Achieve Long-Term Device Autonomy for Wyze Cam with Dedicated Solar Charging
For users seeking extended, hassle-free security monitoring, Wyze offers an innovative solution combining the
Wyze Battery Cam Pro with the
Wyze Battery Cam Solar Panel. This pairing ensures your Wyze Cam stays powered longer without frequent battery swaps or manual recharging, perfect for outdoor use, remote locations, or anywhere you want reliable, continuous surveillance.
Wyze Battery Cam Pro: Powerful, Wire-Free Security
High-Resolution Video & Smart Detection
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution (2560 x 1440), providing crystal-clear footage day and night. Equipped with a CMOS-Starlight sensor and an F1.6 lens, it captures vibrant color night vision enhanced by 2 IR LEDs and 2 white LEDs (187 lumens). Its radar + PIR motion detection intelligently senses movement, reducing false alerts.
Long Battery Life & Weatherproof Design
Powered by removable, rechargeable 6200mAh battery packs, the Battery Cam Pro can last
up to 6 months on a single charge under typical usage. It is IP65 weatherproof, built to withstand temperatures from -20°C to 50°C (-4°F to 122°F), making it ideal for all seasons and outdoor environments.
Wireless & Smart Home Integration
Supporting both 2.4 GHz and 5 GHz WiFi bands, this camera connects seamlessly without the need for a hub. It integrates with Alexa, Google Assistant, and IFTTT for voice control and automation. Two-way audio with a built-in speaker and microphone allows real-time communication, while a 100 dB siren adds an extra layer of security.
Flexible Mounting & Storage
The camera includes a standard 1/4” - 20 mount and a wall mount for versatile installation options. It supports local storage up to 256 GB microSD cards and cloud recording with Cam Plus subscription.
Wyze Battery Cam Solar Panel: Extend Your Camera’s Runtime with Solar Power
Continuous Power from the Sun
The Wyze Battery Cam Solar Panel is designed to keep your Wyze Battery Cam Pro charged by harnessing solar energy. This accessory significantly extends the camera’s battery life, reducing the need for manual recharging and ensuring your camera stays online longer.
Weather-Resistant & Easy to Mount
Built with an IP65 waterproof rating, the solar panel withstands rain, snow, and dust. Its compact size (173 mm x 120 mm x 17 mm) and 360° adjustable mount allow you to position it optimally for maximum sun exposure anywhere outdoors.
Compatibility & Convenience
This solar panel works with Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 models. It includes a 13-foot micro USB cable and USB-C adapter cable, providing flexible installation options even if your camera is mounted far from the panel.
Wyze Battery Cam Pro + Solar Panel Bundle: Ultimate Long-Term Autonomy
All-in-One Solution for Extended Surveillance
The bundled package combines the Wyze Battery Cam Pro with the dedicated solar panel, offering a ready-to-use system for long-term, wire-free security. Enjoy the same 2.5K HDR video quality, radar + PIR motion detection, and weatherproof durability, now powered sustainably by solar energy.
Benefits of the Bundle
- Up to 6 months battery life extended further with solar charging
- No hub required, fully wireless setup
- IP65 weather resistance for both camera and solar panel
- Compatible with Alexa, Google Assistant, and IFTTT
- Local and cloud storage options
“With the Wyze Battery Cam Pro + Solar Panel, you can confidently monitor your property without worrying about battery life interruptions or complicated wiring.”
Enjoy flexible, wire-free security powered by solar energy.
Why Choose Wyze for Long-Term Outdoor Security?
Wyze’s combination of advanced camera technology and solar charging accessories offers a smart, eco-friendly solution for continuous home or property monitoring. Whether you’re securing a vacation home, RV, or remote area, the Wyze Battery Cam Pro with Solar Panel ensures your camera stays powered and ready to protect.
Summary of Key Specs
Feature | Wyze Battery Cam Pro | Wyze Battery Cam Solar Panel | Bundle (Cam + Solar Panel) |
Video Resolution | 2.5K HDR (2560 x 1440) | N/A | 2.5K HDR (2560 x 1440) |
Battery Capacity | 6200mAh, up to 6 months runtime | Solar-powered 2.5W, 5V DC | Extended runtime with solar charging |
Weather Resistance | IP65 | IP65 | IP65 |
Motion Detection | Radar + PIR | N/A | Radar + PIR |
Wireless Connectivity | 2.4 & 5 GHz WiFi | N/A | 2.4 & 5 GHz WiFi |
Mounting | Wall mount included, 1/4” - 20 mount | 360° adjustable mount | Both included |
Compatibility | Android 9.0+, iOS 15.0+ | Compatible with Wyze Battery Cam Pro | Compatible with Wyze Battery Cam Pro |
Conclusion
For those prioritizing
long-term device autonomy and
wire-free convenience, the Wyze Battery Cam Pro paired with the Wyze Battery Cam Solar Panel is the ideal solution. This combination delivers high-quality video surveillance powered sustainably by solar energy, minimizing maintenance and maximizing peace of mind.
What is the Wyze Battery Cam Pro and how does it enhance home security?
The Wyze Battery Cam Pro is a wire-free security camera that delivers 2.5K HDR video resolution for clear footage day and night. It features radar and PIR motion detection to reduce false alerts, two-way audio, a 100 dB siren, and is weatherproof (IP65 rated), making it ideal for outdoor security in all seasons.How long does the Wyze Battery Cam Pro battery last on a single charge?
The Wyze Battery Cam Pro is powered by a removable, rechargeable 6200mAh battery pack that can last up to 6 months on a single charge under typical usage conditions.What are the benefits of using the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel harnesses solar energy to keep your Wyze Battery Cam Pro charged, significantly extending its battery life and reducing the need for manual recharging. It is weather-resistant (IP65 rated) and easy to mount with a 360° adjustable bracket.Is the Wyze Battery Cam Solar Panel compatible with other Wyze cameras?
Yes, the Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro as well as Wyze Cam Outdoor v1 and v2 models.Can the Wyze Battery Cam Pro and Solar Panel be used in extreme weather conditions?
Yes, both the Wyze Battery Cam Pro and the Solar Panel are IP65 weatherproof and can operate in temperatures ranging from -20°C to 50°C (-4°F to 122°F), making them suitable for use in rain, snow, and dust.Does the Wyze Battery Cam Pro require a hub for wireless connectivity?
No, the Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz WiFi bands and does not require a hub for wireless operation.What smart home integrations are available with the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro integrates with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What storage options are available for the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro supports local storage with microSD cards up to 256 GB and offers cloud recording through a Cam Plus subscription.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The bundle includes the Wyze Battery Cam Pro and the Wyze Battery Cam Solar Panel, providing a complete, wire-free security solution with extended battery life powered by solar energy.Why should I choose the Wyze Battery Cam Pro with Solar Panel for outdoor security?
Choosing the Wyze Battery Cam Pro with Solar Panel offers long-term device autonomy, eco-friendly solar charging, high-resolution video, smart motion detection, and reliable performance in all weather conditions, making it an ideal solution for continuous outdoor surveillance.
