Wyze WiFi Smart Switch: Control Devices & Automate with IFTTT
Wyze WiFi Smart Switch and Smart Device Control with IFTTT
Looking to transform your home into a smart haven where your devices work together seamlessly? The Wyze Switch is your gateway to smart lighting and device control, especially when paired with other Wyze products and IFTTT integration. This page highlights how Wyze’s connected home products empower you to control and automate your smart devices effortlessly.
Wyze Switch: Smart Lighting and Device Control
The Wyze Switch is designed to turn your ordinary lights into smart lights that you can control from anywhere. Beyond simple on/off functions, it offers multi-tap controls that let you trigger other Wyze devices such as Wyze Cams, Wyze Lock, and Wyze Robot Vacuum. This makes it a powerful hub for smart home automation. Key Features:
  • Upgrade any room with smart lighting controlled via the Wyze app.
  • Multi-tap functionality for custom actions: single, double, and triple presses.
  • Create automations and schedules, including timers and vacation mode.
  • Power loss recovery ensures your settings stay intact.
  • Seamless integration with the Wyze ecosystem and IFTTT for extended smart device control.
Available in 1-pack and 3-pack options, the Wyze Switch is an affordable way to start your smart home journey. Wyze Switch in Kitchen Lifestyle Control your kitchen lighting and smart devices with Wyze Switch
Wyze Plug: Make Any Device Smart with IFTTT Integration
The Wyze Plug is perfect for making your everyday devices smart. Whether it’s a coffee maker, fan, or air purifier, the Wyze Plug lets you control these devices remotely and automate them using schedules or voice commands. Why Choose Wyze Plug?
  • Compatible with Alexa, Google Assistant, and IFTTT for broad smart home integration.
  • Supports up to 15A devices, perfect for most household electronics.
  • Easy setup with 2.4GHz WiFi connectivity.
  • Available in 2-pack and 4-pack bundles for multiple device control.
  • Indoor use with a compact design that fits any outlet.
With IFTTT support, you can create custom automations that link your Wyze Plug with other smart devices or services, enhancing your home automation experience. Wyze Plug Lifestyle Automate your home appliances with Wyze Plug and IFTTT
Wyze Universal Wi-Fi Chime: Smart Alerts for Your Home
Never miss a notification with the Wyze Universal Wi-Fi Chime. This accessory works with all Wyze Cams and doorbells, providing audible alerts when someone rings your doorbell or when your camera detects activity. Features:
  • Easy plug-in setup with no complicated wiring.
  • Compatible with IFTTT, Alexa, and Google Assistant for smart alerts.
  • Choose from 17 different tones to customize your chime.
  • Connect multiple chimes for whole-home coverage.
  • Compact and stylish black design fits any room.
Use IFTTT to trigger the chime based on various smart home events, such as motion detection or doorbell presses, keeping you informed wherever you are.
Enhance Your Smart Home Network with Wyze Mesh Routers
To ensure your smart devices like the Wyze Switch and Wyze Plug work flawlessly, a strong and reliable WiFi network is essential. Wyze offers two powerful mesh routers designed for modern smart homes:
Wyze Wi-Fi 6 Mesh Router
  • Speeds up to 1 Gbps with Wi-Fi 6 technology.
  • Covers up to 1500 sq. ft. per router and supports 50+ devices.
  • Features parental controls and wired backhaul for stable connections.
  • Simple setup via Bluetooth Low Energy 5.1.
Wyze Wi-Fi 6E Mesh Router Pro
  • Next-level speeds up to 2.5 Gbps with Wi-Fi 6E and access to the 6 GHz band.
  • Covers 2000 sq. ft. per router and supports 75+ devices.
  • Includes advanced hardware accelerators and multiple operation modes.
  • Ideal for large homes with many smart devices.
A robust WiFi network ensures your Wyze smart devices respond instantly to your commands and IFTTT automations. Wyze Mesh Router Setup Reliable WiFi coverage for your smart home devices
Why Choose Wyze for Your Smart Home Automation?
Wyze products are designed to be affordable, easy to use, and highly compatible with popular smart home ecosystems and IFTTT. Whether you want to control your lights, plugs, or receive smart alerts, Wyze offers a comprehensive solution that grows with your smart home needs.
With Wyze Switch, Wyze Plug, and Wyze Universal Wi-Fi Chime, you can create custom automations that control multiple devices simultaneously, triggered by your actions or external events via IFTTT. This flexibility makes Wyze a top choice for smart home enthusiasts.
Summary of Wyze Products for Smart Device Control with IFTTT
ProductKey BenefitIFTTT IntegrationControl Type
Wyze SwitchSmart light switch with multi-tapYesApp & physical taps
Wyze PlugSmart plug for any deviceYesApp & voice commands
Wyze Universal Wi-Fi ChimeSmart alerts for doorbell & camsYesAudible notifications
Wyze Wi-Fi 6 Mesh RouterFast, reliable WiFi for smart homeN/ANetwork backbone
Wyze Wi-Fi 6E Mesh Router ProUltra-fast WiFi with 6 GHz bandN/ANetwork backbone
By integrating Wyze smart devices with IFTTT, you unlock endless possibilities for automating your home, enhancing convenience, security, and energy efficiency. Start your smart home transformation today with Wyze!
FeatureWyze SwitchWyze PlugWyze Universal Wi-Fi Chime
TypeConnected HomeConnected HomeAccessories
DescriptionTurn normal lights into smart lights and control them from anywhere. Multi-tap to control other Wyze devices.Control any outlet from anywhere. Make normal devices smart.Easily set up your home's doorbell with no complicated wiring.
Price1 Pack: $14.99
3 Pack: $41.98
2 Pack: $24.98
4 Pack: $39.98
$19.98
Control MethodWyze app, multi-tap actionsWyze app, voice commands (Alexa, Google)Chimes when doorbell rings or camera detects person
ConnectivityWi-Fi (2.4 GHz)Wi-Fi (2.4 GHz)Wi-Fi (IEEE802.11 b/g/n 2.4 GHz), Bluetooth BLE 5.0
Voice Assistant IntegrationYes (via Wyze app ecosystem)Yes (Alexa, Google Assistant)Yes (Hey Google, Alexa)
Automation FeaturesTimers, schedules, vacation mode, power loss recoveryScheduling, vacation mode, energy monitoring17 different tones, connect multiple devices, smart automations
CompatibilityWorks with Wyze devices (Cams, Lock, Robot Vacuum, Sprinkler)Works with any device plugged into outletCompatible with all Wyze Cams and doorbells
InstallationEasy install Wi-Fi light switchPlug-in smart outletPlug-in, no wiring required
Power InputStandard light switch wiringStandard outlet10-24V AC, 10VA 60Hz
Indoor/Outdoor UseIndoorIndoorIndoor
Warranty/Return30-day hassle-free returns30-day hassle-free returnsNot specified
What is the Wyze Switch and how does it work with IFTTT?The Wyze Switch is a smart light switch that allows you to control your lights and other Wyze devices from anywhere using the Wyze app. With IFTTT integration, you can automate actions and trigger other smart devices, making it a central hub for your smart home automation.
Can I control other Wyze devices with the Wyze Switch?Yes, the Wyze Switch features multi-tap controls that let you trigger other Wyze devices such as Wyze Cams, Wyze Lock, and Wyze Robot Vacuum, enabling seamless smart home automation.
What are the key features of the Wyze Switch?Key features of the Wyze Switch include smart lighting control via the Wyze app, multi-tap functionality for custom actions, automation and scheduling options, power loss recovery, and integration with both the Wyze ecosystem and IFTTT.
How does the Wyze Plug make my devices smart?The Wyze Plug allows you to control everyday devices like coffee makers, fans, and air purifiers remotely. It supports scheduling, voice commands, and IFTTT integration, making it easy to automate and control your devices from anywhere.
Is the Wyze Plug compatible with Alexa and Google Assistant?Yes, the Wyze Plug is compatible with Alexa, Google Assistant, and IFTTT, allowing for broad smart home integration and voice control.
What devices can I use with the Wyze Plug?The Wyze Plug supports devices up to 15A, making it suitable for most household electronics such as lamps, fans, and small appliances.
What is the Wyze Universal Wi-Fi Chime and how does it work?The Wyze Universal Wi-Fi Chime is an accessory that provides audible alerts for Wyze Cams and doorbells. It plugs into any outlet, offers 17 different tones, and can be triggered by smart home events via IFTTT, Alexa, or Google Assistant.
Can I use multiple Wyze Universal Wi-Fi Chimes in my home?Yes, you can connect multiple Wyze Universal Wi-Fi Chimes for whole-home coverage, ensuring you never miss a notification.
How does IFTTT enhance Wyze smart device automation?IFTTT integration allows you to create custom automations that link Wyze devices with each other or with third-party services, enabling advanced smart home scenarios and automations based on triggers like motion detection or scheduled times.
Why do I need a Wyze Mesh Router for my smart home?A strong and reliable WiFi network is essential for smart devices to function properly. Wyze Mesh Routers provide fast, stable, and wide-ranging WiFi coverage, ensuring your Wyze Switch, Plug, and other smart devices respond instantly to your commands and automations.
What is the difference between the Wyze Wi-Fi 6 Mesh Router and the Wyze Wi-Fi 6E Mesh Router Pro?The Wyze Wi-Fi 6 Mesh Router offers speeds up to 1 Gbps and covers up to 1500 sq. ft. per router, supporting 50+ devices. The Wyze Wi-Fi 6E Mesh Router Pro provides next-level speeds up to 2.5 Gbps, covers 2000 sq. ft. per router, and supports 75+ devices, making it ideal for larger homes with many smart devices.
Are Wyze smart home products affordable and easy to use?Yes, Wyze products are designed to be affordable, user-friendly, and highly compatible with popular smart home ecosystems and IFTTT, making them a great choice for both beginners and smart home enthusiasts.
How can I automate my home with Wyze and IFTTT?By integrating Wyze devices with IFTTT, you can create custom automations that control multiple devices simultaneously, triggered by actions such as button presses, motion detection, or scheduled events, enhancing convenience, security, and energy efficiency in your home.
How does the Wyze Switch integrate with other Wyze products?Can I create custom automations with the Wyze Switch using IFTTT?Do you have any deals, ongoing sales, discounts, or promotions?
