Wyze Battery Cam & Solar Panel: Easy Wireless Install in Tough Spots
Wireless Camera Installation Using Wyze Solar Panel in Tricky Locations
When it comes to securing your home or outdoor spaces in hard-to-reach or tricky locations, the Wyze Battery Cam Pro paired with the Wyze Battery Cam Solar Panel offers a powerful, flexible, and weather-resistant solution. This combination ensures continuous monitoring without the hassle of frequent battery changes or wired power sources.
Wyze Battery Cam Pro: The Ultimate Wire-Free Security Camera
High-Quality Video and Smart Features
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution (2560 x 1440), providing crystal-clear footage day and night. Equipped with a CMOS-Starlight sensor and dual IR and white LEDs, it captures sharp images even in low-light conditions.
Wireless and Weatherproof Design
Designed for true wire-free convenience, this camera operates on removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge. Its IP65 weather resistance rating means it can withstand rain, dust, and extreme temperatures from -20°C to 50°C (-4°F to 122°F), making it perfect for outdoor installation.
Advanced Motion Detection and Security
The camera uses a combination of radar and PIR sensors for accurate motion detection, reducing false alerts caused by trees or passing cars. It also features an integrated spotlight and a 100 dB siren to deter intruders immediately.
Easy Setup and Mounting Flexibility
Setting up the Wyze Battery Cam Pro is straightforward via the Wyze app, supporting both 2.4 GHz and 5 GHz Wi-Fi networks. The included wall mount allows for versatile installation on walls or ceilings, with adjustable angles to optimize the field of view (134° diagonal).
Pro Tip: Mount your camera about 7 feet above the ground, tilted 20° downward for optimal motion detection up to 30 feet.
Wyze Battery Cam Solar Panel: Extend Your Camera’s Battery Life Effortlessly
Continuous Power from the Sun
The Wyze Battery Cam Solar Panel is designed to keep your Wyze Battery Cam Pro powered longer by harnessing solar energy. With a 2.5W, 5V DC solar power rating, it provides a sustainable power source that reduces the need for manual recharging.
Weather-Resistant and Easy to Mount Anywhere
Featuring an IP65 waterproof rating, the solar panel is built to endure outdoor conditions such as rain and dust. Its compact dimensions (173 mm x 120 mm x 17 mm) and 360° adjustable mount make it easy to install in challenging locations where direct power outlets are unavailable.
Long Reach Power Cable
The included 13-foot (4m) micro USB-C cable offers flexibility to position the solar panel in the best sun-exposed spot while keeping the camera securely mounted in a preferred location.
What’s Included
  • Solar panel with white frame and black solar cells
  • Wall mount with 360° rotation
  • Micro USB adapter cable and USB-C adapter cable
  • Screws and wall anchors for secure installation
  • Quick start guide for easy setup
Installing Wyze Battery Cam Pro with Solar Panel in Tricky Locations
Step 1: Choose the Right Spot
Identify a location that receives ample sunlight for the solar panel while providing a clear view for the camera. Avoid mounting the camera behind glass or inside enclosures that block motion detection.
Step 2: Mount the Solar Panel
Use the included wall mount and anchors to secure the solar panel in a sunny spot. The 360° mount allows you to angle the panel for maximum sun exposure throughout the day.
Step 3: Install the Wyze Battery Cam Pro
Mount the camera using the included wall mount or a universal metal mount if mounting from a ceiling. Insert the fully charged battery pack and connect the solar panel cable to the camera’s USB-C port.
Step 4: Connect and Configure
Use the Wyze app to connect the camera to your Wi-Fi network and complete the setup. Customize motion detection settings and notification preferences to suit your security needs.
Note: The solar panel helps maintain battery charge but does not fully power the camera in low-light or shaded conditions. It is ideal for extending battery life and reducing charging frequency.
Why Choose Wyze Battery Cam Pro with Solar Panel?
  • Wire-Free Convenience: No need for power outlets or frequent battery swaps.
  • Weatherproof Durability: Both camera and solar panel withstand harsh outdoor environments.
  • Flexible Installation: Mount in hard-to-reach or tricky locations with adjustable mounts and long cables.
  • Smart Security Features: Radar + PIR motion detection, spotlight, siren, and two-way audio.
  • High-Resolution Video: Capture clear, detailed footage day and night.
Outdoor Security Camera Installation Alt text: Wyze Battery Cam Pro installed on a porch with solar panel mounted nearby in sunlight Solar Panel Mounted on Wall Alt text: Wyze Battery Cam Solar Panel mounted on an exterior wall angled towards the sun
Conclusion
For those looking to secure tricky outdoor locations without the hassle of wiring or frequent battery changes, the Wyze Battery Cam Pro combined with the Wyze Battery Cam Solar Panel is an ideal solution. This setup ensures continuous, reliable surveillance powered by clean solar energy, perfect for porches, gardens, RVs, and other challenging spots.
FeatureWyze Battery Cam Solar PanelWyze Battery Cam Pro
TypeAccessoryCamera
Video ResolutionN/A2.5K HDR (2560 x 1440)
Power SourceSolar Panel (extends battery life)Removable, Rechargeable Battery Packs (6200mAh)
Battery LifeExtends battery lifeUp to 6 months per charge
Charging TimeN/AApproximately 9 hours
Weather ResistanceIP65 (weatherproof and dustproof)IP65 (weatherproof)
Compatible CamerasWyze Cam Outdoor v1/v2, Wyze Battery Cam ProN/A (camera itself)
Mounting Options360° Freestyle Mount, mountable anywhere1/4” - 20 standard mount, wall mount included
Power Cable Length13-foot weatherproof power cableN/A
WirelessN/AYes
ConnectivityN/A2.4 & 5 GHz WiFi, Bluetooth 5.1
Motion DetectionN/ARadar + PIR Motion Detection
Spotlight & SirenN/AIntegrated Spotlight (150 lumens) & 100 dB Siren
Local StorageN/ASupports up to 256 GB microSD cards
WeightN/A0.94 lbs
Dimensions173 mm x 120 mm x 17 mm2.5 x 1.8 x 3.5 inches
Price$24.99$89.98 (1 Pack)
Additional FeaturesWeather resistant solar chargingColor Night Vision, Two-way Audio, Bird Detection
What is the Wyze Battery Cam Pro and how does it work?The Wyze Battery Cam Pro is a wire-free security camera designed for both indoor and outdoor use. It features a 2.5K HDR video resolution, advanced motion detection with radar and PIR sensors, and operates on removable, rechargeable battery packs. The camera is weather-resistant (IP65 rated) and can be easily installed in tricky or hard-to-reach locations without the need for wired power sources.
How does the Wyze Battery Cam Solar Panel extend the camera’s battery life?The Wyze Battery Cam Solar Panel harnesses solar energy to keep your Wyze Battery Cam Pro charged for longer periods. With a 2.5W, 5V DC output, it reduces the need for manual recharging by providing a sustainable power source, especially in sunny locations. However, it is designed to extend battery life rather than fully power the camera in low-light or shaded conditions.
Is the Wyze Battery Cam Pro weatherproof and suitable for outdoor installation?Yes, the Wyze Battery Cam Pro is IP65 weather-resistant, making it suitable for outdoor installation. It can withstand rain, dust, and extreme temperatures ranging from -20°C to 50°C (-4°F to 122°F), ensuring reliable performance in various weather conditions.
What are the key features of the Wyze Battery Cam Pro?Key features of the Wyze Battery Cam Pro include 2.5K HDR video resolution, CMOS-Starlight sensor for low-light performance, radar and PIR motion detection, integrated spotlight, 100 dB siren, two-way audio, and support for both 2.4 GHz and 5 GHz Wi-Fi networks. It also offers flexible mounting options and a wide 134° diagonal field of view.
How do I install the Wyze Battery Cam Pro and Solar Panel in tricky locations?To install the Wyze Battery Cam Pro and Solar Panel in tricky locations, first choose a spot with ample sunlight for the solar panel and a clear view for the camera. Mount the solar panel using the included 360° adjustable wall mount, then install the camera using its wall or ceiling mount. Connect the solar panel to the camera’s USB-C port and complete setup via the Wyze app.
What is included with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel package includes the solar panel with a white frame and black solar cells, a 360° adjustable wall mount, a 13-foot (4m) micro USB-C cable, micro USB and USB-C adapter cables, screws and wall anchors for installation, and a quick start guide.
Can the Wyze Battery Cam Pro be used in locations without direct access to power outlets?Yes, the Wyze Battery Cam Pro is designed for wire-free operation and can be installed in locations without direct access to power outlets. When paired with the Wyze Battery Cam Solar Panel, it can be placed in hard-to-reach or remote areas, such as gardens, porches, or RVs, while maintaining extended battery life.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro operates on removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge, depending on usage and environmental conditions. Using the Wyze Battery Cam Solar Panel can further extend the battery life.
What is the recommended mounting height and angle for optimal motion detection?For optimal motion detection, it is recommended to mount the Wyze Battery Cam Pro about 7 feet above the ground and tilt it 20° downward. This setup allows the camera to detect motion effectively up to 30 feet away.
Does the Wyze Battery Cam Solar Panel fully power the camera in all conditions?The Wyze Battery Cam Solar Panel is designed to help maintain the camera’s battery charge and reduce the frequency of manual recharging. However, it may not fully power the camera in low-light or shaded conditions. It works best in locations with ample sunlight.
What are the best locations to install the Wyze Battery Cam Pro for optimal performance?Can the Wyze Battery Cam Solar Panel be used in shaded areas?How do I customize the motion detection settings on the Wyze app?
