Wyze Switch 3 Gang Setup: Compatibility, Features & Smart Control
Wyze Switch 3 Gang Setup Compatibility and Features
If you're looking to upgrade your home lighting with a Wyze Switch 3 gang setup, understanding compatibility and setup options is essential. The Wyze Switch is designed to turn your normal lights into smart lights, allowing you to control them remotely and integrate seamlessly with your Wyze smart home ecosystem.
What is the Wyze Switch?
The Wyze Switch is a WiFi-enabled smart light switch that replaces your traditional wall switch. It allows you to control your lights from anywhere using the Wyze app. The switch supports multi-tap actions to control other Wyze devices such as Wyze Cams, Wyze Lock, and Wyze Robot Vacuum, making it a versatile addition to your smart home.
  • Available in 1 Pack and 3 Pack variants, perfect for a 3 gang switch setup.
  • Easy installation designed to fit standard electrical boxes.
  • Supports timers, schedules, and vacation mode for automated lighting control.
  • Power loss recovery ensures the switch reconnects and resumes previous settings after outages.
"Turn normal lights into smart lights and control them from anywhere."
Compatibility of Wyze Switch 3 Gang Setup
The Wyze Switch 3 pack is ideal for multi-gang switch boxes, such as 3 gang setups, allowing you to control three separate circuits or lights independently. It is compatible with:
  • Standard single-pole wiring setups.
  • Wyze Bulbs with Smart Control enabled, which keeps power flowing to bulbs for uninterrupted automations.
  • The Wyze app on Android and iOS devices for seamless control and automation.
  • Integration with voice assistants like Alexa and Google Assistant for hands-free control.
Smart Control Features
  • Multi-Press Actions: Customize single, double, triple presses, and press-and-hold to control various Wyze devices.
  • Vacation Mode: Simulate occupancy by scheduling lights to turn on/off while you're away.
  • Power Loss Recovery: Automatically reconnects to WiFi and restores previous state after power interruptions.
  • Timers and Schedules: Set your lights to turn on/off at specific times or based on your routines.
Wyze Switch in Kitchen Lifestyle Smart Wyze Switch in a modern kitchen setting, controlled by voice assistants.
Additional Wyze Connected Home Devices to Enhance Your Setup
While the Wyze Switch is perfect for smart lighting control, you can expand your smart home ecosystem with other Wyze connected devices that complement your 3 gang switch setup.
Wyze Plug
  • Makes any normal device smart by allowing remote control via the Wyze app.
  • Available in 2 Pack and 4 Pack sizes.
  • Supports scheduling, timers, and voice control with Alexa, Google Assistant, and IFTTT.
  • Ideal for lamps, fans, coffee makers, and more.
Wyze Plug Outdoor
  • Designed for outdoor use with IP64 weather resistance.
  • Control garden lights, holiday inflatables, and outdoor appliances.
  • Features energy monitoring and overload protection.
  • Compatible with the Wyze app and voice assistants.
Wyze Plug controlling home devices Wyze Plug in use controlling home appliances remotely.
Why Choose Wyze Switch for Your 3 Gang Setup?
  • Affordable Smart Home Upgrade: The 3 pack option offers a cost-effective way to smarten multiple switches at once.
  • Seamless Integration: Works flawlessly with other Wyze devices, creating a unified smart home experience.
  • User-Friendly App: The Wyze app provides intuitive control, automation, and customization.
  • Reliable Performance: Features like power loss recovery and vacation mode ensure your home stays smart and secure.
"Upgrade to smart lighting in any room with Wyze Switch, a smart, WiFi light switch."
Summary
For a 3 gang switch setup, the Wyze Switch 3 pack is the perfect solution to transform your home lighting into a smart, connected system. Its compatibility with standard wiring, Wyze Bulbs, and the Wyze app makes it easy to install and control. Enhance your smart home further with Wyze Plugs and Wyze Plug Outdoor for comprehensive device management. Embrace the convenience, security, and automation that Wyze smart devices bring to your home.
FeatureWyze SwitchWyze PlugWyze Plug Outdoor
TypeConnected HomeConnected HomeConnected Home
DescriptionTurn normal lights into smart lights; multi-tap controls for other Wyze devicesControl any outlet remotely; make devices smartOutdoor smart plug for garden lights and more; weather-resistant
Sizes/Variants1 Pack ($14.99), 3 Pack ($41.98)2 Pack ($24.98), 4 Pack ($39.98)1 Pack ($15.99), 2 Pack ($34.98)
Control MethodWyze app, multi-tap actionsWyze app, voice commands (Alexa, Google)Wyze app, voice commands (Alexa)
Hub RequiredNoNoNo
Voice Assistant SupportYes (Alexa, Google via Wyze ecosystem)Yes (Alexa, Google)Yes (Alexa)
Scheduling/AutomationTimers, schedules, Vacation ModeSchedules, Vacation ModeSchedules, Vacation Mode
Power InputWiFi light switch (hardwired)Standard outlet plugStandard outlet plug (120V~, 60Hz)
Weather ResistanceIndoor useIndoor useIP64 rated for indoor/outdoor use
ConnectivityWiFiWiFi2.4GHz WiFi, Bluetooth V4.2
Max Load/OutputN/A (switch controls lights)N/A (controls plugged devices)15A Max with Overload Protection
Number of OutletsN/A1 outlet per plug2 outlets per plug
Energy MonitoringNoNoYes
Power Loss RecoveryYesNot specifiedNot specified
Integration with Wyze EcosystemYes, multi-tap controls for Wyze Cams, Locks, Robot VacuumYes, works with other Wyze devicesYes, works with Wyze ecosystem
WarrantyNot specifiedNot specified1 Year
What is the Wyze Switch and how does it work?The Wyze Switch is a WiFi-enabled smart light switch that replaces your traditional wall switch, allowing you to control your lights remotely using the Wyze app. It supports multi-tap actions to control other Wyze devices and integrates seamlessly with your Wyze smart home ecosystem.
Is the Wyze Switch compatible with 3 gang switch setups?Yes, the Wyze Switch 3 pack is specifically designed for multi-gang switch boxes, such as 3 gang setups. It allows you to control three separate circuits or lights independently, making it ideal for upgrading multiple switches at once.
What wiring setups are compatible with the Wyze Switch?The Wyze Switch is compatible with standard single-pole wiring setups, making it easy to install in most homes with standard electrical boxes.
Can I use Wyze Switch with Wyze Bulbs?Yes, the Wyze Switch is compatible with Wyze Bulbs when Smart Control is enabled. This feature keeps power flowing to the bulbs, ensuring uninterrupted automations and smart control.
Does the Wyze Switch work with voice assistants?Absolutely. The Wyze Switch integrates with popular voice assistants like Amazon Alexa and Google Assistant, allowing for hands-free control of your lights and connected devices.
What smart features does the Wyze Switch offer?The Wyze Switch offers multi-press actions (single, double, triple press, and press-and-hold) to control various Wyze devices, vacation mode to simulate occupancy, power loss recovery to restore previous settings after outages, and customizable timers and schedules.
How does power loss recovery work on the Wyze Switch?Power loss recovery ensures that after a power outage, the Wyze Switch automatically reconnects to WiFi and resumes its previous state, maintaining your preferred settings and automations.
Can I control the Wyze Switch remotely?Yes, you can control the Wyze Switch from anywhere using the Wyze app on your Android or iOS device, giving you full access to your lighting and automations even when you're away from home.
What other Wyze devices can enhance my 3 gang switch setup?You can expand your smart home by adding Wyze Plugs for remote control of appliances and Wyze Plug Outdoor for weather-resistant outdoor device management. Both integrate with the Wyze app and support voice control.
Why should I choose the Wyze Switch 3 pack for my home?The Wyze Switch 3 pack offers an affordable and convenient way to upgrade multiple switches at once. It provides seamless integration with other Wyze devices, user-friendly app control, reliable performance, and advanced features like vacation mode and power loss recovery.
What other Wyze devices can I integrate with the Wyze Switch?Can you explain how the multi-press actions work with the Wyze Switch?Do you have any deals, ongoing sales, discounts, or promotions?
