 | Android 9.0+, iOS 15.0+ |
Keep your Wyze Battery Cam Pro powered all day with solar energy for uninterrupted security.
Experience uninterrupted video evidence recording with Wyze’s innovative camera and solar charging solutions. Protect your home, RV, or outdoor spaces effortlessly with Wyze Battery Cam Pro and the Solar Panel accessory.
What is the video quality of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro offers stunning 2.5K HDR video resolution (2560 x 1440), providing sharp and detailed footage both day and night. Its advanced CMOS-Starlight sensor and F1.6 lens ensure vibrant color night vision and excellent visibility in low light conditions.How long does the Wyze Battery Cam Pro battery last?
The Wyze Battery Cam Pro operates on removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge, depending on usage and environmental conditions.Is the Wyze Battery Cam Pro weatherproof?
Yes, the Wyze Battery Cam Pro is IP65 weather resistant, making it suitable for outdoor use in rain, snow, and dust. It operates in temperatures ranging from -20°C to 50°C (-4°F to 122°F).How does the Wyze Battery Cam Solar Panel work?
The Wyze Battery Cam Solar Panel is a weather-resistant accessory that continuously powers your Wyze Battery Cam Pro using solar energy. With a 2.5W, 5VDC solar power rating and a 13-foot USB-C cable, it extends your camera’s battery life indefinitely when installed in a location with optimal sun exposure.What Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2, making it a versatile power solution for various Wyze outdoor cameras.Does the Wyze Battery Cam Pro support smart home integration?
Yes, the Wyze Battery Cam Pro supports integration with Alexa, Google Assistant, and IFTTT, allowing for voice control and automation. It also features two-way audio for direct communication through the camera.What motion detection features does the Wyze Battery Cam Pro offer?
The Wyze Battery Cam Pro is equipped with integrated radar and PIR motion detection for accurate movement detection. It sends instant alerts to your smartphone and features a built-in 100 dB siren and spotlight to deter unwanted visitors.Can I store video footage locally on the Wyze Battery Cam Pro?
Yes, the Wyze Battery Cam Pro supports local storage with microSD cards up to 256 GB, as well as cloud recording with a Cam Plus subscription.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The Wyze Battery Cam Pro + Solar Panel bundle includes the high-resolution, wire-free Wyze Battery Cam Pro and the weather-resistant solar panel with a 13-foot USB-C cable, wall mount, screws, anchors, and USB-C adapter cable for easy installation and continuous power.Why should I choose Wyze for my home or outdoor security?
Wyze offers affordable, high-quality security solutions with advanced features like long battery life, smart motion detection, weatherproof design, and eco-friendly solar charging. The combination of the Wyze Battery Cam Pro and Solar Panel ensures uninterrupted video evidence recording for peace of mind.
